Still going like hotcakes...
Re: Still going like hotcakes...
Thanks for recommending Etsy i bought my file too cheers
Yes they are good when I un-zip to a folder they are put into a folder inside where I wold it to go labeled "DXF" only.
I broke down and bought them too. The DXF's cut with no issues at all for me. I am finishing the first parts i cut with a heated and hammered finish then applying a black oil rub. They will eventually get mounted on a finished piece of wood. I made them about 16" with screw holes in them. Will post pics when I get to finishing the pieces.
- steel 35
Thanks guys I compared them and save pennies but here is what I have, same thing with Solid Edge, Auto Cad, at least and they all show the same.
Looks like the regular Inckscape SVG/dxf thing. And I am pretty sure it is.
bhamer; I believe it was your picture elsewhere the convinced me I needed them! Good luck on that picture I know how difficult it is.
- Attachments
- V.JPG (38.22 KiB) Viewed 1903 times
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Ok I stand corrected
the the SVG files look and work ok the DXF files are funky as Steel shows. If I open the with Irfanview they look clean but will not import into Inkscape and in TurboCad they will open but are funky.
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
![Shocked :shock:](./images/smilies/icon_eek.gif)
- steel 35
I recieved a new file with out the fill and saved in R14 ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
- tnbndr
I use them in AutoCad. You need to explode them twice, I think, then select and delete the hatching(fill). They are scaled up to like 5' so I scale them down, put them on layers that I use and then use Polyline edit to join everything. Been working ok like that.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Try a "REGEN" command if using ACAD.steel 35 wrote:Thanks guys I compared them and save pennies but here is what I have, same thing with Solid Edge, Auto Cad, at least and they all show the same.
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
Gecko g540
Proma THC
Millermatic 211
ABMETAT - thanks for the file name, I found them! Now to rename them and put them in several places.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
Allen, What black base do you use? Gloss, flat?abmetal wrote:Black base, then Baby Rockstar Sparkle. We've tried the BRS on other colors but nothing pops like the black base.
Allen
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
Cambam and Mach3
Off hand I can't tell you. I found the "Baby Rockstar Sparkle" on the Prismacolor website and it lists the black to be used as the base. We've used the sparkle on several different colors but it just doesn't show up as good as it does on black.
Allen
Allen
I'd like to give you all a huge THANK YOU!! This forum is amazing and full of so much information that everyone is willing to share. Thank you to Allen "abmetal" for this idea. As I stated in an earlier post, I too bought the Regal Font file there and have made just a few name monograms. I would like to share this one that I made using the "H" monogram and making it for some customers. We cut it out of 18 gauge, they are going to put it on the garden gate. Just used rattle can black shimmer from Hobby Lobby.
Hopefully I get the attachments right the first time, if not...try try again. : )
Julie
Julie
- Attachments
- Garden Sign for Laura & Steve Seymour circle 2.dxf
- (642.93 KiB) Downloaded 123 times
- Garden Sign for Laura & Steve Seymour circle 2 cut paths.pcm
- (412.89 KiB) Downloaded 84 times
- Papa & Yaya's Garden.jpg (51.02 KiB) Viewed 1400 times
To clarify my statement above, I bought the Split Monogram files "regal font" off of Etsy and the files have worked very well for me.
Julie
Julie
