THC issue
THC issue
OK, I have finally had time to work through my THC issue. I have been running manually, so this evening, I tried to get it running, for the most part I succeeded. (ports and pins, active lows and such) I was running a short file, 1 inside cut and then 1 outside cut. It runs its course on the inside and then starts its jog to the pierce point on the outside and stops right before it gets there... Almost like it timed out or something since it wasn't seeing a signal. I tried run from here, backing up, nothing, its frozen.
Is there a delay or time out that I am missing somewhere?
I am attaching the file in case it is in the GCODE, notepad file.
LCTHC (candcnc)
MACH3
SheetCam
LCTHC (candcnc)
MACH3
SheetCam
Re: THC issue
oops. not allowed. otay, here:
N0010 (Filename: Cross Country Keychain smaller slow.tap)
N0020 (Post processor: Mach3 plasma.scpost)
N0030 (Date: 25/08/2013)
N0040 G20 (Units: Inches)
N0050 G53 G90 G91.1 G40
N0060 F1
N0070 S500
N0080 (Part: Cross Country Keychain smaller)
N0090 (Operation: Outside Offset, Layer 1, T2: Plasma, 0.0591 in kerf)
N0100 M06 T2 F180.0 (Plasma, 0.0591 in kerf)
N0110 G00 Z0.4000
N0120 X3.0280 Y0.7781
N0130 Z0.1181
N0140 M03
N0150 G04 P0.5
N0160 G01 Z0.0591 F100.0
N0170 G02 X2.8999 Y0.6501 I-0.1280 J0.0000 F180.0
N0180 G01 X2.8704
N0190 X1.6006
N0200 X1.5415
N0210 X1.5710 Y0.6797
N0220 Y0.6206
N0230 Y0.3571
N0240 Y0.2980
N0250 X1.5415 Y0.3275
N0260 X1.6006
N0270 X2.2044
N0280 X2.2635
N0290 X2.2339 Y0.2980
N0300 Y0.3571
N0310 Y0.4928
N0320 X2.3990
N0330 Y0.4105
N0340 Y0.4098
N0350 G02 X2.3912 Y0.3076 I-0.5129 J-0.0121
N0360 G03 X2.3908 Y0.3041 I0.0291 J-0.0052
N0370 G02 X2.3579 Y0.2245 I-0.1319 J0.0078
N0380 X2.2844 Y0.1870 I-0.1096 J0.1239
N0390 X2.1898 Y0.1780 I-0.0946 J0.4979
N0400 G01 X1.6152 Y0.1781
N0410 X1.6144
N0420 G02 X1.5206 Y0.1869 I-0.0104 J0.3935
N0430 G03 X1.5174 Y0.1874 I-0.0063 J-0.0289
N0440 G02 X1.4487 Y0.2221 I0.0115 J0.1083
N0450 X1.4138 Y0.3073 I0.1763 J0.1219
N0460 X1.4059 Y0.4105 I0.6757 J0.1034
N0470 G01 Y0.6206
N0480 Y0.6797
N0490 X1.4355 Y0.6501
N0500 X1.3764
N0510 X1.2148
N0520 G03 X1.1939 Y0.6415 I0.0000 J-0.0295
N0530 G01 X0.8232 Y0.2709
N0540 X0.7292 Y0.3649
N0550 X0.9640 Y0.5997
N0560 X1.0353 Y0.6710
N0570 X1.0440 Y0.6501
N0580 X0.9431
N0590 X0.8124
N0600 G03 X0.7915 Y0.6415 I0.0000 J-0.0295
N0610 G01 X0.4263 Y0.2763
N0620 X0.3323 Y0.3704
N0630 X0.5774 Y0.6155
N0640 G03 X0.5861 Y0.6364 I-0.0209 J0.0209
N0650 G01 Y0.7943
N0660 G03 X0.5774 Y0.8152 I-0.0296 J0.0000
N0670 G01 X0.3234 Y1.0692
N0680 X0.4175 Y1.1632
N0690 X0.7888 Y0.7919
N0700 G03 X0.8097 Y0.7832 I0.0209 J0.0209
N0710 G01 X0.9650
N0720 X1.0659
N0730 X1.0572 Y0.7624
N0740 X0.9859 Y0.8337
N0750 X0.7504 Y1.0692
N0760 X0.8444 Y1.1632
N0770 X1.2158 Y0.7919
N0780 G03 X1.2367 Y0.7832 I0.0209 J0.0209
N0790 G01 X1.3764
N0800 X1.4355
N0810 X1.4059 Y0.7537
N0820 Y0.8128
N0830 X1.4060 Y0.9945
N0840 X1.4059 Y0.9954
N0850 G02 X1.4137 Y1.0971 I0.4894 J0.0136
N0860 G03 X1.4142 Y1.1006 I-0.0291 J0.0053
N0870 G02 X1.4466 Y1.1805 I0.1350 J-0.0083
N0880 X1.5204 Y1.2184 I0.1130 J-0.1293
N0890 X1.6152 Y1.2273 I0.0944 J-0.4962
N0900 G01 X2.1898
N0910 X2.1907 Y1.2274
N0920 G02 X2.2838 Y1.2184 I0.0118 J-0.3668
N0930 G03 X2.2870 Y1.2179 I0.0065 J0.0288
N0940 G02 X2.3556 Y1.1830 I-0.0123 J-0.1090
N0950 X2.3911 Y1.0976 I-0.1819 J-0.1257
N0960 X2.3990 Y0.9945 I-0.6659 J-0.1035
N0970 G01 Y0.9269
N0980 X2.2339
N0990 Y1.0586
N1000 Y1.1177
N1010 X2.2635 Y1.0881
N1020 X2.2044
N1030 X1.6006
N1040 X1.5415
N1050 X1.5710 Y1.1177
N1060 Y1.0586
N1070 Y0.8128
N1080 Y0.7537
N1090 X1.5415 Y0.7832
N1100 X1.6006
N1110 X2.8704
N1120 X2.9295
N1130 X2.9000 Y0.7537
N1140 X2.8999 Y0.8128
N1150 Y0.9946
N1160 Y0.9951
N1170 G02 X2.9078 Y1.0974 I0.5442 J0.0097
N1180 G03 X2.9082 Y1.1006 I-0.0291 J0.0050
N1190 G02 X2.9406 Y1.1805 I0.1349 J-0.0083
N1200 X3.0144 Y1.2184 I0.1122 J-0.1278
N1210 X3.1092 Y1.2274 I0.0947 J-0.4962
N1220 G01 X3.6838 Y1.2273
N1230 X3.6847
N1240 G02 X3.7779 Y1.2183 I0.0112 J-0.3735
N1250 G03 X3.7811 Y1.2178 I0.0065 J0.0288
N1260 G02 X3.8497 Y1.1829 I-0.0123 J-0.1089
N1270 X3.8850 Y1.0978 I-0.1718 J-0.1213
N1280 X3.8930 Y0.9945 I-0.6660 J-0.1036
N1290 G01 Y0.9364
N1300 X3.7280
N1310 Y1.0586
N1320 Y1.1177
N1330 X3.7575 Y1.0881
N1340 X3.6984
N1350 X3.0946
N1360 X3.0355
N1370 X3.0651 Y1.1177
N1380 Y1.0586
N1390 Y0.8128
N1400 Y0.7537
N1410 X3.0355 Y0.7832
N1420 X3.0946
N1430 X4.2707
N1440 X4.3577
N1450 X4.3453 Y0.7592
N1460 X4.2947 Y0.8300
N1470 X4.1968 Y0.9670
N1480 X4.9729 Y0.7050
N1490 X4.2409 Y0.4722
N1500 X4.3094 Y0.6072
N1510 X4.3445 Y0.6765
N1520 X4.3607 Y0.6501
N1530 X4.2830
N1540 X3.0946
N1550 X3.0355
N1560 X3.0651 Y0.6797
N1570 Y0.6206
N1580 Y0.3571
N1590 Y0.2980
N1600 X3.0355 Y0.3275
N1610 X3.0946
N1620 X3.6984
N1630 X3.7575
N1640 X3.7280 Y0.2980
N1650 Y0.3571
N1660 Y0.4976
N1670 X3.8930
N1680 Y0.4105
N1690 Y0.4097
N1700 G02 X3.8852 Y0.3076 I-0.5050 J-0.0126
N1710 G03 X3.8847 Y0.3042 I0.0291 J-0.0052
N1720 G02 X3.8518 Y0.2245 I-0.1319 J0.0079
N1730 X3.7784 Y0.1869 I-0.1094 J0.1229
N1740 X3.6838 Y0.1780 I-0.0943 J0.4982
N1750 G01 X3.1092
N1760 X3.1084
N1770 G02 X3.0147 Y0.1868 I-0.0107 J0.3896
N1780 G03 X3.0115 Y0.1873 I-0.0063 J-0.0289
N1790 G02 X2.9427 Y0.2220 I0.0116 J0.1084
N1800 X2.9078 Y0.3073 I0.1777 J0.1226
N1810 X2.8999 Y0.4105 I0.6757 J0.1033
N1820 G01 Y0.6206
N1830 Y0.6501
N1840 G02 X3.0280 Y0.7781 I0.1280 J0.0000
N1850 M05
N1860 G00 Z0.4000
N1870 X5.3696 Y1.2276
N1880 Z0.1181
N1890 M03
N1900 G04 P0.5
N1910 G01 Z0.0591 F100.0
N1920 G02 X5.2416 Y1.3556 I-0.0000 J0.1280 F180.0
N1930 G03 X5.1057 Y1.4915 I-0.1354 J0.0005
N1940 G01 X0.1064
N1950 G03 X-0.0295 Y1.3556 I-0.0005 J-0.1354
N1960 G01 Y0.1064
N1970 G03 X0.1064 Y-0.0295 I0.1354 J-0.0005
N1980 G01 X5.1057
N1990 G03 X5.2416 Y0.1064 I0.0005 J0.1354
N2000 G01 Y1.3556
N2010 G02 X5.3701 Y1.4832 I0.1280 J-0.0004
N2020 M05
N2030 G00 Z0.4000
N2040 X0.0000 Y0.0000
N2050 Z0.0000
N2060 M05 M30
N0060 F1
N0070 S500
N0110 G00 Z0.4000
N0130 Z0.1181
N0140 M03
N0150 G04 P0.5
N0180 G01 X2.8704
N0190 X1.6006
N0200 X1.5415
N0220 Y0.6206
N0230 Y0.3571
N0240 Y0.2980
N0260 X1.6006
N0270 X2.2044
N0280 X2.2635
N0300 Y0.3571
N0310 Y0.4928
N0320 X2.3990
N0330 Y0.4105
N0340 Y0.4098
N0410 X1.6144
N0470 G01 Y0.6206
N0480 Y0.6797
N0500 X1.3764
N0510 X1.2148
N0580 X0.9431
N0590 X0.8124
N0650 G01 Y0.7943
N0710 G01 X0.9650
N0720 X1.0659
N0790 G01 X1.3764
N0800 X1.4355
N0820 Y0.8128
N0900 G01 X2.1898
N0970 G01 Y0.9269
N0980 X2.2339
N0990 Y1.0586
N1000 Y1.1177
N1020 X2.2044
N1030 X1.6006
N1040 X1.5415
N1060 Y1.0586
N1070 Y0.8128
N1080 Y0.7537
N1100 X1.6006
N1110 X2.8704
N1120 X2.9295
N1150 Y0.9946
N1160 Y0.9951
N1230 X3.6847
N1290 G01 Y0.9364
N1300 X3.7280
N1310 Y1.0586
N1320 Y1.1177
N1340 X3.6984
N1350 X3.0946
N1360 X3.0355
N1380 Y1.0586
N1390 Y0.8128
N1400 Y0.7537
N1420 X3.0946
N1430 X4.2707
N1440 X4.3577
N1530 X4.2830
N1540 X3.0946
N1550 X3.0355
N1570 Y0.6206
N1580 Y0.3571
N1590 Y0.2980
N1610 X3.0946
N1620 X3.6984
N1630 X3.7575
N1650 Y0.3571
N1660 Y0.4976
N1670 X3.8930
N1680 Y0.4105
N1690 Y0.4097
N1750 G01 X3.1092
N1760 X3.1084
N1820 G01 Y0.6206
N1830 Y0.6501
N1850 M05
N1860 G00 Z0.4000
N1880 Z0.1181
N1890 M03
N1900 G04 P0.5
N1940 G01 X0.1064
N1960 G01 Y0.1064
N1980 G01 X5.1057
N2000 G01 Y1.3556
N2020 M05
N2030 G00 Z0.4000
N2050 Z0.0000
N2060 M05 M30
Re: THC issue
ok... thanks for taking a stab at helping.
Re: THC issue
I know this might sound stupid, but is your sheetcam and Mach3 installed with the licence? otherwise it will only run a few lines of code before it shuts it down.
- JJsCustomDesigns
Re: THC issue
I ran your Gcode thru a simulater since im not at the shop. Seems to run just fine.
Is this what your keychain is supposed to look like?
PM me with details
PM me with details
Re: THC issue
yes, my issue is not with the finished product. It is with the machine stopping between pierce points and having to turn off the THC, then hitting run again and then having to turn the THC back on as it fires. If this is designs intent... its rather... silly.
It was mentioned on the CandCNC group page that it is because I am losing arc... of course it loses arc between pierce points. So, I'm still confused as to why it freezes until I turn off the THC. I have looked at videos on youtube and others do not have this issue, they motor right along.
- JJsCustomDesigns
Re: THC issue
Whats your upper Fault limit set at? I have that problem sometimes where ill finish an interior cut and since the piece drops out or is melted away the arc has no contact with material on the loop out. It faults out and I have to hit stop and run again. Kinda sucks. Happens more than i like to admit.
PM me with details
PM me with details
Re: THC issue
Have you tried MP1000 post processor from CandCNC? Make sure to enter switch offset into it.
- 4.5 Star Member
Re: THC issue
Exactly at what point does it stop. Is it immediately after the torch finishes a cut (i.e. as soon as there's a "lost arc"), or does it finish the cut, then proceed on it's rapid move to the next pierce position, then stop halfway. If it's stopping after a couple of seconds while moving to the next pierce point then I can't see it being caused by a lost arc condition.
Has Mach reported any faults when it stops.
In any case a lost arc should only occur when the torch is supposed to be on. If Mach is halting motion because of lost arc after it's turned the torch off then it seems to be stuffed.
The file runs perfect when I simulate it in Mach, but I would like to know what that "S500" is on line N0070, I've personally never used any gcode command beginning with S although I have occasionally heard about S commands.
Have you checked to see if your Mach application is licensed.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
- JJsCustomDesigns
Re: THC issue
I seen that too. S500 would be Spindle speed for a lathe or mill. ( i run 2 big bore cnc lathes )beefy wrote:
Ken, Can you take a video and post it. They way i interpreted your problem wasnt the same way others seen it.
Last edited by JJsCustomDesigns on Sun Sep 01, 2013 4:38 pm, edited 1 time in total.
PM me with details
PM me with details
Re: THC issue
I will try tomorrow to post a youtube video.
- 4.5 Star Member
Re: THC issue
Ken I'll make sure I don't offer you any help in the future, I'm tired of this sort of crap.SpartanKen wrote:ok... thanks for taking a stab at helping.
After waiting one day you give the above sarcastic comment, like it's your birthright to be given help and others obligation to give it.
So a bunch of members hop in to assist (= giving their time and effort for your benefit) and next thing you just abandon the thread. Didn't notice any thanks in there either, but there again it is everyones obligation to assist you.
I've waited over a week (which is a little bit more than your one day) to see if you were coming back to your thread but looks like you are not.
Rolleyes back at you
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
