Would changing this to turnbuckle be a mistake?
- Sampson Jones
What If I remove the two spring Allen head screws and replace them with short non springed screw and tighten these screws tight , then to pull the motor tight replace the tension spring with a mini turnbuckle that I can tighten ?
Will this be a great idea or a bad idea ?
My thinking is no movement is a good thing , but maybe there is a reason people use the pictured mounted method .
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
CandCNC electronics
Command Lineux
Super z 2
Re: Would changing this to turnbuckle be a mistake?
I got rid of the spring-loaded allen screws, and just bolted it solid. I left the tension spring in place, just to keep the gears meshed while I tightened the screws. No issues since then....
Are those slots where the Z axis moves up and down?
Dave
Dave
No, the slot is to adjust the mesh between the rack and pinion gears.DXF wrote:Are those slots where the Z axis moves up and down?
Dave
This pic shows my setup with the springs, when I was direct drive:
![Image](http://i87.photobucket.com/albums/k139/cbwhitmore/Plaz%20Table/IMG_2388.jpg)
This pic shows mine without the springs, just locked in place by the screw. (with belt reductions)
![Image](http://i87.photobucket.com/albums/k139/cbwhitmore/Plaz%20Table/IMG_2485.jpg)
The Z axis on my Plasma Cam use to slide up and down in the center slot in the picture which created a lot of slop and bound up. I rebuilt it and added these sealed linear bearings which work great and are crash proof.
Dave Hanks
Dave Hanks
- Sampson Jones
Thanks. I Lean , I removed them and went with bolts .
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
