PlasmaCam Disc
PlasmaCam Disc
Does any one know if the art disc's that plasma cam sells will work with other systems? We have a Tracker Nitro table and use their Command and Cut software.
Thanks......
Toni
Thanks......
Toni
- tnbndr
Re: PlasmaCam Disc
I would check with them to see if the art is in dxf format, then it would be compatible with almost any system for importing. If the art if strictly in Plasma CAM's .pcm format then it is not.
There are others out there that sell art work for cutting. Check out Sign Torch or Cascade Metal Designs and others.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- geo4932
Re: PlasmaCam Disc
The Plasmacam art discs are the Plasmacam pcm format.
George
George
Re: PlasmaCam Disc
Thanks for the info.....that really stinks.....tons of stuff on their discs that I love.
Re: PlasmaCam Disc
if they where smart they would sell the disc
then they would make extra money
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
Re: PlasmaCam Disc
Can you load the files into the older version of Plasma Cam and export them as dxf files?crazy59860 wrote:Thanks for the info.....that really stinks.....tons of stuff on their discs that I love.
Dave Hanks
Re: PlasmaCam Disc
Sure you could.
Re: PlasmaCam Disc
I have a few of the disc and it will only let you save in pcm format only.
- Team Tracker
Re: PlasmaCam Disc
Hi Tonicrazy59860 wrote:Does any one know if the art disc's that plasma cam sells will work with other systems? We have a Tracker Nitro table and use their Command and Cut software.
Thanks......
Toni
I would suggest looking towards Cascade Metal Designs for your art files since the PlasmaCam files are proprietary to thier systems. Your Nitro onboard computer comes loaded with hundreds of designs from Cascade that are ready to cut and and you can purchase others from Cascade also. If you purchased your Nitro system second hand it may no longer have the files on the PC in which case we can send them to you. For more art files from Cascade please use this link http://www.customdxffiles.com/
1-800-590-7804
Re: PlasmaCam Disc
Your link dont work
- Team Tracker
Re: PlasmaCam Disc
Just checked and it appears his site is currently unavailable...check back later.MIFab wrote:Your link dont work
1-800-590-7804
Re: PlasmaCam Disc
Thank you Reid, we have purchased from Cascade and Sign Torch but there were a couple of files I really liked on the plasma cam disc. I am new at this but am getting better at the design end of it now. I still have a lot to learn and am so thankful to everyone on this site for all the knowledge they provide.
- Team Tracker
Re: PlasmaCam Disc
No problem at all. If there is a design you want to create but having difficulty with, just fax or email me the image, give us a call, and we can show you how to accomplish what you need. Have a great week.crazy59860 wrote:Thank you Reid, we have purchased from Cascade and Sign Torch but there were a couple of files I really liked on the plasma cam disc. I am new at this but am getting better at the design end of it now. I still have a lot to learn and am so thankful to everyone on this site for all the knowledge they provide.
1-800-590-7804
