A present for your supplier-Business Card Base
Re: A present for your supplier-Business Card Base
how are you guys downloading a DXF. file and editing it? I have ran across this a few times. Id like to personalize this file for my biz. any ideas? I use inkscape and solid works 2d.
Download the file then import it to Inkscape to do your editing
for some reason this file wont do that for me... I tried a few others and it worked... Thanks!
I would like to ask Art & Fire what font he used on the word "Linde". It looks like it would cut very nice. Thanks in advance.
LDR 4x8 Water Table
Hypertherm 65 Machine Torch
Sheet Cam
Mach 3
Sheet Cam
Mach 3
- art&fire
Sorry for the late reply.
I did not use a font for the name Linde. It is actually a trace of their company logo.
Thanks for the file. It cut just lovely...
- Larry83301
camjeep3 wrote:for some reason this file wont do that for me... I tried a few others and it worked... Thanks!
See if this will open for you, OK
Wasn't sure if that was the one you wanted, just went back and loaded the last DXF, if it's a different one you want just let me know, but open this one first and see if that works for you.
Hypertherm 65
Hypertherm 65
- csplazma1
Did this yesterday just to see how the bends would work out. Used 14 gauge and escalade white powder coat from Prismatic powders.
C&S PlaZma Metal Works
LDR Motion Systems 4X8 Water Bladder
Hypertherm Powermax 85 Machine Torch
Everlast PowerPlasma 60 Handheld Torch
Thunder Laser NOVA 51
thanks for the file
Capstone wrote:This has been a great way to use up some scrap 16ga.
Some of you might go to ARC3 for your welding supplies, so please make one for your local supplier too. If you see one already on the counter, you'll know it was from here.
Could someone please reach out I'd love to use this file but I don't have the talent to replace it with my logo.
Here is how to do it so you know next time. Download Capstone's file then in Inkscape using the node tool remove adjacent nodes to disconnect the top from the bottom then remove all top nodes, and then connect the top nodes to form a line at the top. see images below.
Then add your logo and attach it by just connection the two drawings and use the union tool under path highlight one by holding down the shift key then the other.
Could I have this cut file or a 6 card holder?Eggman wrote:Here's my version.
thanks, looks great,
This is great! Thank you for sharing!!
Thanks for the share
Whhere can i get this download?
Go to the first page of this thread for the dxfJoshwelder123 wrote:Whhere can i get this download?
4X4 Plasma Cam DHC2
w/down draft Hypertherm 45
3x4x6 home made powder coating oven
Thanks for the Share!
