Adding tabs
grindergary
Adding tabs
Post by grindergary »
batman.cdr
(23.75 KiB) Downloaded 96 times
I am trying to get my head around adding tabs so I can put ovals around objects.
Can someone explain how to do this. I have attached a CDR file.
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
beefy
4.5 Star Member
4.5 Star Member
Re: Adding tabs
Post by beefy »
Hi Gary,
I tried to open your file (I've got X5) but it wouldn't recognise it, it's not an X6 file is it. If it is save as a .cmx so any version of Coreldraw can open it.
For tabs just draw objects which are the shape of your tabs, ensuring it will overlap the other objects. Select everything and weld so all objects become one peice.
Hope that helps,
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
grindergary
Re: Adding tabs
Batman.cmx
(3.47 KiB) Downloaded 95 times
Thanks Keith,
I will try that. The file is X6 and I will save as a .cmx from now on. Good to know.
Gary
Added file and your instructions worked perfect.
Sheetcam, Mach 3
