Just curious, what is the next step-up from Mach 3 software.
Does it exist?
Who makes it?
What does it cost?
I'm sure Mach 3 is an excellent program, but it seems to require a lot of on the fly tweaking, adjusting, etc. . . to get it to work with plasma tables. I have seen the same thing with it being used with cnc router tables, but not quite as bad . . .This is only my impression . . . but I would like to know if something else exist.
MACH 3's Equal . . .
- CNCCAJUN
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Re: MACH 3's Equal . . .
if you read youre plasma cutter manual . and set youre metal cutting settings. I don't think you have to mess with mach to much. most of the problems ive herd about end up being air problem or worn consumables . I am new to this but I find mach pretty easy to use
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
I agree--after the initial setup, I've had zero problems with Mach3. It just works.
The next step up is an industrial controller...and it's a BIG step.
- HammerDownJustin
Agreed most of the mach issues after setup is a user thinking they can tweak it or update it.
Miller 251 Mig
Miller 251 Mig
