I found this file in the downloads section to use as an example. It is a Toucan.
I want to fill in the outlines so the object will look like the cut out part. I have tried many times to fill this so I can print off a copy to show someone what the object would look like when it is cut out. It seems to fill certain places but not where I need. Any ideas?
Gary
http://plasmaspider.com/download/file.php?id=8567
Fill Help
Fill Help
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
Re: Fill Help
Like this? ,note his feet aren't right, there are 2 lines which automatically join when I combine, not sure how to stop that happening.
What I did was to join curves and then combine, export
Murray
Murray
Re: Fill Help
Thanks Muzza,
I will give it a try. I appreciate the help.
Gary
Gary
Sheetcam, Mach 3
Sheetcam, Mach 3
