Does anyone know a way that I can function the Z axis up and down during a program without making a remote switch and running through my thc wiring setup? I quit using my PROMA thc for numerous reasons and would like to manually control the Z axis using my keyboard (or wireless remote) directly on Mach3. Is this a feasible task or should I stick with wiring a secondary remote? Thanks in advance!
Alex
RJMW
Z axis override
Z axis override
4x8 modified Eagle Plasma
DoubleCad XT2
SheetCam/Mach3
Hypertherm Pmax 1000
https://www.facebook.com/RedJetMetalWorks
DoubleCad XT2
SheetCam/Mach3
Re: Z axis override
In Mach your up/down buttons on the keyboard should work during the program.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
- JJsCustomDesigns
Re: Z axis override
Page up / Page Down buttons
PM me with details
PM me with details
Re: Z axis override
I have tried that before without success, but that has been a while ago. Will try again on my lunch break today and see what ny results are. Thanks!
Alex
RJMW
Alex
RJMW
DoubleCad XT2
SheetCam/Mach3
DoubleCad XT2
SheetCam/Mach3
Re: Z axis override
You have to go to config/ portspins and then set teh thcup and down to emulate then select 2 key as hotkeys. Then save and shutdown and restart mach3 THEN you are good to go. The 2 hotkeys will function as thcup and thcdown.
(;-) TP
(;-) TP
Re: Z axis override
Thanks all for the advice! Will try hotkeys this evening.
DoubleCad XT2
SheetCam/Mach3
DoubleCad XT2
SheetCam/Mach3
