So I know this belongs on a different page but I know there is significantly more traffic here so i thought i'd post a link to see if anyone with a plasmacam and hypertherm setup have the same issue I am having. I am hopeful that this may help others as well. Basically looking to see if my z-axis motor has gone bad based on the funny things it is doing and making it very difficult to get consistent cut/pierce height control.
http://www.plasmaspider.com/viewtopic.php?f=61&t=11476
Need Help with Machine
- yeomansjon
Fast Jonny Custom Design
CNC Plasma Cutting
Plasmacam DHC
Hypertherm Powermax 1000
www.facebook.com/fastjonnycustomdesign
CNC Plasma Cutting
Plasmacam DHC
Re: Need Help with Machine
Check the plugs and wires to it. Had the same problem and that's what it was.
Dave Hanks
Dave Hanks
- yeomansjon
Thank you, good point and I will check that once I get home. I recently cleaned the machine and had everything unplugged but don't think there is any difference between now and before, but i will definitely check.
Also, looks like this thread was bumped from the Free DXF file sharing column so anyone else that sees this can go direct to the link above.
CNC Plasma Cutting
Plasmacam DHC
CNC Plasma Cutting
Plasmacam DHC
