Looking for a trivet......
rickjr
Post by rickjr »
Looking for a dxf file for a trivet if anyone has any they would like to share.......? Thanks.
Wine Country
Re: Looking for a trivet......
Post by Wine Country »
Here is a drawing of a base for a special requested item I drew up last week . You can eliminate the center hole. I
heated and bent the feet on the perimeter down at 90 degrees. Marty
MQUICK
Post by MQUICK »
This is one I use alot. I spot weld 1/2" steel balls at the corners. You could add the fold down legs. The think the balls look better. Mike
griffin
Post by griffin »
What material and thickness do you guys use on those?
MQUICK
Post by MQUICK »
I like using 10 or 11 gage steel.
Mike
