Does anyone use it? Is it safe ? Some say its cancer causing. Are they over reacting ?
PLASMA QUENCH RECIPE
Here's the recipe for home-made PlasmaQuench
1/4 pound of sodium nitrite powder ($15/pound)
1 teaspoon of Physan 20 ($8/8oz bottle)
1 oz Ultramarine blue food-grade dye ($5/oz.)
Mix well, treats 75 gallons of water.
Al
plasma table water RECIPE
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
- elvenhome21
Re: plasma table water RECIPE
I have about a 90-100 gallon table and have well over a pound of sodium nitrite in it, And I still get a ton of flash rust. The slats seem to be doing good but they still have the mill scale on them so hard to tell how everything is doing under the water line, (pan is painted)
I had originally put dye pellets that were supposed to treat 150 gallons in it, but you could hardly tell there was any dye in it after about a day.
overall the sodium nitrite I guess kinda works but its no miracle rust inhibitor. It seems like once you start cutting all the cut material sediment starts to rust in the water anyways and turns the water a rust color.
Bonzi Metalworks
- pony
I dont bother adding dye any more, it is purely cosmetic.abmagrum wrote:Does anyone use it? Is it safe ? Some say its cancer causing. Are they over reacting ?
It doesn't prevent rust, but it does a very good job of retarding it. As for causing cancer, it seems everything causes cancer these day. Sodium nitrite is a salty preservative found in processed meat. Unless you are drinking the plasma quench then I'd be more worried about hot dogs, deli meats, etc.
- Marty
Here is a detailed post I did awhile back on this subject.....I would not use sodium nitrite personally....I have had exlnt results using Sodium Carbonate (NOT Sodium Bi Carbonate)...the post has all the info you would ever want to know on what works for me anyway ...there are pictures as well...
here is the link http://plasmaspider.com/viewtopic.php?f ... ter#p28119
Marty
Marty
Ignition Metal Art Design
Give a man a fish and you have taught him where to come for a fish; Teach him to use Google and the Search Engine on Plasma Spider and he will be able to learn more than you could ever teach him yourself
Thanks, Guys
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
