How far apart are you guys spacing the tubing that runs vertical on large dive through gate?
Mat
What spacing on vertical tubing on gate?
Re: What spacing on vertical tubing on gate?
I believe code is no more than 4" between bars, but please check with local jurisdictions.
Most building code require a spacing of less than 4 inches. As a building inspector one told me he used a 4 inch ball and if it did not pass through opening between the pickets, it meet code.
Jack
Jack
I work for a stair and handrail fabricator and it is true that the 4" rule applies to commercial handrails, but on something like an entrance gate it may not have to be so tight.
PlasmaCam DHC2
Hypertherm Powermax 65
Millermatic 211 MIG Welder
- CNCCAJUN
My brother has done ornamental ironwork for over 25 years in this area and he says the 4" ball is used here by the inspectors. He swearers its an old style copper toilet ball. lol lol lol
Other considerations:
* Will the gates be powered or manually operated?
* Has your community adopted "New York" standards?
* Don't forget tight spacing at bottom for little dogs if they have one.
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
