Reinstall of sheetcam and mach from candcnc
I've had some computer problems and had all the programs running and work well now the hard drive went out and I'm trying to reinstall everything when I install both I get a error that saying mach3 license or sheetcam exist, it all work great the first time what's going on this table is about to drive me crazy lol.
4x8 Precison plasma table
Candcnc
Sheetcam,Mach3
TD cutmaster 82
Candcnc
Sheetcam,Mach3
TD cutmaster 82
Re: Reinstall of sheetcam and mach from candcnc
did you get a copy of all the programs with youre machine?
you may have to just insert youre license .
it should be in youre program folder.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
Its just a Master Install click ignore.
So I ignore it and it just seems to me it not showing the same icons just mach and it used to have the candcnc icons and sheetcam does not install at all
save yourself a headache contact youre manufacturer.
they should be able to tell you how to fix it .
the right way.
the right way.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
What you installed is the Mach 3 plugin from CandCNC nothing to do with Sheetcam. You need to install Sheetcam seperately.
Right but after mach installs I try to install sheetcam and the same error comes up and I ignore it and it we'll finish the install but it don't come up on the desktop, the first time I installed everything it was a breeze
Candcnc
Sheetcam,Mach3
TD cutmaster 82
Candcnc
Sheetcam,Mach3
TD cutmaster 82
Sheetcam give me a c++ error
Candcnc
Sheetcam,Mach3
TD cutmaster 82
Candcnc
Sheetcam,Mach3
TD cutmaster 82
