tread,deck,diamond plate
whatever you happen to call it. How do cut it? tread down, tread up? I'm using CandCNC with mach and a hypertherm pm65. thanks
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
- JJsCustomDesigns
Re: tread,deck,diamond plate
I had my torch snag a diamond and drag my sheet across the table (alum btw). So i cut it tread down. In one of my post about cutting alum diamond plate... seemed everyone thought i was nuts cutting down. Potatoe/Patatoe
I just boost my cutting amps a little - so when the torch gets to the diamond it will cut all the way thru.
PM me with details
PM me with details
depends what way it goes up when finished because the underside will need a little more cleanup
How do you program for the mat thickness? Mat is .105 on the flat. .170 on the tread
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
I actually just cut aluminum diamond plate yesterday for a headache for an international truck with over 100 little squares to see through it. I kept everything the same but I slowed the speed from 190 ipm to 140 ipm, cut absolutely perfect. Only problem I had was the head hit the plate one time because of the warpage in the plate.
If you have a machine with a good height control (you will see it rise and drop rapidly on the igh and low spots) then the best cut quality on diamond plate / treadplate is with the bumps up, smooth side down. Machines with no height control or slow reacting height controls cut this material with bumps down....and a bit more cleanup of dross beads.
kbenz wrote:whatever you happen to call it. How do cut it? tread down, tread up? I'm using CandCNC with mach and a hypertherm pm65. thanks
- BrianMick
Uhmmmm I think you forgot "floor plate"....kbenz wrote:whatever you happen to call it. How do cut it? tread down, tread up? I'm using CandCNC with mach and a hypertherm pm65. thanks
www.midwayiron.com
www.midwayiron.com
Dang, I was trying to cover it allBrianMick wrote:Uhmmmm I think you forgot "floor plate"....kbenz wrote:whatever you happen to call it. How do cut it? tread down, tread up? I'm using CandCNC with mach and a hypertherm pm65. thanks
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
