How to cut single part from DXF
bigdipper
Post by bigdipper »
I recently bought a sample DXF set from DXF Free site. Their are several files that have two drawings. One is created for waterjet and the other for plasma. I am cutting with plasma and I want to just process the one drawing. Can I do this. You can very easily see that I am new but am learning. If anyone can give me some help I would really appreciate it.
abmagrum
Re: How to cut single part from DXF
Post by abmagrum »
I am new too.
but I think in sheet cam you can select that file and move it to a new layer
then when post processing select that layer to cut
there probably is other ways but that works for me
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
Team Tracker
Post by Team Tracker »
If you use a design program like CorelDraw, AutoCAD, etc. you can open the dxf file and eliminate the objects you do not want to cut. It is common to open these purchased files in a design program to change the size, change the design, add some text, etc. so it will be good for you to get started doing this. If you don't have a good design program yet I would recommend CorelDraw and you can download a demo from http://www.corel.com click on the Free Trials link in the top menu bar. Best of luck and have fun.
1-800-590-7804
bigdipper
Post by bigdipper »
Thanks for all the help everyone. Got this finally figured out. Really appreciate the input. Now on to next project.
Bill
Return to “SheetCam”
