Horney Toad
djs
Horney Toad
Post by djs »
I have a dxf file of a Horney Toad with alot of spikes around the body and does not cut well at around 3 inches long on 14 ga material, any one have any Horney Toads either in a dxf or a pcm format.............................. thanks in advance....................
djs
Pyro
Re: Horney Toad
Post by Pyro »
If you get a chance, post a jpg and dxf of the horney toad and I will see what I can do with it.
Loyd
Re: Horney Toad
Post by Loyd »
See if this works.
Loyd
djs
Re: Horney Toad
Post by djs »
that is the exact dxf i have and it does not cut well at around 3 to 6 inches. found it out while i was using it in a fire ring i was cutting. the spikes around the body is the problem for me and my machine using a miller 675 with the fine cut consumbales. thanks anyway loyd.
ericandmollie
Re: Horney Toad
Post by ericandmollie »
I cleaned up all the extra nodes on the toad. There were a lot of open nodes too, which might be the cause of your cutting problem.
Toad_Horned.dxf
