Does anyone know how to bring up the plasma screen set so I can get the THC set up. This is on a Viper plasma cutter that isn't even a year old yet. Viper refuses to help me...even after a complaint to the Virginia Attorney General. It CAN'T be a complicated thing I don't think. Any help would be GREATLY appreciated.
The machine came with draftsight, sheetcam and mach 1.
I won't be "talking up" my Viper plasma cutter.
Also...does anyone have one of these that lives near western NY (southern tier...Buffalo ) area...maybe I could see your setup and learn something...
Bocco
the attachment is the screen that came on the machine...the screen that Viper tech said was good to use...
plasma cutting screen set
Re: plasma cutting screen set
HI, at the top of the screen click on VEIW. Then you will be able to select a new screenset to run.
(;-) TP
(;-) TP
- Oldsarge
Also make sure the file with the .set extension is in the root directory of mach and the folder with the screen pictures is in the bitmaps folder. I'm using the green screen set from CandCNC and I love it!
Oldsarge
Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
