Cutmaster 82 arc ok and touch switch help
Little Leonard
Post by Little Leonard » Tue Jul 16, 2013 8:39 pm
I'm building a plasma table and I'm installing candcnc DTHC in my cutmaster 82, I need to know where the arc ok wires are and the touch switch is. I'm installing there Voltage divider card, THC SENSOR MODULE and there Digital Current Probe any help would be great
mlinehan
Re: Cutmaster 82 arc ok and touch switch help
Post by mlinehan » Wed Jul 17, 2013 8:58 am
Here are directions for the connections you want to make.
Short version: OK to Move is on connector J10, pins 1 & 3.
Arc voltage is on -V Out 1 and Work 1.
Start /Stop is on J10, pins 6 & 8.
You can see these connections drawn in the schematic at the rear of your owner's manual.
Arc Voltage Instructions.pdf
(916.74 KiB) Downloaded 38 times
Little Leonard
Post by Little Leonard » Wed Jul 17, 2013 4:28 pm
Thanks ill give it a try I've looked everywhere for this info
