positioning parts on material
How do I get previously cut files to stay on my material when I close SC? Every time I open SC, the 4X8 sheet does not show what has been cut out of it.
4X8 Homebuilt Table
PrecisionPlasmaLLC Gantry
Hypertherm Powermax 65 w/machine torch
CandCNC BladeRunner Dragon-Cut
CorelDraw X6, Sheetcam, Mach 3
Re: positioning parts on material
Save the .job file, then open that file again the next time you add to that sheet. (File -> Save Job)
I can open a file again, but the file that I try to add replaces the file that was opened first.
4X8 Homebuilt Table
Once you open the existing job file, go File -> New Part. Then import your drawing as usual. Otherwise you're importing a drawing into whatever part is already selected. (and replacing the existing one, as you noticed)
- 4.5 Star Member
Until everything becomes second nature, as a precaution I'd do a "Save Job As" as soon as you open it, so you create a 2nd copy. Then if anything goes wrong you still have your original job file.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Works perfectly. Thanks. These forums are great.
4X8 Homebuilt Table
