I am trying to load a drawing into sheetcam, using dxftool from CorelDraw 5, I am still getting double lines. Why is this?
Would increasing nodes or decreasing nodes in a drawing help prevent this? Or is it something else?
Getting ready to make my first cut tonight and I'd like to eliminate drawing issues first
Ken
double lines after using dxf tool
Re: double lines after using dxf tool
Not sure if it's something you have drawn or auto traced.
If it's drawn you may be getting double lines if you have it filled when you convert to dxf as it makes a line for the line and a line for the fill (even if your in wireframe the fill is there if it's filled, just hidden).
If it's an auto trace maybe you forgot to ungroup from the background after tracing.
I use X5 and I don't use dxf tool so not sure if that adds anything, I wouldn't have thought so.
Reducing nodes shouldn't make any difference but try selecting just one node and dragging it, that will reveal any duplicate lines underneath.
If all else fails there is a macro you can use apparently, I haven't used it but here is a link back to Marty's thread
http://www.plasmaspider.com/viewtopic.php?f=49&t=10248
Let us know how you get on.
Murray
Murray
I'm on X6 and if the object is filled, like with a color, then I get double lines on an export to .dxf.
Victor Simonis
Grey Forest MetalCraft
Helotes, TX 78023
210-872-2622
Helotes, TX 78023
210-872-2622
yes, somehow I filled the drawing.
waiting until tomorrow to fire it up.
that is a very common problem when first using dxf tools for some reason
there's so many ways to get double lines without knowing it
the most common is using convert-outline-to-object and weld/trim with keep-original checked
- 4.5 Star Member
Hi Ken,
until you get that sorted out in cad, if you're ever in a hurry and you've got this problem while in Sheetcam, click on the Contour button, right click on one of the outlines, and select move to new layer. It might move one of the outlines to a completely separate layer within Sheetcam then just untick the layer you don't want.
Not the real answer but a temporary workaround if it works.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Generally Sheetcam will delete the double lines anyway.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
