nick7251
Posts: 108 Joined: Tue Dec 17, 2019 6:28 pm
Post
by nick7251 » Tue Jun 16, 2020 11:43 pm
Code: Select all
N0010 (Filename: 2020.06.04 Mounting Foot v3.tap)
N0020 (Post processor: Wright CNC Constant Touchoff.scpost)
N0030 (Date: 11/06/2020)
N0040 G20 (Units: Inches)
N0050 G53 G90 G40
N0060 F1
N0070 S500
N0080 (Part: 2020.06.04 Mounting Foot v3)
N0090 (Process: Inside Offset, Inside, T7: Plasma, 10G 0.055 in kerf)
N0100 M06 T7 (Plasma, 10G 0.055 in kerf)
N0110 G00 X1.2429 Y1.4305 Z0.5000
N0120 G31 Z -100 F19.685
N0130 G92 Z-0.16
N0140 G00 Z0.1300
N0150 M03
N0160 G04 P0.13
N0170 G01 X1.2429 Y1.4305 Z0.0600 F100
N0180 G02 X1.4691 Y1.4306 I0.1131 J-0.1131 F50.0
N0190 G01 X1.4692 Y0.8806 F50
N0200 G02 X1.3966 Y0.8081 I-0.0725 J0.0000 F50.0
N0210 G01 X0.7466 F50
N0220 G03 X0.7191 Y0.7806 I0.0000 J-0.0275 F50.0
N0230 G01 Y0.2275 F50
N0240 X0.7069
N0250 Y2.1725
N0260 X0.7191
N0270 Y1.5306
N0280 G03 X0.7466 Y1.5031 I0.0275 J0.0000 F50.0
N0290 G01 X1.3966 F50
N0300 G02 X1.4691 Y1.4306 I0.0000 J-0.0725 F50.0
N0310 X1.3091 Y1.2705 I-0.1600 J0.0000
N0320 M05
N0330 G00 Z0.5000
N0340 X2.2957 Y0.2884
N0350 G31 Z -100 F19.685
N0360 G92 Z-0.16
N0370 G00 Z0.1300
N0380 M03
N0390 G04 P0.13
N0400 G01 X2.2957 Y0.2884 Z0.0600 F100
N0410 G02 X2.0866 Y0.3750 I-0.0612 J0.1478 F50.0
N0420 G01 Y1.3750 F50
N0430 G02 X2.4067 Y1.3750 I0.1600 J0.0000 F50.0
N0440 G01 X2.4066 Y0.3750 F50
N0450 G02 X2.2466 Y0.5350 I-0.1600 J0.0000 F50.0
N0460 M05
N0470 G00 Z0.5000
N0480 X0.5000 Y1.0931
N0490 G31 Z -100 F19.685
N0500 G92 Z-0.16
N0510 G00 Z0.1300
N0520 M03
N0530 G04 P0.13
N0540 G01 X0.5000 Y1.0931 Z0.0600 F100
N0550 G02 X0.3400 Y0.9331 I-0.1600 J0.0000 F50.0
N0560 X0.3400 Y0.9331 I0.0000 J0.2225
N0570 X0.1800 Y1.0931 I0.0000 J0.1600
N0580 M05
N0590 G00 Z0.5000
N0600 X0.5000 Y3.2820
N0610 G31 Z -100 F19.685
N0620 G92 Z-0.16
N0630 G00 Z0.1300
N0640 M03
N0650 G04 P0.13
N0660 G01 X0.5000 Y3.2820 Z0.0600 F100
N0670 G02 X0.3400 Y3.1220 I-0.1600 J0.0000 F50.0
N0680 X0.3400 Y3.1220 I0.0000 J0.2225
N0690 X0.1800 Y3.2820 I0.0000 J0.1600
N0700 M05
N0710 G00 Z0.5000
N0720 X1.2429 Y3.6195
N0730 G31 Z -100 F19.685
N0740 G92 Z-0.16
N0750 G00 Z0.1300
N0760 M03
N0770 G04 P0.13
N0780 G01 X1.2429 Y3.6195 Z0.0600 F100
N0790 G02 X1.4692 Y3.6195 I0.1131 J-0.1131 F50.0
N0800 G01 X1.4691 Y3.0695 F50
N0810 G02 X1.3966 Y2.9970 I-0.0725 J0.0000 F50.0
N0820 G01 X0.7466 F50
N0830 G03 X0.7191 Y2.9695 I0.0000 J-0.0275 F50.0
N0840 G01 Y2.3275 F50
N0850 X0.7069
N0860 Y4.2725
N0870 X0.7191
N0880 Y3.7194
N0890 G03 X0.7466 Y3.6920 I0.0275 J0.0000 F50.0
N0900 G01 X1.3966 F50
N0910 G02 X1.4692 Y3.6195 I0.0000 J-0.0725 F50.0
N0920 X1.3091 Y3.4594 I-0.1600 J0.0000
N0930 M05
N0940 G00 Z0.5000
N0950 X2.2957 Y3.0384
N0960 G31 Z -100 F19.685
N0970 G92 Z-0.16
N0980 G00 Z0.1300
N0990 M03
N1000 G04 P0.13
N1010 G01 X2.2957 Y3.0384 Z0.0600 F100
N1020 G02 X2.0867 Y3.1250 I-0.0612 J0.1478 F50.0
N1030 G01 X2.0866 Y4.1250 F50
N1040 G02 X2.4067 Y4.1250 I0.1600 J0.0000 F50.0
N1050 G01 X2.4066 Y3.1250 F50
N1060 G02 X2.2466 Y3.2850 I-0.1600 J0.0000 F50.0
N1070 (Process: Outside Offset, Outside, T7: Plasma, 10G 0.055 in kerf)
N1080 M05
N1090 G00 Z0.5000
N1100 X-0.1875 Y0.2959
N1110 G31 Z -100 F19.685
N1120 G92 Z-0.16
N1130 G00 Z0.1300
N1140 M03
N1150 G04 P0.13
N1160 G01 X-0.1875 Y0.2959 Z0.0600 F100
N1170 G03 X-0.0275 Y0.4559 I0.0000 J0.1600 F50.0
N1180 G01 Y4.3000 F50
N1190 G02 X0.2000 Y4.5275 I0.2275 J0.0000 F50.0
N1200 G01 X2.4467 F50
N1210 G02 X2.6741 Y4.3000 I0.0000 J-0.2275 F50.0
N1220 G01 X2.6742 Y0.2000 F50
N1230 G02 X2.4467 Y-0.0275 I-0.2275 J0.0000 F50.0
N1240 G01 X0.2000 F50
N1250 G02 X-0.0275 Y0.2000 I0.0000 J0.2275 F50.0
N1260 G01 Y0.4559 F50
N1270 G03 X-0.1875 Y0.6159 I-0.1600 J0.0000 F50.0
N1280 M05
N1290 G00 Z0.5000
N1300 M05 M30
robertspark
Posts: 1821 Joined: Mon Jun 12, 2017 6:43 pm
Post
by robertspark » Wed Jun 17, 2020 4:18 am
I don't think it is this but can you remove G53 from the post processor as it should not be located on its own it should have a G0 or G1 before it
Edit the post processor and search for
G53 G90 G40
It will be in the initialisation / setup function (I cannot remember the correct function name)
Just delete G53 and resave and try again please
https://machmotion.com/cnc-info/g-code. ... oordinates
Could you tell me what version of the pokeys plugin you are using please too
Posts: 7829 Joined: Sat Jun 02, 2012 6:04 pm
Post
by acourtjester » Wed Jun 17, 2020 8:42 am
and try this shown in the attached image of your code.
nick7251
Post
by nick7251 » Wed Jun 17, 2020 12:45 pm
robertspark wrote: ↑ Wed Jun 17, 2020 4:18 am
G53 G90 G40
Okay, I have pulled G53 out.
I am on the latest version of the plugin from their website. It is date 5-16-2019 version 3.35
nick7251
Post
by nick7251 » Wed Jun 17, 2020 12:47 pm
acourtjester wrote: ↑ Wed Jun 17, 2020 8:42 am
Okay, I've added the delay in the code. Thank you. I have planned to add it, but wanted to wait to see if any other fixes were mentioned. I don't know if the delay in the code is a fix, or a band-aide.
nick7251
Post
by nick7251 » Wed Jun 17, 2020 1:30 pm
I ran the job with the two recommended changes. Removed G53, and also added delay. It is doing the same thing. For some reason on the final line of the code (The line to return to the beginning) it causes the DRO to jump in value without moving the torch. Such a weird issue.
nick7251
Post
by nick7251 » Wed Jun 17, 2020 1:49 pm
Does this look like it could be the problem in my post?
Code: Select all
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Text (" G04 P")
post.Number (endDelay,"0.###")
post.Eol()
end
end
It doesn't look problematic to me, but that is one of the commands given on the last line, so I thought I would take a closer look with all you smart people out there to help.
I don't know why I even need it there if a M05 command was already given in the G-code, then a move to save z of 1" then another M05???
Code: Select all
N1410 M05
N1420 G00 Z1.0000
N1430 M05 M30
robertspark
Post
by robertspark » Wed Jun 17, 2020 2:07 pm
nick7251 wrote: ↑ Wed Jun 17, 2020 1:49 pm
Code: Select all
function OnPenUp()
post.Eol()
end
end
Code: Select all
N1410 M05
N1420 G00 Z1.0000
N1430 M05 M30
That is all fine.
Two m05's are fine to in a row it acts as a confirmation of turning stuff off (it's a carry over from mills and routers to turn the spindle off.... And make sure it is off at the end of the run)
Take it out or split m05 and M30 by adding a /n between the two in the postprocessor
Can you post your mach3 profile please (the*.XML file) you may need to change it to txt to upload it thanks so I can load it with a pokeys and have a look as I have a couple of the 57e devices available
nick7251
Post
by nick7251 » Wed Jun 17, 2020 2:44 pm
It wouldn't let me upload a .txt either. Only lets me upload picture. So, I pasted it instead.
Code: Select all
<profile>
<Preferences>
<PulseSpeed>1</PulseSpeed>
<Profile>Wright CNC Pro Kit Profile Update 10-19</Profile>
<Layout>Plasma.set</Layout>
<FirstRun>1</FirstRun>
<Units>1</Units>
<Serial>0</Serial>
<Port2Input>0</Port2Input>
<GeckoMode>0</GeckoMode>
<USBINPUTS>16</USBINPUTS>
<USBOUTPUTS>16</USBOUTPUTS>
<Port2On>0</Port2On>
<Port1On>1</Port1On>
<Port1Add>888</Port1Add>
<Port2Add>632</Port2Add>
<MaxCL>0</MaxCL>
<MaxNC10>0</MaxNC10>
<Motor0Active>1</Motor0Active>
<Motor0DirNeg>1</Motor0DirNeg>
<Motor0DirPort>1</Motor0DirPort>
<Motor0DirPin>0</Motor0DirPin>
<Motor0StepNeg>1</Motor0StepNeg>
<Motor0StepPort>1</Motor0StepPort>
<Motor0StepPin>0</Motor0StepPin>
<Motor1Active>1</Motor1Active>
<Motor1DirNeg>0</Motor1DirNeg>
<Motor1DirPort>1</Motor1DirPort>
<Motor1DirPin>0</Motor1DirPin>
<Motor1StepNeg>0</Motor1StepNeg>
<Motor1StepPort>1</Motor1StepPort>
<Motor1StepPin>0</Motor1StepPin>
<Motor2Active>1</Motor2Active>
<Motor2DirNeg>0</Motor2DirNeg>
<Motor2DirPort>1</Motor2DirPort>
<Motor2DirPin>0</Motor2DirPin>
<Motor2StepNeg>0</Motor2StepNeg>
<Motor2StepPort>1</Motor2StepPort>
<Motor2StepPin>0</Motor2StepPin>
<Motor3Active>1</Motor3Active>
<Motor3DirNeg>0</Motor3DirNeg>
<Motor3DirPort>1</Motor3DirPort>
<Motor3DirPin>0</Motor3DirPin>
<Motor3StepNeg>0</Motor3StepNeg>
<Motor3StepPort>1</Motor3StepPort>
<Motor3StepPin>0</Motor3StepPin>
<Motor4Active>0</Motor4Active>
<Motor4DirNeg>1</Motor4DirNeg>
<Motor4DirPort>1</Motor4DirPort>
<Motor4DirPin>0</Motor4DirPin>
<Motor4StepNeg>1</Motor4StepNeg>
<Motor4StepPort>1</Motor4StepPort>
<Motor4StepPin>0</Motor4StepPin>
<Motor5Active>0</Motor5Active>
<Motor5DirNeg>0</Motor5DirNeg>
<Motor5DirPort>0</Motor5DirPort>
<Motor5DirPin>0</Motor5DirPin>
<Motor5StepNeg>0</Motor5StepNeg>
<Motor5StepPort>0</Motor5StepPort>
<Motor5StepPin>0</Motor5StepPin>
<Motor6Active>0</Motor6Active>
<Motor6DirNeg>0</Motor6DirNeg>
<Motor6DirPort>0</Motor6DirPort>
<Motor6DirPin>0</Motor6DirPin>
<Motor6StepNeg>0</Motor6StepNeg>
<Motor6StepPort>0</Motor6StepPort>
<Motor6StepPin>0</Motor6StepPin>
<Input0Active>0</Input0Active>
<Input0Port>1</Input0Port>
<Input0Pin>0</Input0Pin>
<Input0Neg>0</Input0Neg>
<Input0Emulated>0</Input0Emulated>
<Input0EmuKey>0</Input0EmuKey>
<Input1Active>0</Input1Active>
<Input1Port>1</Input1Port>
<Input1Pin>0</Input1Pin>
<Input1Neg>0</Input1Neg>
<Input1Emulated>0</Input1Emulated>
<Input1EmuKey>0</Input1EmuKey>
<Input2Active>1</Input2Active>
<Input2Port>1</Input2Port>
<Input2Pin>0</Input2Pin>
<Input2Neg>0</Input2Neg>
<Input2Emulated>1</Input2Emulated>
<Input2EmuKey>0</Input2EmuKey>
<Input3Active>0</Input3Active>
<Input3Port>1</Input3Port>
<Input3Pin>0</Input3Pin>
<Input3Neg>0</Input3Neg>
<Input3Emulated>0</Input3Emulated>
<Input3EmuKey>0</Input3EmuKey>
<Input4Active>0</Input4Active>
<Input4Port>1</Input4Port>
<Input4Pin>0</Input4Pin>
<Input4Neg>0</Input4Neg>
<Input4Emulated>0</Input4Emulated>
<Input4EmuKey>0</Input4EmuKey>
<Input5Active>1</Input5Active>
<Input5Port>1</Input5Port>
<Input5Pin>0</Input5Pin>
<Input5Neg>0</Input5Neg>
<Input5Emulated>1</Input5Emulated>
<Input5EmuKey>0</Input5EmuKey>
<Input6Active>0</Input6Active>
<Input6Port>1</Input6Port>
<Input6Pin>0</Input6Pin>
<Input6Neg>0</Input6Neg>
<Input6Emulated>0</Input6Emulated>
<Input6EmuKey>0</Input6EmuKey>
<Input7Active>0</Input7Active>
<Input7Port>1</Input7Port>
<Input7Pin>0</Input7Pin>
<Input7Neg>0</Input7Neg>
<Input7Emulated>0</Input7Emulated>
<Input7EmuKey>0</Input7EmuKey>
<Input8Active>1</Input8Active>
<Input8Port>1</Input8Port>
<Input8Pin>0</Input8Pin>
<Input8Neg>0</Input8Neg>
<Input8Emulated>1</Input8Emulated>
<Input8EmuKey>0</Input8EmuKey>
<Input9Active>0</Input9Active>
<Input9Port>1</Input9Port>
<Input9Pin>0</Input9Pin>
<Input9Neg>0</Input9Neg>
<Input9Emulated>0</Input9Emulated>
<Input9EmuKey>0</Input9EmuKey>
<Input10Active>0</Input10Active>
<Input10Port>1</Input10Port>
<Input10Pin>0</Input10Pin>
<Input10Neg>0</Input10Neg>
<Input10Emulated>0</Input10Emulated>
<Input10EmuKey>0</Input10EmuKey>
<Input11Active>0</Input11Active>
<Input11Port>1</Input11Port>
<Input11Pin>0</Input11Pin>
<Input11Neg>0</Input11Neg>
<Input11Emulated>0</Input11Emulated>
<Input11EmuKey>0</Input11EmuKey>
<Input12Active>0</Input12Active>
<Input12Port>1</Input12Port>
<Input12Pin>0</Input12Pin>
<Input12Neg>0</Input12Neg>
<Input12Emulated>0</Input12Emulated>
<Input12EmuKey>0</Input12EmuKey>
<Input13Active>0</Input13Active>
<Input13Port>1</Input13Port>
<Input13Pin>0</Input13Pin>
<Input13Neg>0</Input13Neg>
<Input13Emulated>0</Input13Emulated>
<Input13EmuKey>0</Input13EmuKey>
<Input14Active>0</Input14Active>
<Input14Port>1</Input14Port>
<Input14Pin>0</Input14Pin>
<Input14Neg>0</Input14Neg>
<Input14Emulated>0</Input14Emulated>
<Input14EmuKey>0</Input14EmuKey>
<Input15Active>0</Input15Active>
<Input15Port>1</Input15Port>
<Input15Pin>0</Input15Pin>
<Input15Neg>0</Input15Neg>
<Input15Emulated>0</Input15Emulated>
<Input15EmuKey>0</Input15EmuKey>
<Input16Active>0</Input16Active>
<Input16Port>1</Input16Port>
<Input16Pin>0</Input16Pin>
<Input16Neg>0</Input16Neg>
<Input16Emulated>0</Input16Emulated>
<Input16EmuKey>0</Input16EmuKey>
<Input17Active>0</Input17Active>
<Input17Port>1</Input17Port>
<Input17Pin>0</Input17Pin>
<Input17Neg>0</Input17Neg>
<Input17Emulated>0</Input17Emulated>
<Input17EmuKey>0</Input17EmuKey>
<Input18Active>0</Input18Active>
<Input18Port>1</Input18Port>
<Input18Pin>0</Input18Pin>
<Input18Neg>0</Input18Neg>
<Input18Emulated>0</Input18Emulated>
<Input18EmuKey>0</Input18EmuKey>
<Input19Active>0</Input19Active>
<Input19Port>1</Input19Port>
<Input19Pin>0</Input19Pin>
<Input19Neg>0</Input19Neg>
<Input19Emulated>0</Input19Emulated>
<Input19EmuKey>0</Input19EmuKey>
<Input20Active>0</Input20Active>
<Input20Port>1</Input20Port>
<Input20Pin>0</Input20Pin>
<Input20Neg>0</Input20Neg>
<Input20Emulated>0</Input20Emulated>
<Input20EmuKey>0</Input20EmuKey>
<Input21Active>0</Input21Active>
<Input21Port>1</Input21Port>
<Input21Pin>0</Input21Pin>
<Input21Neg>0</Input21Neg>
<Input21Emulated>0</Input21Emulated>
<Input21EmuKey>0</Input21EmuKey>
<Input22Active>1</Input22Active>
<Input22Port>1</Input22Port>
<Input22Pin>1</Input22Pin>
<Input22Neg>1</Input22Neg>
<Input22Emulated>0</Input22Emulated>
<Input22EmuKey>0</Input22EmuKey>
<Input23Active>0</Input23Active>
<Input23Port>1</Input23Port>
<Input23Pin>0</Input23Pin>
<Input23Neg>1</Input23Neg>
<Input23Emulated>0</Input23Emulated>
<Input23EmuKey>0</Input23EmuKey>
<Input24Active>0</Input24Active>
<Input24Port>1</Input24Port>
<Input24Pin>0</Input24Pin>
<Input24Neg>0</Input24Neg>
<Input24Emulated>0</Input24Emulated>
<Input24EmuKey>0</Input24EmuKey>
<Input25Active>1</Input25Active>
<Input25Port>1</Input25Port>
<Input25Pin>0</Input25Pin>
<Input25Neg>0</Input25Neg>
<Input25Emulated>0</Input25Emulated>
<Input25EmuKey>0</Input25EmuKey>
<Input26Active>1</Input26Active>
<Input26Port>1</Input26Port>
<Input26Pin>12</Input26Pin>
<Input26Neg>1</Input26Neg>
<Input26Emulated>0</Input26Emulated>
<Input26EmuKey>0</Input26EmuKey>
<Input27Active>1</Input27Active>
<Input27Port>1</Input27Port>
<Input27Pin>8</Input27Pin>
<Input27Neg>1</Input27Neg>
<Input27Emulated>0</Input27Emulated>
<Input27EmuKey>0</Input27EmuKey>
<Input28Active>1</Input28Active>
<Input28Port>1</Input28Port>
<Input28Pin>13</Input28Pin>
<Input28Neg>1</Input28Neg>
<Input28Emulated>0</Input28Emulated>
<Input28EmuKey>0</Input28EmuKey>
<Input29Active>0</Input29Active>
<Input29Port>1</Input29Port>
<Input29Pin>0</Input29Pin>
<Input29Neg>0</Input29Neg>
<Input29Emulated>0</Input29Emulated>
<Input29EmuKey>0</Input29EmuKey>
<Input30Active>0</Input30Active>
<Input30Port>1</Input30Port>
<Input30Pin>0</Input30Pin>
<Input30Neg>0</Input30Neg>
<Input30Emulated>0</Input30Emulated>
<Input30EmuKey>0</Input30EmuKey>
<Input31Active>0</Input31Active>
<Input31Port>1</Input31Port>
<Input31Pin>0</Input31Pin>
<Input31Neg>0</Input31Neg>
<Input31Emulated>0</Input31Emulated>
<Input31EmuKey>0</Input31EmuKey>
<Input32Active>0</Input32Active>
<Input32Port>1</Input32Port>
<Input32Pin>0</Input32Pin>
<Input32Neg>0</Input32Neg>
<Input32Emulated>0</Input32Emulated>
<Input32EmuKey>0</Input32EmuKey>
<Input33Active>0</Input33Active>
<Input33Port>1</Input33Port>
<Input33Pin>0</Input33Pin>
<Input33Neg>0</Input33Neg>
<Input33Emulated>0</Input33Emulated>
<Input33EmuKey>0</Input33EmuKey>
<Input34Active>0</Input34Active>
<Input34Port>0</Input34Port>
<Input34Pin>0</Input34Pin>
<Input34Neg>0</Input34Neg>
<Input34Emulated>0</Input34Emulated>
<Input34EmuKey>0</Input34EmuKey>
<Input35Active>0</Input35Active>
<Input35Port>0</Input35Port>
<Input35Pin>0</Input35Pin>
<Input35Neg>0</Input35Neg>
<Input35Emulated>0</Input35Emulated>
<Input35EmuKey>0</Input35EmuKey>
<Input36Active>0</Input36Active>
<Input36Port>0</Input36Port>
<Input36Pin>0</Input36Pin>
<Input36Neg>0</Input36Neg>
<Input36Emulated>0</Input36Emulated>
<Input36EmuKey>0</Input36EmuKey>
<Input37Active>0</Input37Active>
<Input37Port>0</Input37Port>
<Input37Pin>0</Input37Pin>
<Input37Neg>0</Input37Neg>
<Input37Emulated>0</Input37Emulated>
<Input37EmuKey>0</Input37EmuKey>
<Input38Active>0</Input38Active>
<Input38Port>0</Input38Port>
<Input38Pin>0</Input38Pin>
<Input38Neg>0</Input38Neg>
<Input38Emulated>0</Input38Emulated>
<Input38EmuKey>0</Input38EmuKey>
<Input39Active>0</Input39Active>
<Input39Port>0</Input39Port>
<Input39Pin>0</Input39Pin>
<Input39Neg>0</Input39Neg>
<Input39Emulated>0</Input39Emulated>
<Input39EmuKey>0</Input39EmuKey>
<Input40Active>0</Input40Active>
<Input40Port>0</Input40Port>
<Input40Pin>0</Input40Pin>
<Input40Neg>0</Input40Neg>
<Input40Emulated>0</Input40Emulated>
<Input40EmuKey>0</Input40EmuKey>
<Input41Active>0</Input41Active>
<Input41Port>0</Input41Port>
<Input41Pin>0</Input41Pin>
<Input41Neg>0</Input41Neg>
<Input41Emulated>0</Input41Emulated>
<Input41EmuKey>0</Input41EmuKey>
<Input42Active>0</Input42Active>
<Input42Port>0</Input42Port>
<Input42Pin>0</Input42Pin>
<Input42Neg>0</Input42Neg>
<Input42Emulated>0</Input42Emulated>
<Input42EmuKey>0</Input42EmuKey>
<Input43Active>0</Input43Active>
<Input43Port>0</Input43Port>
<Input43Pin>0</Input43Pin>
<Input43Neg>0</Input43Neg>
<Input43Emulated>0</Input43Emulated>
<Input43EmuKey>0</Input43EmuKey>
<Input44Active>0</Input44Active>
<Input44Port>0</Input44Port>
<Input44Pin>0</Input44Pin>
<Input44Neg>0</Input44Neg>
<Input44Emulated>0</Input44Emulated>
<Input44EmuKey>0</Input44EmuKey>
<Input45Active>0</Input45Active>
<Input45Port>0</Input45Port>
<Input45Pin>0</Input45Pin>
<Input45Neg>0</Input45Neg>
<Input45Emulated>0</Input45Emulated>
<Input45EmuKey>0</Input45EmuKey>
<Input46Active>0</Input46Active>
<Input46Port>0</Input46Port>
<Input46Pin>0</Input46Pin>
<Input46Neg>0</Input46Neg>
<Input46Emulated>0</Input46Emulated>
<Input46EmuKey>0</Input46EmuKey>
<Input47Active>0</Input47Active>
<Input47Port>0</Input47Port>
<Input47Pin>0</Input47Pin>
<Input47Neg>0</Input47Neg>
<Input47Emulated>0</Input47Emulated>
<Input47EmuKey>0</Input47EmuKey>
<Input48Active>0</Input48Active>
<Input48Port>0</Input48Port>
<Input48Pin>0</Input48Pin>
<Input48Neg>0</Input48Neg>
<Input48Emulated>0</Input48Emulated>
<Input48EmuKey>0</Input48EmuKey>
<Input49Active>0</Input49Active>
<Input49Port>0</Input49Port>
<Input49Pin>0</Input49Pin>
<Input49Neg>0</Input49Neg>
<Input49Emulated>0</Input49Emulated>
<Input49EmuKey>0</Input49EmuKey>
<Input50Active>0</Input50Active>
<Input50Port>0</Input50Port>
<Input50Pin>0</Input50Pin>
<Input50Neg>0</Input50Neg>
<Input50Emulated>0</Input50Emulated>
<Input50EmuKey>0</Input50EmuKey>
<Input51Active>0</Input51Active>
<Input51Port>0</Input51Port>
<Input51Pin>0</Input51Pin>
<Input51Neg>0</Input51Neg>
<Input51Emulated>0</Input51Emulated>
<Input51EmuKey>0</Input51EmuKey>
<Input52Active>0</Input52Active>
<Input52Port>0</Input52Port>
<Input52Pin>0</Input52Pin>
<Input52Neg>0</Input52Neg>
<Input52Emulated>0</Input52Emulated>
<Input52EmuKey>0</Input52EmuKey>
<Output0Active>0</Output0Active>
<Output0Port>1</Output0Port>
<Output0Pin>16</Output0Pin>
<Output0Neg>0</Output0Neg>
<Output1Active>1</Output1Active>
<Output1Port>1</Output1Port>
<Output1Pin>1</Output1Pin>
<Output1Neg>0</Output1Neg>
<Output2Active>0</Output2Active>
<Output2Port>1</Output2Port>
<Output2Pin>0</Output2Pin>
<Output2Neg>0</Output2Neg>
<Output3Active>0</Output3Active>
<Output3Port>1</Output3Port>
<Output3Pin>0</Output3Pin>
<Output3Neg>0</Output3Neg>
<Output4Active>0</Output4Active>
<Output4Port>1</Output4Port>
<Output4Pin>0</Output4Pin>
<Output4Neg>0</Output4Neg>
<Output5Active>0</Output5Active>
<Output5Port>1</Output5Port>
<Output5Pin>0</Output5Pin>
<Output5Neg>0</Output5Neg>
<Output6Active>0</Output6Active>
<Output6Port>1</Output6Port>
<Output6Pin>0</Output6Pin>
<Output6Neg>0</Output6Neg>
<Output7Active>1</Output7Active>
<Output7Port>1</Output7Port>
<Output7Pin>14</Output7Pin>
<Output7Neg>1</Output7Neg>
<Output8Active>0</Output8Active>
<Output8Port>1</Output8Port>
<Output8Pin>0</Output8Pin>
<Output8Neg>0</Output8Neg>
<Output9Active>0</Output9Active>
<Output9Port>1</Output9Port>
<Output9Pin>0</Output9Pin>
<Output9Neg>0</Output9Neg>
<Output10Active>0</Output10Active>
<Output10Port>1</Output10Port>
<Output10Pin>0</Output10Pin>
<Output10Neg>0</Output10Neg>
<Output11Active>0</Output11Active>
<Output11Port>1</Output11Port>
<Output11Pin>0</Output11Pin>
<Output11Neg>0</Output11Neg>
<Output12Active>0</Output12Active>
<Output12Port>1</Output12Port>
<Output12Pin>0</Output12Pin>
<Output12Neg>0</Output12Neg>
<Output13Active>0</Output13Active>
<Output13Port>1</Output13Port>
<Output13Pin>0</Output13Pin>
<Output13Neg>0</Output13Neg>
<Output14Active>0</Output14Active>
<Output14Port>1</Output14Port>
<Output14Pin>0</Output14Pin>
<Output14Neg>0</Output14Neg>
<Output15Active>0</Output15Active>
<Output15Port>1</Output15Port>
<Output15Pin>0</Output15Pin>
<Output15Neg>0</Output15Neg>
<Output16Active>0</Output16Active>
<Output16Port>1</Output16Port>
<Output16Pin>0</Output16Pin>
<Output16Neg>0</Output16Neg>
<Output17Active>0</Output17Active>
<Output17Port>1</Output17Port>
<Output17Pin>0</Output17Pin>
<Output17Neg>0</Output17Neg>
<Output18Active>0</Output18Active>
<Output18Port>1</Output18Port>
<Output18Pin>0</Output18Pin>
<Output18Neg>0</Output18Neg>
<Output19Active>0</Output19Active>
<Output19Port>1</Output19Port>
<Output19Pin>0</Output19Pin>
<Output19Neg>0</Output19Neg>
<Output20Active>0</Output20Active>
<Output20Port>1</Output20Port>
<Output20Pin>0</Output20Pin>
<Output20Neg>0</Output20Neg>
<Output21Active>0</Output21Active>
<Output21Port>1</Output21Port>
<Output21Pin>0</Output21Pin>
<Output21Neg>0</Output21Neg>
<Output22Active>0</Output22Active>
<Output22Port>1</Output22Port>
<Output22Pin>0</Output22Pin>
<Output22Neg>0</Output22Neg>
<Output23Active>0</Output23Active>
<Output23Port>1</Output23Port>
<Output23Pin>0</Output23Pin>
<Output23Neg>0</Output23Neg>
<Output24Active>0</Output24Active>
<Output24Port>1</Output24Port>
<Output24Pin>0</Output24Pin>
<Output24Neg>0</Output24Neg>
<Output25Active>0</Output25Active>
<Output25Port>1</Output25Port>
<Output25Pin>0</Output25Pin>
<Output25Neg>0</Output25Neg>
<Output26Active>0</Output26Active>
<Output26Port>1</Output26Port>
<Output26Pin>0</Output26Pin>
<Output26Neg>0</Output26Neg>
<Output27Active>0</Output27Active>
<Output27Port>1</Output27Port>
<Output27Pin>0</Output27Pin>
<Output27Neg>0</Output27Neg>
<Output28Active>0</Output28Active>
<Output28Port>1</Output28Port>
<Output28Pin>0</Output28Pin>
<Output28Neg>0</Output28Neg>
<Output29Active>0</Output29Active>
<Output29Port>1</Output29Port>
<Output29Pin>0</Output29Pin>
<Output29Neg>0</Output29Neg>
<Output30Active>0</Output30Active>
<Output30Port>0</Output30Port>
<Output30Pin>0</Output30Pin>
<Output30Neg>0</Output30Neg>
<Encoder0Active>0</Encoder0Active>
<Encoder0APort>0</Encoder0APort>
<Encoder0APin>0</Encoder0APin>
<Encoder0BPort>0</Encoder0BPort>
<Encoder0BPin>0</Encoder0BPin>
<Encoder0Cal>1.000000</Encoder0Cal>
<Encoder1Active>0</Encoder1Active>
<Encoder1APort>0</Encoder1APort>
<Encoder1APin>0</Encoder1APin>
<Encoder1BPort>0</Encoder1BPort>
<Encoder1BPin>0</Encoder1BPin>
<Encoder1Cal>1.000000</Encoder1Cal>
<Encoder2Active>0</Encoder2Active>
<Encoder2APort>0</Encoder2APort>
<Encoder2APin>0</Encoder2APin>
<Encoder2BPort>0</Encoder2BPort>
<Encoder2BPin>0</Encoder2BPin>
<Encoder2Cal>1.000000</Encoder2Cal>
<Encoder3Active>0</Encoder3Active>
<Encoder3APort>0</Encoder3APort>
<Encoder3APin>0</Encoder3APin>
<Encoder3BPort>0</Encoder3BPort>
<Encoder3BPin>0</Encoder3BPin>
<Encoder3Cal>1.000000</Encoder3Cal>
<Encoder4Active>0</Encoder4Active>
<Encoder4APort>0</Encoder4APort>
<Encoder4APin>0</Encoder4APin>
<Encoder4BPort>0</Encoder4BPort>
<Encoder4BPin>0</Encoder4BPin>
<Encoder4Cal>1.000000</Encoder4Cal>
<Encoder5Active>0</Encoder5Active>
<Encoder5APort>0</Encoder5APort>
<Encoder5APin>0</Encoder5APin>
<Encoder5BPort>0</Encoder5BPort>
<Encoder5BPin>0</Encoder5BPin>
<Encoder5Cal>1.000000</Encoder5Cal>
<Encoder6Active>0</Encoder6Active>
<Encoder6APort>0</Encoder6APort>
<Encoder6APin>0</Encoder6APin>
<Encoder6BPort>0</Encoder6BPort>
<Encoder6BPin>0</Encoder6BPin>
<Encoder6Cal>1.000000</Encoder6Cal>
<Encoder7Active>0</Encoder7Active>
<Encoder7APort>0</Encoder7APort>
<Encoder7APin>0</Encoder7APin>
<Encoder7BPort>0</Encoder7BPort>
<Encoder7BPin>0</Encoder7BPin>
<Encoder7Cal/>
<Configured>1</Configured>
<SlavePrim>0</SlavePrim>
<Slave>-1</Slave>
<AxisKeys0>39</AxisKeys0>
<AxisKeys1>37</AxisKeys1>
<AxisKeys2>38</AxisKeys2>
<AxisKeys3>40</AxisKeys3>
<AxisKeys4>33</AxisKeys4>
<AxisKeys5>34</AxisKeys5>
<AxisKeys6>999</AxisKeys6>
<AxisKeys7>999</AxisKeys7>
<AxisKeys8>999</AxisKeys8>
<AxisKeys9>999</AxisKeys9>
<AxisKeys10>999</AxisKeys10>
<AxisKeys11>999</AxisKeys11>
<DROHotKey>999</DROHotKey>
<ListKey>999</ListKey>
<MDIHotKey>999</MDIHotKey>
<GCodeHotKey>999</GCodeHotKey>
<OEM1>-1</OEM1>
<OEM2>-1</OEM2>
<OEM3>-1</OEM3>
<OEM4>-1</OEM4>
<OEM5>-1</OEM5>
<OEM6>-1</OEM6>
<PulseWidth>0</PulseWidth>
<DirPulse>0</DirPulse>
<BackX>0.</BackX>
<BackY>0.</BackY>
<BackZ>0.</BackZ>
<BackA>0.</BackA>
<BackB>0.</BackB>
<BackC>0.</BackC>
<BackSpeed>20.</BackSpeed>
<BB>0.</BB>
<BR>0.</BR>
<BG>0.</BG>
<FB>1.</FB>
<FR>0.</FR>
<FG>0.</FG>
<RB>0.</RB>
<RR>1.</RR>
<RG>0.</RG>
<AB>0.7</AB>
<AR>0.7</AR>
<AG>0.2</AG>
<EG>1.</EG>
<ER>1.</ER>
<EB>0.</EB>
<JogFollow>0</JogFollow>
<G92Off>1</G92Off>
<RadiusCompOff>1</RadiusCompOff>
<Debounce>25</Debounce>
<PlasmaMode>0</PlasmaMode>
<NoAngle>1</NoAngle>
<AAngular>1</AAngular>
<BAngular>1</BAngular>
<CAngular>1</CAngular>
<IndexDebounce>0</IndexDebounce>
<DROPERSIST>1</DROPERSIST>
<DwellinMilli>0</DwellinMilli>
<IJMode>1</IJMode>
<INIT>G80</INIT>
<InitAllResets>0</InitAllResets>
<AutoScreens>1</AutoScreens>
<TORCHVON>0</TORCHVON>
<TORCHVOLTS>0</TORCHVOLTS>
<HWSAFE>1</HWSAFE>
<ShortRot>0</ShortRot>
<LookAhead>20</LookAhead>
<WatchDog>0</WatchDog>
<Plane>0</Plane>
<MPG1>0</MPG1>
<MPG2>0</MPG2>
<HotKeysPersist>0</HotKeysPersist>
<HoldInput1>0</HoldInput1>
<M3s>21911</M3s>
<UseCR>0</UseCR>
<PlasmaHome>0</PlasmaHome>
<Homann>0</Homann>
<UseSLS>0</UseSLS>
<Dist0>1.e+005</Dist0>
<Dist1>1.4e+005</Dist1>
<Dist2>1.1e+004</Dist2>
<Dist3>0.</Dist3>
<Dist4>0.</Dist4>
<Dist5>0.</Dist5>
<OverMode2>0</OverMode2>
<BitPack1>0</BitPack1>
<BitPack1Reg>16</BitPack1Reg>
<BitPackOut>0</BitPackOut>
<BitPackOutReg>16</BitPackOutReg>
<LaserPort>1</LaserPort>
<LaserBaud>9600</LaserBaud>
<LaserStops>1</LaserStops>
<LaserData>1</LaserData>
<LaserInit>></LaserInit>
<LaserCommand>></LaserCommand>
<MacroPump>0</MacroPump>
<VelMode>0</VelMode>
<VelPer1>5.</VelPer1>
<VelPer2>5.</VelPer2>
<MPGFeed>1.e+002</MPGFeed>
<ModSpindleCal>1.638e+004</ModSpindleCal>
<ModSpindleOn>0</ModSpindleOn>
<ModSpindleReg>64</ModSpindleReg>
<ShuttleAccel>8192</ShuttleAccel>
<Flash>1</Flash>
<ImmediateOff>0</ImmediateOff>
<UseSafeZ>0</UseSafeZ>
<AdvancedComp>1</AdvancedComp>
<TorchOff>0</TorchOff>
<LaserStandby>0</LaserStandby>
<RaiseLower>1</RaiseLower>
<OEMDUAL>0</OEMDUAL>
<IncBuffer>5</IncBuffer>
<Formula0>x</Formula0>
<Formula1>y</Formula1>
<Formula2>z</Formula2>
<Formula3>a</Formula3>
<Formula4>b</Formula4>
<Formula5>c</Formula5>
<Formular>0</Formular>
<PanelOut>350</PanelOut>
<nModBusReg>0</nModBusReg>
<ModBusRegOn>0</ModBusRegOn>
<Tool>7</Tool>
<Sherline>0</Sherline>
<ToolPost>1</ToolPost>
<RapidOverRide>0</RapidOverRide>
<XCLength>1.3e+003</XCLength>
<YCLength>1.3e+003</YCLength>
<ZCLength>1.3e+003</ZCLength>
<ToolPostOffset>0.</ToolPostOffset>
<OEM7>-1</OEM7>
<OEM8>-1</OEM8>
<OEM9>-1</OEM9>
<OEM10>-1</OEM10>
<OEM11>-1</OEM11>
<OEM12>-1</OEM12>
<OEM13>-1</OEM13>
<OEM14>-1</OEM14>
<OEM15>-1</OEM15>
<MPGVel0>1.e+002</MPGVel0>
<MPGVel1>1.e+002</MPGVel1>
<MPGVel2>1.e+002</MPGVel2>
<MPGVel3>1.e+002</MPGVel3>
<MPGVel4>1.e+002</MPGVel4>
<MPGVel5>1.e+002</MPGVel5>
<MPGVel6>1.e+002</MPGVel6>
<ByPassFeed>1.e+003</ByPassFeed>
<XMapOn>0</XMapOn>
<YMapOn>0</YMapOn>
<ZMapOn>0</ZMapOn>
<SecondsOn>2331746</SecondsOn>
<SerialType>0</SerialType>
<SpinAverage>0</SpinAverage>
<Dig4Axis>0</Dig4Axis>
<DigLetter>0</DigLetter>
<CutType>0</CutType>
<InfeedType>0</InfeedType>
<LastWizard>C:\Mach3\Addons\4th Axis Digitize\digitize.set</LastWizard>
<Z25D>0</Z25D>
<ModBus>0</ModBus>
<ChargeAlwaysOn>0</ChargeAlwaysOn>
<ToolFlip>0</ToolFlip>
<SpinCCW>7</SpinCCW>
<SpinCW>7</SpinCW>
<Flood>9</Flood>
<Mist>10</Mist>
<SpinActual>0</SpinActual>
<SpinDelayCW>0.</SpinDelayCW>
<SpinDelayCCW>0.</SpinDelayCCW>
<SpinDownCW>0.</SpinDownCW>
<SpinDownCCW>0.</SpinDownCCW>
<StockSize>50</StockSize>
<ShowSolid>0</ShowSolid>
<RapidFeed>1.e+003</RapidFeed>
<MatRed>0.</MatRed>
<MatGreen>0.1</MatGreen>
<MatBlue>0.1</MatBlue>
<SpinP>0.25</SpinP>
<SpinI>1.</SpinI>
<SpinD>0.3</SpinD>
<SpinClosed>0</SpinClosed>
<MinPerPass>0.1</MinPerPass>
<NoSpindle>0</NoSpindle>
<NoFlood>1</NoFlood>
<PWMin>0</PWMin>
<PULLEY>3</PULLEY>
<SPEED1>1000</SPEED1>
<SPEED2>2000</SPEED2>
<SPEED3>4000</SPEED3>
<SPEED4>8000</SPEED4>
<LSPEED1>0</LSPEED1>
<LSPEED2>0</LSPEED2>
<LSPEED3>0</LSPEED3>
<LSPEED4>0</LSPEED4>
<PWM>0</PWM>
<RefSpeed0>20</RefSpeed0>
<RefSpeed1>20</RefSpeed1>
<RefSpeed2>20</RefSpeed2>
<RefSpeed3>20</RefSpeed3>
<RefSpeed4>20</RefSpeed4>
<RefSpeed5>20</RefSpeed5>
<M0SoftRamp>2.</M0SoftRamp>
<M1SoftRamp>2.</M1SoftRamp>
<M2SoftRamp>0.5</M2SoftRamp>
<M3SoftRamp>2.</M3SoftRamp>
<M4SoftRamp>1.</M4SoftRamp>
<M5SoftRamp>1.</M5SoftRamp>
<FeedInc>5.</FeedInc>
<DepthLastPass>0.</DepthLastPass>
<InFeed>29.5</InFeed>
<Spring>1.</Spring>
<MinDepth>1.e-003</MinDepth>
<XClear>0.1</XClear>
<ZClear>0.1</ZClear>
<CutDepth>0.1</CutDepth>
<Chamfer>0.</Chamfer>
<DepthFirstPass>0.1</DepthFirstPass>
<M0Max>47.75</M0Max>
<M1Max>95.75</M1Max>
<M2Max>0.</M2Max>
<M3Max>95.75</M3Max>
<M4Max>100.</M4Max>
<M5Max>100.</M5Max>
<M0Min>0.</M0Min>
<M1Min>0.</M1Min>
<M2Min>-4.</M2Min>
<M3Min>0.</M3Min>
<M4Min>-100.</M4Min>
<M5Min>-100.</M5Min>
<M0Neg>0</M0Neg>
<M1Neg>0</M1Neg>
<M2Neg>1</M2Neg>
<M3Neg>0</M3Neg>
<M4Neg>0</M4Neg>
<M5Neg>0</M5Neg>
<M0AutoZero>1</M0AutoZero>
<M1AutoZero>1</M1AutoZero>
<M2AutoZero>1</M2AutoZero>
<M3AutoZero>1</M3AutoZero>
<M4AutoZero>1</M4AutoZero>
<M5AutoZero>1</M5AutoZero>
<M0Rev>0</M0Rev>
<M1Rev>0</M1Rev>
<M2Rev>1</M2Rev>
<M3Rev>1</M3Rev>
<M4Rev>0</M4Rev>
<M5Rev>0</M5Rev>
<M6Rev>0</M6Rev>
<OffPersist>1</OffPersist>
<Diameter>0</Diameter>
<OffDialogs>1</OffDialogs>
<G54Back>0</G54Back>
<GougeCheck>0</GougeCheck>
<AxisToMotor0>0</AxisToMotor0>
<AxisToMotor1>1</AxisToMotor1>
<AxisToMotor2>2</AxisToMotor2>
<AxisToMotor3>3</AxisToMotor3>
<AxisToMotor4>4</AxisToMotor4>
<AxisToMotor5>5</AxisToMotor5>
<AxisToMotor6>6</AxisToMotor6>
<JogActive>1</JogActive>
<BLState0>0</BLState0>
<BLState1>1</BLState1>
<BLState2>1</BLState2>
<BLState3>1</BLState3>
<BLState4>0</BLState4>
<BLState5>0</BLState5>
<SlowMode>0</SlowMode>
<JogPersist>1</JogPersist>
<ToolRotations>0</ToolRotations>
<SoftLimit>0</SoftLimit>
<JogMode>0</JogMode>
<JogMode2>0</JogMode2>
<EncJogAxis2>2</EncJogAxis2>
<TaperRatio>1.</TaperRatio>
<XStart>-254</XStart>
<YStart>778</YStart>
<ZStart>45105</ZStart>
<AStart>0</AStart>
<BStart>0</BStart>
<CStart>0</CStart>
<SpinInc>1</SpinInc>
<Enc0>0.</Enc0>
<Enc1>4.</Enc1>
<Enc2>0.</Enc2>
<Enc3>0.</Enc3>
<TangentalControl>0</TangentalControl>
<BaudRate>9600</BaudRate>
<ComPort>1</ComPort>
<NoPlunge>1</NoPlunge>
<PlungeLimit>75</PlungeLimit>
<AutoTool>0</AutoTool>
<AutoSpindle>0</AutoSpindle>
<LaserMode>0</LaserMode>
<FeedMode>0</FeedMode>
<OriginSphere>0</OriginSphere>
<m_3dCompass>1</m_3dCompass>
<Boundries>0</Boundries>
<ToolPosition>1</ToolPosition>
<AParallel>0</AParallel>
<ZINHPersist>0</ZINHPersist>
<OVPersist>1</OVPersist>
<BacklashOn>0</BacklashOn>
<PathMode>2</PathMode>
<ThrottleFunc>2</ThrottleFunc>
<JoyOn>0</JoyOn>
<PWMBase>5000</PWMBase>
<JogSpeed>100.</JogSpeed>
<G73PullBack>0.1</G73PullBack>
<CVFeedOn>0</CVFeedOn>
<CVFeedRate>1.</CVFeedRate>
<AtoX>0.</AtoX>
<AtoY>0.</AtoY>
<AtoZ>0.</AtoZ>
<OEMDRO0>0.</OEMDRO0>
<OEMLED0>0</OEMLED0>
<OEMDRO1>0.</OEMDRO1>
<OEMLED1>0</OEMLED1>
<OEMDRO2>0.</OEMDRO2>
<OEMLED2>0</OEMLED2>
<OEMDRO3>0.</OEMDRO3>
<OEMLED3>0</OEMLED3>
<OEMDRO4>0.</OEMDRO4>
<OEMLED4>0</OEMLED4>
<OEMDRO5>0.</OEMDRO5>
<OEMLED5>0</OEMLED5>
<OEMDRO6>0.</OEMDRO6>
<OEMLED6>0</OEMLED6>
<OEMDRO7>0.</OEMDRO7>
<OEMLED7>0</OEMLED7>
<OEMDRO8>0.</OEMDRO8>
<OEMLED8>0</OEMLED8>
<OEMDRO9>0.</OEMDRO9>
<OEMLED9>0</OEMLED9>
<OEMDRO10>0.</OEMDRO10>
<OEMLED10>0</OEMLED10>
<OEMDRO11>0.</OEMDRO11>
<OEMLED11>0</OEMLED11>
<OEMDRO12>0.</OEMDRO12>
<OEMLED12>0</OEMLED12>
<OEMDRO13>0.</OEMDRO13>
<OEMLED13>0</OEMLED13>
<OEMDRO14>0.</OEMDRO14>
<OEMLED14>0</OEMLED14>
<OEMDRO15>0.</OEMDRO15>
<OEMLED15>0</OEMLED15>
<OEMDRO16>0.</OEMDRO16>
<OEMLED16>0</OEMLED16>
<OEMDRO17>0.</OEMDRO17>
<OEMLED17>0</OEMLED17>
<OEMDRO18>0.</OEMDRO18>
<OEMLED18>0</OEMLED18>
<OEMDRO19>0.</OEMDRO19>
<OEMLED19>0</OEMLED19>
<OEMDRO20>0.</OEMDRO20>
<OEMLED20>0</OEMLED20>
<OEMDRO21>0.</OEMDRO21>
<OEMLED21>0</OEMLED21>
<OEMDRO22>0.</OEMDRO22>
<OEMLED22>0</OEMLED22>
<OEMDRO23>0.</OEMDRO23>
<OEMLED23>0</OEMLED23>
<OEMDRO24>0.</OEMDRO24>
<OEMLED24>0</OEMLED24>
<OEMDRO25>0.</OEMDRO25>
<OEMLED25>0</OEMLED25>
<OEMDRO26>0.</OEMDRO26>
<OEMLED26>0</OEMLED26>
<OEMDRO27>0.</OEMDRO27>
<OEMLED27>0</OEMLED27>
<OEMDRO28>0.</OEMDRO28>
<OEMLED28>0</OEMLED28>
<OEMDRO29>0.</OEMDRO29>
<OEMLED29>0</OEMLED29>
<OEMDRO30>0.</OEMDRO30>
<OEMLED30>0</OEMLED30>
<OEMDRO31>0.</OEMDRO31>
<OEMLED31>0</OEMLED31>
<OEMDRO32>0.</OEMDRO32>
<OEMLED32>0</OEMLED32>
<OEMDRO33>0.</OEMDRO33>
<OEMLED33>0</OEMLED33>
<OEMDRO34>0.</OEMDRO34>
<OEMLED34>0</OEMLED34>
<OEMDRO35>0.</OEMDRO35>
<OEMLED35>0</OEMLED35>
<OEMDRO36>0.</OEMDRO36>
<OEMLED36>0</OEMLED36>
<OEMDRO37>0.</OEMDRO37>
<OEMLED37>1</OEMLED37>
<OEMDRO38>0.</OEMDRO38>
<OEMLED38>0</OEMLED38>
<OEMDRO39>0.</OEMDRO39>
<OEMLED39>0</OEMLED39>
<OEMDRO40>0.</OEMDRO40>
<OEMLED40>0</OEMLED40>
<OEMDRO41>0.</OEMDRO41>
<OEMLED41>0</OEMLED41>
<OEMDRO42>3200.</OEMDRO42>
<OEMLED42>0</OEMLED42>
<OEMDRO43>6.</OEMDRO43>
<OEMLED43>0</OEMLED43>
<OEMDRO44>0.</OEMDRO44>
<OEMLED44>0</OEMLED44>
<OEMDRO45>0.</OEMDRO45>
<OEMLED45>0</OEMLED45>
<OEMDRO46>36.000003</OEMDRO46>
<OEMLED46>0</OEMLED46>
<OEMDRO47>2.</OEMDRO47>
<OEMLED47>0</OEMLED47>
<OEMDRO48>2.</OEMDRO48>
<OEMLED48>0</OEMLED48>
<OEMDRO49>2.</OEMDRO49>
<OEMLED49>0</OEMLED49>
<OEMDRO50>0.</OEMDRO50>
<OEMLED50>0</OEMLED50>
<OEMDRO51>0.</OEMDRO51>
<OEMLED51>0</OEMLED51>
<OEMDRO52>800.</OEMDRO52>
<OEMLED52>0</OEMLED52>
<OEMDRO53>0.</OEMDRO53>
<OEMLED53>0</OEMLED53>
<OEMDRO54>0.</OEMDRO54>
<OEMLED54>0</OEMLED54>
<OEMDRO55>0.</OEMDRO55>
<OEMLED55>0</OEMLED55>
<OEMDRO56>0.</OEMDRO56>
<OEMLED56>0</OEMLED56>
<OEMDRO57>0.</OEMDRO57>
<OEMLED57>0</OEMLED57>
<OEMDRO58>0.</OEMDRO58>
<OEMLED58>0</OEMLED58>
<OEMDRO59>0.</OEMDRO59>
<OEMLED59>0</OEMLED59>
<OEMDRO60>0.</OEMDRO60>
<OEMLED60>0</OEMLED60>
<OEMDRO61>0.</OEMDRO61>
<OEMLED61>0</OEMLED61>
<OEMDRO62>0.</OEMDRO62>
<OEMLED62>0</OEMLED62>
<OEMDRO63>0.</OEMDRO63>
<OEMLED63>0</OEMLED63>
<OEMDRO64>0.</OEMDRO64>
<OEMLED64>0</OEMLED64>
<OEMDRO65>0.</OEMDRO65>
<OEMLED65>0</OEMLED65>
<OEMDRO66>0.</OEMDRO66>
<OEMLED66>0</OEMLED66>
<OEMDRO67>0.</OEMDRO67>
<OEMLED67>0</OEMLED67>
<OEMDRO68>0.</OEMDRO68>
<OEMLED68>0</OEMLED68>
<OEMDRO69>0.</OEMDRO69>
<OEMLED69>0</OEMLED69>
<OEMDRO70>0.</OEMDRO70>
<OEMLED70>0</OEMLED70>
<OEMDRO71>0.</OEMDRO71>
<OEMLED71>0</OEMLED71>
<OEMDRO72>0.</OEMDRO72>
<OEMLED72>0</OEMLED72>
<OEMDRO73>0.</OEMDRO73>
<OEMLED73>0</OEMLED73>
<OEMDRO74>0.</OEMDRO74>
<OEMLED74>0</OEMLED74>
<OEMDRO75>0.</OEMDRO75>
<OEMLED75>0</OEMLED75>
<OEMDRO76>0.</OEMDRO76>
<OEMLED76>0</OEMLED76>
<OEMDRO77>0.</OEMDRO77>
<OEMLED77>0</OEMLED77>
<OEMDRO78>0.</OEMDRO78>
<OEMLED78>0</OEMLED78>
<OEMDRO79>0.</OEMDRO79>
<OEMLED79>0</OEMLED79>
<OEMDRO80>0.</OEMDRO80>
<OEMLED80>0</OEMLED80>
<OEMDRO81>0.</OEMDRO81>
<OEMLED81>0</OEMLED81>
<OEMDRO82>0.</OEMDRO82>
<OEMLED82>0</OEMLED82>
<OEMDRO83>0.</OEMDRO83>
<OEMLED83>0</OEMLED83>
<OEMDRO84>0.</OEMDRO84>
<OEMLED84>0</OEMLED84>
<OEMDRO85>0.</OEMDRO85>
<OEMLED85>0</OEMLED85>
<OEMDRO86>0.</OEMDRO86>
<OEMLED86>0</OEMLED86>
<OEMDRO87>0.</OEMDRO87>
<OEMLED87>0</OEMLED87>
<OEMDRO88>0.</OEMDRO88>
<OEMLED88>0</OEMLED88>
<OEMDRO89>0.</OEMDRO89>
<OEMLED89>0</OEMLED89>
<OEMDRO90>0.</OEMDRO90>
<OEMLED90>0</OEMLED90>
<OEMDRO91>0.</OEMDRO91>
<OEMLED91>0</OEMLED91>
<OEMDRO92>0.</OEMDRO92>
<OEMLED92>0</OEMLED92>
<OEMDRO93>0.</OEMDRO93>
<OEMLED93>0</OEMLED93>
<OEMDRO94>0.</OEMDRO94>
<OEMLED94>0</OEMLED94>
<OEMDRO95>0.</OEMDRO95>
<OEMLED95>0</OEMLED95>
<OEMDRO96>0.</OEMDRO96>
<OEMLED96>0</OEMLED96>
<OEMDRO97>0.</OEMDRO97>
<OEMLED97>0</OEMLED97>
<OEMDRO98>0.</OEMDRO98>
<OEMLED98>0</OEMLED98>
<OEMDRO99>0.</OEMDRO99>
<OEMLED99>0</OEMLED99>
<OEMDRO100>0.</OEMDRO100>
<OEMLED100>0</OEMLED100>
<OEMDRO101>0.</OEMDRO101>
<OEMLED101>0</OEMLED101>
<OEMDRO102>0.</OEMDRO102>
<OEMLED102>0</OEMLED102>
<OEMDRO103>0.</OEMDRO103>
<OEMLED103>0</OEMLED103>
<OEMDRO104>0.</OEMDRO104>
<OEMLED104>0</OEMLED104>
<OEMDRO105>0.</OEMDRO105>
<OEMLED105>0</OEMLED105>
<OEMDRO106>0.</OEMDRO106>
<OEMLED106>0</OEMLED106>
<OEMDRO107>0.</OEMDRO107>
<OEMLED107>0</OEMLED107>
<OEMDRO108>0.</OEMDRO108>
<OEMLED108>0</OEMLED108>
<OEMDRO109>0.</OEMDRO109>
<OEMLED109>0</OEMLED109>
<OEMDRO110>0.</OEMDRO110>
<OEMLED110>0</OEMLED110>
<OEMDRO111>0.</OEMDRO111>
<OEMLED111>0</OEMLED111>
<OEMDRO112>0.</OEMDRO112>
<OEMLED112>0</OEMLED112>
<OEMDRO113>0.</OEMDRO113>
<OEMLED113>0</OEMLED113>
<OEMDRO114>0.</OEMDRO114>
<OEMLED114>0</OEMLED114>
<OEMDRO115>0.</OEMDRO115>
<OEMLED115>0</OEMLED115>
<OEMDRO116>0.</OEMDRO116>
<OEMLED116>0</OEMLED116>
<OEMDRO117>0.</OEMDRO117>
<OEMLED117>0</OEMLED117>
<OEMDRO118>0.</OEMDRO118>
<OEMLED118>0</OEMLED118>
<OEMDRO119>0.</OEMDRO119>
<OEMLED119>0</OEMLED119>
<OEMDRO120>0.</OEMDRO120>
<OEMLED120>0</OEMLED120>
<OEMDRO121>0.</OEMDRO121>
<OEMLED121>0</OEMLED121>
<OEMDRO122>0.</OEMDRO122>
<OEMLED122>0</OEMLED122>
<OEMDRO123>0.</OEMDRO123>
<OEMLED123>0</OEMLED123>
<OEMDRO124>0.</OEMDRO124>
<OEMLED124>0</OEMLED124>
<OEMDRO125>0.</OEMDRO125>
<OEMLED125>0</OEMLED125>
<OEMDRO126>0.</OEMDRO126>
<OEMLED126>0</OEMLED126>
<OEMDRO127>0.</OEMDRO127>
<OEMLED127>0</OEMLED127>
<OEMDRO128>0.</OEMDRO128>
<OEMLED128>0</OEMLED128>
<OEMDRO129>0.</OEMDRO129>
<OEMLED129>0</OEMLED129>
<OEMDRO130>0.</OEMDRO130>
<OEMLED130>0</OEMLED130>
<OEMDRO131>0.</OEMDRO131>
<OEMLED131>0</OEMLED131>
<OEMDRO132>0.</OEMDRO132>
<OEMLED132>0</OEMLED132>
<OEMDRO133>0.</OEMDRO133>
<OEMLED133>0</OEMLED133>
<OEMDRO134>0.</OEMDRO134>
<OEMLED134>0</OEMLED134>
<OEMDRO135>0.</OEMDRO135>
<OEMLED135>0</OEMLED135>
<OEMDRO136>0.</OEMDRO136>
<OEMLED136>0</OEMLED136>
<OEMDRO137>0.</OEMDRO137>
<OEMLED137>0</OEMLED137>
<OEMDRO138>0.</OEMDRO138>
<OEMLED138>0</OEMLED138>
<OEMDRO139>0.</OEMDRO139>
<OEMLED139>0</OEMLED139>
<OEMDRO140>0.</OEMDRO140>
<OEMLED140>0</OEMLED140>
<OEMDRO141>0.</OEMDRO141>
<OEMLED141>0</OEMLED141>
<OEMDRO142>0.</OEMDRO142>
<OEMLED142>0</OEMLED142>
<OEMDRO143>0.</OEMDRO143>
<OEMLED143>0</OEMLED143>
<OEMDRO144>0.</OEMDRO144>
<OEMLED144>0</OEMLED144>
<OEMDRO145>0.</OEMDRO145>
<OEMLED145>0</OEMLED145>
<OEMDRO146>0.</OEMDRO146>
<OEMLED146>0</OEMLED146>
<OEMDRO147>0.</OEMDRO147>
<OEMLED147>0</OEMLED147>
<OEMDRO148>0.</OEMDRO148>
<OEMLED148>0</OEMLED148>
<OEMDRO149>0.</OEMDRO149>
<OEMLED149>0</OEMLED149>
<OEMDRO150>0.</OEMDRO150>
<OEMLED150>0</OEMLED150>
<OEMDRO151>0.</OEMDRO151>
<OEMLED151>0</OEMLED151>
<OEMDRO152>0.</OEMDRO152>
<OEMLED152>0</OEMLED152>
<OEMDRO153>0.</OEMDRO153>
<OEMLED153>0</OEMLED153>
<OEMDRO154>0.</OEMDRO154>
<OEMLED154>0</OEMLED154>
<OEMDRO155>0.</OEMDRO155>
<OEMLED155>0</OEMLED155>
<OEMDRO156>0.</OEMDRO156>
<OEMLED156>0</OEMLED156>
<OEMDRO157>0.</OEMDRO157>
<OEMLED157>0</OEMLED157>
<OEMDRO158>0.</OEMDRO158>
<OEMLED158>0</OEMLED158>
<OEMDRO159>0.</OEMDRO159>
<OEMLED159>0</OEMLED159>
<OEMDRO160>0.</OEMDRO160>
<OEMLED160>0</OEMLED160>
<OEMDRO161>0.</OEMDRO161>
<OEMLED161>0</OEMLED161>
<OEMDRO162>0.</OEMDRO162>
<OEMLED162>0</OEMLED162>
<OEMDRO163>0.</OEMDRO163>
<OEMLED163>0</OEMLED163>
<OEMDRO164>0.</OEMDRO164>
<OEMLED164>0</OEMLED164>
<OEMDRO165>0.</OEMDRO165>
<OEMLED165>0</OEMLED165>
<OEMDRO166>0.</OEMDRO166>
<OEMLED166>0</OEMLED166>
<OEMDRO167>0.</OEMDRO167>
<OEMLED167>0</OEMLED167>
<OEMDRO168>0.</OEMDRO168>
<OEMLED168>0</OEMLED168>
<OEMDRO169>0.</OEMDRO169>
<OEMLED169>0</OEMLED169>
<OEMDRO170>0.</OEMDRO170>
<OEMLED170>0</OEMLED170>
<OEMDRO171>0.</OEMDRO171>
<OEMLED171>0</OEMLED171>
<OEMDRO172>0.</OEMDRO172>
<OEMLED172>0</OEMLED172>
<OEMDRO173>0.</OEMDRO173>
<OEMLED173>0</OEMLED173>
<OEMDRO174>0.</OEMDRO174>
<OEMLED174>0</OEMLED174>
<OEMDRO175>0.</OEMDRO175>
<OEMLED175>0</OEMLED175>
<OEMDRO176>0.</OEMDRO176>
<OEMLED176>0</OEMLED176>
<OEMDRO177>0.</OEMDRO177>
<OEMLED177>0</OEMLED177>
<OEMDRO178>0.</OEMDRO178>
<OEMLED178>0</OEMLED178>
<OEMDRO179>0.</OEMDRO179>
<OEMLED179>0</OEMLED179>
<OEMDRO180>0.</OEMDRO180>
<OEMLED180>0</OEMLED180>
<OEMDRO181>0.</OEMDRO181>
<OEMLED181>0</OEMLED181>
<OEMDRO182>0.</OEMDRO182>
<OEMLED182>0</OEMLED182>
<OEMDRO183>0.</OEMDRO183>
<OEMLED183>0</OEMLED183>
<OEMDRO184>0.</OEMDRO184>
<OEMLED184>0</OEMLED184>
<OEMDRO185>0.</OEMDRO185>
<OEMLED185>0</OEMLED185>
<OEMDRO186>0.</OEMDRO186>
<OEMLED186>0</OEMLED186>
<OEMDRO187>0.</OEMDRO187>
<OEMLED187>0</OEMLED187>
<OEMDRO188>0.</OEMDRO188>
<OEMLED188>0</OEMLED188>
<OEMDRO189>0.</OEMDRO189>
<OEMLED189>0</OEMLED189>
<OEMDRO190>0.</OEMDRO190>
<OEMLED190>0</OEMLED190>
<OEMDRO191>0.</OEMDRO191>
<OEMLED191>0</OEMLED191>
<OEMDRO192>0.</OEMDRO192>
<OEMLED192>0</OEMLED192>
<OEMDRO193>0.</OEMDRO193>
<OEMLED193>0</OEMLED193>
<OEMDRO194>0.</OEMDRO194>
<OEMLED194>0</OEMLED194>
<OEMDRO195>0.</OEMDRO195>
<OEMLED195>0</OEMLED195>
<OEMDRO196>0.</OEMDRO196>
<OEMLED196>0</OEMLED196>
<OEMDRO197>0.</OEMDRO197>
<OEMLED197>0</OEMLED197>
<OEMDRO198>0.</OEMDRO198>
<OEMLED198>0</OEMLED198>
<OEMDRO199>0.</OEMDRO199>
<OEMLED199>0</OEMLED199>
<OEMDRO200>0.</OEMDRO200>
<OEMLED200>0</OEMLED200>
<OEMDRO201>0.</OEMDRO201>
<OEMLED201>0</OEMLED201>
<OEMDRO202>0.</OEMDRO202>
<OEMLED202>0</OEMLED202>
<OEMDRO203>0.</OEMDRO203>
<OEMLED203>0</OEMLED203>
<OEMDRO204>0.</OEMDRO204>
<OEMLED204>0</OEMLED204>
<OEMDRO205>0.</OEMDRO205>
<OEMLED205>0</OEMLED205>
<OEMDRO206>0.</OEMDRO206>
<OEMLED206>0</OEMLED206>
<OEMDRO207>0.</OEMDRO207>
<OEMLED207>0</OEMLED207>
<OEMDRO208>0.</OEMDRO208>
<OEMLED208>0</OEMLED208>
<OEMDRO209>0.</OEMDRO209>
<OEMLED209>0</OEMLED209>
<OEMDRO210>0.</OEMDRO210>
<OEMLED210>0</OEMLED210>
<OEMDRO211>0.</OEMDRO211>
<OEMLED211>0</OEMLED211>
<OEMDRO212>0.</OEMDRO212>
<OEMLED212>0</OEMLED212>
<OEMDRO213>0.</OEMDRO213>
<OEMLED213>0</OEMLED213>
<OEMDRO214>0.</OEMDRO214>
<OEMLED214>0</OEMLED214>
<OEMDRO215>0.</OEMDRO215>
<OEMLED215>0</OEMLED215>
<OEMDRO216>0.</OEMDRO216>
<OEMLED216>0</OEMLED216>
<OEMDRO217>0.</OEMDRO217>
<OEMLED217>0</OEMLED217>
<OEMDRO218>0.</OEMDRO218>
<OEMLED218>0</OEMLED218>
<OEMDRO219>0.</OEMDRO219>
<OEMLED219>0</OEMLED219>
<OEMDRO220>0.</OEMDRO220>
<OEMLED220>0</OEMLED220>
<OEMDRO221>0.</OEMDRO221>
<OEMLED221>0</OEMLED221>
<OEMDRO222>0.</OEMDRO222>
<OEMLED222>0</OEMLED222>
<OEMDRO223>0.</OEMDRO223>
<OEMLED223>0</OEMLED223>
<OEMDRO224>0.</OEMDRO224>
<OEMLED224>0</OEMLED224>
<OEMDRO225>0.</OEMDRO225>
<OEMLED225>0</OEMLED225>
<OEMDRO226>0.</OEMDRO226>
<OEMLED226>0</OEMLED226>
<OEMDRO227>0.</OEMDRO227>
<OEMLED227>0</OEMLED227>
<OEMDRO228>0.</OEMDRO228>
<OEMLED228>0</OEMLED228>
<OEMDRO229>0.</OEMDRO229>
<OEMLED229>0</OEMLED229>
<OEMDRO230>0.</OEMDRO230>
<OEMLED230>0</OEMLED230>
<OEMDRO231>0.</OEMDRO231>
<OEMLED231>0</OEMLED231>
<OEMDRO232>0.</OEMDRO232>
<OEMLED232>0</OEMLED232>
<OEMDRO233>0.</OEMDRO233>
<OEMLED233>0</OEMLED233>
<OEMDRO234>0.</OEMDRO234>
<OEMLED234>0</OEMLED234>
<OEMDRO235>0.</OEMDRO235>
<OEMLED235>0</OEMLED235>
<OEMDRO236>0.</OEMDRO236>
<OEMLED236>0</OEMLED236>
<OEMDRO237>0.</OEMDRO237>
<OEMLED237>0</OEMLED237>
<OEMDRO238>0.</OEMDRO238>
<OEMLED238>0</OEMLED238>
<OEMDRO239>0.</OEMDRO239>
<OEMLED239>0</OEMLED239>
<OEMDRO240>0.</OEMDRO240>
<OEMLED240>0</OEMLED240>
<OEMDRO241>0.</OEMDRO241>
<OEMLED241>0</OEMLED241>
<OEMDRO242>0.</OEMDRO242>
<OEMLED242>0</OEMLED242>
<OEMDRO243>0.</OEMDRO243>
<OEMLED243>0</OEMLED243>
<OEMDRO244>0.</OEMDRO244>
<OEMLED244>0</OEMLED244>
<OEMDRO245>0.</OEMDRO245>
<OEMLED245>0</OEMLED245>
<OEMDRO246>0.</OEMDRO246>
<OEMLED246>0</OEMLED246>
<OEMDRO247>0.</OEMDRO247>
<OEMLED247>0</OEMLED247>
<OEMDRO248>0.</OEMDRO248>
<OEMLED248>0</OEMLED248>
<OEMDRO249>0.</OEMDRO249>
<OEMLED249>0</OEMLED249>
<OEMDRO250>0.</OEMDRO250>
<OEMLED250>0</OEMLED250>
<OEMDRO251>0.</OEMDRO251>
<OEMLED251>0</OEMLED251>
<OEMDRO252>0.</OEMDRO252>
<OEMLED252>0</OEMLED252>
<OEMDRO253>0.</OEMDRO253>
<OEMLED253>0</OEMLED253>
<OEMDRO254>0.</OEMDRO254>
<OEMLED254>0</OEMLED254>
<OEMDRO255>0.</OEMDRO255>
<OEMLED255>0</OEMLED255>
<JogInc>1.e-003</JogInc>
<JogSlide>0.1</JogSlide>
<THCMax>5.</THCMax>
<THCMin>0.</THCMin>
<RadiusA>0.</RadiusA>
<RadiusB>0.</RadiusB>
<RadiusC>0.</RadiusC>
<LiftLevel>1.</LiftLevel>
<LiftAngle>45.</LiftAngle>
<InhibitDepth>0.</InhibitDepth>
<LaserXGrid>0.</LaserXGrid>
<LaserYGrid>0.</LaserYGrid>
<LaserAGrid>0.</LaserAGrid>
<JogInc0>1.</JogInc0>
<JogInc1>0.1</JogInc1>
<JogInc2>1.e-002</JogInc2>
<JogInc3>1.e-003</JogInc3>
<JogInc4>1.e-004</JogInc4>
<JogInc5>1.</JogInc5>
<JogInc6>0.1</JogInc6>
<JogInc7>1.e-002</JogInc7>
<JogInc8>1.e-003</JogInc8>
<JogInc9>1.e-004</JogInc9>
<THCSpeed>12.</THCSpeed>
<BlendFactor>1.e-002</BlendFactor>
<M0RefHome>0</M0RefHome>
<M1RefHome>0</M1RefHome>
<M2RefHome>0</M2RefHome>
<M3RefHome>0</M3RefHome>
<M4RefHome>0</M4RefHome>
<M5RefHome>0</M5RefHome>
<MRU10>C:\Mach3\GCode\balld.tap</MRU10>
<MRU9>C:\Mach3\GCode\ball.tap</MRU9>
<MRU8>C:\Mach3\GCode\Cross.tap</MRU8>
<MRU7>C:\Users\nick7\Desktop\Plasma\ILoveUtah.tap</MRU7>
<MRU6>C:\Users\nick7\Desktop\Plasma\ILoveStatesMap.tap</MRU6>
<MRU5>C:\Users\nick7\Desktop\Plasma\69Mustang.tap</MRU5>
<MRU4>C:\Users\nick7\Desktop\Plasma\ChevyCamaro.tap</MRU4>
<MRU3>C:\Users\nick7\Desktop\Plasma\CircleMonogram11.tap</MRU3>
<MRU2>C:\Users\nick7\Desktop\Plasma\2020.06.04 Mounting Foot v3.tap</MRU2>
<MRU1>C:\Users\nick7\Desktop\Plasma\2020.06.04 Mounting Foot v3-nickpost.tap</MRU1>
<ToolPersist>0</ToolPersist>
<KeepRef>0</KeepRef>
<TurnRevArc>1</TurnRevArc>
<DROFont>Arial</DROFont>
<LabelFont>Arial</LabelFont>
<CodeFont>Arial</CodeFont>
<PierceDelay>1.</PierceDelay>
<VelPer3>5.</VelPer3>
<TouchX>0.</TouchX>
<G20X>0.</G20X>
<G20Y>0.</G20Y>
<G20Z>0.</G20Z>
<G20A>0.</G20A>
<G20B>0.</G20B>
<G20C>0.</G20C>
<FrontRear>0.</FrontRear>
<EncJogAxis3>2</EncJogAxis3>
<WarnOnReset>0</WarnOnReset>
<NURBS>0</NURBS>
<HiRes>0</HiRes>
<DelinChar>12</DelinChar>
<Rot360>0</Rot360>
<SerialServo>0</SerialServo>
<ToolLines>0</ToolLines>
<UDP>0</UDP>
<DefDir>C:\Mach3</DefDir>
<NewPath>0</NewPath>
<SafeZStop>0</SafeZStop>
<SafeZType>1</SafeZType>
<UseDiam>0</UseDiam>
<SPINREV1>0</SPINREV1>
<SPINREV2>0</SPINREV2>
<SPINREV3>0</SPINREV3>
<SPINREV4>0</SPINREV4>
<SPEED5>25000</SPEED5>
<LSPEED5>0</LSPEED5>
<SPINREV5>0</SPINREV5>
<SPEED6>25000</SPEED6>
<LSPEED6>0</LSPEED6>
<SPINREV6>0</SPINREV6>
<SPEED7>25000</SPEED7>
<LSPEED7>0</LSPEED7>
<SPINREV7>0</SPINREV7>
<SPEED8>25000</SPEED8>
<LSPEED8>0</LSPEED8>
<SPINREV8>0</SPINREV8>
<SPEED9>25000</SPEED9>
<LSPEED9>0</LSPEED9>
<SPINREV9>0</SPINREV9>
<SPEED10>25000</SPEED10>
<LSPEED10>0</LSPEED10>
<SPINREV10>0</SPINREV10>
<SPEED11>25000</SPEED11>
<LSPEED11>0</LSPEED11>
<SPINREV11>0</SPINREV11>
<SPEED12>25000</SPEED12>
<LSPEED12>0</LSPEED12>
<SPINREV12>0</SPINREV12>
<SPEED13>25000</SPEED13>
<LSPEED13>0</LSPEED13>
<SPINREV13>0</SPINREV13>
<SPEED14>25000</SPEED14>
<LSPEED14>0</LSPEED14>
<SPINREV14>0</SPINREV14>
<SPEED15>25000</SPEED15>
<LSPEED15>0</LSPEED15>
<SPINREV15>0</SPINREV15>
<SPEED16>25000</SPEED16>
<LSPEED16>0</LSPEED16>
<SPINREV16>0</SPINREV16>
<SPEED17>25000</SPEED17>
<LSPEED17>0</LSPEED17>
<SPINREV17>0</SPINREV17>
<SPEED18>25000</SPEED18>
<LSPEED18>0</LSPEED18>
<SPINREV18>0</SPINREV18>
<SPEED19>25000</SPEED19>
<LSPEED19>0</LSPEED19>
<SPINREV19>0</SPINREV19>
<SPEED20>25000</SPEED20>
<LSPEED20>0</LSPEED20>
<SPINREV20>0</SPINREV20>
<SPEED21>25000</SPEED21>
<LSPEED21>0</LSPEED21>
<SPINREV21>0</SPINREV21>
<SPEED22>25000</SPEED22>
<LSPEED22>0</LSPEED22>
<SPINREV22>0</SPINREV22>
<SPEED23>25000</SPEED23>
<LSPEED23>0</LSPEED23>
<SPINREV23>0</SPINREV23>
<SPEED24>25000</SPEED24>
<LSPEED24>0</LSPEED24>
<SPINREV24>0</SPINREV24>
<SPEED25>25000</SPEED25>
<LSPEED25>0</LSPEED25>
<SPINREV25>0</SPINREV25>
<m_SafeZ>0.5</m_SafeZ>
<EncJogAxis1>0</EncJogAxis1>
<AutoCalcs>0</AutoCalcs>
<CVUseAngle>1</CVUseAngle>
<CVDegrees>89.</CVDegrees>
<M30SpinOff>1</M30SpinOff>
<Boxed>1</Boxed>
<ButtonFont>Arial</ButtonFont>
<OVSpinInc>10</OVSpinInc>
<Syskey1>1</Syskey1>
<ModPlug>0</ModPlug>
<KeyClick>0</KeyClick>
<THC5>0</THC5>
<ModPort>1</ModPort>
<AutoBaud>57600</AutoBaud>
<AutoType1>0</AutoType1>
<AutoType2>0</AutoType2>
<AutoType3>0</AutoType3>
<AutoType4>0</AutoType4>
<AutoOn1>0</AutoOn1>
<AutoOn2>0</AutoOn2>
<AutoOn3>0</AutoOn3>
<AutoOn4>0</AutoOn4>
<AutoSlave1>0</AutoSlave1>
<AutoSlave2>0</AutoSlave2>
<AutoSlave3>0</AutoSlave3>
<AutoSlave4>0</AutoSlave4>
<AutoStart1>0</AutoStart1>
<AutoStart2>0</AutoStart2>
<AutoStart3>0</AutoStart3>
<AutoStart4>0</AutoStart4>
<AutoEnd1>0</AutoEnd1>
<AutoEnd2>0</AutoEnd2>
<AutoEnd3>0</AutoEnd3>
<AutoEnd4>0</AutoEnd4>
<RTSON>0</RTSON>
<TIMEOUT>100</TIMEOUT>
<Hertz>50</Hertz>
<Prot>3</Prot>
<ID>None</ID>
<LastUser>WCP2200B20 B9GS</LastUser>
<ROTSOFT>1</ROTSOFT>
<PROBETLO>0</PROBETLO>
<SlaveHome>0</SlaveHome>
<JogHeat>0</JogHeat>
<SPINRATIO1>1.</SPINRATIO1>
<SPINRATIO2>1.</SPINRATIO2>
<SPINRATIO3>1.</SPINRATIO3>
<SPINRATIO4>1.</SPINRATIO4>
<SPINRATIO5>1.</SPINRATIO5>
<SPINRATIO6>1.</SPINRATIO6>
<SPINRATIO7>1.</SPINRATIO7>
<SPINRATIO8>1.</SPINRATIO8>
<SPINRATIO9>1.</SPINRATIO9>
<SPINRATIO10>1.</SPINRATIO10>
<SPINRATIO11>1.</SPINRATIO11>
<SPINRATIO12>1.</SPINRATIO12>
<SPINRATIO13>1.</SPINRATIO13>
<SPINRATIO14>1.</SPINRATIO14>
<SPINRATIO15>1.</SPINRATIO15>
<SPINRATIO16>1.</SPINRATIO16>
<SPINRATIO17>1.</SPINRATIO17>
<SPINRATIO18>1.</SPINRATIO18>
<SPINRATIO19>1.</SPINRATIO19>
<SPINRATIO20>1.</SPINRATIO20>
<SPINRATIO21>1.</SPINRATIO21>
<SPINRATIO22>1.</SPINRATIO22>
<SPINRATIO23>1.</SPINRATIO23>
<SPINRATIO24>1.</SPINRATIO24>
<SPINRATIO25>1.</SPINRATIO25>
<Running>0</Running>
<TCPMODBUS>0</TCPMODBUS>
<MenuOff>0</MenuOff>
<ZBar>1</ZBar>
<IgnoreMacros>0</IgnoreMacros>
<DwellTrigger>0</DwellTrigger>
<M7Delay>0.</M7Delay>
<M8Delay>0.</M8Delay>
<Encoder0>0</Encoder0>
<Encoder1>4</Encoder1>
<Encoder2>0</Encoder2>
<Encoder3>0</Encoder3>
<Encoder4>0</Encoder4>
<Encoder5>0</Encoder5>
<Encoder6>0</Encoder6>
<M9After>0</M9After>
<Steps6>1.</Steps6>
<LockFROs>1</LockFROs>
<OEMDRO256>0.</OEMDRO256>
<OEMLED256>0</OEMLED256>
<OEMDRO257>0.</OEMDRO257>
<OEMLED257>0</OEMLED257>
<OEMDRO258>0.</OEMDRO258>
<OEMLED258>0</OEMLED258>
<OEMDRO259>0.</OEMDRO259>
<OEMLED259>0</OEMLED259>
<OEMDRO260>0.</OEMDRO260>
<OEMLED260>0</OEMLED260>
<OEMDRO261>0.</OEMDRO261>
<OEMLED261>0</OEMLED261>
<OEMDRO262>0.</OEMDRO262>
<OEMLED262>0</OEMLED262>
<OEMDRO263>0.</OEMDRO263>
<OEMLED263>0</OEMLED263>
<OEMDRO264>0.</OEMDRO264>
<OEMLED264>0</OEMLED264>
<OEMDRO265>0.</OEMDRO265>
<OEMLED265>0</OEMLED265>
<OEMDRO266>0.</OEMDRO266>
<OEMLED266>0</OEMLED266>
<OEMDRO267>0.</OEMDRO267>
<OEMLED267>0</OEMLED267>
<OEMDRO268>0.</OEMDRO268>
<OEMLED268>0</OEMLED268>
<OEMDRO269>0.</OEMDRO269>
<OEMLED269>0</OEMLED269>
<OEMDRO270>0.</OEMDRO270>
<OEMLED270>0</OEMLED270>
<OEMDRO271>0.</OEMDRO271>
<OEMLED271>0</OEMLED271>
<OEMDRO272>0.</OEMDRO272>
<OEMLED272>0</OEMLED272>
<OEMDRO273>0.</OEMDRO273>
<OEMLED273>0</OEMLED273>
<OEMDRO274>0.</OEMDRO274>
<OEMLED274>0</OEMLED274>
<OEMDRO275>0.</OEMDRO275>
<OEMLED275>0</OEMLED275>
<OEMDRO276>0.</OEMDRO276>
<OEMLED276>0</OEMLED276>
<OEMDRO277>0.</OEMDRO277>
<OEMLED277>0</OEMLED277>
<OEMDRO278>0.</OEMDRO278>
<OEMLED278>0</OEMLED278>
<OEMDRO279>0.</OEMDRO279>
<OEMLED279>0</OEMLED279>
<OEMDRO280>0.</OEMDRO280>
<OEMLED280>0</OEMLED280>
<OEMDRO281>0.</OEMDRO281>
<OEMLED281>0</OEMLED281>
<OEMDRO282>0.</OEMDRO282>
<OEMLED282>0</OEMLED282>
<OEMDRO283>0.</OEMDRO283>
<OEMLED283>0</OEMLED283>
<OEMDRO284>0.</OEMDRO284>
<OEMLED284>0</OEMLED284>
<OEMDRO285>0.</OEMDRO285>
<OEMLED285>0</OEMLED285>
<OEMDRO286>0.</OEMDRO286>
<OEMLED286>0</OEMLED286>
<OEMDRO287>0.</OEMDRO287>
<OEMLED287>0</OEMLED287>
<OEMDRO288>0.</OEMDRO288>
<OEMLED288>0</OEMLED288>
<OEMDRO289>0.</OEMDRO289>
<OEMLED289>0</OEMLED289>
<OEMDRO290>0.</OEMDRO290>
<OEMLED290>0</OEMLED290>
<OEMDRO291>0.</OEMDRO291>
<OEMLED291>0</OEMLED291>
<OEMDRO292>0.</OEMDRO292>
<OEMLED292>0</OEMLED292>
<OEMDRO293>0.</OEMDRO293>
<OEMLED293>0</OEMLED293>
<OEMDRO294>0.</OEMDRO294>
<OEMLED294>0</OEMLED294>
<OEMDRO295>0.</OEMDRO295>
<OEMLED295>0</OEMLED295>
<OEMDRO296>0.</OEMDRO296>
<OEMLED296>0</OEMLED296>
<OEMDRO297>0.</OEMDRO297>
<OEMLED297>0</OEMLED297>
<OEMDRO298>0.</OEMDRO298>
<OEMLED298>0</OEMLED298>
<OEMDRO299>0.</OEMDRO299>
<OEMLED299>0</OEMLED299>
<OEMDRO2100>0.</OEMDRO2100>
<OEMLED2100>0</OEMLED2100>
<OEMDRO2101>0.</OEMDRO2101>
<OEMLED2101>0</OEMLED2101>
<OEMDRO2102>0.</OEMDRO2102>
<OEMLED2102>0</OEMLED2102>
<OEMDRO2103>0.</OEMDRO2103>
<OEMLED2103>0</OEMLED2103>
<OEMDRO2104>0.</OEMDRO2104>
<OEMLED2104>0</OEMLED2104>
<OEMDRO2105>0.</OEMDRO2105>
<OEMLED2105>0</OEMLED2105>
<OEMDRO2106>0.</OEMDRO2106>
<OEMLED2106>0</OEMLED2106>
<OEMDRO2107>0.</OEMDRO2107>
<OEMLED2107>0</OEMLED2107>
<OEMDRO2108>0.</OEMDRO2108>
<OEMLED2108>0</OEMLED2108>
<OEMDRO2109>0.</OEMDRO2109>
<OEMLED2109>0</OEMLED2109>
<OEMDRO2110>0.</OEMDRO2110>
<OEMLED2110>0</OEMLED2110>
<OEMDRO2111>0.</OEMDRO2111>
<OEMLED2111>0</OEMLED2111>
<OEMDRO2112>0.</OEMDRO2112>
<OEMLED2112>0</OEMLED2112>
<OEMDRO2113>0.</OEMDRO2113>
<OEMLED2113>0</OEMLED2113>
<OEMDRO2114>0.</OEMDRO2114>
<OEMLED2114>0</OEMLED2114>
<OEMDRO2115>0.</OEMDRO2115>
<OEMLED2115>0</OEMLED2115>
<OEMDRO2116>0.</OEMDRO2116>
<OEMLED2116>0</OEMLED2116>
<OEMDRO2117>0.</OEMDRO2117>
<OEMLED2117>0</OEMLED2117>
<OEMDRO2118>0.</OEMDRO2118>
<OEMLED2118>0</OEMLED2118>
<OEMDRO2119>0.</OEMDRO2119>
<OEMLED2119>0</OEMLED2119>
<OEMDRO2120>0.</OEMDRO2120>
<OEMLED2120>0</OEMLED2120>
<OEMDRO2121>0.</OEMDRO2121>
<OEMLED2121>0</OEMLED2121>
<OEMDRO2122>0.</OEMDRO2122>
<OEMLED2122>0</OEMLED2122>
<OEMDRO2123>0.</OEMDRO2123>
<OEMLED2123>0</OEMLED2123>
<OEMDRO2124>0.</OEMDRO2124>
<OEMLED2124>0</OEMLED2124>
<OEMDRO2125>0.</OEMDRO2125>
<OEMLED2125>0</OEMLED2125>
<OEMDRO2126>0.</OEMDRO2126>
<OEMLED2126>0</OEMLED2126>
<OEMDRO2127>0.</OEMDRO2127>
<OEMLED2127>0</OEMLED2127>
<OEMDRO2128>0.</OEMDRO2128>
<OEMLED2128>0</OEMLED2128>
<OEMDRO2129>0.</OEMDRO2129>
<OEMLED2129>0</OEMLED2129>
<OEMDRO2130>0.</OEMDRO2130>
<OEMLED2130>0</OEMLED2130>
<OEMDRO2131>0.</OEMDRO2131>
<OEMLED2131>0</OEMLED2131>
<OEMDRO2132>0.</OEMDRO2132>
<OEMLED2132>0</OEMLED2132>
<OEMDRO2133>0.</OEMDRO2133>
<OEMLED2133>0</OEMLED2133>
<OEMDRO2134>0.</OEMDRO2134>
<OEMLED2134>0</OEMLED2134>
<OEMDRO2135>0.</OEMDRO2135>
<OEMLED2135>0</OEMLED2135>
<OEMDRO2136>0.</OEMDRO2136>
<OEMLED2136>0</OEMLED2136>
<OEMDRO2137>0.</OEMDRO2137>
<OEMLED2137>0</OEMLED2137>
<OEMDRO2138>0.</OEMDRO2138>
<OEMLED2138>0</OEMLED2138>
<OEMDRO2139>0.</OEMDRO2139>
<OEMLED2139>0</OEMLED2139>
<OEMDRO2140>0.</OEMDRO2140>
<OEMLED2140>0</OEMLED2140>
<OEMDRO2141>0.</OEMDRO2141>
<OEMLED2141>0</OEMLED2141>
<OEMDRO2142>0.</OEMDRO2142>
<OEMLED2142>0</OEMLED2142>
<OEMDRO2143>0.</OEMDRO2143>
<OEMLED2143>0</OEMLED2143>
<OEMDRO2144>0.</OEMDRO2144>
<OEMLED2144>0</OEMLED2144>
<OEMDRO2145>0.</OEMDRO2145>
<OEMLED2145>0</OEMLED2145>
<OEMDRO2146>0.</OEMDRO2146>
<OEMLED2146>0</OEMLED2146>
<OEMDRO2147>0.</OEMDRO2147>
<OEMLED2147>0</OEMLED2147>
<OEMDRO2148>0.</OEMDRO2148>
<OEMLED2148>0</OEMLED2148>
<OEMDRO2149>0.</OEMDRO2149>
<OEMLED2149>0</OEMLED2149>
<OEMDRO2150>0.</OEMDRO2150>
<OEMLED2150>0</OEMLED2150>
<OEMDRO2151>0.</OEMDRO2151>
<OEMLED2151>0</OEMLED2151>
<OEMDRO2152>0.</OEMDRO2152>
<OEMLED2152>0</OEMLED2152>
<OEMDRO2153>0.</OEMDRO2153>
<OEMLED2153>0</OEMLED2153>
<OEMDRO2154>0.</OEMDRO2154>
<OEMLED2154>0</OEMLED2154>
<OEMDRO2155>0.</OEMDRO2155>
<OEMLED2155>0</OEMLED2155>
<OEMDRO2156>0.</OEMDRO2156>
<OEMLED2156>0</OEMLED2156>
<OEMDRO2157>0.</OEMDRO2157>
<OEMLED2157>0</OEMLED2157>
<OEMDRO2158>0.</OEMDRO2158>
<OEMLED2158>0</OEMLED2158>
<OEMDRO2159>0.</OEMDRO2159>
<OEMLED2159>0</OEMLED2159>
<OEMDRO2160>0.</OEMDRO2160>
<OEMLED2160>0</OEMLED2160>
<OEMDRO2161>0.</OEMDRO2161>
<OEMLED2161>0</OEMLED2161>
<OEMDRO2162>0.</OEMDRO2162>
<OEMLED2162>0</OEMLED2162>
<OEMDRO2163>0.</OEMDRO2163>
<OEMLED2163>0</OEMLED2163>
<OEMDRO2164>0.</OEMDRO2164>
<OEMLED2164>0</OEMLED2164>
<OEMDRO2165>0.</OEMDRO2165>
<OEMLED2165>0</OEMLED2165>
<OEMDRO2166>0.</OEMDRO2166>
<OEMLED2166>0</OEMLED2166>
<OEMDRO2167>0.</OEMDRO2167>
<OEMLED2167>0</OEMLED2167>
<OEMDRO2168>0.</OEMDRO2168>
<OEMLED2168>0</OEMLED2168>
<OEMDRO2169>0.</OEMDRO2169>
<OEMLED2169>0</OEMLED2169>
<OEMDRO2170>0.</OEMDRO2170>
<OEMLED2170>0</OEMLED2170>
<OEMDRO2171>0.</OEMDRO2171>
<OEMLED2171>0</OEMLED2171>
<OEMDRO2172>0.</OEMDRO2172>
<OEMLED2172>0</OEMLED2172>
<OEMDRO2173>0.</OEMDRO2173>
<OEMLED2173>0</OEMLED2173>
<OEMDRO2174>0.</OEMDRO2174>
<OEMLED2174>0</OEMLED2174>
<OEMDRO2175>0.</OEMDRO2175>
<OEMLED2175>0</OEMLED2175>
<OEMDRO2176>0.</OEMDRO2176>
<OEMLED2176>0</OEMLED2176>
<OEMDRO2177>0.</OEMDRO2177>
<OEMLED2177>0</OEMLED2177>
<OEMDRO2178>0.</OEMDRO2178>
<OEMLED2178>0</OEMLED2178>
<OEMDRO2179>0.</OEMDRO2179>
<OEMLED2179>0</OEMLED2179>
<OEMDRO2180>0.</OEMDRO2180>
<OEMLED2180>0</OEMLED2180>
<OEMDRO2181>0.</OEMDRO2181>
<OEMLED2181>0</OEMLED2181>
<OEMDRO2182>0.</OEMDRO2182>
<OEMLED2182>0</OEMLED2182>
<OEMDRO2183>0.</OEMDRO2183>
<OEMLED2183>0</OEMLED2183>
<OEMDRO2184>0.</OEMDRO2184>
<OEMLED2184>0</OEMLED2184>
<OEMDRO2185>0.</OEMDRO2185>
<OEMLED2185>0</OEMLED2185>
<OEMDRO2186>0.</OEMDRO2186>
<OEMLED2186>0</OEMLED2186>
<OEMDRO2187>0.</OEMDRO2187>
<OEMLED2187>0</OEMLED2187>
<OEMDRO2188>0.</OEMDRO2188>
<OEMLED2188>0</OEMLED2188>
<OEMDRO2189>0.</OEMDRO2189>
<OEMLED2189>0</OEMLED2189>
<OEMDRO2190>0.</OEMDRO2190>
<OEMLED2190>0</OEMLED2190>
<OEMDRO2191>0.</OEMDRO2191>
<OEMLED2191>0</OEMLED2191>
<OEMDRO2192>0.</OEMDRO2192>
<OEMLED2192>0</OEMLED2192>
<OEMDRO2193>0.</OEMDRO2193>
<OEMLED2193>0</OEMLED2193>
<OEMDRO2194>0.</OEMDRO2194>
<OEMLED2194>0</OEMLED2194>
<OEMDRO2195>0.</OEMDRO2195>
<OEMLED2195>0</OEMLED2195>
<OEMDRO2196>0.</OEMDRO2196>
<OEMLED2196>0</OEMLED2196>
<OEMDRO2197>0.</OEMDRO2197>
<OEMLED2197>0</OEMLED2197>
<OEMDRO2198>0.</OEMDRO2198>
<OEMLED2198>0</OEMLED2198>
<OEMDRO2199>0.</OEMDRO2199>
<OEMLED2199>0</OEMLED2199>
<OEMDRO2200>0.</OEMDRO2200>
<OEMLED2200>0</OEMLED2200>
<OEMDRO2201>0.</OEMDRO2201>
<OEMLED2201>0</OEMLED2201>
<OEMDRO2202>0.</OEMDRO2202>
<OEMLED2202>0</OEMLED2202>
<OEMDRO2203>0.</OEMDRO2203>
<OEMLED2203>0</OEMLED2203>
<OEMDRO2204>0.</OEMDRO2204>
<OEMLED2204>0</OEMLED2204>
<OEMDRO2205>0.</OEMDRO2205>
<OEMLED2205>0</OEMLED2205>
<OEMDRO2206>0.</OEMDRO2206>
<OEMLED2206>0</OEMLED2206>
<OEMDRO2207>0.</OEMDRO2207>
<OEMLED2207>0</OEMLED2207>
<OEMDRO2208>0.</OEMDRO2208>
<OEMLED2208>0</OEMLED2208>
<OEMDRO2209>0.</OEMDRO2209>
<OEMLED2209>0</OEMLED2209>
<OEMDRO2210>0.</OEMDRO2210>
<OEMLED2210>0</OEMLED2210>
<OEMDRO2211>0.</OEMDRO2211>
<OEMLED2211>0</OEMLED2211>
<OEMDRO2212>0.</OEMDRO2212>
<OEMLED2212>0</OEMLED2212>
<OEMDRO2213>0.</OEMDRO2213>
<OEMLED2213>0</OEMLED2213>
<OEMDRO2214>0.</OEMDRO2214>
<OEMLED2214>0</OEMLED2214>
<OEMDRO2215>0.</OEMDRO2215>
<OEMLED2215>0</OEMLED2215>
<OEMDRO2216>0.</OEMDRO2216>
<OEMLED2216>0</OEMLED2216>
<OEMDRO2217>0.</OEMDRO2217>
<OEMLED2217>0</OEMLED2217>
<OEMDRO2218>0.</OEMDRO2218>
<OEMLED2218>0</OEMLED2218>
<OEMDRO2219>0.</OEMDRO2219>
<OEMLED2219>0</OEMLED2219>
<OEMDRO2220>0.</OEMDRO2220>
<OEMLED2220>0</OEMLED2220>
<OEMDRO2221>0.</OEMDRO2221>
<OEMLED2221>0</OEMLED2221>
<OEMDRO2222>0.</OEMDRO2222>
<OEMLED2222>0</OEMLED2222>
<OEMDRO2223>0.</OEMDRO2223>
<OEMLED2223>0</OEMLED2223>
<OEMDRO2224>0.</OEMDRO2224>
<OEMLED2224>0</OEMLED2224>
<OEMDRO2225>0.</OEMDRO2225>
<OEMLED2225>0</OEMLED2225>
<OEMDRO2226>0.</OEMDRO2226>
<OEMLED2226>0</OEMLED2226>
<OEMDRO2227>0.</OEMDRO2227>
<OEMLED2227>0</OEMLED2227>
<OEMDRO2228>0.</OEMDRO2228>
<OEMLED2228>0</OEMLED2228>
<OEMDRO2229>0.</OEMDRO2229>
<OEMLED2229>0</OEMLED2229>
<OEMDRO2230>0.</OEMDRO2230>
<OEMLED2230>0</OEMLED2230>
<OEMDRO2231>0.</OEMDRO2231>
<OEMLED2231>0</OEMLED2231>
<OEMDRO2232>0.</OEMDRO2232>
<OEMLED2232>0</OEMLED2232>
<OEMDRO2233>0.</OEMDRO2233>
<OEMLED2233>0</OEMLED2233>
<OEMDRO2234>0.</OEMDRO2234>
<OEMLED2234>0</OEMLED2234>
<OEMDRO2235>0.</OEMDRO2235>
<OEMLED2235>0</OEMLED2235>
<OEMDRO2236>0.</OEMDRO2236>
<OEMLED2236>0</OEMLED2236>
<OEMDRO2237>0.</OEMDRO2237>
<OEMLED2237>0</OEMLED2237>
<OEMDRO2238>0.</OEMDRO2238>
<OEMLED2238>0</OEMLED2238>
<OEMDRO2239>0.</OEMDRO2239>
<OEMLED2239>0</OEMLED2239>
<OEMDRO2240>0.</OEMDRO2240>
<OEMLED2240>0</OEMLED2240>
<OEMDRO2241>0.</OEMDRO2241>
<OEMLED2241>0</OEMLED2241>
<OEMDRO2242>0.</OEMDRO2242>
<OEMLED2242>0</OEMLED2242>
<OEMDRO2243>0.</OEMDRO2243>
<OEMLED2243>0</OEMLED2243>
<OEMDRO2244>0.</OEMDRO2244>
<OEMLED2244>0</OEMLED2244>
<OEMDRO2245>0.</OEMDRO2245>
<OEMLED2245>0</OEMLED2245>
<OEMDRO2246>0.</OEMDRO2246>
<OEMLED2246>0</OEMLED2246>
<OEMDRO2247>0.</OEMDRO2247>
<OEMLED2247>0</OEMLED2247>
<OEMDRO2248>0.</OEMDRO2248>
<OEMLED2248>0</OEMLED2248>
<OEMDRO2249>0.</OEMDRO2249>
<OEMLED2249>0</OEMLED2249>
<OEMDRO2250>0.</OEMDRO2250>
<OEMLED2250>0</OEMLED2250>
<OEMDRO2251>0.</OEMDRO2251>
<OEMLED2251>0</OEMLED2251>
<OEMDRO2252>0.</OEMDRO2252>
<OEMLED2252>0</OEMLED2252>
<OEMDRO2253>0.</OEMDRO2253>
<OEMLED2253>0</OEMLED2253>
<OEMDRO2254>0.</OEMDRO2254>
<OEMLED2254>0</OEMLED2254>
<OEMDRO2255>0.</OEMDRO2255>
<OEMLED2255>0</OEMLED2255>
<OEMDRO2256>0.</OEMDRO2256>
<OEMLED2256>0</OEMLED2256>
<OEMDRO2257>0.</OEMDRO2257>
<OEMLED2257>0</OEMLED2257>
<OEMDRO2258>0.</OEMDRO2258>
<OEMLED2258>0</OEMLED2258>
<OEMDRO2259>0.</OEMDRO2259>
<OEMLED2259>0</OEMLED2259>
<OEMDRO2260>0.</OEMDRO2260>
<OEMLED2260>0</OEMLED2260>
<OEMDRO2261>0.</OEMDRO2261>
<OEMLED2261>0</OEMLED2261>
<OEMDRO2262>0.</OEMDRO2262>
<OEMLED2262>0</OEMLED2262>
<OEMDRO2263>0.</OEMDRO2263>
<OEMLED2263>0</OEMLED2263>
<OEMDRO2264>0.</OEMDRO2264>
<OEMLED2264>0</OEMLED2264>
<OEMDRO2265>0.</OEMDRO2265>
<OEMLED2265>0</OEMLED2265>
<OEMDRO2266>0.</OEMDRO2266>
<OEMLED2266>0</OEMLED2266>
<OEMDRO2267>0.</OEMDRO2267>
<OEMLED2267>0</OEMLED2267>
<OEMDRO2268>0.</OEMDRO2268>
<OEMLED2268>0</OEMLED2268>
<OEMDRO2269>0.</OEMDRO2269>
<OEMLED2269>0</OEMLED2269>
<OEMDRO2270>0.</OEMDRO2270>
<OEMLED2270>0</OEMLED2270>
<OEMDRO2271>0.</OEMDRO2271>
<OEMLED2271>0</OEMLED2271>
<OEMDRO2272>0.</OEMDRO2272>
<OEMLED2272>0</OEMLED2272>
<OEMDRO2273>0.</OEMDRO2273>
<OEMLED2273>0</OEMLED2273>
<OEMDRO2274>0.</OEMDRO2274>
<OEMLED2274>0</OEMLED2274>
<OEMDRO2275>0.</OEMDRO2275>
<OEMLED2275>0</OEMLED2275>
<OEMDRO2276>0.</OEMDRO2276>
<OEMLED2276>0</OEMLED2276>
<OEMDRO2277>0.</OEMDRO2277>
<OEMLED2277>0</OEMLED2277>
<OEMDRO2278>0.</OEMDRO2278>
<OEMLED2278>0</OEMLED2278>
<OEMDRO2279>0.</OEMDRO2279>
<OEMLED2279>0</OEMLED2279>
<OEMDRO2280>0.</OEMDRO2280>
<OEMLED2280>0</OEMLED2280>
<OEMDRO2281>0.</OEMDRO2281>
<OEMLED2281>0</OEMLED2281>
<OEMDRO2282>0.</OEMDRO2282>
<OEMLED2282>0</OEMLED2282>
<OEMDRO2283>0.</OEMDRO2283>
<OEMLED2283>0</OEMLED2283>
<OEMDRO2284>0.</OEMDRO2284>
<OEMLED2284>0</OEMLED2284>
<OEMDRO2285>0.</OEMDRO2285>
<OEMLED2285>0</OEMLED2285>
<OEMDRO2286>0.</OEMDRO2286>
<OEMLED2286>0</OEMLED2286>
<OEMDRO2287>0.</OEMDRO2287>
<OEMLED2287>0</OEMLED2287>
<OEMDRO2288>0.</OEMDRO2288>
<OEMLED2288>0</OEMLED2288>
<OEMDRO2289>0.</OEMDRO2289>
<OEMLED2289>0</OEMLED2289>
<OEMDRO2290>0.</OEMDRO2290>
<OEMLED2290>0</OEMLED2290>
<OEMDRO2291>0.</OEMDRO2291>
<OEMLED2291>0</OEMLED2291>
<OEMDRO2292>0.</OEMDRO2292>
<OEMLED2292>0</OEMLED2292>
<OEMDRO2293>0.</OEMDRO2293>
<OEMLED2293>0</OEMLED2293>
<OEMDRO2294>0.</OEMDRO2294>
<OEMLED2294>0</OEMLED2294>
<OEMDRO2295>0.</OEMDRO2295>
<OEMLED2295>0</OEMLED2295>
<OEMDRO2296>0.</OEMDRO2296>
<OEMLED2296>0</OEMLED2296>
<OEMDRO2297>0.</OEMDRO2297>
<OEMLED2297>0</OEMLED2297>
<OEMDRO2298>0.</OEMDRO2298>
<OEMLED2298>0</OEMLED2298>
<OEMDRO2299>0.</OEMDRO2299>
<OEMLED2299>0</OEMLED2299>
<OEMDRO2300>0.</OEMDRO2300>
<OEMLED2300>0</OEMLED2300>
<OEMDRO2301>0.</OEMDRO2301>
<OEMLED2301>0</OEMLED2301>
<OEMDRO2302>0.</OEMDRO2302>
<OEMLED2302>0</OEMLED2302>
<OEMDRO2303>0.</OEMDRO2303>
<OEMLED2303>0</OEMLED2303>
<OEMDRO2304>0.</OEMDRO2304>
<OEMLED2304>0</OEMLED2304>
<OEMDRO2305>0.</OEMDRO2305>
<OEMLED2305>0</OEMLED2305>
<OEMDRO2306>0.</OEMDRO2306>
<OEMLED2306>0</OEMLED2306>
<OEMDRO2307>0.</OEMDRO2307>
<OEMLED2307>0</OEMLED2307>
<OEMDRO2308>0.</OEMDRO2308>
<OEMLED2308>0</OEMLED2308>
<OEMDRO2309>0.</OEMDRO2309>
<OEMLED2309>0</OEMLED2309>
<OEMDRO2310>0.</OEMDRO2310>
<OEMLED2310>0</OEMLED2310>
<OEMDRO2311>0.</OEMDRO2311>
<OEMLED2311>0</OEMLED2311>
<OEMDRO2312>0.</OEMDRO2312>
<OEMLED2312>0</OEMLED2312>
<OEMDRO2313>0.</OEMDRO2313>
<OEMLED2313>0</OEMLED2313>
<OEMDRO2314>0.</OEMDRO2314>
<OEMLED2314>0</OEMLED2314>
<OEMDRO2315>0.</OEMDRO2315>
<OEMLED2315>0</OEMLED2315>
<OEMDRO2316>0.</OEMDRO2316>
<OEMLED2316>0</OEMLED2316>
<OEMDRO2317>0.</OEMDRO2317>
<OEMLED2317>0</OEMLED2317>
<OEMDRO2318>0.</OEMDRO2318>
<OEMLED2318>0</OEMLED2318>
<OEMDRO2319>0.</OEMDRO2319>
<OEMLED2319>0</OEMLED2319>
<OEMDRO2320>0.</OEMDRO2320>
<OEMLED2320>0</OEMLED2320>
<OEMDRO2321>0.</OEMDRO2321>
<OEMLED2321>0</OEMLED2321>
<OEMDRO2322>0.</OEMDRO2322>
<OEMLED2322>0</OEMLED2322>
<OEMDRO2323>0.</OEMDRO2323>
<OEMLED2323>0</OEMLED2323>
<OEMDRO2324>0.</OEMDRO2324>
<OEMLED2324>0</OEMLED2324>
<OEMDRO2325>0.</OEMDRO2325>
<OEMLED2325>0</OEMLED2325>
<OEMDRO2326>0.</OEMDRO2326>
<OEMLED2326>0</OEMLED2326>
<OEMDRO2327>0.</OEMDRO2327>
<OEMLED2327>0</OEMLED2327>
<OEMDRO2328>0.</OEMDRO2328>
<OEMLED2328>0</OEMLED2328>
<OEMDRO2329>0.</OEMDRO2329>
<OEMLED2329>0</OEMLED2329>
<OEMDRO2330>0.</OEMDRO2330>
<OEMLED2330>0</OEMLED2330>
<OEMDRO2331>0.</OEMDRO2331>
<OEMLED2331>0</OEMLED2331>
<OEMDRO2332>0.</OEMDRO2332>
<OEMLED2332>0</OEMLED2332>
<OEMDRO2333>0.</OEMDRO2333>
<OEMLED2333>0</OEMLED2333>
<OEMDRO2334>0.</OEMDRO2334>
<OEMLED2334>0</OEMLED2334>
<OEMDRO2335>0.</OEMDRO2335>
<OEMLED2335>0</OEMLED2335>
<OEMDRO2336>0.</OEMDRO2336>
<OEMLED2336>0</OEMLED2336>
<OEMDRO2337>0.</OEMDRO2337>
<OEMLED2337>0</OEMLED2337>
<OEMDRO2338>0.</OEMDRO2338>
<OEMLED2338>0</OEMLED2338>
<OEMDRO2339>0.</OEMDRO2339>
<OEMLED2339>0</OEMLED2339>
<OEMDRO2340>0.</OEMDRO2340>
<OEMLED2340>0</OEMLED2340>
<OEMDRO2341>0.</OEMDRO2341>
<OEMLED2341>0</OEMLED2341>
<OEMDRO2342>0.</OEMDRO2342>
<OEMLED2342>0</OEMLED2342>
<OEMDRO2343>0.</OEMDRO2343>
<OEMLED2343>0</OEMLED2343>
<OEMDRO2344>0.</OEMDRO2344>
<OEMLED2344>0</OEMLED2344>
<OEMDRO2345>0.</OEMDRO2345>
<OEMLED2345>0</OEMLED2345>
<OEMDRO2346>0.</OEMDRO2346>
<OEMLED2346>0</OEMLED2346>
<OEMDRO2347>0.</OEMDRO2347>
<OEMLED2347>0</OEMLED2347>
<OEMDRO2348>0.</OEMDRO2348>
<OEMLED2348>0</OEMLED2348>
<OEMDRO2349>0.</OEMDRO2349>
<OEMLED2349>0</OEMLED2349>
<OEMDRO2350>0.</OEMDRO2350>
<OEMLED2350>0</OEMLED2350>
<OEMDRO2351>0.</OEMDRO2351>
<OEMLED2351>0</OEMLED2351>
<OEMDRO2352>0.</OEMDRO2352>
<OEMLED2352>0</OEMLED2352>
<OEMDRO2353>0.</OEMDRO2353>
<OEMLED2353>0</OEMLED2353>
<OEMDRO2354>0.</OEMDRO2354>
<OEMLED2354>0</OEMLED2354>
<OEMDRO2355>0.</OEMDRO2355>
<OEMLED2355>0</OEMLED2355>
<OEMDRO2356>0.</OEMDRO2356>
<OEMLED2356>0</OEMLED2356>
<OEMDRO2357>0.</OEMDRO2357>
<OEMLED2357>0</OEMLED2357>
<OEMDRO2358>0.</OEMDRO2358>
<OEMLED2358>0</OEMLED2358>
<OEMDRO2359>0.</OEMDRO2359>
<OEMLED2359>0</OEMLED2359>
<OEMDRO2360>0.</OEMDRO2360>
<OEMLED2360>0</OEMLED2360>
<OEMDRO2361>0.</OEMDRO2361>
<OEMLED2361>0</OEMLED2361>
<OEMDRO2362>0.</OEMDRO2362>
<OEMLED2362>0</OEMLED2362>
<OEMDRO2363>0.</OEMDRO2363>
<OEMLED2363>0</OEMLED2363>
<OEMDRO2364>0.</OEMDRO2364>
<OEMLED2364>0</OEMLED2364>
<OEMDRO2365>0.</OEMDRO2365>
<OEMLED2365>0</OEMLED2365>
<OEMDRO2366>0.</OEMDRO2366>
<OEMLED2366>0</OEMLED2366>
<OEMDRO2367>0.</OEMDRO2367>
<OEMLED2367>0</OEMLED2367>
<OEMDRO2368>0.</OEMDRO2368>
<OEMLED2368>0</OEMLED2368>
<OEMDRO2369>0.</OEMDRO2369>
<OEMLED2369>0</OEMLED2369>
<OEMDRO2370>0.</OEMDRO2370>
<OEMLED2370>0</OEMLED2370>
<OEMDRO2371>0.</OEMDRO2371>
<OEMLED2371>0</OEMLED2371>
<OEMDRO2372>0.</OEMDRO2372>
<OEMLED2372>0</OEMLED2372>
<OEMDRO2373>0.</OEMDRO2373>
<OEMLED2373>0</OEMLED2373>
<OEMDRO2374>0.</OEMDRO2374>
<OEMLED2374>0</OEMLED2374>
<OEMDRO2375>0.</OEMDRO2375>
<OEMLED2375>0</OEMLED2375>
<OEMDRO2376>0.</OEMDRO2376>
<OEMLED2376>0</OEMLED2376>
<OEMDRO2377>0.</OEMDRO2377>
<OEMLED2377>0</OEMLED2377>
<OEMDRO2378>0.</OEMDRO2378>
<OEMLED2378>0</OEMLED2378>
<OEMDRO2379>0.</OEMDRO2379>
<OEMLED2379>0</OEMLED2379>
<OEMDRO2380>0.</OEMDRO2380>
<OEMLED2380>0</OEMLED2380>
<OEMDRO2381>0.</OEMDRO2381>
<OEMLED2381>0</OEMLED2381>
<OEMDRO2382>0.</OEMDRO2382>
<OEMLED2382>0</OEMLED2382>
<OEMDRO2383>0.</OEMDRO2383>
<OEMLED2383>0</OEMLED2383>
<OEMDRO2384>0.</OEMDRO2384>
<OEMLED2384>0</OEMLED2384>
<OEMDRO2385>0.</OEMDRO2385>
<OEMLED2385>0</OEMLED2385>
<OEMDRO2386>0.</OEMDRO2386>
<OEMLED2386>0</OEMLED2386>
<OEMDRO2387>0.</OEMDRO2387>
<OEMLED2387>0</OEMLED2387>
<OEMDRO2388>0.</OEMDRO2388>
<OEMLED2388>0</OEMLED2388>
<OEMDRO2389>0.</OEMDRO2389>
<OEMLED2389>0</OEMLED2389>
<OEMDRO2390>0.</OEMDRO2390>
<OEMLED2390>0</OEMLED2390>
<OEMDRO2391>0.</OEMDRO2391>
<OEMLED2391>0</OEMLED2391>
<OEMDRO2392>0.</OEMDRO2392>
<OEMLED2392>0</OEMLED2392>
<OEMDRO2393>0.</OEMDRO2393>
<OEMLED2393>0</OEMLED2393>
<OEMDRO2394>0.</OEMDRO2394>
<OEMLED2394>0</OEMLED2394>
<OEMDRO2395>0.</OEMDRO2395>
<OEMLED2395>0</OEMLED2395>
<OEMDRO2396>0.</OEMDRO2396>
<OEMLED2396>0</OEMLED2396>
<OEMDRO2397>0.</OEMDRO2397>
<OEMLED2397>0</OEMLED2397>
<OEMDRO2398>0.</OEMDRO2398>
<OEMLED2398>0</OEMLED2398>
<OEMDRO2399>0.</OEMDRO2399>
<OEMLED2399>0</OEMLED2399>
<OEMDRO2400>0.</OEMDRO2400>
<OEMLED2400>0</OEMLED2400>
<OEMDRO2401>0.</OEMDRO2401>
<OEMLED2401>0</OEMLED2401>
<OEMDRO2402>0.</OEMDRO2402>
<OEMLED2402>0</OEMLED2402>
<OEMDRO2403>0.</OEMDRO2403>
<OEMLED2403>0</OEMLED2403>
<OEMDRO2404>0.</OEMDRO2404>
<OEMLED2404>0</OEMLED2404>
<OEMDRO2405>0.</OEMDRO2405>
<OEMLED2405>0</OEMLED2405>
<OEMDRO2406>0.</OEMDRO2406>
<OEMLED2406>0</OEMLED2406>
<OEMDRO2407>0.</OEMDRO2407>
<OEMLED2407>0</OEMLED2407>
<OEMDRO2408>0.</OEMDRO2408>
<OEMLED2408>0</OEMLED2408>
<OEMDRO2409>0.</OEMDRO2409>
<OEMLED2409>0</OEMLED2409>
<OEMDRO2410>0.</OEMDRO2410>
<OEMLED2410>0</OEMLED2410>
<OEMDRO2411>0.</OEMDRO2411>
<OEMLED2411>0</OEMLED2411>
<OEMDRO2412>0.</OEMDRO2412>
<OEMLED2412>0</OEMLED2412>
<OEMDRO2413>0.</OEMDRO2413>
<OEMLED2413>0</OEMLED2413>
<OEMDRO2414>0.</OEMDRO2414>
<OEMLED2414>0</OEMLED2414>
<OEMDRO2415>0.</OEMDRO2415>
<OEMLED2415>0</OEMLED2415>
<OEMDRO2416>0.</OEMDRO2416>
<OEMLED2416>0</OEMLED2416>
<OEMDRO2417>0.</OEMDRO2417>
<OEMLED2417>0</OEMLED2417>
<OEMDRO2418>0.</OEMDRO2418>
<OEMLED2418>0</OEMLED2418>
<OEMDRO2419>0.</OEMDRO2419>
<OEMLED2419>0</OEMLED2419>
<OEMDRO2420>0.</OEMDRO2420>
<OEMLED2420>0</OEMLED2420>
<OEMDRO2421>0.</OEMDRO2421>
<OEMLED2421>0</OEMLED2421>
<OEMDRO2422>0.</OEMDRO2422>
<OEMLED2422>0</OEMLED2422>
<OEMDRO2423>0.</OEMDRO2423>
<OEMLED2423>0</OEMLED2423>
<OEMDRO2424>0.</OEMDRO2424>
<OEMLED2424>0</OEMLED2424>
<OEMDRO2425>0.</OEMDRO2425>
<OEMLED2425>0</OEMLED2425>
<OEMDRO2426>0.</OEMDRO2426>
<OEMLED2426>0</OEMLED2426>
<OEMDRO2427>0.</OEMDRO2427>
<OEMLED2427>0</OEMLED2427>
<OEMDRO2428>0.</OEMDRO2428>
<OEMLED2428>0</OEMLED2428>
<OEMDRO2429>0.</OEMDRO2429>
<OEMLED2429>0</OEMLED2429>
<OEMDRO2430>0.</OEMDRO2430>
<OEMLED2430>0</OEMLED2430>
<OEMDRO2431>0.</OEMDRO2431>
<OEMLED2431>0</OEMLED2431>
<OEMDRO2432>0.</OEMDRO2432>
<OEMLED2432>0</OEMLED2432>
<OEMDRO2433>0.</OEMDRO2433>
<OEMLED2433>0</OEMLED2433>
<OEMDRO2434>0.</OEMDRO2434>
<OEMLED2434>0</OEMLED2434>
<OEMDRO2435>0.</OEMDRO2435>
<OEMLED2435>0</OEMLED2435>
<OEMDRO2436>0.</OEMDRO2436>
<OEMLED2436>0</OEMLED2436>
<OEMDRO2437>0.</OEMDRO2437>
<OEMLED2437>0</OEMLED2437>
<OEMDRO2438>0.</OEMDRO2438>
<OEMLED2438>0</OEMLED2438>
<OEMDRO2439>0.</OEMDRO2439>
<OEMLED2439>0</OEMLED2439>
<OEMDRO2440>0.</OEMDRO2440>
<OEMLED2440>0</OEMLED2440>
<OEMDRO2441>0.</OEMDRO2441>
<OEMLED2441>0</OEMLED2441>
<OEMDRO2442>0.</OEMDRO2442>
<OEMLED2442>0</OEMLED2442>
<OEMDRO2443>0.</OEMDRO2443>
<OEMLED2443>0</OEMLED2443>
<OEMDRO2444>0.</OEMDRO2444>
<OEMLED2444>0</OEMLED2444>
<OEMDRO2445>0.</OEMDRO2445>
<OEMLED2445>0</OEMLED2445>
<OEMDRO2446>0.</OEMDRO2446>
<OEMLED2446>0</OEMLED2446>
<OEMDRO2447>0.</OEMDRO2447>
<OEMLED2447>0</OEMLED2447>
<OEMDRO2448>0.</OEMDRO2448>
<OEMLED2448>0</OEMLED2448>
<OEMDRO2449>0.</OEMDRO2449>
<OEMLED2449>0</OEMLED2449>
<OEMDRO2450>0.</OEMDRO2450>
<OEMLED2450>0</OEMLED2450>
<OEMDRO2451>0.</OEMDRO2451>
<OEMLED2451>0</OEMLED2451>
<OEMDRO2452>0.</OEMDRO2452>
<OEMLED2452>0</OEMLED2452>
<OEMDRO2453>0.</OEMDRO2453>
<OEMLED2453>0</OEMLED2453>
<OEMDRO2454>0.</OEMDRO2454>
<OEMLED2454>0</OEMLED2454>
<OEMDRO2455>0.</OEMDRO2455>
<OEMLED2455>0</OEMLED2455>
<OEMDRO2456>0.</OEMDRO2456>
<OEMLED2456>0</OEMLED2456>
<OEMDRO2457>0.</OEMDRO2457>
<OEMLED2457>0</OEMLED2457>
<OEMDRO2458>0.</OEMDRO2458>
<OEMLED2458>0</OEMLED2458>
<OEMDRO2459>0.</OEMDRO2459>
<OEMLED2459>0</OEMLED2459>
<OEMDRO2460>0.</OEMDRO2460>
<OEMLED2460>0</OEMLED2460>
<OEMDRO2461>0.</OEMDRO2461>
<OEMLED2461>0</OEMLED2461>
<OEMDRO2462>0.</OEMDRO2462>
<OEMLED2462>0</OEMLED2462>
<OEMDRO2463>0.</OEMDRO2463>
<OEMLED2463>0</OEMLED2463>
<OEMDRO2464>0.</OEMDRO2464>
<OEMLED2464>0</OEMLED2464>
<OEMDRO2465>0.</OEMDRO2465>
<OEMLED2465>0</OEMLED2465>
<OEMDRO2466>0.</OEMDRO2466>
<OEMLED2466>0</OEMLED2466>
<OEMDRO2467>0.</OEMDRO2467>
<OEMLED2467>0</OEMLED2467>
<OEMDRO2468>0.</OEMDRO2468>
<OEMLED2468>0</OEMLED2468>
<OEMDRO2469>0.</OEMDRO2469>
<OEMLED2469>0</OEMLED2469>
<OEMDRO2470>0.</OEMDRO2470>
<OEMLED2470>0</OEMLED2470>
<OEMDRO2471>0.</OEMDRO2471>
<OEMLED2471>0</OEMLED2471>
<OEMDRO2472>0.</OEMDRO2472>
<OEMLED2472>0</OEMLED2472>
<OEMDRO2473>0.</OEMDRO2473>
<OEMLED2473>0</OEMLED2473>
<OEMDRO2474>0.</OEMDRO2474>
<OEMLED2474>0</OEMLED2474>
<OEMDRO2475>0.</OEMDRO2475>
<OEMLED2475>0</OEMLED2475>
<OEMDRO2476>0.</OEMDRO2476>
<OEMLED2476>0</OEMLED2476>
<OEMDRO2477>0.</OEMDRO2477>
<OEMLED2477>0</OEMLED2477>
<OEMDRO2478>0.</OEMDRO2478>
<OEMLED2478>0</OEMLED2478>
<OEMDRO2479>0.</OEMDRO2479>
<OEMLED2479>0</OEMLED2479>
<OEMDRO2480>0.</OEMDRO2480>
<OEMLED2480>0</OEMLED2480>
<OEMDRO2481>0.</OEMDRO2481>
<OEMLED2481>0</OEMLED2481>
<OEMDRO2482>0.</OEMDRO2482>
<OEMLED2482>0</OEMLED2482>
<OEMDRO2483>0.</OEMDRO2483>
<OEMLED2483>0</OEMLED2483>
<OEMDRO2484>0.</OEMDRO2484>
<OEMLED2484>0</OEMLED2484>
<OEMDRO2485>0.</OEMDRO2485>
<OEMLED2485>0</OEMLED2485>
<OEMDRO2486>0.</OEMDRO2486>
<OEMLED2486>0</OEMLED2486>
<OEMDRO2487>0.</OEMDRO2487>
<OEMLED2487>0</OEMLED2487>
<OEMDRO2488>0.</OEMDRO2488>
<OEMLED2488>0</OEMLED2488>
<OEMDRO2489>0.</OEMDRO2489>
<OEMLED2489>0</OEMLED2489>
<OEMDRO2490>0.</OEMDRO2490>
<OEMLED2490>0</OEMLED2490>
<OEMDRO2491>0.</OEMDRO2491>
<OEMLED2491>0</OEMLED2491>
<OEMDRO2492>0.</OEMDRO2492>
<OEMLED2492>0</OEMLED2492>
<OEMDRO2493>0.</OEMDRO2493>
<OEMLED2493>0</OEMLED2493>
<OEMDRO2494>0.</OEMDRO2494>
<OEMLED2494>0</OEMLED2494>
<OEMDRO2495>0.</OEMDRO2495>
<OEMLED2495>0</OEMLED2495>
<OEMDRO2496>0.</OEMDRO2496>
<OEMLED2496>0</OEMLED2496>
<OEMDRO2497>0.</OEMDRO2497>
<OEMLED2497>0</OEMLED2497>
<OEMDRO2498>0.</OEMDRO2498>
<OEMLED2498>0</OEMLED2498>
<OEMDRO2499>0.</OEMDRO2499>
<OEMLED2499>0</OEMLED2499>
<OEMDRO2500>0.</OEMDRO2500>
<OEMLED2500>0</OEMLED2500>
<OEMDRO2501>0.</OEMDRO2501>
<OEMLED2501>0</OEMLED2501>
<OEMDRO2502>0.</OEMDRO2502>
<OEMLED2502>0</OEMLED2502>
<OEMDRO2503>0.</OEMDRO2503>
<OEMLED2503>0</OEMLED2503>
<OEMDRO2504>0.</OEMDRO2504>
<OEMLED2504>0</OEMLED2504>
<OEMDRO2505>0.</OEMDRO2505>
<OEMLED2505>0</OEMLED2505>
<OEMDRO2506>0.</OEMDRO2506>
<OEMLED2506>0</OEMLED2506>
<OEMDRO2507>0.</OEMDRO2507>
<OEMLED2507>0</OEMLED2507>
<OEMDRO2508>0.</OEMDRO2508>
<OEMLED2508>0</OEMLED2508>
<OEMDRO2509>0.</OEMDRO2509>
<OEMLED2509>0</OEMLED2509>
<OEMDRO2510>0.</OEMDRO2510>
<OEMLED2510>0</OEMLED2510>
<OEMDRO2511>0.</OEMDRO2511>
<OEMLED2511>0</OEMLED2511>
<OEMDRO2512>0.</OEMDRO2512>
<OEMLED2512>0</OEMLED2512>
<OEMDRO2513>0.</OEMDRO2513>
<OEMLED2513>0</OEMLED2513>
<OEMDRO2514>0.</OEMDRO2514>
<OEMLED2514>0</OEMLED2514>
<OEMDRO2515>0.</OEMDRO2515>
<OEMLED2515>0</OEMLED2515>
<OEMDRO2516>0.</OEMDRO2516>
<OEMLED2516>0</OEMLED2516>
<OEMDRO2517>0.</OEMDRO2517>
<OEMLED2517>0</OEMLED2517>
<OEMDRO2518>0.</OEMDRO2518>
<OEMLED2518>0</OEMLED2518>
<OEMDRO2519>0.</OEMDRO2519>
<OEMLED2519>0</OEMLED2519>
<OEMDRO2520>0.</OEMDRO2520>
<OEMLED2520>0</OEMLED2520>
<OEMDRO2521>0.</OEMDRO2521>
<OEMLED2521>0</OEMLED2521>
<OEMDRO2522>0.</OEMDRO2522>
<OEMLED2522>0</OEMLED2522>
<OEMDRO2523>0.</OEMDRO2523>
<OEMLED2523>0</OEMLED2523>
<OEMDRO2524>0.</OEMDRO2524>
<OEMLED2524>0</OEMLED2524>
<OEMDRO2525>0.</OEMDRO2525>
<OEMLED2525>0</OEMLED2525>
<OEMDRO2526>0.</OEMDRO2526>
<OEMLED2526>0</OEMLED2526>
<OEMDRO2527>0.</OEMDRO2527>
<OEMLED2527>0</OEMLED2527>
<OEMDRO2528>0.</OEMDRO2528>
<OEMLED2528>0</OEMLED2528>
<OEMDRO2529>0.</OEMDRO2529>
<OEMLED2529>0</OEMLED2529>
<OEMDRO2530>0.</OEMDRO2530>
<OEMLED2530>0</OEMLED2530>
<OEMDRO2531>0.</OEMDRO2531>
<OEMLED2531>0</OEMLED2531>
<OEMDRO2532>0.</OEMDRO2532>
<OEMLED2532>0</OEMLED2532>
<OEMDRO2533>0.</OEMDRO2533>
<OEMLED2533>0</OEMLED2533>
<OEMDRO2534>0.</OEMDRO2534>
<OEMLED2534>0</OEMLED2534>
<OEMDRO2535>0.</OEMDRO2535>
<OEMLED2535>0</OEMLED2535>
<OEMDRO2536>0.</OEMDRO2536>
<OEMLED2536>0</OEMLED2536>
<OEMDRO2537>0.</OEMDRO2537>
<OEMLED2537>0</OEMLED2537>
<OEMDRO2538>0.</OEMDRO2538>
<OEMLED2538>0</OEMLED2538>
<OEMDRO2539>0.</OEMDRO2539>
<OEMLED2539>0</OEMLED2539>
<OEMDRO2540>0.</OEMDRO2540>
<OEMLED2540>0</OEMLED2540>
<OEMDRO2541>0.</OEMDRO2541>
<OEMLED2541>0</OEMLED2541>
<OEMDRO2542>0.</OEMDRO2542>
<OEMLED2542>0</OEMLED2542>
<OEMDRO2543>0.</OEMDRO2543>
<OEMLED2543>0</OEMLED2543>
<OEMDRO2544>0.</OEMDRO2544>
<OEMLED2544>0</OEMLED2544>
<OEMDRO2545>0.</OEMDRO2545>
<OEMLED2545>0</OEMLED2545>
<OEMDRO2546>0.</OEMDRO2546>
<OEMLED2546>0</OEMLED2546>
<OEMDRO2547>0.</OEMDRO2547>
<OEMLED2547>0</OEMLED2547>
<OEMDRO2548>0.</OEMDRO2548>
<OEMLED2548>0</OEMLED2548>
<OEMDRO2549>0.</OEMDRO2549>
<OEMLED2549>0</OEMLED2549>
<OEMDRO2550>0.</OEMDRO2550>
<OEMLED2550>0</OEMLED2550>
<OEMDRO2551>0.</OEMDRO2551>
<OEMLED2551>0</OEMLED2551>
<OEMDRO2552>0.</OEMDRO2552>
<OEMLED2552>0</OEMLED2552>
<OEMDRO2553>0.</OEMDRO2553>
<OEMLED2553>0</OEMLED2553>
<OEMDRO2554>0.</OEMDRO2554>
<OEMLED2554>0</OEMLED2554>
<OEMDRO2555>0.</OEMDRO2555>
<OEMLED2555>0</OEMLED2555>
<OEMDRO2556>0.</OEMDRO2556>
<OEMLED2556>0</OEMLED2556>
<OEMDRO2557>0.</OEMDRO2557>
<OEMLED2557>0</OEMLED2557>
<OEMDRO2558>0.</OEMDRO2558>
<OEMLED2558>0</OEMLED2558>
<OEMDRO2559>0.</OEMDRO2559>
<OEMLED2559>0</OEMLED2559>
<OEMDRO2560>0.</OEMDRO2560>
<OEMLED2560>0</OEMLED2560>
<OEMDRO2561>0.</OEMDRO2561>
<OEMLED2561>0</OEMLED2561>
<OEMDRO2562>0.</OEMDRO2562>
<OEMLED2562>0</OEMLED2562>
<OEMDRO2563>0.</OEMDRO2563>
<OEMLED2563>0</OEMLED2563>
<OEMDRO2564>0.</OEMDRO2564>
<OEMLED2564>0</OEMLED2564>
<OEMDRO2565>0.</OEMDRO2565>
<OEMLED2565>0</OEMLED2565>
<OEMDRO2566>0.</OEMDRO2566>
<OEMLED2566>0</OEMLED2566>
<OEMDRO2567>0.</OEMDRO2567>
<OEMLED2567>0</OEMLED2567>
<OEMDRO2568>0.</OEMDRO2568>
<OEMLED2568>0</OEMLED2568>
<OEMDRO2569>0.</OEMDRO2569>
<OEMLED2569>0</OEMLED2569>
<OEMDRO2570>0.</OEMDRO2570>
<OEMLED2570>0</OEMLED2570>
<OEMDRO2571>0.</OEMDRO2571>
<OEMLED2571>0</OEMLED2571>
<OEMDRO2572>0.</OEMDRO2572>
<OEMLED2572>0</OEMLED2572>
<OEMDRO2573>0.</OEMDRO2573>
<OEMLED2573>0</OEMLED2573>
<OEMDRO2574>0.</OEMDRO2574>
<OEMLED2574>0</OEMLED2574>
<OEMDRO2575>0.</OEMDRO2575>
<OEMLED2575>0</OEMLED2575>
<OEMDRO2576>0.</OEMDRO2576>
<OEMLED2576>0</OEMLED2576>
<OEMDRO2577>0.</OEMDRO2577>
<OEMLED2577>0</OEMLED2577>
<OEMDRO2578>0.</OEMDRO2578>
<OEMLED2578>0</OEMLED2578>
<OEMDRO2579>0.</OEMDRO2579>
<OEMLED2579>0</OEMLED2579>
<OEMDRO2580>0.</OEMDRO2580>
<OEMLED2580>0</OEMLED2580>
<OEMDRO2581>0.</OEMDRO2581>
<OEMLED2581>0</OEMLED2581>
<OEMDRO2582>0.</OEMDRO2582>
<OEMLED2582>0</OEMLED2582>
<OEMDRO2583>0.</OEMDRO2583>
<OEMLED2583>0</OEMLED2583>
<OEMDRO2584>0.</OEMDRO2584>
<OEMLED2584>0</OEMLED2584>
<OEMDRO2585>0.</OEMDRO2585>
<OEMLED2585>0</OEMLED2585>
<OEMDRO2586>0.</OEMDRO2586>
<OEMLED2586>0</OEMLED2586>
<OEMDRO2587>0.</OEMDRO2587>
<OEMLED2587>0</OEMLED2587>
<OEMDRO2588>0.</OEMDRO2588>
<OEMLED2588>0</OEMLED2588>
<OEMDRO2589>0.</OEMDRO2589>
<OEMLED2589>0</OEMLED2589>
<OEMDRO2590>0.</OEMDRO2590>
<OEMLED2590>0</OEMLED2590>
<OEMDRO2591>0.</OEMDRO2591>
<OEMLED2591>0</OEMLED2591>
<OEMDRO2592>0.</OEMDRO2592>
<OEMLED2592>0</OEMLED2592>
<OEMDRO2593>0.</OEMDRO2593>
<OEMLED2593>0</OEMLED2593>
<OEMDRO2594>0.</OEMDRO2594>
<OEMLED2594>0</OEMLED2594>
<OEMDRO2595>0.</OEMDRO2595>
<OEMLED2595>0</OEMLED2595>
<OEMDRO2596>0.</OEMDRO2596>
<OEMLED2596>0</OEMLED2596>
<OEMDRO2597>0.</OEMDRO2597>
<OEMLED2597>0</OEMLED2597>
<OEMDRO2598>0.</OEMDRO2598>
<OEMLED2598>0</OEMLED2598>
<OEMDRO2599>0.</OEMDRO2599>
<OEMLED2599>0</OEMLED2599>
<OEMDRO2600>0.</OEMDRO2600>
<OEMLED2600>0</OEMLED2600>
<OEMDRO2601>0.</OEMDRO2601>
<OEMLED2601>0</OEMLED2601>
<OEMDRO2602>0.</OEMDRO2602>
<OEMLED2602>0</OEMLED2602>
<OEMDRO2603>0.</OEMDRO2603>
<OEMLED2603>0</OEMLED2603>
<OEMDRO2604>0.</OEMDRO2604>
<OEMLED2604>0</OEMLED2604>
<OEMDRO2605>0.</OEMDRO2605>
<OEMLED2605>0</OEMLED2605>
<OEMDRO2606>0.</OEMDRO2606>
<OEMLED2606>0</OEMLED2606>
<OEMDRO2607>0.</OEMDRO2607>
<OEMLED2607>0</OEMLED2607>
<OEMDRO2608>0.</OEMDRO2608>
<OEMLED2608>0</OEMLED2608>
<OEMDRO2609>0.</OEMDRO2609>
<OEMLED2609>0</OEMLED2609>
<OEMDRO2610>0.</OEMDRO2610>
<OEMLED2610>0</OEMLED2610>
<OEMDRO2611>0.</OEMDRO2611>
<OEMLED2611>0</OEMLED2611>
<OEMDRO2612>0.</OEMDRO2612>
<OEMLED2612>0</OEMLED2612>
<OEMDRO2613>0.</OEMDRO2613>
<OEMLED2613>0</OEMLED2613>
<OEMDRO2614>0.</OEMDRO2614>
<OEMLED2614>0</OEMLED2614>
<OEMDRO2615>0.</OEMDRO2615>
<OEMLED2615>0</OEMLED2615>
<OEMDRO2616>0.</OEMDRO2616>
<OEMLED2616>0</OEMLED2616>
<OEMDRO2617>0.</OEMDRO2617>
<OEMLED2617>0</OEMLED2617>
<OEMDRO2618>0.</OEMDRO2618>
<OEMLED2618>0</OEMLED2618>
<OEMDRO2619>0.</OEMDRO2619>
<OEMLED2619>0</OEMLED2619>
<OEMDRO2620>0.</OEMDRO2620>
<OEMLED2620>0</OEMLED2620>
<OEMDRO2621>0.</OEMDRO2621>
<OEMLED2621>0</OEMLED2621>
<OEMDRO2622>0.</OEMDRO2622>
<OEMLED2622>0</OEMLED2622>
<OEMDRO2623>0.</OEMDRO2623>
<OEMLED2623>0</OEMLED2623>
<OEMDRO2624>0.</OEMDRO2624>
<OEMLED2624>0</OEMLED2624>
<OEMDRO2625>0.</OEMDRO2625>
<OEMLED2625>0</OEMLED2625>
<OEMDRO2626>0.</OEMDRO2626>
<OEMLED2626>0</OEMLED2626>
<OEMDRO2627>0.</OEMDRO2627>
<OEMLED2627>0</OEMLED2627>
<OEMDRO2628>0.</OEMDRO2628>
<OEMLED2628>0</OEMLED2628>
<OEMDRO2629>0.</OEMDRO2629>
<OEMLED2629>0</OEMLED2629>
<OEMDRO2630>0.</OEMDRO2630>
<OEMLED2630>0</OEMLED2630>
<OEMDRO2631>0.</OEMDRO2631>
<OEMLED2631>0</OEMLED2631>
<OEMDRO2632>0.</OEMDRO2632>
<OEMLED2632>0</OEMLED2632>
<OEMDRO2633>0.</OEMDRO2633>
<OEMLED2633>0</OEMLED2633>
<OEMDRO2634>0.</OEMDRO2634>
<OEMLED2634>0</OEMLED2634>
<OEMDRO2635>0.</OEMDRO2635>
<OEMLED2635>0</OEMLED2635>
<OEMDRO2636>0.</OEMDRO2636>
<OEMLED2636>0</OEMLED2636>
<OEMDRO2637>0.</OEMDRO2637>
<OEMLED2637>0</OEMLED2637>
<OEMDRO2638>0.</OEMDRO2638>
<OEMLED2638>0</OEMLED2638>
<OEMDRO2639>0.</OEMDRO2639>
<OEMLED2639>0</OEMLED2639>
<OEMDRO2640>0.</OEMDRO2640>
<OEMLED2640>0</OEMLED2640>
<OEMDRO2641>0.</OEMDRO2641>
<OEMLED2641>0</OEMLED2641>
<OEMDRO2642>0.</OEMDRO2642>
<OEMLED2642>0</OEMLED2642>
<OEMDRO2643>0.</OEMDRO2643>
<OEMLED2643>0</OEMLED2643>
<OEMDRO2644>0.</OEMDRO2644>
<OEMLED2644>0</OEMLED2644>
<OEMDRO2645>0.</OEMDRO2645>
<OEMLED2645>0</OEMLED2645>
<OEMDRO2646>0.</OEMDRO2646>
<OEMLED2646>0</OEMLED2646>
<OEMDRO2647>0.</OEMDRO2647>
<OEMLED2647>0</OEMLED2647>
<OEMDRO2648>0.</OEMDRO2648>
<OEMLED2648>0</OEMLED2648>
<OEMDRO2649>0.</OEMDRO2649>
<OEMLED2649>0</OEMLED2649>
<OEMDRO2650>0.</OEMDRO2650>
<OEMLED2650>0</OEMLED2650>
<OEMDRO2651>0.</OEMDRO2651>
<OEMLED2651>0</OEMLED2651>
<OEMDRO2652>0.</OEMDRO2652>
<OEMLED2652>0</OEMLED2652>
<OEMDRO2653>0.</OEMDRO2653>
<OEMLED2653>0</OEMLED2653>
<OEMDRO2654>0.</OEMDRO2654>
<OEMLED2654>0</OEMLED2654>
<OEMDRO2655>0.</OEMDRO2655>
<OEMLED2655>0</OEMLED2655>
<OEMDRO2656>0.</OEMDRO2656>
<OEMLED2656>0</OEMLED2656>
<OEMDRO2657>0.</OEMDRO2657>
<OEMLED2657>0</OEMLED2657>
<OEMDRO2658>0.</OEMDRO2658>
<OEMLED2658>0</OEMLED2658>
<OEMDRO2659>0.</OEMDRO2659>
<OEMLED2659>0</OEMLED2659>
<OEMDRO2660>0.</OEMDRO2660>
<OEMLED2660>0</OEMLED2660>
<OEMDRO2661>0.</OEMDRO2661>
<OEMLED2661>0</OEMLED2661>
<OEMDRO2662>0.</OEMDRO2662>
<OEMLED2662>0</OEMLED2662>
<OEMDRO2663>0.</OEMDRO2663>
<OEMLED2663>0</OEMLED2663>
<OEMDRO2664>0.</OEMDRO2664>
<OEMLED2664>0</OEMLED2664>
<OEMDRO2665>0.</OEMDRO2665>
<OEMLED2665>0</OEMLED2665>
<OEMDRO2666>0.</OEMDRO2666>
<OEMLED2666>0</OEMLED2666>
<OEMDRO2667>0.</OEMDRO2667>
<OEMLED2667>0</OEMLED2667>
<OEMDRO2668>0.</OEMDRO2668>
<OEMLED2668>0</OEMLED2668>
<OEMDRO2669>0.</OEMDRO2669>
<OEMLED2669>0</OEMLED2669>
<OEMDRO2670>0.</OEMDRO2670>
<OEMLED2670>0</OEMLED2670>
<OEMDRO2671>0.</OEMDRO2671>
<OEMLED2671>0</OEMLED2671>
<OEMDRO2672>0.</OEMDRO2672>
<OEMLED2672>0</OEMLED2672>
<OEMDRO2673>0.</OEMDRO2673>
<OEMLED2673>0</OEMLED2673>
<OEMDRO2674>0.</OEMDRO2674>
<OEMLED2674>0</OEMLED2674>
<OEMDRO2675>0.</OEMDRO2675>
<OEMLED2675>0</OEMLED2675>
<OEMDRO2676>0.</OEMDRO2676>
<OEMLED2676>0</OEMLED2676>
<OEMDRO2677>0.</OEMDRO2677>
<OEMLED2677>0</OEMLED2677>
<OEMDRO2678>0.</OEMDRO2678>
<OEMLED2678>0</OEMLED2678>
<OEMDRO2679>0.</OEMDRO2679>
<OEMLED2679>0</OEMLED2679>
<OEMDRO2680>0.</OEMDRO2680>
<OEMLED2680>0</OEMLED2680>
<OEMDRO2681>0.</OEMDRO2681>
<OEMLED2681>0</OEMLED2681>
<OEMDRO2682>0.</OEMDRO2682>
<OEMLED2682>0</OEMLED2682>
<OEMDRO2683>0.</OEMDRO2683>
<OEMLED2683>0</OEMLED2683>
<OEMDRO2684>0.</OEMDRO2684>
<OEMLED2684>0</OEMLED2684>
<OEMDRO2685>0.</OEMDRO2685>
<OEMLED2685>0</OEMLED2685>
<OEMDRO2686>0.</OEMDRO2686>
<OEMLED2686>0</OEMLED2686>
<OEMDRO2687>0.</OEMDRO2687>
<OEMLED2687>0</OEMLED2687>
<OEMDRO2688>0.</OEMDRO2688>
<OEMLED2688>0</OEMLED2688>
<OEMDRO2689>0.</OEMDRO2689>
<OEMLED2689>0</OEMLED2689>
<OEMDRO2690>0.</OEMDRO2690>
<OEMLED2690>0</OEMLED2690>
<OEMDRO2691>0.</OEMDRO2691>
<OEMLED2691>0</OEMLED2691>
<OEMDRO2692>0.</OEMDRO2692>
<OEMLED2692>0</OEMLED2692>
<OEMDRO2693>0.</OEMDRO2693>
<OEMLED2693>0</OEMLED2693>
<OEMDRO2694>0.</OEMDRO2694>
<OEMLED2694>0</OEMLED2694>
<OEMDRO2695>0.</OEMDRO2695>
<OEMLED2695>0</OEMLED2695>
<OEMDRO2696>0.</OEMDRO2696>
<OEMLED2696>0</OEMLED2696>
<OEMDRO2697>0.</OEMDRO2697>
<OEMLED2697>0</OEMLED2697>
<OEMDRO2698>0.</OEMDRO2698>
<OEMLED2698>0</OEMLED2698>
<OEMDRO2699>0.</OEMDRO2699>
<OEMLED2699>0</OEMLED2699>
<OEMDRO2700>0.</OEMDRO2700>
<OEMLED2700>0</OEMLED2700>
<OEMDRO2701>0.</OEMDRO2701>
<OEMLED2701>0</OEMLED2701>
<OEMDRO2702>0.</OEMDRO2702>
<OEMLED2702>0</OEMLED2702>
<OEMDRO2703>0.</OEMDRO2703>
<OEMLED2703>0</OEMLED2703>
<OEMDRO2704>0.</OEMDRO2704>
<OEMLED2704>0</OEMLED2704>
<OEMDRO2705>0.</OEMDRO2705>
<OEMLED2705>0</OEMLED2705>
<OEMDRO2706>0.</OEMDRO2706>
<OEMLED2706>0</OEMLED2706>
<OEMDRO2707>0.</OEMDRO2707>
<OEMLED2707>0</OEMLED2707>
<OEMDRO2708>0.</OEMDRO2708>
<OEMLED2708>0</OEMLED2708>
<OEMDRO2709>0.</OEMDRO2709>
<OEMLED2709>0</OEMLED2709>
<OEMDRO2710>0.</OEMDRO2710>
<OEMLED2710>0</OEMLED2710>
<OEMDRO2711>0.</OEMDRO2711>
<OEMLED2711>0</OEMLED2711>
<OEMDRO2712>0.</OEMDRO2712>
<OEMLED2712>0</OEMLED2712>
<OEMDRO2713>0.</OEMDRO2713>
<OEMLED2713>0</OEMLED2713>
<OEMDRO2714>0.</OEMDRO2714>
<OEMLED2714>0</OEMLED2714>
<OEMDRO2715>0.</OEMDRO2715>
<OEMLED2715>0</OEMLED2715>
<OEMDRO2716>0.</OEMDRO2716>
<OEMLED2716>0</OEMLED2716>
<OEMDRO2717>0.</OEMDRO2717>
<OEMLED2717>0</OEMLED2717>
<OEMDRO2718>0.</OEMDRO2718>
<OEMLED2718>0</OEMLED2718>
<OEMDRO2719>0.</OEMDRO2719>
<OEMLED2719>0</OEMLED2719>
<OEMDRO2720>0.</OEMDRO2720>
<OEMLED2720>0</OEMLED2720>
<OEMDRO2721>0.</OEMDRO2721>
<OEMLED2721>0</OEMLED2721>
<OEMDRO2722>0.</OEMDRO2722>
<OEMLED2722>0</OEMLED2722>
<OEMDRO2723>0.</OEMDRO2723>
<OEMLED2723>0</OEMLED2723>
<OEMDRO2724>0.</OEMDRO2724>
<OEMLED2724>0</OEMLED2724>
<OEMDRO2725>0.</OEMDRO2725>
<OEMLED2725>0</OEMLED2725>
<OEMDRO2726>0.</OEMDRO2726>
<OEMLED2726>0</OEMLED2726>
<OEMDRO2727>0.</OEMDRO2727>
<OEMLED2727>0</OEMLED2727>
<OEMDRO2728>0.</OEMDRO2728>
<OEMLED2728>0</OEMLED2728>
<OEMDRO2729>0.</OEMDRO2729>
<OEMLED2729>0</OEMLED2729>
<OEMDRO2730>0.</OEMDRO2730>
<OEMLED2730>0</OEMLED2730>
<OEMDRO2731>0.</OEMDRO2731>
<OEMLED2731>0</OEMLED2731>
<OEMDRO2732>0.</OEMDRO2732>
<OEMLED2732>0</OEMLED2732>
<OEMDRO2733>0.</OEMDRO2733>
<OEMLED2733>0</OEMLED2733>
<OEMDRO2734>0.</OEMDRO2734>
<OEMLED2734>0</OEMLED2734>
<OEMDRO2735>0.</OEMDRO2735>
<OEMLED2735>0</OEMLED2735>
<OEMDRO2736>0.</OEMDRO2736>
<OEMLED2736>0</OEMLED2736>
<OEMDRO2737>0.</OEMDRO2737>
<OEMLED2737>0</OEMLED2737>
<OEMDRO2738>0.</OEMDRO2738>
<OEMLED2738>0</OEMLED2738>
<OEMDRO2739>0.</OEMDRO2739>
<OEMLED2739>0</OEMLED2739>
<OEMDRO2740>0.</OEMDRO2740>
<OEMLED2740>0</OEMLED2740>
<OEMDRO2741>0.</OEMDRO2741>
<OEMLED2741>0</OEMLED2741>
<OEMDRO2742>0.</OEMDRO2742>
<OEMLED2742>0</OEMLED2742>
<OEMDRO2743>0.</OEMDRO2743>
<OEMLED2743>0</OEMLED2743>
<OEMDRO2744>0.</OEMDRO2744>
<OEMLED2744>0</OEMLED2744>
<OEMDRO2745>0.</OEMDRO2745>
<OEMLED2745>0</OEMLED2745>
<OEMDRO2746>0.</OEMDRO2746>
<OEMLED2746>0</OEMLED2746>
<OEMDRO2747>0.</OEMDRO2747>
<OEMLED2747>0</OEMLED2747>
<OEMDRO2748>0.</OEMDRO2748>
<OEMLED2748>0</OEMLED2748>
<OEMDRO2749>0.</OEMDRO2749>
<OEMLED2749>0</OEMLED2749>
<OEMDRO2750>0.</OEMDRO2750>
<OEMLED2750>0</OEMLED2750>
<OEMDRO2751>0.</OEMDRO2751>
<OEMLED2751>0</OEMLED2751>
<OEMDRO2752>0.</OEMDRO2752>
<OEMLED2752>0</OEMLED2752>
<OEMDRO2753>0.</OEMDRO2753>
<OEMLED2753>0</OEMLED2753>
<OEMDRO2754>0.</OEMDRO2754>
<OEMLED2754>0</OEMLED2754>
<OEMDRO2755>0.</OEMDRO2755>
<OEMLED2755>0</OEMLED2755>
<OEMDRO2756>0.</OEMDRO2756>
<OEMLED2756>0</OEMLED2756>
<OEMDRO2757>0.</OEMDRO2757>
<OEMLED2757>0</OEMLED2757>
<OEMDRO2758>0.</OEMDRO2758>
<OEMLED2758>0</OEMLED2758>
<OEMDRO2759>0.</OEMDRO2759>
<OEMLED2759>0</OEMLED2759>
<OEMDRO2760>0.</OEMDRO2760>
<OEMLED2760>0</OEMLED2760>
<OEMDRO2761>0.</OEMDRO2761>
<OEMLED2761>0</OEMLED2761>
<OEMDRO2762>0.</OEMDRO2762>
<OEMLED2762>0</OEMLED2762>
<OEMDRO2763>0.</OEMDRO2763>
<OEMLED2763>0</OEMLED2763>
<OEMDRO2764>0.</OEMDRO2764>
<OEMLED2764>0</OEMLED2764>
<OEMDRO2765>0.</OEMDRO2765>
<OEMLED2765>0</OEMLED2765>
<OEMDRO2766>0.</OEMDRO2766>
<OEMLED2766>0</OEMLED2766>
<OEMDRO2767>0.</OEMDRO2767>
<OEMLED2767>0</OEMLED2767>
<OEMDRO2768>0.</OEMDRO2768>
<OEMLED2768>0</OEMLED2768>
<OEMDRO2769>0.</OEMDRO2769>
<OEMLED2769>0</OEMLED2769>
<OEMDRO2770>0.</OEMDRO2770>
<OEMLED2770>0</OEMLED2770>
<OEMDRO2771>0.</OEMDRO2771>
<OEMLED2771>0</OEMLED2771>
<OEMDRO2772>0.</OEMDRO2772>
<OEMLED2772>0</OEMLED2772>
<OEMDRO2773>0.</OEMDRO2773>
<OEMLED2773>0</OEMLED2773>
<OEMDRO2774>0.</OEMDRO2774>
<OEMLED2774>0</OEMLED2774>
<OEMDRO2775>0.</OEMDRO2775>
<OEMLED2775>0</OEMLED2775>
<OEMDRO2776>0.</OEMDRO2776>
<OEMLED2776>0</OEMLED2776>
<OEMDRO2777>0.</OEMDRO2777>
<OEMLED2777>0</OEMLED2777>
<OEMDRO2778>0.</OEMDRO2778>
<OEMLED2778>0</OEMLED2778>
<OEMDRO2779>0.</OEMDRO2779>
<OEMLED2779>0</OEMLED2779>
<OEMDRO2780>0.</OEMDRO2780>
<OEMLED2780>0</OEMLED2780>
<OEMDRO2781>0.</OEMDRO2781>
<OEMLED2781>0</OEMLED2781>
<OEMDRO2782>0.</OEMDRO2782>
<OEMLED2782>0</OEMLED2782>
<OEMDRO2783>0.</OEMDRO2783>
<OEMLED2783>0</OEMLED2783>
<OEMDRO2784>0.</OEMDRO2784>
<OEMLED2784>0</OEMLED2784>
<OEMDRO2785>0.</OEMDRO2785>
<OEMLED2785>0</OEMLED2785>
<OEMDRO2786>0.</OEMDRO2786>
<OEMLED2786>0</OEMLED2786>
<OEMDRO2787>0.</OEMDRO2787>
<OEMLED2787>0</OEMLED2787>
<OEMDRO2788>0.</OEMDRO2788>
<OEMLED2788>0</OEMLED2788>
<OEMDRO2789>0.</OEMDRO2789>
<OEMLED2789>0</OEMLED2789>
<OEMDRO2790>0.</OEMDRO2790>
<OEMLED2790>0</OEMLED2790>
<OEMDRO2791>0.</OEMDRO2791>
<OEMLED2791>0</OEMLED2791>
<OEMDRO2792>0.</OEMDRO2792>
<OEMLED2792>0</OEMLED2792>
<OEMDRO2793>0.</OEMDRO2793>
<OEMLED2793>0</OEMLED2793>
<OEMDRO2794>0.</OEMDRO2794>
<OEMLED2794>0</OEMLED2794>
<OEMDRO2795>0.</OEMDRO2795>
<OEMLED2795>0</OEMLED2795>
<OEMDRO2796>0.</OEMDRO2796>
<OEMLED2796>0</OEMLED2796>
<OEMDRO2797>0.</OEMDRO2797>
<OEMLED2797>0</OEMLED2797>
<OEMDRO2798>0.</OEMDRO2798>
<OEMLED2798>0</OEMLED2798>
<OEMDRO2799>0.</OEMDRO2799>
<OEMLED2799>0</OEMLED2799>
<OEMDRO2800>0.</OEMDRO2800>
<OEMLED2800>0</OEMLED2800>
<OEMDRO2801>0.</OEMDRO2801>
<OEMLED2801>0</OEMLED2801>
<OEMDRO2802>0.</OEMDRO2802>
<OEMLED2802>0</OEMLED2802>
<OEMDRO2803>0.</OEMDRO2803>
<OEMLED2803>0</OEMLED2803>
<OEMDRO2804>0.</OEMDRO2804>
<OEMLED2804>0</OEMLED2804>
<OEMDRO2805>0.</OEMDRO2805>
<OEMLED2805>0</OEMLED2805>
<OEMDRO2806>0.</OEMDRO2806>
<OEMLED2806>0</OEMLED2806>
<OEMDRO2807>0.</OEMDRO2807>
<OEMLED2807>0</OEMLED2807>
<OEMDRO2808>0.</OEMDRO2808>
<OEMLED2808>0</OEMLED2808>
<OEMDRO2809>0.</OEMDRO2809>
<OEMLED2809>0</OEMLED2809>
<OEMDRO2810>0.</OEMDRO2810>
<OEMLED2810>0</OEMLED2810>
<OEMDRO2811>0.</OEMDRO2811>
<OEMLED2811>0</OEMLED2811>
<OEMDRO2812>0.</OEMDRO2812>
<OEMLED2812>0</OEMLED2812>
<OEMDRO2813>0.</OEMDRO2813>
<OEMLED2813>0</OEMLED2813>
<OEMDRO2814>0.</OEMDRO2814>
<OEMLED2814>0</OEMLED2814>
<OEMDRO2815>0.</OEMDRO2815>
<OEMLED2815>0</OEMLED2815>
<OEMDRO2816>0.</OEMDRO2816>
<OEMLED2816>0</OEMLED2816>
<OEMDRO2817>0.</OEMDRO2817>
<OEMLED2817>0</OEMLED2817>
<OEMDRO2818>0.</OEMDRO2818>
<OEMLED2818>0</OEMLED2818>
<OEMDRO2819>0.</OEMDRO2819>
<OEMLED2819>0</OEMLED2819>
<OEMDRO2820>0.</OEMDRO2820>
<OEMLED2820>0</OEMLED2820>
<OEMDRO2821>0.</OEMDRO2821>
<OEMLED2821>0</OEMLED2821>
<OEMDRO2822>0.</OEMDRO2822>
<OEMLED2822>0</OEMLED2822>
<OEMDRO2823>0.</OEMDRO2823>
<OEMLED2823>0</OEMLED2823>
<OEMDRO2824>0.</OEMDRO2824>
<OEMLED2824>0</OEMLED2824>
<OEMDRO2825>0.</OEMDRO2825>
<OEMLED2825>0</OEMLED2825>
<OEMDRO2826>0.</OEMDRO2826>
<OEMLED2826>0</OEMLED2826>
<OEMDRO2827>0.</OEMDRO2827>
<OEMLED2827>0</OEMLED2827>
<OEMDRO2828>0.</OEMDRO2828>
<OEMLED2828>0</OEMLED2828>
<OEMDRO2829>0.</OEMDRO2829>
<OEMLED2829>0</OEMLED2829>
<OEMDRO2830>0.</OEMDRO2830>
<OEMLED2830>0</OEMLED2830>
<OEMDRO2831>0.</OEMDRO2831>
<OEMLED2831>0</OEMLED2831>
<OEMDRO2832>0.</OEMDRO2832>
<OEMLED2832>0</OEMLED2832>
<OEMDRO2833>0.</OEMDRO2833>
<OEMLED2833>0</OEMLED2833>
<OEMDRO2834>0.</OEMDRO2834>
<OEMLED2834>0</OEMLED2834>
<OEMDRO2835>0.</OEMDRO2835>
<OEMLED2835>0</OEMLED2835>
<OEMDRO2836>0.</OEMDRO2836>
<OEMLED2836>0</OEMLED2836>
<OEMDRO2837>0.</OEMDRO2837>
<OEMLED2837>0</OEMLED2837>
<OEMDRO2838>0.</OEMDRO2838>
<OEMLED2838>0</OEMLED2838>
<OEMDRO2839>0.</OEMDRO2839>
<OEMLED2839>0</OEMLED2839>
<OEMDRO2840>0.</OEMDRO2840>
<OEMLED2840>0</OEMLED2840>
<OEMDRO2841>0.</OEMDRO2841>
<OEMLED2841>0</OEMLED2841>
<OEMDRO2842>0.</OEMDRO2842>
<OEMLED2842>0</OEMLED2842>
<OEMDRO2843>0.</OEMDRO2843>
<OEMLED2843>0</OEMLED2843>
<OEMDRO2844>0.</OEMDRO2844>
<OEMLED2844>0</OEMLED2844>
<OEMDRO2845>0.</OEMDRO2845>
<OEMLED2845>0</OEMLED2845>
<OEMDRO2846>0.</OEMDRO2846>
<OEMLED2846>0</OEMLED2846>
<OEMDRO2847>0.</OEMDRO2847>
<OEMLED2847>0</OEMLED2847>
<OEMDRO2848>0.</OEMDRO2848>
<OEMLED2848>0</OEMLED2848>
<OEMDRO2849>0.</OEMDRO2849>
<OEMLED2849>0</OEMLED2849>
<OEMDRO2850>0.</OEMDRO2850>
<OEMLED2850>0</OEMLED2850>
<OEMDRO2851>0.</OEMDRO2851>
<OEMLED2851>0</OEMLED2851>
<OEMDRO2852>0.</OEMDRO2852>
<OEMLED2852>0</OEMLED2852>
<OEMDRO2853>0.</OEMDRO2853>
<OEMLED2853>0</OEMLED2853>
<OEMDRO2854>0.</OEMDRO2854>
<OEMLED2854>0</OEMLED2854>
<OEMDRO2855>0.</OEMDRO2855>
<OEMLED2855>0</OEMLED2855>
<OEMDRO2856>0.</OEMDRO2856>
<OEMLED2856>0</OEMLED2856>
<OEMDRO2857>0.</OEMDRO2857>
<OEMLED2857>0</OEMLED2857>
<OEMDRO2858>0.</OEMDRO2858>
<OEMLED2858>0</OEMLED2858>
<OEMDRO2859>0.</OEMDRO2859>
<OEMLED2859>0</OEMLED2859>
<OEMDRO2860>0.</OEMDRO2860>
<OEMLED2860>0</OEMLED2860>
<OEMDRO2861>0.</OEMDRO2861>
<OEMLED2861>0</OEMLED2861>
<OEMDRO2862>0.</OEMDRO2862>
<OEMLED2862>0</OEMLED2862>
<OEMDRO2863>0.</OEMDRO2863>
<OEMLED2863>0</OEMLED2863>
<OEMDRO2864>0.</OEMDRO2864>
<OEMLED2864>0</OEMLED2864>
<OEMDRO2865>0.</OEMDRO2865>
<OEMLED2865>0</OEMLED2865>
<OEMDRO2866>0.</OEMDRO2866>
<OEMLED2866>0</OEMLED2866>
<OEMDRO2867>0.</OEMDRO2867>
<OEMLED2867>0</OEMLED2867>
<OEMDRO2868>0.</OEMDRO2868>
<OEMLED2868>0</OEMLED2868>
<OEMDRO2869>0.</OEMDRO2869>
<OEMLED2869>0</OEMLED2869>
<OEMDRO2870>0.</OEMDRO2870>
<OEMLED2870>0</OEMLED2870>
<OEMDRO2871>0.</OEMDRO2871>
<OEMLED2871>0</OEMLED2871>
<OEMDRO2872>0.</OEMDRO2872>
<OEMLED2872>0</OEMLED2872>
<OEMDRO2873>0.</OEMDRO2873>
<OEMLED2873>0</OEMLED2873>
<OEMDRO2874>0.</OEMDRO2874>
<OEMLED2874>0</OEMLED2874>
<OEMDRO2875>0.</OEMDRO2875>
<OEMLED2875>0</OEMLED2875>
<OEMDRO2876>0.</OEMDRO2876>
<OEMLED2876>0</OEMLED2876>
<OEMDRO2877>0.</OEMDRO2877>
<OEMLED2877>0</OEMLED2877>
<OEMDRO2878>0.</OEMDRO2878>
<OEMLED2878>0</OEMLED2878>
<OEMDRO2879>0.</OEMDRO2879>
<OEMLED2879>0</OEMLED2879>
<OEMDRO2880>0.</OEMDRO2880>
<OEMLED2880>0</OEMLED2880>
<OEMDRO2881>0.</OEMDRO2881>
<OEMLED2881>0</OEMLED2881>
<OEMDRO2882>0.</OEMDRO2882>
<OEMLED2882>0</OEMLED2882>
<OEMDRO2883>0.</OEMDRO2883>
<OEMLED2883>0</OEMLED2883>
<OEMDRO2884>0.</OEMDRO2884>
<OEMLED2884>0</OEMLED2884>
<OEMDRO2885>0.</OEMDRO2885>
<OEMLED2885>0</OEMLED2885>
<OEMDRO2886>0.</OEMDRO2886>
<OEMLED2886>0</OEMLED2886>
<OEMDRO2887>0.</OEMDRO2887>
<OEMLED2887>0</OEMLED2887>
<OEMDRO2888>0.</OEMDRO2888>
<OEMLED2888>0</OEMLED2888>
<OEMDRO2889>0.</OEMDRO2889>
<OEMLED2889>0</OEMLED2889>
<OEMDRO2890>0.</OEMDRO2890>
<OEMLED2890>0</OEMLED2890>
<OEMDRO2891>0.</OEMDRO2891>
<OEMLED2891>0</OEMLED2891>
<OEMDRO2892>0.</OEMDRO2892>
<OEMLED2892>0</OEMLED2892>
<OEMDRO2893>0.</OEMDRO2893>
<OEMLED2893>0</OEMLED2893>
<OEMDRO2894>0.</OEMDRO2894>
<OEMLED2894>0</OEMLED2894>
<OEMDRO2895>0.</OEMDRO2895>
<OEMLED2895>0</OEMLED2895>
<OEMDRO2896>0.</OEMDRO2896>
<OEMLED2896>0</OEMLED2896>
<OEMDRO2897>0.</OEMDRO2897>
<OEMLED2897>0</OEMLED2897>
<OEMDRO2898>0.</OEMDRO2898>
<OEMLED2898>0</OEMLED2898>
<OEMDRO2899>0.</OEMDRO2899>
<OEMLED2899>0</OEMLED2899>
<OEMDRO2900>0.</OEMDRO2900>
<OEMLED2900>0</OEMLED2900>
<OEMDRO2901>0.</OEMDRO2901>
<OEMLED2901>0</OEMLED2901>
<OEMDRO2902>0.</OEMDRO2902>
<OEMLED2902>0</OEMLED2902>
<OEMDRO2903>0.</OEMDRO2903>
<OEMLED2903>0</OEMLED2903>
<OEMDRO2904>0.</OEMDRO2904>
<OEMLED2904>0</OEMLED2904>
<OEMDRO2905>0.</OEMDRO2905>
<OEMLED2905>0</OEMLED2905>
<OEMDRO2906>0.</OEMDRO2906>
<OEMLED2906>0</OEMLED2906>
<OEMDRO2907>0.</OEMDRO2907>
<OEMLED2907>0</OEMLED2907>
<OEMDRO2908>0.</OEMDRO2908>
<OEMLED2908>0</OEMLED2908>
<OEMDRO2909>0.</OEMDRO2909>
<OEMLED2909>0</OEMLED2909>
<OEMDRO2910>0.</OEMDRO2910>
<OEMLED2910>0</OEMLED2910>
<OEMDRO2911>0.</OEMDRO2911>
<OEMLED2911>0</OEMLED2911>
<OEMDRO2912>0.</OEMDRO2912>
<OEMLED2912>0</OEMLED2912>
<OEMDRO2913>0.</OEMDRO2913>
<OEMLED2913>0</OEMLED2913>
<OEMDRO2914>0.</OEMDRO2914>
<OEMLED2914>0</OEMLED2914>
<OEMDRO2915>0.</OEMDRO2915>
<OEMLED2915>0</OEMLED2915>
<OEMDRO2916>0.</OEMDRO2916>
<OEMLED2916>0</OEMLED2916>
<OEMDRO2917>0.</OEMDRO2917>
<OEMLED2917>0</OEMLED2917>
<OEMDRO2918>0.</OEMDRO2918>
<OEMLED2918>0</OEMLED2918>
<OEMDRO2919>0.</OEMDRO2919>
<OEMLED2919>0</OEMLED2919>
<OEMDRO2920>0.</OEMDRO2920>
<OEMLED2920>0</OEMLED2920>
<OEMDRO2921>0.</OEMDRO2921>
<OEMLED2921>0</OEMLED2921>
<OEMDRO2922>0.</OEMDRO2922>
<OEMLED2922>0</OEMLED2922>
<OEMDRO2923>0.</OEMDRO2923>
<OEMLED2923>0</OEMLED2923>
<OEMDRO2924>0.</OEMDRO2924>
<OEMLED2924>0</OEMLED2924>
<OEMDRO2925>0.</OEMDRO2925>
<OEMLED2925>0</OEMLED2925>
<OEMDRO2926>0.</OEMDRO2926>
<OEMLED2926>0</OEMLED2926>
<OEMDRO2927>0.</OEMDRO2927>
<OEMLED2927>0</OEMLED2927>
<OEMDRO2928>0.</OEMDRO2928>
<OEMLED2928>0</OEMLED2928>
<OEMDRO2929>0.</OEMDRO2929>
<OEMLED2929>0</OEMLED2929>
<OEMDRO2930>0.</OEMDRO2930>
<OEMLED2930>0</OEMLED2930>
<OEMDRO2931>0.</OEMDRO2931>
<OEMLED2931>0</OEMLED2931>
<OEMDRO2932>0.</OEMDRO2932>
<OEMLED2932>0</OEMLED2932>
<OEMDRO2933>0.</OEMDRO2933>
<OEMLED2933>0</OEMLED2933>
<OEMDRO2934>0.</OEMDRO2934>
<OEMLED2934>0</OEMLED2934>
<OEMDRO2935>0.</OEMDRO2935>
<OEMLED2935>0</OEMLED2935>
<OEMDRO2936>0.</OEMDRO2936>
<OEMLED2936>0</OEMLED2936>
<OEMDRO2937>0.</OEMDRO2937>
<OEMLED2937>0</OEMLED2937>
<OEMDRO2938>0.</OEMDRO2938>
<OEMLED2938>0</OEMLED2938>
<OEMDRO2939>0.</OEMDRO2939>
<OEMLED2939>0</OEMLED2939>
<OEMDRO2940>0.</OEMDRO2940>
<OEMLED2940>0</OEMLED2940>
<OEMDRO2941>0.</OEMDRO2941>
<OEMLED2941>0</OEMLED2941>
<OEMDRO2942>0.</OEMDRO2942>
<OEMLED2942>0</OEMLED2942>
<OEMDRO2943>0.</OEMDRO2943>
<OEMLED2943>0</OEMLED2943>
<OEMDRO2944>0.</OEMDRO2944>
<OEMLED2944>0</OEMLED2944>
<OEMDRO2945>0.</OEMDRO2945>
<OEMLED2945>0</OEMLED2945>
<OEMDRO2946>0.</OEMDRO2946>
<OEMLED2946>0</OEMLED2946>
<OEMDRO2947>0.</OEMDRO2947>
<OEMLED2947>0</OEMLED2947>
<OEMDRO2948>0.</OEMDRO2948>
<OEMLED2948>0</OEMLED2948>
<OEMDRO2949>0.</OEMDRO2949>
<OEMLED2949>0</OEMLED2949>
<OEMDRO2950>0.</OEMDRO2950>
<OEMLED2950>0</OEMLED2950>
<OEMDRO2951>0.</OEMDRO2951>
<OEMLED2951>0</OEMLED2951>
<OEMDRO2952>0.</OEMDRO2952>
<OEMLED2952>0</OEMLED2952>
<OEMDRO2953>0.</OEMDRO2953>
<OEMLED2953>0</OEMLED2953>
<OEMDRO2954>0.</OEMDRO2954>
<OEMLED2954>0</OEMLED2954>
<OEMDRO2955>0.</OEMDRO2955>
<OEMLED2955>0</OEMLED2955>
<OEMDRO2956>0.</OEMDRO2956>
<OEMLED2956>0</OEMLED2956>
<OEMDRO2957>0.</OEMDRO2957>
<OEMLED2957>0</OEMLED2957>
<OEMDRO2958>0.</OEMDRO2958>
<OEMLED2958>0</OEMLED2958>
<OEMDRO2959>0.</OEMDRO2959>
<OEMLED2959>0</OEMLED2959>
<OEMDRO2960>0.</OEMDRO2960>
<OEMLED2960>0</OEMLED2960>
<OEMDRO2961>0.</OEMDRO2961>
<OEMLED2961>0</OEMLED2961>
<OEMDRO2962>0.</OEMDRO2962>
<OEMLED2962>0</OEMLED2962>
<OEMDRO2963>0.</OEMDRO2963>
<OEMLED2963>0</OEMLED2963>
<OEMDRO2964>0.</OEMDRO2964>
<OEMLED2964>0</OEMLED2964>
<OEMDRO2965>0.</OEMDRO2965>
<OEMLED2965>0</OEMLED2965>
<OEMDRO2966>0.</OEMDRO2966>
<OEMLED2966>0</OEMLED2966>
<OEMDRO2967>0.</OEMDRO2967>
<OEMLED2967>0</OEMLED2967>
<OEMDRO2968>0.</OEMDRO2968>
<OEMLED2968>0</OEMLED2968>
<OEMDRO2969>0.</OEMDRO2969>
<OEMLED2969>0</OEMLED2969>
<OEMDRO2970>0.</OEMDRO2970>
<OEMLED2970>0</OEMLED2970>
<OEMDRO2971>0.</OEMDRO2971>
<OEMLED2971>0</OEMLED2971>
<OEMDRO2972>0.</OEMDRO2972>
<OEMLED2972>0</OEMLED2972>
<OEMDRO2973>0.</OEMDRO2973>
<OEMLED2973>0</OEMLED2973>
<OEMDRO2974>0.</OEMDRO2974>
<OEMLED2974>0</OEMLED2974>
<OEMDRO2975>0.</OEMDRO2975>
<OEMLED2975>0</OEMLED2975>
<OEMDRO2976>0.</OEMDRO2976>
<OEMLED2976>0</OEMLED2976>
<OEMDRO2977>0.</OEMDRO2977>
<OEMLED2977>0</OEMLED2977>
<OEMDRO2978>0.</OEMDRO2978>
<OEMLED2978>0</OEMLED2978>
<OEMDRO2979>0.</OEMDRO2979>
<OEMLED2979>0</OEMLED2979>
<OEMDRO2980>0.</OEMDRO2980>
<OEMLED2980>0</OEMLED2980>
<OEMDRO2981>0.</OEMDRO2981>
<OEMLED2981>0</OEMLED2981>
<OEMDRO2982>0.</OEMDRO2982>
<OEMLED2982>0</OEMLED2982>
<OEMDRO2983>0.</OEMDRO2983>
<OEMLED2983>0</OEMLED2983>
<OEMDRO2984>0.</OEMDRO2984>
<OEMLED2984>0</OEMLED2984>
<OEMDRO2985>0.</OEMDRO2985>
<OEMLED2985>0</OEMLED2985>
<OEMDRO2986>0.</OEMDRO2986>
<OEMLED2986>0</OEMLED2986>
<OEMDRO2987>0.</OEMDRO2987>
<OEMLED2987>0</OEMLED2987>
<OEMDRO2988>0.</OEMDRO2988>
<OEMLED2988>0</OEMLED2988>
<OEMDRO2989>0.</OEMDRO2989>
<OEMLED2989>0</OEMLED2989>
<OEMDRO2990>0.</OEMDRO2990>
<OEMLED2990>0</OEMLED2990>
<OEMDRO2991>0.</OEMDRO2991>
<OEMLED2991>0</OEMLED2991>
<OEMDRO2992>0.</OEMDRO2992>
<OEMLED2992>0</OEMLED2992>
<OEMDRO2993>0.</OEMDRO2993>
<OEMLED2993>0</OEMLED2993>
<OEMDRO2994>0.</OEMDRO2994>
<OEMLED2994>0</OEMLED2994>
<OEMDRO2995>0.</OEMDRO2995>
<OEMLED2995>0</OEMLED2995>
<OEMDRO2996>0.</OEMDRO2996>
<OEMLED2996>0</OEMLED2996>
<OEMDRO2997>0.</OEMDRO2997>
<OEMLED2997>0</OEMLED2997>
<OEMDRO2998>0.</OEMDRO2998>
<OEMLED2998>0</OEMLED2998>
<OEMDRO2999>0.</OEMDRO2999>
<OEMLED2999>0</OEMLED2999>
<Slave0>3</Slave0>
<Slave1>0</Slave1>
<Slave2>3</Slave2>
<OEMDRO2_0>0.</OEMDRO2_0>
<OEMLED2_0>0</OEMLED2_0>
<OEMDRO2_1>0.</OEMDRO2_1>
<OEMLED2_1>0</OEMLED2_1>
<OEMDRO2_2>0.</OEMDRO2_2>
<OEMLED2_2>0</OEMLED2_2>
<OEMDRO2_3>0.</OEMDRO2_3>
<OEMLED2_3>0</OEMLED2_3>
<OEMDRO2_4>0.</OEMDRO2_4>
<OEMLED2_4>0</OEMLED2_4>
<OEMDRO2_5>0.</OEMDRO2_5>
<OEMLED2_5>0</OEMLED2_5>
<OEMDRO2_6>0.</OEMDRO2_6>
<OEMLED2_6>0</OEMLED2_6>
<OEMDRO2_7>0.</OEMDRO2_7>
<OEMLED2_7>0</OEMLED2_7>
<OEMDRO2_8>0.</OEMDRO2_8>
<OEMLED2_8>0</OEMLED2_8>
<OEMDRO2_9>0.</OEMDRO2_9>
<OEMLED2_9>0</OEMLED2_9>
<OEMDRO2_10>0.</OEMDRO2_10>
<OEMLED2_10>0</OEMLED2_10>
<OEMDRO2_11>0.</OEMDRO2_11>
<OEMLED2_11>0</OEMLED2_11>
<OEMDRO2_12>0.</OEMDRO2_12>
<OEMLED2_12>0</OEMLED2_12>
<OEMDRO2_13>0.</OEMDRO2_13>
<OEMLED2_13>0</OEMLED2_13>
<OEMDRO2_14>0.</OEMDRO2_14>
<OEMLED2_14>0</OEMLED2_14>
<OEMDRO2_15>0.</OEMDRO2_15>
<OEMLED2_15>0</OEMLED2_15>
<OEMDRO2_16>0.</OEMDRO2_16>
<OEMLED2_16>0</OEMLED2_16>
<OEMDRO2_17>0.</OEMDRO2_17>
<OEMLED2_17>0</OEMLED2_17>
<OEMDRO2_18>0.</OEMDRO2_18>
<OEMLED2_18>0</OEMLED2_18>
<OEMDRO2_19>0.</OEMDRO2_19>
<OEMLED2_19>0</OEMLED2_19>
<OEMDRO2_20>0.</OEMDRO2_20>
<OEMLED2_20>0</OEMLED2_20>
<OEMDRO2_21>0.</OEMDRO2_21>
<OEMLED2_21>0</OEMLED2_21>
<OEMDRO2_22>0.</OEMDRO2_22>
<OEMLED2_22>0</OEMLED2_22>
<OEMDRO2_23>0.</OEMDRO2_23>
<OEMLED2_23>0</OEMLED2_23>
<OEMDRO2_24>0.</OEMDRO2_24>
<OEMLED2_24>0</OEMLED2_24>
<OEMDRO2_25>0.</OEMDRO2_25>
<OEMLED2_25>0</OEMLED2_25>
<OEMDRO2_26>0.</OEMDRO2_26>
<OEMLED2_26>0</OEMLED2_26>
<OEMDRO2_27>0.</OEMDRO2_27>
<OEMLED2_27>0</OEMLED2_27>
<OEMDRO2_28>0.</OEMDRO2_28>
<OEMLED2_28>0</OEMLED2_28>
<OEMDRO2_29>0.</OEMDRO2_29>
<OEMLED2_29>0</OEMLED2_29>
<OEMDRO2_30>0.</OEMDRO2_30>
<OEMLED2_30>0</OEMLED2_30>
<OEMDRO2_31>0.</OEMDRO2_31>
<OEMLED2_31>0</OEMLED2_31>
<OEMDRO2_32>0.</OEMDRO2_32>
<OEMLED2_32>0</OEMLED2_32>
<OEMDRO2_33>0.</OEMDRO2_33>
<OEMLED2_33>0</OEMLED2_33>
<OEMDRO2_34>0.</OEMDRO2_34>
<OEMLED2_34>0</OEMLED2_34>
<OEMDRO2_35>0.</OEMDRO2_35>
<OEMLED2_35>0</OEMLED2_35>
<OEMDRO2_36>0.</OEMDRO2_36>
<OEMLED2_36>0</OEMLED2_36>
<OEMDRO2_37>0.</OEMDRO2_37>
<OEMLED2_37>0</OEMLED2_37>
<OEMDRO2_38>0.</OEMDRO2_38>
<OEMLED2_38>0</OEMLED2_38>
<OEMDRO2_39>0.</OEMDRO2_39>
<OEMLED2_39>0</OEMLED2_39>
<OEMDRO2_40>0.</OEMDRO2_40>
<OEMLED2_40>0</OEMLED2_40>
<OEMDRO2_41>0.</OEMDRO2_41>
<OEMLED2_41>0</OEMLED2_41>
<OEMDRO2_42>0.</OEMDRO2_42>
<OEMLED2_42>0</OEMLED2_42>
<OEMDRO2_43>0.</OEMDRO2_43>
<OEMLED2_43>0</OEMLED2_43>
<OEMDRO2_44>0.</OEMDRO2_44>
<OEMLED2_44>0</OEMLED2_44>
<OEMDRO2_45>0.</OEMDRO2_45>
<OEMLED2_45>0</OEMLED2_45>
<OEMDRO2_46>0.</OEMDRO2_46>
<OEMLED2_46>0</OEMLED2_46>
<OEMDRO2_47>0.</OEMDRO2_47>
<OEMLED2_47>0</OEMLED2_47>
<OEMDRO2_48>0.</OEMDRO2_48>
<OEMLED2_48>0</OEMLED2_48>
<OEMDRO2_49>0.</OEMDRO2_49>
<OEMLED2_49>0</OEMLED2_49>
<OEMDRO2_50>0.</OEMDRO2_50>
<OEMLED2_50>0</OEMLED2_50>
<OEMDRO2_51>0.</OEMDRO2_51>
<OEMLED2_51>0</OEMLED2_51>
<OEMDRO2_52>0.</OEMDRO2_52>
<OEMLED2_52>0</OEMLED2_52>
<OEMDRO2_53>0.</OEMDRO2_53>
<OEMLED2_53>0</OEMLED2_53>
<OEMDRO2_54>0.</OEMDRO2_54>
<OEMLED2_54>0</OEMLED2_54>
<OEMDRO2_55>0.</OEMDRO2_55>
<OEMLED2_55>0</OEMLED2_55>
<OEMDRO2_56>0.</OEMDRO2_56>
<OEMLED2_56>0</OEMLED2_56>
<OEMDRO2_57>0.</OEMDRO2_57>
<OEMLED2_57>0</OEMLED2_57>
<OEMDRO2_58>0.</OEMDRO2_58>
<OEMLED2_58>0</OEMLED2_58>
<OEMDRO2_59>0.</OEMDRO2_59>
<OEMLED2_59>0</OEMLED2_59>
<OEMDRO2_60>0.</OEMDRO2_60>
<OEMLED2_60>0</OEMLED2_60>
<OEMDRO2_61>0.</OEMDRO2_61>
<OEMLED2_61>0</OEMLED2_61>
<OEMDRO2_62>0.</OEMDRO2_62>
<OEMLED2_62>0</OEMLED2_62>
<OEMDRO2_63>0.</OEMDRO2_63>
<OEMLED2_63>0</OEMLED2_63>
<OEMDRO2_64>0.</OEMDRO2_64>
<OEMLED2_64>0</OEMLED2_64>
<OEMDRO2_65>0.</OEMDRO2_65>
<OEMLED2_65>0</OEMLED2_65>
<OEMDRO2_66>0.</OEMDRO2_66>
<OEMLED2_66>0</OEMLED2_66>
<OEMDRO2_67>0.</OEMDRO2_67>
<OEMLED2_67>0</OEMLED2_67>
<OEMDRO2_68>0.</OEMDRO2_68>
<OEMLED2_68>0</OEMLED2_68>
<OEMDRO2_69>0.</OEMDRO2_69>
<OEMLED2_69>0</OEMLED2_69>
<OEMDRO2_70>0.</OEMDRO2_70>
<OEMLED2_70>0</OEMLED2_70>
<OEMDRO2_71>0.</OEMDRO2_71>
<OEMLED2_71>0</OEMLED2_71>
<OEMDRO2_72>0.</OEMDRO2_72>
<OEMLED2_72>0</OEMLED2_72>
<OEMDRO2_73>0.</OEMDRO2_73>
<OEMLED2_73>0</OEMLED2_73>
<OEMDRO2_74>0.</OEMDRO2_74>
<OEMLED2_74>0</OEMLED2_74>
<OEMDRO2_75>0.</OEMDRO2_75>
<OEMLED2_75>0</OEMLED2_75>
<OEMDRO2_76>0.</OEMDRO2_76>
<OEMLED2_76>0</OEMLED2_76>
<OEMDRO2_77>0.</OEMDRO2_77>
<OEMLED2_77>0</OEMLED2_77>
<OEMDRO2_78>0.</OEMDRO2_78>
<OEMLED2_78>0</OEMLED2_78>
<OEMDRO2_79>0.</OEMDRO2_79>
<OEMLED2_79>0</OEMLED2_79>
<OEMDRO2_80>0.</OEMDRO2_80>
<OEMLED2_80>0</OEMLED2_80>
<OEMDRO2_81>0.</OEMDRO2_81>
<OEMLED2_81>0</OEMLED2_81>
<OEMDRO2_82>0.</OEMDRO2_82>
<OEMLED2_82>0</OEMLED2_82>
<OEMDRO2_83>0.</OEMDRO2_83>
<OEMLED2_83>0</OEMLED2_83>
<OEMDRO2_84>0.</OEMDRO2_84>
<OEMLED2_84>0</OEMLED2_84>
<OEMDRO2_85>0.</OEMDRO2_85>
<OEMLED2_85>0</OEMLED2_85>
<OEMDRO2_86>0.</OEMDRO2_86>
<OEMLED2_86>0</OEMLED2_86>
<OEMDRO2_87>0.</OEMDRO2_87>
<OEMLED2_87>0</OEMLED2_87>
<OEMDRO2_88>0.</OEMDRO2_88>
<OEMLED2_88>0</OEMLED2_88>
<OEMDRO2_89>0.</OEMDRO2_89>
<OEMLED2_89>0</OEMLED2_89>
<OEMDRO2_90>0.</OEMDRO2_90>
<OEMLED2_90>0</OEMLED2_90>
<OEMDRO2_91>0.</OEMDRO2_91>
<OEMLED2_91>0</OEMLED2_91>
<OEMDRO2_92>0.</OEMDRO2_92>
<OEMLED2_92>0</OEMLED2_92>
<OEMDRO2_93>0.</OEMDRO2_93>
<OEMLED2_93>0</OEMLED2_93>
<OEMDRO2_94>0.</OEMDRO2_94>
<OEMLED2_94>0</OEMLED2_94>
<OEMDRO2_95>0.</OEMDRO2_95>
<OEMLED2_95>0</OEMLED2_95>
<OEMDRO2_96>0.</OEMDRO2_96>
<OEMLED2_96>0</OEMLED2_96>
<OEMDRO2_97>0.</OEMDRO2_97>
<OEMLED2_97>0</OEMLED2_97>
<OEMDRO2_98>0.</OEMDRO2_98>
<OEMLED2_98>0</OEMLED2_98>
<OEMDRO2_99>0.</OEMDRO2_99>
<OEMLED2_99>0</OEMLED2_99>
<OEMDRO2_100>0.</OEMDRO2_100>
<OEMLED2_100>0</OEMLED2_100>
<OEMDRO2_101>0.</OEMDRO2_101>
<OEMLED2_101>0</OEMLED2_101>
<OEMDRO2_102>0.</OEMDRO2_102>
<OEMLED2_102>0</OEMLED2_102>
<OEMDRO2_103>0.</OEMDRO2_103>
<OEMLED2_103>0</OEMLED2_103>
<OEMDRO2_104>0.</OEMDRO2_104>
<OEMLED2_104>0</OEMLED2_104>
<OEMDRO2_105>0.</OEMDRO2_105>
<OEMLED2_105>0</OEMLED2_105>
<OEMDRO2_106>0.</OEMDRO2_106>
<OEMLED2_106>0</OEMLED2_106>
<OEMDRO2_107>0.</OEMDRO2_107>
<OEMLED2_107>0</OEMLED2_107>
<OEMDRO2_108>0.</OEMDRO2_108>
<OEMLED2_108>0</OEMLED2_108>
<OEMDRO2_109>0.</OEMDRO2_109>
<OEMLED2_109>0</OEMLED2_109>
<OEMDRO2_110>0.</OEMDRO2_110>
<OEMLED2_110>0</OEMLED2_110>
<OEMDRO2_111>0.</OEMDRO2_111>
<OEMLED2_111>0</OEMLED2_111>
<OEMDRO2_112>0.</OEMDRO2_112>
<OEMLED2_112>0</OEMLED2_112>
<OEMDRO2_113>0.</OEMDRO2_113>
<OEMLED2_113>0</OEMLED2_113>
<OEMDRO2_114>0.</OEMDRO2_114>
<OEMLED2_114>0</OEMLED2_114>
<OEMDRO2_115>0.</OEMDRO2_115>
<OEMLED2_115>0</OEMLED2_115>
<OEMDRO2_116>0.</OEMDRO2_116>
<OEMLED2_116>0</OEMLED2_116>
<OEMDRO2_117>0.</OEMDRO2_117>
<OEMLED2_117>0</OEMLED2_117>
<OEMDRO2_118>0.</OEMDRO2_118>
<OEMLED2_118>0</OEMLED2_118>
<OEMDRO2_119>0.</OEMDRO2_119>
<OEMLED2_119>0</OEMLED2_119>
<OEMDRO2_120>0.</OEMDRO2_120>
<OEMLED2_120>0</OEMLED2_120>
<OEMDRO2_121>0.</OEMDRO2_121>
<OEMLED2_121>0</OEMLED2_121>
<OEMDRO2_122>0.</OEMDRO2_122>
<OEMLED2_122>0</OEMLED2_122>
<OEMDRO2_123>0.</OEMDRO2_123>
<OEMLED2_123>0</OEMLED2_123>
<OEMDRO2_124>0.</OEMDRO2_124>
<OEMLED2_124>0</OEMLED2_124>
<OEMDRO2_125>0.</OEMDRO2_125>
<OEMLED2_125>0</OEMLED2_125>
<OEMDRO2_126>0.</OEMDRO2_126>
<OEMLED2_126>0</OEMLED2_126>
<OEMDRO2_127>0.</OEMDRO2_127>
<OEMLED2_127>0</OEMLED2_127>
<OEMDRO2_128>0.</OEMDRO2_128>
<OEMLED2_128>0</OEMLED2_128>
<OEMDRO2_129>0.</OEMDRO2_129>
<OEMLED2_129>0</OEMLED2_129>
<OEMDRO2_130>0.</OEMDRO2_130>
<OEMLED2_130>0</OEMLED2_130>
<OEMDRO2_131>0.</OEMDRO2_131>
<OEMLED2_131>0</OEMLED2_131>
<OEMDRO2_132>0.</OEMDRO2_132>
<OEMLED2_132>0</OEMLED2_132>
<OEMDRO2_133>0.</OEMDRO2_133>
<OEMLED2_133>0</OEMLED2_133>
<OEMDRO2_134>0.</OEMDRO2_134>
<OEMLED2_134>0</OEMLED2_134>
<OEMDRO2_135>0.</OEMDRO2_135>
<OEMLED2_135>0</OEMLED2_135>
<OEMDRO2_136>0.</OEMDRO2_136>
<OEMLED2_136>0</OEMLED2_136>
<OEMDRO2_137>0.</OEMDRO2_137>
<OEMLED2_137>0</OEMLED2_137>
<OEMDRO2_138>0.</OEMDRO2_138>
<OEMLED2_138>0</OEMLED2_138>
<OEMDRO2_139>0.</OEMDRO2_139>
<OEMLED2_139>0</OEMLED2_139>
<OEMDRO2_140>0.</OEMDRO2_140>
<OEMLED2_140>0</OEMLED2_140>
<OEMDRO2_141>0.</OEMDRO2_141>
<OEMLED2_141>0</OEMLED2_141>
<OEMDRO2_142>0.</OEMDRO2_142>
<OEMLED2_142>0</OEMLED2_142>
<OEMDRO2_143>0.</OEMDRO2_143>
<OEMLED2_143>0</OEMLED2_143>
<OEMDRO2_144>0.</OEMDRO2_144>
<OEMLED2_144>0</OEMLED2_144>
<OEMDRO2_145>0.</OEMDRO2_145>
<OEMLED2_145>0</OEMLED2_145>
<OEMDRO2_146>0.</OEMDRO2_146>
<OEMLED2_146>0</OEMLED2_146>
<OEMDRO2_147>0.</OEMDRO2_147>
<OEMLED2_147>0</OEMLED2_147>
<OEMDRO2_148>0.</OEMDRO2_148>
<OEMLED2_148>0</OEMLED2_148>
<OEMDRO2_149>0.</OEMDRO2_149>
<OEMLED2_149>0</OEMLED2_149>
<OEMDRO2_150>0.</OEMDRO2_150>
<OEMLED2_150>0</OEMLED2_150>
<OEMDRO2_151>0.</OEMDRO2_151>
<OEMLED2_151>0</OEMLED2_151>
<OEMDRO2_152>0.</OEMDRO2_152>
<OEMLED2_152>0</OEMLED2_152>
<OEMDRO2_153>0.</OEMDRO2_153>
<OEMLED2_153>0</OEMLED2_153>
<OEMDRO2_154>0.</OEMDRO2_154>
<OEMLED2_154>0</OEMLED2_154>
<OEMDRO2_155>0.</OEMDRO2_155>
<OEMLED2_155>0</OEMLED2_155>
<OEMDRO2_156>0.</OEMDRO2_156>
<OEMLED2_156>0</OEMLED2_156>
<OEMDRO2_157>0.</OEMDRO2_157>
<OEMLED2_157>0</OEMLED2_157>
<OEMDRO2_158>0.</OEMDRO2_158>
<OEMLED2_158>0</OEMLED2_158>
<OEMDRO2_159>0.</OEMDRO2_159>
<OEMLED2_159>0</OEMLED2_159>
<OEMDRO2_160>0.</OEMDRO2_160>
<OEMLED2_160>0</OEMLED2_160>
<OEMDRO2_161>0.</OEMDRO2_161>
<OEMLED2_161>0</OEMLED2_161>
<OEMDRO2_162>0.</OEMDRO2_162>
<OEMLED2_162>0</OEMLED2_162>
<OEMDRO2_163>0.</OEMDRO2_163>
<OEMLED2_163>0</OEMLED2_163>
<OEMDRO2_164>0.</OEMDRO2_164>
<OEMLED2_164>0</OEMLED2_164>
<OEMDRO2_165>0.</OEMDRO2_165>
<OEMLED2_165>0</OEMLED2_165>
<OEMDRO2_166>0.</OEMDRO2_166>
<OEMLED2_166>0</OEMLED2_166>
<OEMDRO2_167>0.</OEMDRO2_167>
<OEMLED2_167>0</OEMLED2_167>
<OEMDRO2_168>0.</OEMDRO2_168>
<OEMLED2_168>0</OEMLED2_168>
<OEMDRO2_169>0.</OEMDRO2_169>
<OEMLED2_169>0</OEMLED2_169>
<OEMDRO2_170>0.</OEMDRO2_170>
<OEMLED2_170>0</OEMLED2_170>
<OEMDRO2_171>0.</OEMDRO2_171>
<OEMLED2_171>0</OEMLED2_171>
<OEMDRO2_172>0.</OEMDRO2_172>
<OEMLED2_172>0</OEMLED2_172>
<OEMDRO2_173>0.</OEMDRO2_173>
<OEMLED2_173>0</OEMLED2_173>
<OEMDRO2_174>0.</OEMDRO2_174>
<OEMLED2_174>0</OEMLED2_174>
<OEMDRO2_175>0.</OEMDRO2_175>
<OEMLED2_175>0</OEMLED2_175>
<OEMDRO2_176>0.</OEMDRO2_176>
<OEMLED2_176>0</OEMLED2_176>
<OEMDRO2_177>0.</OEMDRO2_177>
<OEMLED2_177>0</OEMLED2_177>
<OEMDRO2_178>0.</OEMDRO2_178>
<OEMLED2_178>0</OEMLED2_178>
<OEMDRO2_179>0.</OEMDRO2_179>
<OEMLED2_179>0</OEMLED2_179>
<OEMDRO2_180>0.</OEMDRO2_180>
<OEMLED2_180>0</OEMLED2_180>
<OEMDRO2_181>0.</OEMDRO2_181>
<OEMLED2_181>0</OEMLED2_181>
<OEMDRO2_182>0.</OEMDRO2_182>
<OEMLED2_182>0</OEMLED2_182>
<OEMDRO2_183>0.</OEMDRO2_183>
<OEMLED2_183>0</OEMLED2_183>
<OEMDRO2_184>0.</OEMDRO2_184>
<OEMLED2_184>0</OEMLED2_184>
<OEMDRO2_185>0.</OEMDRO2_185>
<OEMLED2_185>0</OEMLED2_185>
<OEMDRO2_186>0.</OEMDRO2_186>
<OEMLED2_186>0</OEMLED2_186>
<OEMDRO2_187>0.</OEMDRO2_187>
<OEMLED2_187>0</OEMLED2_187>
<OEMDRO2_188>0.</OEMDRO2_188>
<OEMLED2_188>0</OEMLED2_188>
<OEMDRO2_189>0.</OEMDRO2_189>
<OEMLED2_189>0</OEMLED2_189>
<OEMDRO2_190>0.</OEMDRO2_190>
<OEMLED2_190>0</OEMLED2_190>
<OEMDRO2_191>0.</OEMDRO2_191>
<OEMLED2_191>0</OEMLED2_191>
<OEMDRO2_192>0.</OEMDRO2_192>
<OEMLED2_192>0</OEMLED2_192>
<OEMDRO2_193>0.</OEMDRO2_193>
<OEMLED2_193>0</OEMLED2_193>
<OEMDRO2_194>0.</OEMDRO2_194>
<OEMLED2_194>0</OEMLED2_194>
<OEMDRO2_195>0.</OEMDRO2_195>
<OEMLED2_195>0</OEMLED2_195>
<OEMDRO2_196>0.</OEMDRO2_196>
<OEMLED2_196>0</OEMLED2_196>
<OEMDRO2_197>0.</OEMDRO2_197>
<OEMLED2_197>0</OEMLED2_197>
<OEMDRO2_198>0.</OEMDRO2_198>
<OEMLED2_198>0</OEMLED2_198>
<OEMDRO2_199>0.</OEMDRO2_199>
<OEMLED2_199>0</OEMLED2_199>
<OEMDRO2_200>0.</OEMDRO2_200>
<OEMLED2_200>0</OEMLED2_200>
<OEMDRO2_201>0.</OEMDRO2_201>
<OEMLED2_201>0</OEMLED2_201>
<OEMDRO2_202>0.</OEMDRO2_202>
<OEMLED2_202>0</OEMLED2_202>
<OEMDRO2_203>0.</OEMDRO2_203>
<OEMLED2_203>0</OEMLED2_203>
<OEMDRO2_204>0.</OEMDRO2_204>
<OEMLED2_204>0</OEMLED2_204>
<OEMDRO2_205>0.</OEMDRO2_205>
<OEMLED2_205>0</OEMLED2_205>
<OEMDRO2_206>0.</OEMDRO2_206>
<OEMLED2_206>0</OEMLED2_206>
<OEMDRO2_207>0.</OEMDRO2_207>
<OEMLED2_207>0</OEMLED2_207>
<OEMDRO2_208>0.</OEMDRO2_208>
<OEMLED2_208>0</OEMLED2_208>
<OEMDRO2_209>0.</OEMDRO2_209>
<OEMLED2_209>0</OEMLED2_209>
<OEMDRO2_210>0.</OEMDRO2_210>
<OEMLED2_210>0</OEMLED2_210>
<OEMDRO2_211>0.</OEMDRO2_211>
<OEMLED2_211>0</OEMLED2_211>
<OEMDRO2_212>0.</OEMDRO2_212>
<OEMLED2_212>0</OEMLED2_212>
<OEMDRO2_213>0.</OEMDRO2_213>
<OEMLED2_213>0</OEMLED2_213>
<OEMDRO2_214>0.</OEMDRO2_214>
<OEMLED2_214>0</OEMLED2_214>
<OEMDRO2_215>0.</OEMDRO2_215>
<OEMLED2_215>0</OEMLED2_215>
<OEMDRO2_216>0.</OEMDRO2_216>
<OEMLED2_216>0</OEMLED2_216>
<OEMDRO2_217>0.</OEMDRO2_217>
<OEMLED2_217>0</OEMLED2_217>
<OEMDRO2_218>0.</OEMDRO2_218>
<OEMLED2_218>0</OEMLED2_218>
<OEMDRO2_219>0.</OEMDRO2_219>
<OEMLED2_219>0</OEMLED2_219>
<OEMDRO2_220>0.</OEMDRO2_220>
<OEMLED2_220>0</OEMLED2_220>
<OEMDRO2_221>0.</OEMDRO2_221>
<OEMLED2_221>0</OEMLED2_221>
<OEMDRO2_222>0.</OEMDRO2_222>
<OEMLED2_222>0</OEMLED2_222>
<OEMDRO2_223>0.</OEMDRO2_223>
<OEMLED2_223>0</OEMLED2_223>
<OEMDRO2_224>0.</OEMDRO2_224>
<OEMLED2_224>0</OEMLED2_224>
<OEMDRO2_225>0.</OEMDRO2_225>
<OEMLED2_225>0</OEMLED2_225>
<OEMDRO2_226>0.</OEMDRO2_226>
<OEMLED2_226>0</OEMLED2_226>
<OEMDRO2_227>0.</OEMDRO2_227>
<OEMLED2_227>0</OEMLED2_227>
<OEMDRO2_228>0.</OEMDRO2_228>
<OEMLED2_228>0</OEMLED2_228>
<OEMDRO2_229>0.</OEMDRO2_229>
<OEMLED2_229>0</OEMLED2_229>
<OEMDRO2_230>0.</OEMDRO2_230>
<OEMLED2_230>0</OEMLED2_230>
<OEMDRO2_231>0.</OEMDRO2_231>
<OEMLED2_231>0</OEMLED2_231>
<OEMDRO2_232>0.</OEMDRO2_232>
<OEMLED2_232>0</OEMLED2_232>
<OEMDRO2_233>0.</OEMDRO2_233>
<OEMLED2_233>0</OEMLED2_233>
<OEMDRO2_234>0.</OEMDRO2_234>
<OEMLED2_234>0</OEMLED2_234>
<OEMDRO2_235>0.</OEMDRO2_235>
<OEMLED2_235>0</OEMLED2_235>
<OEMDRO2_236>0.</OEMDRO2_236>
<OEMLED2_236>0</OEMLED2_236>
<OEMDRO2_237>0.</OEMDRO2_237>
<OEMLED2_237>0</OEMLED2_237>
<OEMDRO2_238>0.</OEMDRO2_238>
<OEMLED2_238>0</OEMLED2_238>
<OEMDRO2_239>0.</OEMDRO2_239>
<OEMLED2_239>0</OEMLED2_239>
<OEMDRO2_240>0.</OEMDRO2_240>
<OEMLED2_240>0</OEMLED2_240>
<OEMDRO2_241>0.</OEMDRO2_241>
<OEMLED2_241>0</OEMLED2_241>
<OEMDRO2_242>0.</OEMDRO2_242>
<OEMLED2_242>0</OEMLED2_242>
<OEMDRO2_243>0.</OEMDRO2_243>
<OEMLED2_243>0</OEMLED2_243>
<OEMDRO2_244>0.</OEMDRO2_244>
<OEMLED2_244>0</OEMLED2_244>
<OEMDRO2_245>0.</OEMDRO2_245>
<OEMLED2_245>0</OEMLED2_245>
<OEMDRO2_246>0.</OEMDRO2_246>
<OEMLED2_246>0</OEMLED2_246>
<OEMDRO2_247>0.</OEMDRO2_247>
<OEMLED2_247>0</OEMLED2_247>
<OEMDRO2_248>0.</OEMDRO2_248>
<OEMLED2_248>0</OEMLED2_248>
<OEMDRO2_249>0.</OEMDRO2_249>
<OEMLED2_249>0</OEMLED2_249>
<OEMDRO2_250>0.</OEMDRO2_250>
<OEMLED2_250>0</OEMLED2_250>
<OEMDRO2_251>0.</OEMDRO2_251>
<OEMLED2_251>0</OEMLED2_251>
<OEMDRO2_252>0.</OEMDRO2_252>
<OEMLED2_252>0</OEMLED2_252>
<OEMDRO2_253>0.</OEMDRO2_253>
<OEMLED2_253>0</OEMLED2_253>
<OEMDRO2_254>0.</OEMDRO2_254>
<OEMLED2_254>0</OEMLED2_254>
<OEMDRO2_255>0.</OEMDRO2_255>
<OEMLED2_255>0</OEMLED2_255>
<OEMDRO2_256>0.</OEMDRO2_256>
<OEMLED2_256>0</OEMLED2_256>
<OEMDRO2_257>0.</OEMDRO2_257>
<OEMLED2_257>0</OEMLED2_257>
<OEMDRO2_258>0.</OEMDRO2_258>
<OEMLED2_258>0</OEMLED2_258>
<OEMDRO2_259>0.</OEMDRO2_259>
<OEMLED2_259>0</OEMLED2_259>
<OEMDRO2_260>0.</OEMDRO2_260>
<OEMLED2_260>0</OEMLED2_260>
<OEMDRO2_261>0.</OEMDRO2_261>
<OEMLED2_261>0</OEMLED2_261>
<OEMDRO2_262>0.</OEMDRO2_262>
<OEMLED2_262>0</OEMLED2_262>
<OEMDRO2_263>0.</OEMDRO2_263>
<OEMLED2_263>0</OEMLED2_263>
<OEMDRO2_264>0.</OEMDRO2_264>
<OEMLED2_264>0</OEMLED2_264>
<OEMDRO2_265>0.</OEMDRO2_265>
<OEMLED2_265>0</OEMLED2_265>
<OEMDRO2_266>0.</OEMDRO2_266>
<OEMLED2_266>0</OEMLED2_266>
<OEMDRO2_267>0.</OEMDRO2_267>
<OEMLED2_267>0</OEMLED2_267>
<OEMDRO2_268>0.</OEMDRO2_268>
<OEMLED2_268>0</OEMLED2_268>
<OEMDRO2_269>0.</OEMDRO2_269>
<OEMLED2_269>0</OEMLED2_269>
<OEMDRO2_270>0.</OEMDRO2_270>
<OEMLED2_270>0</OEMLED2_270>
<OEMDRO2_271>0.</OEMDRO2_271>
<OEMLED2_271>0</OEMLED2_271>
<OEMDRO2_272>0.</OEMDRO2_272>
<OEMLED2_272>0</OEMLED2_272>
<OEMDRO2_273>0.</OEMDRO2_273>
<OEMLED2_273>0</OEMLED2_273>
<OEMDRO2_274>0.</OEMDRO2_274>
<OEMLED2_274>0</OEMLED2_274>
<OEMDRO2_275>0.</OEMDRO2_275>
<OEMLED2_275>0</OEMLED2_275>
<OEMDRO2_276>0.</OEMDRO2_276>
<OEMLED2_276>0</OEMLED2_276>
<OEMDRO2_277>0.</OEMDRO2_277>
<OEMLED2_277>0</OEMLED2_277>
<OEMDRO2_278>0.</OEMDRO2_278>
<OEMLED2_278>0</OEMLED2_278>
<OEMDRO2_279>0.</OEMDRO2_279>
<OEMLED2_279>0</OEMLED2_279>
<OEMDRO2_280>0.</OEMDRO2_280>
<OEMLED2_280>0</OEMLED2_280>
<OEMDRO2_281>0.</OEMDRO2_281>
<OEMLED2_281>0</OEMLED2_281>
<OEMDRO2_282>0.</OEMDRO2_282>
<OEMLED2_282>0</OEMLED2_282>
<OEMDRO2_283>0.</OEMDRO2_283>
<OEMLED2_283>0</OEMLED2_283>
<OEMDRO2_284>0.</OEMDRO2_284>
<OEMLED2_284>0</OEMLED2_284>
<OEMDRO2_285>0.</OEMDRO2_285>
<OEMLED2_285>0</OEMLED2_285>
<OEMDRO2_286>0.</OEMDRO2_286>
<OEMLED2_286>0</OEMLED2_286>
<OEMDRO2_287>0.</OEMDRO2_287>
<OEMLED2_287>0</OEMLED2_287>
<OEMDRO2_288>0.</OEMDRO2_288>
<OEMLED2_288>0</OEMLED2_288>
<OEMDRO2_289>0.</OEMDRO2_289>
<OEMLED2_289>0</OEMLED2_289>
<OEMDRO2_290>0.</OEMDRO2_290>
<OEMLED2_290>0</OEMLED2_290>
<OEMDRO2_291>0.</OEMDRO2_291>
<OEMLED2_291>0</OEMLED2_291>
<OEMDRO2_292>0.</OEMDRO2_292>
<OEMLED2_292>0</OEMLED2_292>
<OEMDRO2_293>0.</OEMDRO2_293>
<OEMLED2_293>0</OEMLED2_293>
<OEMDRO2_294>0.</OEMDRO2_294>
<OEMLED2_294>0</OEMLED2_294>
<OEMDRO2_295>0.</OEMDRO2_295>
<OEMLED2_295>0</OEMLED2_295>
<OEMDRO2_296>0.</OEMDRO2_296>
<OEMLED2_296>0</OEMLED2_296>
<OEMDRO2_297>0.</OEMDRO2_297>
<OEMLED2_297>0</OEMLED2_297>
<OEMDRO2_298>0.</OEMDRO2_298>
<OEMLED2_298>0</OEMLED2_298>
<OEMDRO2_299>0.</OEMDRO2_299>
<OEMLED2_299>0</OEMLED2_299>
<OEMDRO2_300>0.</OEMDRO2_300>
<OEMLED2_300>0</OEMLED2_300>
<OEMDRO2_301>0.</OEMDRO2_301>
<OEMLED2_301>0</OEMLED2_301>
<OEMDRO2_302>0.</OEMDRO2_302>
<OEMLED2_302>0</OEMLED2_302>
<OEMDRO2_303>0.</OEMDRO2_303>
<OEMLED2_303>0</OEMLED2_303>
<OEMDRO2_304>0.</OEMDRO2_304>
<OEMLED2_304>0</OEMLED2_304>
<OEMDRO2_305>0.</OEMDRO2_305>
<OEMLED2_305>0</OEMLED2_305>
<OEMDRO2_306>0.</OEMDRO2_306>
<OEMLED2_306>0</OEMLED2_306>
<OEMDRO2_307>0.</OEMDRO2_307>
<OEMLED2_307>0</OEMLED2_307>
<OEMDRO2_308>0.</OEMDRO2_308>
<OEMLED2_308>0</OEMLED2_308>
<OEMDRO2_309>0.</OEMDRO2_309>
<OEMLED2_309>0</OEMLED2_309>
<OEMDRO2_310>0.</OEMDRO2_310>
<OEMLED2_310>0</OEMLED2_310>
<OEMDRO2_311>0.</OEMDRO2_311>
<OEMLED2_311>0</OEMLED2_311>
<OEMDRO2_312>0.</OEMDRO2_312>
<OEMLED2_312>0</OEMLED2_312>
<OEMDRO2_313>0.</OEMDRO2_313>
<OEMLED2_313>0</OEMLED2_313>
<OEMDRO2_314>0.</OEMDRO2_314>
<OEMLED2_314>0</OEMLED2_314>
<OEMDRO2_315>0.</OEMDRO2_315>
<OEMLED2_315>0</OEMLED2_315>
<OEMDRO2_316>0.</OEMDRO2_316>
<OEMLED2_316>0</OEMLED2_316>
<OEMDRO2_317>0.</OEMDRO2_317>
<OEMLED2_317>0</OEMLED2_317>
<OEMDRO2_318>0.</OEMDRO2_318>
<OEMLED2_318>0</OEMLED2_318>
<OEMDRO2_319>0.</OEMDRO2_319>
<OEMLED2_319>0</OEMLED2_319>
<OEMDRO2_320>0.</OEMDRO2_320>
<OEMLED2_320>0</OEMLED2_320>
<OEMDRO2_321>0.</OEMDRO2_321>
<OEMLED2_321>0</OEMLED2_321>
<OEMDRO2_322>0.</OEMDRO2_322>
<OEMLED2_322>0</OEMLED2_322>
<OEMDRO2_323>0.</OEMDRO2_323>
<OEMLED2_323>0</OEMLED2_323>
<OEMDRO2_324>0.</OEMDRO2_324>
<OEMLED2_324>0</OEMLED2_324>
<OEMDRO2_325>0.</OEMDRO2_325>
<OEMLED2_325>0</OEMLED2_325>
<OEMDRO2_326>0.</OEMDRO2_326>
<OEMLED2_326>0</OEMLED2_326>
<OEMDRO2_327>0.</OEMDRO2_327>
<OEMLED2_327>0</OEMLED2_327>
<OEMDRO2_328>0.</OEMDRO2_328>
<OEMLED2_328>0</OEMLED2_328>
<OEMDRO2_329>0.</OEMDRO2_329>
<OEMLED2_329>0</OEMLED2_329>
<OEMDRO2_330>0.</OEMDRO2_330>
<OEMLED2_330>0</OEMLED2_330>
<OEMDRO2_331>0.</OEMDRO2_331>
<OEMLED2_331>0</OEMLED2_331>
<OEMDRO2_332>0.</OEMDRO2_332>
<OEMLED2_332>0</OEMLED2_332>
<OEMDRO2_333>0.</OEMDRO2_333>
<OEMLED2_333>0</OEMLED2_333>
<OEMDRO2_334>0.</OEMDRO2_334>
<OEMLED2_334>0</OEMLED2_334>
<OEMDRO2_335>0.</OEMDRO2_335>
<OEMLED2_335>0</OEMLED2_335>
<OEMDRO2_336>0.</OEMDRO2_336>
<OEMLED2_336>0</OEMLED2_336>
<OEMDRO2_337>0.</OEMDRO2_337>
<OEMLED2_337>0</OEMLED2_337>
<OEMDRO2_338>0.</OEMDRO2_338>
<OEMLED2_338>0</OEMLED2_338>
<OEMDRO2_339>0.</OEMDRO2_339>
<OEMLED2_339>0</OEMLED2_339>
<OEMDRO2_340>0.</OEMDRO2_340>
<OEMLED2_340>0</OEMLED2_340>
<OEMDRO2_341>0.</OEMDRO2_341>
<OEMLED2_341>0</OEMLED2_341>
<OEMDRO2_342>0.</OEMDRO2_342>
<OEMLED2_342>0</OEMLED2_342>
<OEMDRO2_343>0.</OEMDRO2_343>
<OEMLED2_343>0</OEMLED2_343>
<OEMDRO2_344>0.</OEMDRO2_344>
<OEMLED2_344>0</OEMLED2_344>
<OEMDRO2_345>0.</OEMDRO2_345>
<OEMLED2_345>0</OEMLED2_345>
<OEMDRO2_346>0.</OEMDRO2_346>
<OEMLED2_346>0</OEMLED2_346>
<OEMDRO2_347>0.</OEMDRO2_347>
<OEMLED2_347>0</OEMLED2_347>
<OEMDRO2_348>0.</OEMDRO2_348>
<OEMLED2_348>0</OEMLED2_348>
<OEMDRO2_349>0.</OEMDRO2_349>
<OEMLED2_349>0</OEMLED2_349>
<OEMDRO2_350>0.</OEMDRO2_350>
<OEMLED2_350>0</OEMLED2_350>
<OEMDRO2_351>0.</OEMDRO2_351>
<OEMLED2_351>0</OEMLED2_351>
<OEMDRO2_352>0.</OEMDRO2_352>
<OEMLED2_352>0</OEMLED2_352>
<OEMDRO2_353>0.</OEMDRO2_353>
<OEMLED2_353>0</OEMLED2_353>
<OEMDRO2_354>0.</OEMDRO2_354>
<OEMLED2_354>0</OEMLED2_354>
<OEMDRO2_355>0.</OEMDRO2_355>
<OEMLED2_355>0</OEMLED2_355>
<OEMDRO2_356>0.</OEMDRO2_356>
<OEMLED2_356>0</OEMLED2_356>
<OEMDRO2_357>0.</OEMDRO2_357>
<OEMLED2_357>0</OEMLED2_357>
<OEMDRO2_358>0.</OEMDRO2_358>
<OEMLED2_358>0</OEMLED2_358>
<OEMDRO2_359>0.</OEMDRO2_359>
<OEMLED2_359>0</OEMLED2_359>
<OEMDRO2_360>0.</OEMDRO2_360>
<OEMLED2_360>0</OEMLED2_360>
<OEMDRO2_361>0.</OEMDRO2_361>
<OEMLED2_361>0</OEMLED2_361>
<OEMDRO2_362>0.</OEMDRO2_362>
<OEMLED2_362>0</OEMLED2_362>
<OEMDRO2_363>0.</OEMDRO2_363>
<OEMLED2_363>0</OEMLED2_363>
<OEMDRO2_364>0.</OEMDRO2_364>
<OEMLED2_364>0</OEMLED2_364>
<OEMDRO2_365>0.</OEMDRO2_365>
<OEMLED2_365>0</OEMLED2_365>
<OEMDRO2_366>0.</OEMDRO2_366>
<OEMLED2_366>0</OEMLED2_366>
<OEMDRO2_367>0.</OEMDRO2_367>
<OEMLED2_367>0</OEMLED2_367>
<OEMDRO2_368>0.</OEMDRO2_368>
<OEMLED2_368>0</OEMLED2_368>
<OEMDRO2_369>0.</OEMDRO2_369>
<OEMLED2_369>0</OEMLED2_369>
<OEMDRO2_370>0.</OEMDRO2_370>
<OEMLED2_370>0</OEMLED2_370>
<OEMDRO2_371>0.</OEMDRO2_371>
<OEMLED2_371>0</OEMLED2_371>
<OEMDRO2_372>0.</OEMDRO2_372>
<OEMLED2_372>0</OEMLED2_372>
<OEMDRO2_373>0.</OEMDRO2_373>
<OEMLED2_373>0</OEMLED2_373>
<OEMDRO2_374>0.</OEMDRO2_374>
<OEMLED2_374>0</OEMLED2_374>
<OEMDRO2_375>0.</OEMDRO2_375>
<OEMLED2_375>0</OEMLED2_375>
<OEMDRO2_376>0.</OEMDRO2_376>
<OEMLED2_376>0</OEMLED2_376>
<OEMDRO2_377>0.</OEMDRO2_377>
<OEMLED2_377>0</OEMLED2_377>
<OEMDRO2_378>0.</OEMDRO2_378>
<OEMLED2_378>0</OEMLED2_378>
<OEMDRO2_379>0.</OEMDRO2_379>
<OEMLED2_379>0</OEMLED2_379>
<OEMDRO2_380>0.</OEMDRO2_380>
<OEMLED2_380>0</OEMLED2_380>
<OEMDRO2_381>0.</OEMDRO2_381>
<OEMLED2_381>0</OEMLED2_381>
<OEMDRO2_382>0.</OEMDRO2_382>
<OEMLED2_382>0</OEMLED2_382>
<OEMDRO2_383>0.</OEMDRO2_383>
<OEMLED2_383>0</OEMLED2_383>
<OEMDRO2_384>0.</OEMDRO2_384>
<OEMLED2_384>0</OEMLED2_384>
<OEMDRO2_385>0.</OEMDRO2_385>
<OEMLED2_385>0</OEMLED2_385>
<OEMDRO2_386>0.</OEMDRO2_386>
<OEMLED2_386>0</OEMLED2_386>
<OEMDRO2_387>0.</OEMDRO2_387>
<OEMLED2_387>0</OEMLED2_387>
<OEMDRO2_388>0.</OEMDRO2_388>
<OEMLED2_388>0</OEMLED2_388>
<OEMDRO2_389>0.</OEMDRO2_389>
<OEMLED2_389>0</OEMLED2_389>
<OEMDRO2_390>0.</OEMDRO2_390>
<OEMLED2_390>0</OEMLED2_390>
<OEMDRO2_391>0.</OEMDRO2_391>
<OEMLED2_391>0</OEMLED2_391>
<OEMDRO2_392>0.</OEMDRO2_392>
<OEMLED2_392>0</OEMLED2_392>
<OEMDRO2_393>0.</OEMDRO2_393>
<OEMLED2_393>0</OEMLED2_393>
<OEMDRO2_394>0.</OEMDRO2_394>
<OEMLED2_394>0</OEMLED2_394>
<OEMDRO2_395>0.</OEMDRO2_395>
<OEMLED2_395>0</OEMLED2_395>
<OEMDRO2_396>0.</OEMDRO2_396>
<OEMLED2_396>0</OEMLED2_396>
<OEMDRO2_397>0.</OEMDRO2_397>
<OEMLED2_397>0</OEMLED2_397>
<OEMDRO2_398>0.</OEMDRO2_398>
<OEMLED2_398>0</OEMLED2_398>
<OEMDRO2_399>0.</OEMDRO2_399>
<OEMLED2_399>0</OEMLED2_399>
<OEMDRO2_400>0.</OEMDRO2_400>
<OEMLED2_400>0</OEMLED2_400>
<OEMDRO2_401>0.</OEMDRO2_401>
<OEMLED2_401>0</OEMLED2_401>
<OEMDRO2_402>0.</OEMDRO2_402>
<OEMLED2_402>0</OEMLED2_402>
<OEMDRO2_403>0.</OEMDRO2_403>
<OEMLED2_403>0</OEMLED2_403>
<OEMDRO2_404>0.</OEMDRO2_404>
<OEMLED2_404>0</OEMLED2_404>
<OEMDRO2_405>0.</OEMDRO2_405>
<OEMLED2_405>0</OEMLED2_405>
<OEMDRO2_406>0.</OEMDRO2_406>
<OEMLED2_406>0</OEMLED2_406>
<OEMDRO2_407>0.</OEMDRO2_407>
<OEMLED2_407>0</OEMLED2_407>
<OEMDRO2_408>0.</OEMDRO2_408>
<OEMLED2_408>0</OEMLED2_408>
<OEMDRO2_409>0.</OEMDRO2_409>
<OEMLED2_409>0</OEMLED2_409>
<OEMDRO2_410>0.</OEMDRO2_410>
<OEMLED2_410>0</OEMLED2_410>
<OEMDRO2_411>0.</OEMDRO2_411>
<OEMLED2_411>0</OEMLED2_411>
<OEMDRO2_412>0.</OEMDRO2_412>
<OEMLED2_412>0</OEMLED2_412>
<OEMDRO2_413>0.</OEMDRO2_413>
<OEMLED2_413>0</OEMLED2_413>
<OEMDRO2_414>0.</OEMDRO2_414>
<OEMLED2_414>0</OEMLED2_414>
<OEMDRO2_415>0.</OEMDRO2_415>
<OEMLED2_415>0</OEMLED2_415>
<OEMDRO2_416>0.</OEMDRO2_416>
<OEMLED2_416>0</OEMLED2_416>
<OEMDRO2_417>0.</OEMDRO2_417>
<OEMLED2_417>0</OEMLED2_417>
<OEMDRO2_418>0.</OEMDRO2_418>
<OEMLED2_418>0</OEMLED2_418>
<OEMDRO2_419>0.</OEMDRO2_419>
<OEMLED2_419>0</OEMLED2_419>
<OEMDRO2_420>0.</OEMDRO2_420>
<OEMLED2_420>0</OEMLED2_420>
<OEMDRO2_421>0.</OEMDRO2_421>
<OEMLED2_421>0</OEMLED2_421>
<OEMDRO2_422>0.</OEMDRO2_422>
<OEMLED2_422>0</OEMLED2_422>
<OEMDRO2_423>0.</OEMDRO2_423>
<OEMLED2_423>0</OEMLED2_423>
<OEMDRO2_424>0.</OEMDRO2_424>
<OEMLED2_424>0</OEMLED2_424>
<OEMDRO2_425>0.</OEMDRO2_425>
<OEMLED2_425>0</OEMLED2_425>
<OEMDRO2_426>0.</OEMDRO2_426>
<OEMLED2_426>0</OEMLED2_426>
<OEMDRO2_427>0.</OEMDRO2_427>
<OEMLED2_427>0</OEMLED2_427>
<OEMDRO2_428>0.</OEMDRO2_428>
<OEMLED2_428>0</OEMLED2_428>
<OEMDRO2_429>0.</OEMDRO2_429>
<OEMLED2_429>0</OEMLED2_429>
<OEMDRO2_430>0.</OEMDRO2_430>
<OEMLED2_430>0</OEMLED2_430>
<OEMDRO2_431>0.</OEMDRO2_431>
<OEMLED2_431>0</OEMLED2_431>
<OEMDRO2_432>0.</OEMDRO2_432>
<OEMLED2_432>0</OEMLED2_432>
<OEMDRO2_433>0.</OEMDRO2_433>
<OEMLED2_433>0</OEMLED2_433>
<OEMDRO2_434>0.</OEMDRO2_434>
<OEMLED2_434>0</OEMLED2_434>
<OEMDRO2_435>0.</OEMDRO2_435>
<OEMLED2_435>0</OEMLED2_435>
<OEMDRO2_436>0.</OEMDRO2_436>
<OEMLED2_436>0</OEMLED2_436>
<OEMDRO2_437>0.</OEMDRO2_437>
<OEMLED2_437>0</OEMLED2_437>
<OEMDRO2_438>0.</OEMDRO2_438>
<OEMLED2_438>0</OEMLED2_438>
<OEMDRO2_439>0.</OEMDRO2_439>
<OEMLED2_439>0</OEMLED2_439>
<OEMDRO2_440>0.</OEMDRO2_440>
<OEMLED2_440>0</OEMLED2_440>
<OEMDRO2_441>0.</OEMDRO2_441>
<OEMLED2_441>0</OEMLED2_441>
<OEMDRO2_442>0.</OEMDRO2_442>
<OEMLED2_442>0</OEMLED2_442>
<OEMDRO2_443>0.</OEMDRO2_443>
<OEMLED2_443>0</OEMLED2_443>
<OEMDRO2_444>0.</OEMDRO2_444>
<OEMLED2_444>0</OEMLED2_444>
<OEMDRO2_445>0.</OEMDRO2_445>
<OEMLED2_445>0</OEMLED2_445>
<OEMDRO2_446>0.</OEMDRO2_446>
<OEMLED2_446>0</OEMLED2_446>
<OEMDRO2_447>0.</OEMDRO2_447>
<OEMLED2_447>0</OEMLED2_447>
<OEMDRO2_448>0.</OEMDRO2_448>
<OEMLED2_448>0</OEMLED2_448>
<OEMDRO2_449>0.</OEMDRO2_449>
<OEMLED2_449>0</OEMLED2_449>
<OEMDRO2_450>0.</OEMDRO2_450>
<OEMLED2_450>0</OEMLED2_450>
<OEMDRO2_451>0.</OEMDRO2_451>
<OEMLED2_451>0</OEMLED2_451>
<OEMDRO2_452>0.</OEMDRO2_452>
<OEMLED2_452>0</OEMLED2_452>
<OEMDRO2_453>0.</OEMDRO2_453>
<OEMLED2_453>0</OEMLED2_453>
<OEMDRO2_454>0.</OEMDRO2_454>
<OEMLED2_454>0</OEMLED2_454>
<OEMDRO2_455>0.</OEMDRO2_455>
<OEMLED2_455>0</OEMLED2_455>
<OEMDRO2_456>0.</OEMDRO2_456>
<OEMLED2_456>0</OEMLED2_456>
<OEMDRO2_457>0.</OEMDRO2_457>
<OEMLED2_457>0</OEMLED2_457>
<OEMDRO2_458>0.</OEMDRO2_458>
<OEMLED2_458>0</OEMLED2_458>
<OEMDRO2_459>0.</OEMDRO2_459>
<OEMLED2_459>0</OEMLED2_459>
<OEMDRO2_460>0.</OEMDRO2_460>
<OEMLED2_460>0</OEMLED2_460>
<OEMDRO2_461>0.</OEMDRO2_461>
<OEMLED2_461>0</OEMLED2_461>
<OEMDRO2_462>0.</OEMDRO2_462>
<OEMLED2_462>0</OEMLED2_462>
<OEMDRO2_463>0.</OEMDRO2_463>
<OEMLED2_463>0</OEMLED2_463>
<OEMDRO2_464>0.</OEMDRO2_464>
<OEMLED2_464>0</OEMLED2_464>
<OEMDRO2_465>0.</OEMDRO2_465>
<OEMLED2_465>0</OEMLED2_465>
<OEMDRO2_466>0.</OEMDRO2_466>
<OEMLED2_466>0</OEMLED2_466>
<OEMDRO2_467>0.</OEMDRO2_467>
<OEMLED2_467>0</OEMLED2_467>
<OEMDRO2_468>0.</OEMDRO2_468>
<OEMLED2_468>0</OEMLED2_468>
<OEMDRO2_469>0.</OEMDRO2_469>
<OEMLED2_469>0</OEMLED2_469>
<OEMDRO2_470>0.</OEMDRO2_470>
<OEMLED2_470>0</OEMLED2_470>
<OEMDRO2_471>0.</OEMDRO2_471>
<OEMLED2_471>0</OEMLED2_471>
<OEMDRO2_472>0.</OEMDRO2_472>
<OEMLED2_472>0</OEMLED2_472>
<OEMDRO2_473>0.</OEMDRO2_473>
<OEMLED2_473>0</OEMLED2_473>
<OEMDRO2_474>0.</OEMDRO2_474>
<OEMLED2_474>0</OEMLED2_474>
<OEMDRO2_475>0.</OEMDRO2_475>
<OEMLED2_475>0</OEMLED2_475>
<OEMDRO2_476>0.</OEMDRO2_476>
<OEMLED2_476>0</OEMLED2_476>
<OEMDRO2_477>0.</OEMDRO2_477>
<OEMLED2_477>0</OEMLED2_477>
<OEMDRO2_478>0.</OEMDRO2_478>
<OEMLED2_478>0</OEMLED2_478>
<OEMDRO2_479>0.</OEMDRO2_479>
<OEMLED2_479>0</OEMLED2_479>
<OEMDRO2_480>0.</OEMDRO2_480>
<OEMLED2_480>0</OEMLED2_480>
<OEMDRO2_481>0.</OEMDRO2_481>
<OEMLED2_481>0</OEMLED2_481>
<OEMDRO2_482>0.</OEMDRO2_482>
<OEMLED2_482>0</OEMLED2_482>
<OEMDRO2_483>0.</OEMDRO2_483>
<OEMLED2_483>0</OEMLED2_483>
<OEMDRO2_484>0.</OEMDRO2_484>
<OEMLED2_484>0</OEMLED2_484>
<OEMDRO2_485>0.</OEMDRO2_485>
<OEMLED2_485>0</OEMLED2_485>
<OEMDRO2_486>0.</OEMDRO2_486>
<OEMLED2_486>0</OEMLED2_486>
<OEMDRO2_487>0.</OEMDRO2_487>
<OEMLED2_487>0</OEMLED2_487>
<OEMDRO2_488>0.</OEMDRO2_488>
<OEMLED2_488>0</OEMLED2_488>
<OEMDRO2_489>0.</OEMDRO2_489>
<OEMLED2_489>0</OEMLED2_489>
<OEMDRO2_490>0.</OEMDRO2_490>
<OEMLED2_490>0</OEMLED2_490>
<OEMDRO2_491>0.</OEMDRO2_491>
<OEMLED2_491>0</OEMLED2_491>
<OEMDRO2_492>0.</OEMDRO2_492>
<OEMLED2_492>0</OEMLED2_492>
<OEMDRO2_493>0.</OEMDRO2_493>
<OEMLED2_493>0</OEMLED2_493>
<OEMDRO2_494>0.</OEMDRO2_494>
<OEMLED2_494>0</OEMLED2_494>
<OEMDRO2_495>0.</OEMDRO2_495>
<OEMLED2_495>0</OEMLED2_495>
<OEMDRO2_496>0.</OEMDRO2_496>
<OEMLED2_496>0</OEMLED2_496>
<OEMDRO2_497>0.</OEMDRO2_497>
<OEMLED2_497>0</OEMLED2_497>
<OEMDRO2_498>0.</OEMDRO2_498>
<OEMLED2_498>0</OEMLED2_498>
<OEMDRO2_499>0.</OEMDRO2_499>
<OEMLED2_499>0</OEMLED2_499>
<OEMDRO2_500>0.</OEMDRO2_500>
<OEMLED2_500>0</OEMLED2_500>
<OEMDRO2_501>0.</OEMDRO2_501>
<OEMLED2_501>0</OEMLED2_501>
<OEMDRO2_502>0.</OEMDRO2_502>
<OEMLED2_502>0</OEMLED2_502>
<OEMDRO2_503>0.</OEMDRO2_503>
<OEMLED2_503>0</OEMLED2_503>
<OEMDRO2_504>0.</OEMDRO2_504>
<OEMLED2_504>0</OEMLED2_504>
<OEMDRO2_505>0.</OEMDRO2_505>
<OEMLED2_505>0</OEMLED2_505>
<OEMDRO2_506>0.</OEMDRO2_506>
<OEMLED2_506>0</OEMLED2_506>
<OEMDRO2_507>0.</OEMDRO2_507>
<OEMLED2_507>0</OEMLED2_507>
<OEMDRO2_508>0.</OEMDRO2_508>
<OEMLED2_508>0</OEMLED2_508>
<OEMDRO2_509>0.</OEMDRO2_509>
<OEMLED2_509>0</OEMLED2_509>
<OEMDRO2_510>0.</OEMDRO2_510>
<OEMLED2_510>0</OEMLED2_510>
<OEMDRO2_511>0.</OEMDRO2_511>
<OEMLED2_511>0</OEMLED2_511>
<OEMDRO2_512>0.</OEMDRO2_512>
<OEMLED2_512>0</OEMLED2_512>
<OEMDRO2_513>0.</OEMDRO2_513>
<OEMLED2_513>0</OEMLED2_513>
<OEMDRO2_514>0.</OEMDRO2_514>
<OEMLED2_514>0</OEMLED2_514>
<OEMDRO2_515>0.</OEMDRO2_515>
<OEMLED2_515>0</OEMLED2_515>
<OEMDRO2_516>0.</OEMDRO2_516>
<OEMLED2_516>0</OEMLED2_516>
<OEMDRO2_517>0.</OEMDRO2_517>
<OEMLED2_517>0</OEMLED2_517>
<OEMDRO2_518>0.</OEMDRO2_518>
<OEMLED2_518>0</OEMLED2_518>
<OEMDRO2_519>0.</OEMDRO2_519>
<OEMLED2_519>0</OEMLED2_519>
<OEMDRO2_520>0.</OEMDRO2_520>
<OEMLED2_520>0</OEMLED2_520>
<OEMDRO2_521>0.</OEMDRO2_521>
<OEMLED2_521>0</OEMLED2_521>
<OEMDRO2_522>0.</OEMDRO2_522>
<OEMLED2_522>0</OEMLED2_522>
<OEMDRO2_523>0.</OEMDRO2_523>
<OEMLED2_523>0</OEMLED2_523>
<OEMDRO2_524>0.</OEMDRO2_524>
<OEMLED2_524>0</OEMLED2_524>
<OEMDRO2_525>0.</OEMDRO2_525>
<OEMLED2_525>0</OEMLED2_525>
<OEMDRO2_526>0.</OEMDRO2_526>
<OEMLED2_526>0</OEMLED2_526>
<OEMDRO2_527>0.</OEMDRO2_527>
<OEMLED2_527>0</OEMLED2_527>
<OEMDRO2_528>0.</OEMDRO2_528>
<OEMLED2_528>0</OEMLED2_528>
<OEMDRO2_529>0.</OEMDRO2_529>
<OEMLED2_529>0</OEMLED2_529>
<OEMDRO2_530>0.</OEMDRO2_530>
<OEMLED2_530>0</OEMLED2_530>
<OEMDRO2_531>0.</OEMDRO2_531>
<OEMLED2_531>0</OEMLED2_531>
<OEMDRO2_532>0.</OEMDRO2_532>
<OEMLED2_532>0</OEMLED2_532>
<OEMDRO2_533>0.</OEMDRO2_533>
<OEMLED2_533>0</OEMLED2_533>
<OEMDRO2_534>0.</OEMDRO2_534>
<OEMLED2_534>0</OEMLED2_534>
<OEMDRO2_535>0.</OEMDRO2_535>
<OEMLED2_535>0</OEMLED2_535>
<OEMDRO2_536>0.</OEMDRO2_536>
<OEMLED2_536>0</OEMLED2_536>
<OEMDRO2_537>0.</OEMDRO2_537>
<OEMLED2_537>0</OEMLED2_537>
<OEMDRO2_538>0.</OEMDRO2_538>
<OEMLED2_538>0</OEMLED2_538>
<OEMDRO2_539>0.</OEMDRO2_539>
<OEMLED2_539>0</OEMLED2_539>
<OEMDRO2_540>0.</OEMDRO2_540>
<OEMLED2_540>0</OEMLED2_540>
<OEMDRO2_541>0.</OEMDRO2_541>
<OEMLED2_541>0</OEMLED2_541>
<OEMDRO2_542>0.</OEMDRO2_542>
<OEMLED2_542>0</OEMLED2_542>
<OEMDRO2_543>0.</OEMDRO2_543>
<OEMLED2_543>0</OEMLED2_543>
<OEMDRO2_544>0.</OEMDRO2_544>
<OEMLED2_544>0</OEMLED2_544>
<OEMDRO2_545>0.</OEMDRO2_545>
<OEMLED2_545>0</OEMLED2_545>
<OEMDRO2_546>0.</OEMDRO2_546>
<OEMLED2_546>0</OEMLED2_546>
<OEMDRO2_547>0.</OEMDRO2_547>
<OEMLED2_547>0</OEMLED2_547>
<OEMDRO2_548>0.</OEMDRO2_548>
<OEMLED2_548>0</OEMLED2_548>
<OEMDRO2_549>0.</OEMDRO2_549>
<OEMLED2_549>0</OEMLED2_549>
<OEMDRO2_550>0.</OEMDRO2_550>
<OEMLED2_550>0</OEMLED2_550>
<OEMDRO2_551>0.</OEMDRO2_551>
<OEMLED2_551>0</OEMLED2_551>
<OEMDRO2_552>0.</OEMDRO2_552>
<OEMLED2_552>0</OEMLED2_552>
<OEMDRO2_553>0.</OEMDRO2_553>
<OEMLED2_553>0</OEMLED2_553>
<OEMDRO2_554>0.</OEMDRO2_554>
<OEMLED2_554>0</OEMLED2_554>
<OEMDRO2_555>0.</OEMDRO2_555>
<OEMLED2_555>0</OEMLED2_555>
<OEMDRO2_556>0.</OEMDRO2_556>
<OEMLED2_556>0</OEMLED2_556>
<OEMDRO2_557>0.</OEMDRO2_557>
<OEMLED2_557>0</OEMLED2_557>
<OEMDRO2_558>0.</OEMDRO2_558>
<OEMLED2_558>0</OEMLED2_558>
<OEMDRO2_559>0.</OEMDRO2_559>
<OEMLED2_559>0</OEMLED2_559>
<OEMDRO2_560>0.</OEMDRO2_560>
<OEMLED2_560>0</OEMLED2_560>
<OEMDRO2_561>0.</OEMDRO2_561>
<OEMLED2_561>0</OEMLED2_561>
<OEMDRO2_562>0.</OEMDRO2_562>
<OEMLED2_562>0</OEMLED2_562>
<OEMDRO2_563>0.</OEMDRO2_563>
<OEMLED2_563>0</OEMLED2_563>
<OEMDRO2_564>0.</OEMDRO2_564>
<OEMLED2_564>0</OEMLED2_564>
<OEMDRO2_565>0.</OEMDRO2_565>
<OEMLED2_565>0</OEMLED2_565>
<OEMDRO2_566>0.</OEMDRO2_566>
<OEMLED2_566>0</OEMLED2_566>
<OEMDRO2_567>0.</OEMDRO2_567>
<OEMLED2_567>0</OEMLED2_567>
<OEMDRO2_568>0.</OEMDRO2_568>
<OEMLED2_568>0</OEMLED2_568>
<OEMDRO2_569>0.</OEMDRO2_569>
<OEMLED2_569>0</OEMLED2_569>
<OEMDRO2_570>0.</OEMDRO2_570>
<OEMLED2_570>0</OEMLED2_570>
<OEMDRO2_571>0.</OEMDRO2_571>
<OEMLED2_571>0</OEMLED2_571>
<OEMDRO2_572>0.</OEMDRO2_572>
<OEMLED2_572>0</OEMLED2_572>
<OEMDRO2_573>0.</OEMDRO2_573>
<OEMLED2_573>0</OEMLED2_573>
<OEMDRO2_574>0.</OEMDRO2_574>
<OEMLED2_574>0</OEMLED2_574>
<OEMDRO2_575>0.</OEMDRO2_575>
<OEMLED2_575>0</OEMLED2_575>
<OEMDRO2_576>0.</OEMDRO2_576>
<OEMLED2_576>0</OEMLED2_576>
<OEMDRO2_577>0.</OEMDRO2_577>
<OEMLED2_577>0</OEMLED2_577>
<OEMDRO2_578>0.</OEMDRO2_578>
<OEMLED2_578>0</OEMLED2_578>
<OEMDRO2_579>0.</OEMDRO2_579>
<OEMLED2_579>0</OEMLED2_579>
<OEMDRO2_580>0.</OEMDRO2_580>
<OEMLED2_580>0</OEMLED2_580>
<OEMDRO2_581>0.</OEMDRO2_581>
<OEMLED2_581>0</OEMLED2_581>
<OEMDRO2_582>0.</OEMDRO2_582>
<OEMLED2_582>0</OEMLED2_582>
<OEMDRO2_583>0.</OEMDRO2_583>
<OEMLED2_583>0</OEMLED2_583>
<OEMDRO2_584>0.</OEMDRO2_584>
<OEMLED2_584>0</OEMLED2_584>
<OEMDRO2_585>0.</OEMDRO2_585>
<OEMLED2_585>0</OEMLED2_585>
<OEMDRO2_586>0.</OEMDRO2_586>
<OEMLED2_586>0</OEMLED2_586>
<OEMDRO2_587>0.</OEMDRO2_587>
<OEMLED2_587>0</OEMLED2_587>
<OEMDRO2_588>0.</OEMDRO2_588>
<OEMLED2_588>0</OEMLED2_588>
<OEMDRO2_589>0.</OEMDRO2_589>
<OEMLED2_589>0</OEMLED2_589>
<OEMDRO2_590>0.</OEMDRO2_590>
<OEMLED2_590>0</OEMLED2_590>
<OEMDRO2_591>0.</OEMDRO2_591>
<OEMLED2_591>0</OEMLED2_591>
<OEMDRO2_592>0.</OEMDRO2_592>
<OEMLED2_592>0</OEMLED2_592>
<OEMDRO2_593>0.</OEMDRO2_593>
<OEMLED2_593>0</OEMLED2_593>
<OEMDRO2_594>0.</OEMDRO2_594>
<OEMLED2_594>0</OEMLED2_594>
<OEMDRO2_595>0.</OEMDRO2_595>
<OEMLED2_595>0</OEMLED2_595>
<OEMDRO2_596>0.</OEMDRO2_596>
<OEMLED2_596>0</OEMLED2_596>
<OEMDRO2_597>0.</OEMDRO2_597>
<OEMLED2_597>0</OEMLED2_597>
<OEMDRO2_598>0.</OEMDRO2_598>
<OEMLED2_598>0</OEMLED2_598>
<OEMDRO2_599>0.</OEMDRO2_599>
<OEMLED2_599>0</OEMLED2_599>
<OEMDRO2_600>0.</OEMDRO2_600>
<OEMLED2_600>0</OEMLED2_600>
<OEMDRO2_601>0.</OEMDRO2_601>
<OEMLED2_601>0</OEMLED2_601>
<OEMDRO2_602>0.</OEMDRO2_602>
<OEMLED2_602>0</OEMLED2_602>
<OEMDRO2_603>0.</OEMDRO2_603>
<OEMLED2_603>0</OEMLED2_603>
<OEMDRO2_604>0.</OEMDRO2_604>
<OEMLED2_604>0</OEMLED2_604>
<OEMDRO2_605>0.</OEMDRO2_605>
<OEMLED2_605>0</OEMLED2_605>
<OEMDRO2_606>0.</OEMDRO2_606>
<OEMLED2_606>0</OEMLED2_606>
<OEMDRO2_607>0.</OEMDRO2_607>
<OEMLED2_607>0</OEMLED2_607>
<OEMDRO2_608>0.</OEMDRO2_608>
<OEMLED2_608>0</OEMLED2_608>
<OEMDRO2_609>0.</OEMDRO2_609>
<OEMLED2_609>0</OEMLED2_609>
<OEMDRO2_610>0.</OEMDRO2_610>
<OEMLED2_610>0</OEMLED2_610>
<OEMDRO2_611>0.</OEMDRO2_611>
<OEMLED2_611>0</OEMLED2_611>
<OEMDRO2_612>0.</OEMDRO2_612>
<OEMLED2_612>0</OEMLED2_612>
<OEMDRO2_613>0.</OEMDRO2_613>
<OEMLED2_613>0</OEMLED2_613>
<OEMDRO2_614>0.</OEMDRO2_614>
<OEMLED2_614>0</OEMLED2_614>
<OEMDRO2_615>0.</OEMDRO2_615>
<OEMLED2_615>0</OEMLED2_615>
<OEMDRO2_616>0.</OEMDRO2_616>
<OEMLED2_616>0</OEMLED2_616>
<OEMDRO2_617>0.</OEMDRO2_617>
<OEMLED2_617>0</OEMLED2_617>
<OEMDRO2_618>0.</OEMDRO2_618>
<OEMLED2_618>0</OEMLED2_618>
<OEMDRO2_619>0.</OEMDRO2_619>
<OEMLED2_619>0</OEMLED2_619>
<OEMDRO2_620>0.</OEMDRO2_620>
<OEMLED2_620>0</OEMLED2_620>
<OEMDRO2_621>0.</OEMDRO2_621>
<OEMLED2_621>0</OEMLED2_621>
<OEMDRO2_622>0.</OEMDRO2_622>
<OEMLED2_622>0</OEMLED2_622>
<OEMDRO2_623>0.</OEMDRO2_623>
<OEMLED2_623>0</OEMLED2_623>
<OEMDRO2_624>0.</OEMDRO2_624>
<OEMLED2_624>0</OEMLED2_624>
<OEMDRO2_625>0.</OEMDRO2_625>
<OEMLED2_625>0</OEMLED2_625>
<OEMDRO2_626>0.</OEMDRO2_626>
<OEMLED2_626>0</OEMLED2_626>
<OEMDRO2_627>0.</OEMDRO2_627>
<OEMLED2_627>0</OEMLED2_627>
<OEMDRO2_628>0.</OEMDRO2_628>
<OEMLED2_628>0</OEMLED2_628>
<OEMDRO2_629>0.</OEMDRO2_629>
<OEMLED2_629>0</OEMLED2_629>
<OEMDRO2_630>0.</OEMDRO2_630>
<OEMLED2_630>0</OEMLED2_630>
<OEMDRO2_631>0.</OEMDRO2_631>
<OEMLED2_631>0</OEMLED2_631>
<OEMDRO2_632>0.</OEMDRO2_632>
<OEMLED2_632>0</OEMLED2_632>
<OEMDRO2_633>0.</OEMDRO2_633>
<OEMLED2_633>0</OEMLED2_633>
<OEMDRO2_634>0.</OEMDRO2_634>
<OEMLED2_634>0</OEMLED2_634>
<OEMDRO2_635>0.</OEMDRO2_635>
<OEMLED2_635>0</OEMLED2_635>
<OEMDRO2_636>0.</OEMDRO2_636>
<OEMLED2_636>0</OEMLED2_636>
<OEMDRO2_637>0.</OEMDRO2_637>
<OEMLED2_637>0</OEMLED2_637>
<OEMDRO2_638>0.</OEMDRO2_638>
<OEMLED2_638>0</OEMLED2_638>
<OEMDRO2_639>0.</OEMDRO2_639>
<OEMLED2_639>0</OEMLED2_639>
<OEMDRO2_640>0.</OEMDRO2_640>
<OEMLED2_640>0</OEMLED2_640>
<OEMDRO2_641>0.</OEMDRO2_641>
<OEMLED2_641>0</OEMLED2_641>
<OEMDRO2_642>0.</OEMDRO2_642>
<OEMLED2_642>0</OEMLED2_642>
<OEMDRO2_643>0.</OEMDRO2_643>
<OEMLED2_643>0</OEMLED2_643>
<OEMDRO2_644>0.</OEMDRO2_644>
<OEMLED2_644>0</OEMLED2_644>
<OEMDRO2_645>0.</OEMDRO2_645>
<OEMLED2_645>0</OEMLED2_645>
<OEMDRO2_646>0.</OEMDRO2_646>
<OEMLED2_646>0</OEMLED2_646>
<OEMDRO2_647>0.</OEMDRO2_647>
<OEMLED2_647>0</OEMLED2_647>
<OEMDRO2_648>0.</OEMDRO2_648>
<OEMLED2_648>0</OEMLED2_648>
<OEMDRO2_649>0.</OEMDRO2_649>
<OEMLED2_649>0</OEMLED2_649>
<OEMDRO2_650>0.</OEMDRO2_650>
<OEMLED2_650>0</OEMLED2_650>
<OEMDRO2_651>0.</OEMDRO2_651>
<OEMLED2_651>0</OEMLED2_651>
<OEMDRO2_652>0.</OEMDRO2_652>
<OEMLED2_652>0</OEMLED2_652>
<OEMDRO2_653>0.</OEMDRO2_653>
<OEMLED2_653>0</OEMLED2_653>
<OEMDRO2_654>0.</OEMDRO2_654>
<OEMLED2_654>0</OEMLED2_654>
<OEMDRO2_655>0.</OEMDRO2_655>
<OEMLED2_655>0</OEMLED2_655>
<OEMDRO2_656>0.</OEMDRO2_656>
<OEMLED2_656>0</OEMLED2_656>
<OEMDRO2_657>0.</OEMDRO2_657>
<OEMLED2_657>0</OEMLED2_657>
<OEMDRO2_658>0.</OEMDRO2_658>
<OEMLED2_658>0</OEMLED2_658>
<OEMDRO2_659>0.</OEMDRO2_659>
<OEMLED2_659>0</OEMLED2_659>
<OEMDRO2_660>0.</OEMDRO2_660>
<OEMLED2_660>0</OEMLED2_660>
<OEMDRO2_661>0.</OEMDRO2_661>
<OEMLED2_661>0</OEMLED2_661>
<OEMDRO2_662>0.</OEMDRO2_662>
<OEMLED2_662>0</OEMLED2_662>
<OEMDRO2_663>0.</OEMDRO2_663>
<OEMLED2_663>0</OEMLED2_663>
<OEMDRO2_664>0.</OEMDRO2_664>
<OEMLED2_664>0</OEMLED2_664>
<OEMDRO2_665>0.</OEMDRO2_665>
<OEMLED2_665>0</OEMLED2_665>
<OEMDRO2_666>0.</OEMDRO2_666>
<OEMLED2_666>0</OEMLED2_666>
<OEMDRO2_667>0.</OEMDRO2_667>
<OEMLED2_667>0</OEMLED2_667>
<OEMDRO2_668>0.</OEMDRO2_668>
<OEMLED2_668>0</OEMLED2_668>
<OEMDRO2_669>0.</OEMDRO2_669>
<OEMLED2_669>0</OEMLED2_669>
<OEMDRO2_670>0.</OEMDRO2_670>
<OEMLED2_670>0</OEMLED2_670>
<OEMDRO2_671>0.</OEMDRO2_671>
<OEMLED2_671>0</OEMLED2_671>
<OEMDRO2_672>0.</OEMDRO2_672>
<OEMLED2_672>0</OEMLED2_672>
<OEMDRO2_673>0.</OEMDRO2_673>
<OEMLED2_673>0</OEMLED2_673>
<OEMDRO2_674>0.</OEMDRO2_674>
<OEMLED2_674>0</OEMLED2_674>
<OEMDRO2_675>0.</OEMDRO2_675>
<OEMLED2_675>0</OEMLED2_675>
<OEMDRO2_676>0.</OEMDRO2_676>
<OEMLED2_676>0</OEMLED2_676>
<OEMDRO2_677>0.</OEMDRO2_677>
<OEMLED2_677>0</OEMLED2_677>
<OEMDRO2_678>0.</OEMDRO2_678>
<OEMLED2_678>0</OEMLED2_678>
<OEMDRO2_679>0.</OEMDRO2_679>
<OEMLED2_679>0</OEMLED2_679>
<OEMDRO2_680>0.</OEMDRO2_680>
<OEMLED2_680>0</OEMLED2_680>
<OEMDRO2_681>0.</OEMDRO2_681>
<OEMLED2_681>0</OEMLED2_681>
<OEMDRO2_682>0.</OEMDRO2_682>
<OEMLED2_682>0</OEMLED2_682>
<OEMDRO2_683>0.</OEMDRO2_683>
<OEMLED2_683>0</OEMLED2_683>
<OEMDRO2_684>0.</OEMDRO2_684>
<OEMLED2_684>0</OEMLED2_684>
<OEMDRO2_685>0.</OEMDRO2_685>
<OEMLED2_685>0</OEMLED2_685>
<OEMDRO2_686>0.</OEMDRO2_686>
<OEMLED2_686>0</OEMLED2_686>
<OEMDRO2_687>0.</OEMDRO2_687>
<OEMLED2_687>0</OEMLED2_687>
<OEMDRO2_688>0.</OEMDRO2_688>
<OEMLED2_688>0</OEMLED2_688>
<OEMDRO2_689>0.</OEMDRO2_689>
<OEMLED2_689>0</OEMLED2_689>
<OEMDRO2_690>0.</OEMDRO2_690>
<OEMLED2_690>0</OEMLED2_690>
<OEMDRO2_691>0.</OEMDRO2_691>
<OEMLED2_691>0</OEMLED2_691>
<OEMDRO2_692>0.</OEMDRO2_692>
<OEMLED2_692>0</OEMLED2_692>
<OEMDRO2_693>0.</OEMDRO2_693>
<OEMLED2_693>0</OEMLED2_693>
<OEMDRO2_694>0.</OEMDRO2_694>
<OEMLED2_694>0</OEMLED2_694>
<OEMDRO2_695>0.</OEMDRO2_695>
<OEMLED2_695>0</OEMLED2_695>
<OEMDRO2_696>0.</OEMDRO2_696>
<OEMLED2_696>0</OEMLED2_696>
<OEMDRO2_697>0.</OEMDRO2_697>
<OEMLED2_697>0</OEMLED2_697>
<OEMDRO2_698>0.</OEMDRO2_698>
<OEMLED2_698>0</OEMLED2_698>
<OEMDRO2_699>0.</OEMDRO2_699>
<OEMLED2_699>0</OEMLED2_699>
<OEMDRO2_700>0.</OEMDRO2_700>
<OEMLED2_700>0</OEMLED2_700>
<OEMDRO2_701>0.</OEMDRO2_701>
<OEMLED2_701>0</OEMLED2_701>
<OEMDRO2_702>0.</OEMDRO2_702>
<OEMLED2_702>0</OEMLED2_702>
<OEMDRO2_703>0.</OEMDRO2_703>
<OEMLED2_703>0</OEMLED2_703>
<OEMDRO2_704>0.</OEMDRO2_704>
<OEMLED2_704>0</OEMLED2_704>
<OEMDRO2_705>0.</OEMDRO2_705>
<OEMLED2_705>0</OEMLED2_705>
<OEMDRO2_706>0.</OEMDRO2_706>
<OEMLED2_706>0</OEMLED2_706>
<OEMDRO2_707>0.</OEMDRO2_707>
<OEMLED2_707>0</OEMLED2_707>
<OEMDRO2_708>0.</OEMDRO2_708>
<OEMLED2_708>0</OEMLED2_708>
<OEMDRO2_709>0.</OEMDRO2_709>
<OEMLED2_709>0</OEMLED2_709>
<OEMDRO2_710>0.</OEMDRO2_710>
<OEMLED2_710>0</OEMLED2_710>
<OEMDRO2_711>0.</OEMDRO2_711>
<OEMLED2_711>0</OEMLED2_711>
<OEMDRO2_712>0.</OEMDRO2_712>
<OEMLED2_712>0</OEMLED2_712>
<OEMDRO2_713>0.</OEMDRO2_713>
<OEMLED2_713>0</OEMLED2_713>
<OEMDRO2_714>0.</OEMDRO2_714>
<OEMLED2_714>0</OEMLED2_714>
<OEMDRO2_715>0.</OEMDRO2_715>
<OEMLED2_715>0</OEMLED2_715>
<OEMDRO2_716>0.</OEMDRO2_716>
<OEMLED2_716>0</OEMLED2_716>
<OEMDRO2_717>0.</OEMDRO2_717>
<OEMLED2_717>0</OEMLED2_717>
<OEMDRO2_718>0.</OEMDRO2_718>
<OEMLED2_718>0</OEMLED2_718>
<OEMDRO2_719>0.</OEMDRO2_719>
<OEMLED2_719>0</OEMLED2_719>
<OEMDRO2_720>0.</OEMDRO2_720>
<OEMLED2_720>0</OEMLED2_720>
<OEMDRO2_721>0.</OEMDRO2_721>
<OEMLED2_721>0</OEMLED2_721>
<OEMDRO2_722>0.</OEMDRO2_722>
<OEMLED2_722>0</OEMLED2_722>
<OEMDRO2_723>0.</OEMDRO2_723>
<OEMLED2_723>0</OEMLED2_723>
<OEMDRO2_724>0.</OEMDRO2_724>
<OEMLED2_724>0</OEMLED2_724>
<OEMDRO2_725>0.</OEMDRO2_725>
<OEMLED2_725>0</OEMLED2_725>
<OEMDRO2_726>0.</OEMDRO2_726>
<OEMLED2_726>0</OEMLED2_726>
<OEMDRO2_727>0.</OEMDRO2_727>
<OEMLED2_727>0</OEMLED2_727>
<OEMDRO2_728>0.</OEMDRO2_728>
<OEMLED2_728>0</OEMLED2_728>
<OEMDRO2_729>0.</OEMDRO2_729>
<OEMLED2_729>0</OEMLED2_729>
<OEMDRO2_730>0.</OEMDRO2_730>
<OEMLED2_730>0</OEMLED2_730>
<OEMDRO2_731>0.</OEMDRO2_731>
<OEMLED2_731>0</OEMLED2_731>
<OEMDRO2_732>0.</OEMDRO2_732>
<OEMLED2_732>0</OEMLED2_732>
<OEMDRO2_733>0.</OEMDRO2_733>
<OEMLED2_733>0</OEMLED2_733>
<OEMDRO2_734>0.</OEMDRO2_734>
<OEMLED2_734>0</OEMLED2_734>
<OEMDRO2_735>0.</OEMDRO2_735>
<OEMLED2_735>0</OEMLED2_735>
<OEMDRO2_736>0.</OEMDRO2_736>
<OEMLED2_736>0</OEMLED2_736>
<OEMDRO2_737>0.</OEMDRO2_737>
<OEMLED2_737>0</OEMLED2_737>
<OEMDRO2_738>0.</OEMDRO2_738>
<OEMLED2_738>0</OEMLED2_738>
<OEMDRO2_739>0.</OEMDRO2_739>
<OEMLED2_739>0</OEMLED2_739>
<OEMDRO2_740>0.</OEMDRO2_740>
<OEMLED2_740>0</OEMLED2_740>
<OEMDRO2_741>0.</OEMDRO2_741>
<OEMLED2_741>0</OEMLED2_741>
<OEMDRO2_742>0.</OEMDRO2_742>
<OEMLED2_742>0</OEMLED2_742>
<OEMDRO2_743>0.</OEMDRO2_743>
<OEMLED2_743>0</OEMLED2_743>
<OEMDRO2_744>0.</OEMDRO2_744>
<OEMLED2_744>0</OEMLED2_744>
<OEMDRO2_745>0.</OEMDRO2_745>
<OEMLED2_745>0</OEMLED2_745>
<OEMDRO2_746>0.</OEMDRO2_746>
<OEMLED2_746>0</OEMLED2_746>
<OEMDRO2_747>0.</OEMDRO2_747>
<OEMLED2_747>0</OEMLED2_747>
<OEMDRO2_748>0.</OEMDRO2_748>
<OEMLED2_748>0</OEMLED2_748>
<OEMDRO2_749>0.</OEMDRO2_749>
<OEMLED2_749>0</OEMLED2_749>
<OEMDRO2_750>0.</OEMDRO2_750>
<OEMLED2_750>0</OEMLED2_750>
<OEMDRO2_751>0.</OEMDRO2_751>
<OEMLED2_751>0</OEMLED2_751>
<OEMDRO2_752>0.</OEMDRO2_752>
<OEMLED2_752>0</OEMLED2_752>
<OEMDRO2_753>0.</OEMDRO2_753>
<OEMLED2_753>0</OEMLED2_753>
<OEMDRO2_754>0.</OEMDRO2_754>
<OEMLED2_754>0</OEMLED2_754>
<OEMDRO2_755>0.</OEMDRO2_755>
<OEMLED2_755>0</OEMLED2_755>
<OEMDRO2_756>0.</OEMDRO2_756>
<OEMLED2_756>0</OEMLED2_756>
<OEMDRO2_757>0.</OEMDRO2_757>
<OEMLED2_757>0</OEMLED2_757>
<OEMDRO2_758>0.</OEMDRO2_758>
<OEMLED2_758>0</OEMLED2_758>
<OEMDRO2_759>0.</OEMDRO2_759>
<OEMLED2_759>0</OEMLED2_759>
<OEMDRO2_760>0.</OEMDRO2_760>
<OEMLED2_760>0</OEMLED2_760>
<OEMDRO2_761>0.</OEMDRO2_761>
<OEMLED2_761>0</OEMLED2_761>
<OEMDRO2_762>0.</OEMDRO2_762>
<OEMLED2_762>0</OEMLED2_762>
<OEMDRO2_763>0.</OEMDRO2_763>
<OEMLED2_763>0</OEMLED2_763>
<OEMDRO2_764>0.</OEMDRO2_764>
<OEMLED2_764>0</OEMLED2_764>
<OEMDRO2_765>0.</OEMDRO2_765>
<OEMLED2_765>0</OEMLED2_765>
<OEMDRO2_766>0.</OEMDRO2_766>
<OEMLED2_766>0</OEMLED2_766>
<OEMDRO2_767>0.</OEMDRO2_767>
<OEMLED2_767>0</OEMLED2_767>
<OEMDRO2_768>0.</OEMDRO2_768>
<OEMLED2_768>0</OEMLED2_768>
<OEMDRO2_769>0.</OEMDRO2_769>
<OEMLED2_769>0</OEMLED2_769>
<OEMDRO2_770>0.</OEMDRO2_770>
<OEMLED2_770>0</OEMLED2_770>
<OEMDRO2_771>0.</OEMDRO2_771>
<OEMLED2_771>0</OEMLED2_771>
<OEMDRO2_772>0.</OEMDRO2_772>
<OEMLED2_772>0</OEMLED2_772>
<OEMDRO2_773>0.</OEMDRO2_773>
<OEMLED2_773>0</OEMLED2_773>
<OEMDRO2_774>0.</OEMDRO2_774>
<OEMLED2_774>0</OEMLED2_774>
<OEMDRO2_775>0.</OEMDRO2_775>
<OEMLED2_775>0</OEMLED2_775>
<OEMDRO2_776>0.</OEMDRO2_776>
<OEMLED2_776>0</OEMLED2_776>
<OEMDRO2_777>0.</OEMDRO2_777>
<OEMLED2_777>0</OEMLED2_777>
<OEMDRO2_778>0.</OEMDRO2_778>
<OEMLED2_778>0</OEMLED2_778>
<OEMDRO2_779>0.</OEMDRO2_779>
<OEMLED2_779>0</OEMLED2_779>
<OEMDRO2_780>0.</OEMDRO2_780>
<OEMLED2_780>0</OEMLED2_780>
<OEMDRO2_781>0.</OEMDRO2_781>
<OEMLED2_781>0</OEMLED2_781>
<OEMDRO2_782>0.</OEMDRO2_782>
<OEMLED2_782>0</OEMLED2_782>
<OEMDRO2_783>0.</OEMDRO2_783>
<OEMLED2_783>0</OEMLED2_783>
<OEMDRO2_784>0.</OEMDRO2_784>
<OEMLED2_784>0</OEMLED2_784>
<OEMDRO2_785>0.</OEMDRO2_785>
<OEMLED2_785>0</OEMLED2_785>
<OEMDRO2_786>0.</OEMDRO2_786>
<OEMLED2_786>0</OEMLED2_786>
<OEMDRO2_787>0.</OEMDRO2_787>
<OEMLED2_787>0</OEMLED2_787>
<OEMDRO2_788>0.</OEMDRO2_788>
<OEMLED2_788>0</OEMLED2_788>
<OEMDRO2_789>0.</OEMDRO2_789>
<OEMLED2_789>0</OEMLED2_789>
<OEMDRO2_790>0.</OEMDRO2_790>
<OEMLED2_790>0</OEMLED2_790>
<OEMDRO2_791>0.</OEMDRO2_791>
<OEMLED2_791>0</OEMLED2_791>
<OEMDRO2_792>0.</OEMDRO2_792>
<OEMLED2_792>0</OEMLED2_792>
<OEMDRO2_793>0.</OEMDRO2_793>
<OEMLED2_793>0</OEMLED2_793>
<OEMDRO2_794>0.</OEMDRO2_794>
<OEMLED2_794>0</OEMLED2_794>
<OEMDRO2_795>0.</OEMDRO2_795>
<OEMLED2_795>0</OEMLED2_795>
<OEMDRO2_796>0.</OEMDRO2_796>
<OEMLED2_796>0</OEMLED2_796>
<OEMDRO2_797>0.</OEMDRO2_797>
<OEMLED2_797>0</OEMLED2_797>
<OEMDRO2_798>0.</OEMDRO2_798>
<OEMLED2_798>0</OEMLED2_798>
<OEMDRO2_799>0.</OEMDRO2_799>
<OEMLED2_799>0</OEMLED2_799>
<OEMDRO2_800>0.</OEMDRO2_800>
<OEMLED2_800>0</OEMLED2_800>
<OEMDRO2_801>0.</OEMDRO2_801>
<OEMLED2_801>0</OEMLED2_801>
<OEMDRO2_802>0.</OEMDRO2_802>
<OEMLED2_802>0</OEMLED2_802>
<OEMDRO2_803>0.</OEMDRO2_803>
<OEMLED2_803>0</OEMLED2_803>
<OEMDRO2_804>0.</OEMDRO2_804>
<OEMLED2_804>0</OEMLED2_804>
<OEMDRO2_805>0.</OEMDRO2_805>
<OEMLED2_805>0</OEMLED2_805>
<OEMDRO2_806>0.</OEMDRO2_806>
<OEMLED2_806>0</OEMLED2_806>
<OEMDRO2_807>0.</OEMDRO2_807>
<OEMLED2_807>0</OEMLED2_807>
<OEMDRO2_808>0.</OEMDRO2_808>
<OEMLED2_808>0</OEMLED2_808>
<OEMDRO2_809>0.</OEMDRO2_809>
<OEMLED2_809>0</OEMLED2_809>
<OEMDRO2_810>0.</OEMDRO2_810>
<OEMLED2_810>0</OEMLED2_810>
<OEMDRO2_811>0.</OEMDRO2_811>
<OEMLED2_811>0</OEMLED2_811>
<OEMDRO2_812>0.</OEMDRO2_812>
<OEMLED2_812>0</OEMLED2_812>
<OEMDRO2_813>0.</OEMDRO2_813>
<OEMLED2_813>0</OEMLED2_813>
<OEMDRO2_814>0.</OEMDRO2_814>
<OEMLED2_814>0</OEMLED2_814>
<OEMDRO2_815>0.</OEMDRO2_815>
<OEMLED2_815>0</OEMLED2_815>
<OEMDRO2_816>0.</OEMDRO2_816>
<OEMLED2_816>0</OEMLED2_816>
<OEMDRO2_817>0.</OEMDRO2_817>
<OEMLED2_817>0</OEMLED2_817>
<OEMDRO2_818>0.</OEMDRO2_818>
<OEMLED2_818>0</OEMLED2_818>
<OEMDRO2_819>0.</OEMDRO2_819>
<OEMLED2_819>0</OEMLED2_819>
<OEMDRO2_820>0.</OEMDRO2_820>
<OEMLED2_820>0</OEMLED2_820>
<OEMDRO2_821>0.</OEMDRO2_821>
<OEMLED2_821>0</OEMLED2_821>
<OEMDRO2_822>0.</OEMDRO2_822>
<OEMLED2_822>0</OEMLED2_822>
<OEMDRO2_823>0.</OEMDRO2_823>
<OEMLED2_823>0</OEMLED2_823>
<OEMDRO2_824>0.</OEMDRO2_824>
<OEMLED2_824>0</OEMLED2_824>
<OEMDRO2_825>0.</OEMDRO2_825>
<OEMLED2_825>0</OEMLED2_825>
<OEMDRO2_826>0.</OEMDRO2_826>
<OEMLED2_826>0</OEMLED2_826>
<OEMDRO2_827>0.</OEMDRO2_827>
<OEMLED2_827>0</OEMLED2_827>
<OEMDRO2_828>0.</OEMDRO2_828>
<OEMLED2_828>0</OEMLED2_828>
<OEMDRO2_829>0.</OEMDRO2_829>
<OEMLED2_829>0</OEMLED2_829>
<OEMDRO2_830>0.</OEMDRO2_830>
<OEMLED2_830>0</OEMLED2_830>
<OEMDRO2_831>0.</OEMDRO2_831>
<OEMLED2_831>0</OEMLED2_831>
<OEMDRO2_832>0.</OEMDRO2_832>
<OEMLED2_832>0</OEMLED2_832>
<OEMDRO2_833>0.</OEMDRO2_833>
<OEMLED2_833>0</OEMLED2_833>
<OEMDRO2_834>0.</OEMDRO2_834>
<OEMLED2_834>0</OEMLED2_834>
<OEMDRO2_835>0.</OEMDRO2_835>
<OEMLED2_835>0</OEMLED2_835>
<OEMDRO2_836>0.</OEMDRO2_836>
<OEMLED2_836>0</OEMLED2_836>
<OEMDRO2_837>0.</OEMDRO2_837>
<OEMLED2_837>0</OEMLED2_837>
<OEMDRO2_838>0.</OEMDRO2_838>
<OEMLED2_838>0</OEMLED2_838>
<OEMDRO2_839>0.</OEMDRO2_839>
<OEMLED2_839>0</OEMLED2_839>
<OEMDRO2_840>0.</OEMDRO2_840>
<OEMLED2_840>0</OEMLED2_840>
<OEMDRO2_841>0.</OEMDRO2_841>
<OEMLED2_841>0</OEMLED2_841>
<OEMDRO2_842>0.</OEMDRO2_842>
<OEMLED2_842>0</OEMLED2_842>
<OEMDRO2_843>0.</OEMDRO2_843>
<OEMLED2_843>0</OEMLED2_843>
<OEMDRO2_844>0.</OEMDRO2_844>
<OEMLED2_844>0</OEMLED2_844>
<OEMDRO2_845>0.</OEMDRO2_845>
<OEMLED2_845>0</OEMLED2_845>
<OEMDRO2_846>0.</OEMDRO2_846>
<OEMLED2_846>0</OEMLED2_846>
<OEMDRO2_847>0.</OEMDRO2_847>
<OEMLED2_847>0</OEMLED2_847>
<OEMDRO2_848>0.</OEMDRO2_848>
<OEMLED2_848>0</OEMLED2_848>
<OEMDRO2_849>0.</OEMDRO2_849>
<OEMLED2_849>0</OEMLED2_849>
<OEMDRO2_850>0.</OEMDRO2_850>
<OEMLED2_850>0</OEMLED2_850>
<OEMDRO2_851>0.</OEMDRO2_851>
<OEMLED2_851>0</OEMLED2_851>
<OEMDRO2_852>0.</OEMDRO2_852>
<OEMLED2_852>0</OEMLED2_852>
<OEMDRO2_853>0.</OEMDRO2_853>
<OEMLED2_853>0</OEMLED2_853>
<OEMDRO2_854>0.</OEMDRO2_854>
<OEMLED2_854>0</OEMLED2_854>
<OEMDRO2_855>0.</OEMDRO2_855>
<OEMLED2_855>0</OEMLED2_855>
<OEMDRO2_856>0.</OEMDRO2_856>
<OEMLED2_856>0</OEMLED2_856>
<OEMDRO2_857>0.</OEMDRO2_857>
<OEMLED2_857>0</OEMLED2_857>
<OEMDRO2_858>0.</OEMDRO2_858>
<OEMLED2_858>0</OEMLED2_858>
<OEMDRO2_859>0.</OEMDRO2_859>
<OEMLED2_859>0</OEMLED2_859>
<OEMDRO2_860>0.</OEMDRO2_860>
<OEMLED2_860>0</OEMLED2_860>
<OEMDRO2_861>0.</OEMDRO2_861>
<OEMLED2_861>0</OEMLED2_861>
<OEMDRO2_862>0.</OEMDRO2_862>
<OEMLED2_862>0</OEMLED2_862>
<OEMDRO2_863>0.</OEMDRO2_863>
<OEMLED2_863>0</OEMLED2_863>
<OEMDRO2_864>0.</OEMDRO2_864>
<OEMLED2_864>0</OEMLED2_864>
<OEMDRO2_865>0.</OEMDRO2_865>
<OEMLED2_865>0</OEMLED2_865>
<OEMDRO2_866>0.</OEMDRO2_866>
<OEMLED2_866>0</OEMLED2_866>
<OEMDRO2_867>0.</OEMDRO2_867>
<OEMLED2_867>0</OEMLED2_867>
<OEMDRO2_868>0.</OEMDRO2_868>
<OEMLED2_868>0</OEMLED2_868>
<OEMDRO2_869>0.</OEMDRO2_869>
<OEMLED2_869>0</OEMLED2_869>
<OEMDRO2_870>0.</OEMDRO2_870>
<OEMLED2_870>0</OEMLED2_870>
<OEMDRO2_871>0.</OEMDRO2_871>
<OEMLED2_871>0</OEMLED2_871>
<OEMDRO2_872>0.</OEMDRO2_872>
<OEMLED2_872>0</OEMLED2_872>
<OEMDRO2_873>0.</OEMDRO2_873>
<OEMLED2_873>0</OEMLED2_873>
<OEMDRO2_874>0.</OEMDRO2_874>
<OEMLED2_874>0</OEMLED2_874>
<OEMDRO2_875>0.</OEMDRO2_875>
<OEMLED2_875>0</OEMLED2_875>
<OEMDRO2_876>0.</OEMDRO2_876>
<OEMLED2_876>0</OEMLED2_876>
<OEMDRO2_877>0.</OEMDRO2_877>
<OEMLED2_877>0</OEMLED2_877>
<OEMDRO2_878>0.</OEMDRO2_878>
<OEMLED2_878>0</OEMLED2_878>
<OEMDRO2_879>0.</OEMDRO2_879>
<OEMLED2_879>0</OEMLED2_879>
<OEMDRO2_880>0.</OEMDRO2_880>
<OEMLED2_880>0</OEMLED2_880>
<OEMDRO2_881>0.</OEMDRO2_881>
<OEMLED2_881>0</OEMLED2_881>
<OEMDRO2_882>0.</OEMDRO2_882>
<OEMLED2_882>0</OEMLED2_882>
<OEMDRO2_883>0.</OEMDRO2_883>
<OEMLED2_883>0</OEMLED2_883>
<OEMDRO2_884>0.</OEMDRO2_884>
<OEMLED2_884>0</OEMLED2_884>
<OEMDRO2_885>0.</OEMDRO2_885>
<OEMLED2_885>0</OEMLED2_885>
<OEMDRO2_886>0.</OEMDRO2_886>
<OEMLED2_886>0</OEMLED2_886>
<OEMDRO2_887>0.</OEMDRO2_887>
<OEMLED2_887>0</OEMLED2_887>
<OEMDRO2_888>0.</OEMDRO2_888>
<OEMLED2_888>0</OEMLED2_888>
<OEMDRO2_889>0.</OEMDRO2_889>
<OEMLED2_889>0</OEMLED2_889>
<OEMDRO2_890>0.</OEMDRO2_890>
<OEMLED2_890>0</OEMLED2_890>
<OEMDRO2_891>0.</OEMDRO2_891>
<OEMLED2_891>0</OEMLED2_891>
<OEMDRO2_892>0.</OEMDRO2_892>
<OEMLED2_892>0</OEMLED2_892>
<OEMDRO2_893>0.</OEMDRO2_893>
<OEMLED2_893>0</OEMLED2_893>
<OEMDRO2_894>0.</OEMDRO2_894>
<OEMLED2_894>0</OEMLED2_894>
<OEMDRO2_895>0.</OEMDRO2_895>
<OEMLED2_895>0</OEMLED2_895>
<OEMDRO2_896>0.</OEMDRO2_896>
<OEMLED2_896>0</OEMLED2_896>
<OEMDRO2_897>0.</OEMDRO2_897>
<OEMLED2_897>0</OEMLED2_897>
<OEMDRO2_898>0.</OEMDRO2_898>
<OEMLED2_898>0</OEMLED2_898>
<OEMDRO2_899>0.</OEMDRO2_899>
<OEMLED2_899>0</OEMLED2_899>
<OEMDRO2_900>0.</OEMDRO2_900>
<OEMLED2_900>0</OEMLED2_900>
<OEMDRO2_901>0.</OEMDRO2_901>
<OEMLED2_901>0</OEMLED2_901>
<OEMDRO2_902>0.</OEMDRO2_902>
<OEMLED2_902>0</OEMLED2_902>
<OEMDRO2_903>0.</OEMDRO2_903>
<OEMLED2_903>0</OEMLED2_903>
<OEMDRO2_904>0.</OEMDRO2_904>
<OEMLED2_904>0</OEMLED2_904>
<OEMDRO2_905>0.</OEMDRO2_905>
<OEMLED2_905>0</OEMLED2_905>
<OEMDRO2_906>0.</OEMDRO2_906>
<OEMLED2_906>0</OEMLED2_906>
<OEMDRO2_907>0.</OEMDRO2_907>
<OEMLED2_907>0</OEMLED2_907>
<OEMDRO2_908>0.</OEMDRO2_908>
<OEMLED2_908>0</OEMLED2_908>
<OEMDRO2_909>0.</OEMDRO2_909>
<OEMLED2_909>0</OEMLED2_909>
<OEMDRO2_910>0.</OEMDRO2_910>
<OEMLED2_910>0</OEMLED2_910>
<OEMDRO2_911>0.</OEMDRO2_911>
<OEMLED2_911>0</OEMLED2_911>
<OEMDRO2_912>0.</OEMDRO2_912>
<OEMLED2_912>0</OEMLED2_912>
<OEMDRO2_913>0.</OEMDRO2_913>
<OEMLED2_913>0</OEMLED2_913>
<OEMDRO2_914>0.</OEMDRO2_914>
<OEMLED2_914>0</OEMLED2_914>
<OEMDRO2_915>0.</OEMDRO2_915>
<OEMLED2_915>0</OEMLED2_915>
<OEMDRO2_916>0.</OEMDRO2_916>
<OEMLED2_916>0</OEMLED2_916>
<OEMDRO2_917>0.</OEMDRO2_917>
<OEMLED2_917>0</OEMLED2_917>
<OEMDRO2_918>0.</OEMDRO2_918>
<OEMLED2_918>0</OEMLED2_918>
<OEMDRO2_919>0.</OEMDRO2_919>
<OEMLED2_919>0</OEMLED2_919>
<OEMDRO2_920>0.</OEMDRO2_920>
<OEMLED2_920>0</OEMLED2_920>
<OEMDRO2_921>0.</OEMDRO2_921>
<OEMLED2_921>0</OEMLED2_921>
<OEMDRO2_922>0.</OEMDRO2_922>
<OEMLED2_922>0</OEMLED2_922>
<OEMDRO2_923>0.</OEMDRO2_923>
<OEMLED2_923>0</OEMLED2_923>
<OEMDRO2_924>0.</OEMDRO2_924>
<OEMLED2_924>0</OEMLED2_924>
<OEMDRO2_925>0.</OEMDRO2_925>
<OEMLED2_925>0</OEMLED2_925>
<OEMDRO2_926>0.</OEMDRO2_926>
<OEMLED2_926>0</OEMLED2_926>
<OEMDRO2_927>0.</OEMDRO2_927>
<OEMLED2_927>0</OEMLED2_927>
<OEMDRO2_928>0.</OEMDRO2_928>
<OEMLED2_928>0</OEMLED2_928>
<OEMDRO2_929>0.</OEMDRO2_929>
<OEMLED2_929>0</OEMLED2_929>
<OEMDRO2_930>0.</OEMDRO2_930>
<OEMLED2_930>0</OEMLED2_930>
<OEMDRO2_931>0.</OEMDRO2_931>
<OEMLED2_931>0</OEMLED2_931>
<OEMDRO2_932>0.</OEMDRO2_932>
<OEMLED2_932>0</OEMLED2_932>
<OEMDRO2_933>0.</OEMDRO2_933>
<OEMLED2_933>0</OEMLED2_933>
<OEMDRO2_934>0.</OEMDRO2_934>
<OEMLED2_934>0</OEMLED2_934>
<OEMDRO2_935>0.</OEMDRO2_935>
<OEMLED2_935>0</OEMLED2_935>
<OEMDRO2_936>0.</OEMDRO2_936>
<OEMLED2_936>0</OEMLED2_936>
<OEMDRO2_937>0.</OEMDRO2_937>
<OEMLED2_937>0</OEMLED2_937>
<OEMDRO2_938>0.</OEMDRO2_938>
<OEMLED2_938>0</OEMLED2_938>
<OEMDRO2_939>0.</OEMDRO2_939>
<OEMLED2_939>0</OEMLED2_939>
<OEMDRO2_940>0.</OEMDRO2_940>
<OEMLED2_940>0</OEMLED2_940>
<OEMDRO2_941>0.</OEMDRO2_941>
<OEMLED2_941>0</OEMLED2_941>
<OEMDRO2_942>0.</OEMDRO2_942>
<OEMLED2_942>0</OEMLED2_942>
<OEMDRO2_943>0.</OEMDRO2_943>
<OEMLED2_943>0</OEMLED2_943>
<OEMDRO2_944>0.</OEMDRO2_944>
<OEMLED2_944>0</OEMLED2_944>
<OEMDRO2_945>0.</OEMDRO2_945>
<OEMLED2_945>0</OEMLED2_945>
<OEMDRO2_946>0.</OEMDRO2_946>
<OEMLED2_946>0</OEMLED2_946>
<OEMDRO2_947>0.</OEMDRO2_947>
<OEMLED2_947>0</OEMLED2_947>
<OEMDRO2_948>0.</OEMDRO2_948>
<OEMLED2_948>0</OEMLED2_948>
<OEMDRO2_949>0.</OEMDRO2_949>
<OEMLED2_949>0</OEMLED2_949>
<OEMDRO2_950>0.</OEMDRO2_950>
<OEMLED2_950>0</OEMLED2_950>
<OEMDRO2_951>0.</OEMDRO2_951>
<OEMLED2_951>0</OEMLED2_951>
<OEMDRO2_952>0.</OEMDRO2_952>
<OEMLED2_952>0</OEMLED2_952>
<OEMDRO2_953>0.</OEMDRO2_953>
<OEMLED2_953>0</OEMLED2_953>
<OEMDRO2_954>0.</OEMDRO2_954>
<OEMLED2_954>0</OEMLED2_954>
<OEMDRO2_955>0.</OEMDRO2_955>
<OEMLED2_955>0</OEMLED2_955>
<OEMDRO2_956>0.</OEMDRO2_956>
<OEMLED2_956>0</OEMLED2_956>
<OEMDRO2_957>0.</OEMDRO2_957>
<OEMLED2_957>0</OEMLED2_957>
<OEMDRO2_958>0.</OEMDRO2_958>
<OEMLED2_958>0</OEMLED2_958>
<OEMDRO2_959>0.</OEMDRO2_959>
<OEMLED2_959>0</OEMLED2_959>
<OEMDRO2_960>0.</OEMDRO2_960>
<OEMLED2_960>0</OEMLED2_960>
<OEMDRO2_961>0.</OEMDRO2_961>
<OEMLED2_961>0</OEMLED2_961>
<OEMDRO2_962>0.</OEMDRO2_962>
<OEMLED2_962>0</OEMLED2_962>
<OEMDRO2_963>0.</OEMDRO2_963>
<OEMLED2_963>0</OEMLED2_963>
<OEMDRO2_964>0.</OEMDRO2_964>
<OEMLED2_964>0</OEMLED2_964>
<OEMDRO2_965>0.</OEMDRO2_965>
<OEMLED2_965>0</OEMLED2_965>
<OEMDRO2_966>0.</OEMDRO2_966>
<OEMLED2_966>0</OEMLED2_966>
<OEMDRO2_967>0.</OEMDRO2_967>
<OEMLED2_967>0</OEMLED2_967>
<OEMDRO2_968>0.</OEMDRO2_968>
<OEMLED2_968>0</OEMLED2_968>
<OEMDRO2_969>0.</OEMDRO2_969>
<OEMLED2_969>0</OEMLED2_969>
<OEMDRO2_970>0.</OEMDRO2_970>
<OEMLED2_970>0</OEMLED2_970>
<OEMDRO2_971>0.</OEMDRO2_971>
<OEMLED2_971>0</OEMLED2_971>
<OEMDRO2_972>0.</OEMDRO2_972>
<OEMLED2_972>0</OEMLED2_972>
<OEMDRO2_973>0.</OEMDRO2_973>
<OEMLED2_973>0</OEMLED2_973>
<OEMDRO2_974>0.</OEMDRO2_974>
<OEMLED2_974>0</OEMLED2_974>
<OEMDRO2_975>0.</OEMDRO2_975>
<OEMLED2_975>0</OEMLED2_975>
<OEMDRO2_976>0.</OEMDRO2_976>
<OEMLED2_976>0</OEMLED2_976>
<OEMDRO2_977>0.</OEMDRO2_977>
<OEMLED2_977>0</OEMLED2_977>
<OEMDRO2_978>0.</OEMDRO2_978>
<OEMLED2_978>0</OEMLED2_978>
<OEMDRO2_979>0.</OEMDRO2_979>
<OEMLED2_979>0</OEMLED2_979>
<OEMDRO2_980>0.</OEMDRO2_980>
<OEMLED2_980>0</OEMLED2_980>
<OEMDRO2_981>0.</OEMDRO2_981>
<OEMLED2_981>0</OEMLED2_981>
<OEMDRO2_982>0.</OEMDRO2_982>
<OEMLED2_982>0</OEMLED2_982>
<OEMDRO2_983>0.</OEMDRO2_983>
<OEMLED2_983>0</OEMLED2_983>
<OEMDRO2_984>0.</OEMDRO2_984>
<OEMLED2_984>0</OEMLED2_984>
<OEMDRO2_985>0.</OEMDRO2_985>
<OEMLED2_985>0</OEMLED2_985>
<OEMDRO2_986>0.</OEMDRO2_986>
<OEMLED2_986>0</OEMLED2_986>
<OEMDRO2_987>0.</OEMDRO2_987>
<OEMLED2_987>0</OEMLED2_987>
<OEMDRO2_988>0.</OEMDRO2_988>
<OEMLED2_988>0</OEMLED2_988>
<OEMDRO2_989>0.</OEMDRO2_989>
<OEMLED2_989>0</OEMLED2_989>
<OEMDRO2_990>0.</OEMDRO2_990>
<OEMLED2_990>0</OEMLED2_990>
<OEMDRO2_991>0.</OEMDRO2_991>
<OEMLED2_991>0</OEMLED2_991>
<OEMDRO2_992>0.</OEMDRO2_992>
<OEMLED2_992>0</OEMLED2_992>
<OEMDRO2_993>0.</OEMDRO2_993>
<OEMLED2_993>0</OEMLED2_993>
<OEMDRO2_994>0.</OEMDRO2_994>
<OEMLED2_994>0</OEMLED2_994>
<OEMDRO2_995>0.</OEMDRO2_995>
<OEMLED2_995>0</OEMLED2_995>
<OEMDRO2_996>0.</OEMDRO2_996>
<OEMLED2_996>0</OEMLED2_996>
<OEMDRO2_997>0.</OEMDRO2_997>
<OEMLED2_997>0</OEMLED2_997>
<OEMDRO2_998>0.</OEMDRO2_998>
<OEMLED2_998>0</OEMLED2_998>
<OEMDRO2_999>0.</OEMDRO2_999>
<OEMLED2_999>0</OEMLED2_999>
<Vel0>5.833</Vel0>
<Acc0>27.</Acc0>
<Steps0>1357.707053</Steps0>
<Vel1>5.833</Vel1>
<Acc1>27.</Acc1>
<Steps1>1357.999202</Steps1>
<Vel2>0.5</Vel2>
<Acc2>10.</Acc2>
<Steps2>32111.09174</Steps2>
<Vel3>5.833</Vel3>
<Acc3>27.</Acc3>
<Steps3>1357.999202</Steps3>
<ACLength>50</ACLength>
<BCLength>50</BCLength>
<CCLength>50</CCLength>
<AMapOn>0</AMapOn>
<BMapOn>0</BMapOn>
<CMapOn>0</CMapOn>
<THC_Delay_Check>0.</THC_Delay_Check>
<GExt>*.tap</GExt>
<GPath>C:\Users\nick7\Desktop\Plasma\2020.06.04 Mounting Foot v3-nickpost.tap</GPath>
<Steps4>533.3738</Steps4>
<IGNORETOOL>1</IGNORETOOL>
<Editor>C:\PROGRA~2\NOTEPA~1\NOTEPA~1.EXE</Editor><EnableResetHotKey>999</EnableResetHotKey></Preferences>
<Mach3Mill>
<WPVB>500</WPVB>
<WPVT>100</WPVT>
<WPVL>50</WPVL>
<WPVR>400</WPVR>
</Mach3Mill>
<Control>
<Device>PoKeys-PoLabs-v3.35-20190516</Device>
<Default>1</Default>
</Control>
<VideoPlugIn>
<DROcolor>0</DROcolor>
<TOOLcolor>8421440</TOOLcolor>
<CROSScolor>4194304</CROSScolor>
<ShowTool>1</ShowTool>
<ShowMousePos>1</ShowMousePos>
<ShowAxisPos>1</ShowAxisPos>
<ToolDia>0.5</ToolDia>
<ScaleFactor>2.e-003</ScaleFactor>
<FlipAxis>0</FlipAxis>
</VideoPlugIn>
<GCodeVar>
<GVar500>0.</GVar500>
<GVar501>0.</GVar501>
<GVar502>0.</GVar502>
<GVar503>0.</GVar503>
<GVar504>0.</GVar504>
<GVar505>0.</GVar505>
<GVar506>0.</GVar506>
<GVar507>0.</GVar507>
<GVar508>0.</GVar508>
<GVar509>0.</GVar509>
<GVar510>0.</GVar510>
<GVar511>0.</GVar511>
<GVar512>0.</GVar512>
<GVar513>0.</GVar513>
<GVar514>0.</GVar514>
<GVar515>0.</GVar515>
<GVar516>0.</GVar516>
<GVar517>0.</GVar517>
<GVar518>0.</GVar518>
<GVar519>0.</GVar519>
<GVar520>0.</GVar520>
<GVar521>0.</GVar521>
<GVar522>0.</GVar522>
<GVar523>0.</GVar523>
<GVar524>0.</GVar524>
<GVar525>0.</GVar525>
<GVar526>0.</GVar526>
<GVar527>0.</GVar527>
<GVar528>0.</GVar528>
<GVar529>0.</GVar529>
<GVar530>0.</GVar530>
<GVar531>0.</GVar531>
<GVar532>0.</GVar532>
<GVar533>0.</GVar533>
<GVar534>0.</GVar534>
<GVar535>0.</GVar535>
<GVar536>0.</GVar536>
<GVar537>0.</GVar537>
<GVar538>0.</GVar538>
<GVar539>0.</GVar539>
<GVar540>0.</GVar540>
<GVar541>0.</GVar541>
<GVar542>0.</GVar542>
<GVar543>0.</GVar543>
<GVar544>0.</GVar544>
<GVar545>0.</GVar545>
<GVar546>0.</GVar546>
<GVar547>0.</GVar547>
<GVar548>0.</GVar548>
<GVar549>0.</GVar549>
<GVar550>0.</GVar550>
<GVar551>0.</GVar551>
<GVar552>0.</GVar552>
<GVar553>0.</GVar553>
<GVar554>0.</GVar554>
<GVar555>0.</GVar555>
<GVar556>0.</GVar556>
<GVar557>0.</GVar557>
<GVar558>0.</GVar558>
<GVar559>0.</GVar559>
<GVar560>0.</GVar560>
<GVar561>0.</GVar561>
<GVar562>0.</GVar562>
<GVar563>0.</GVar563>
<GVar564>0.</GVar564>
<GVar565>0.</GVar565>
<GVar566>0.</GVar566>
<GVar567>0.</GVar567>
<GVar568>0.</GVar568>
<GVar569>0.</GVar569>
<GVar570>0.</GVar570>
<GVar571>0.</GVar571>
<GVar572>0.</GVar572>
<GVar573>0.</GVar573>
<GVar574>0.</GVar574>
<GVar575>0.</GVar575>
<GVar576>0.</GVar576>
<GVar577>0.</GVar577>
<GVar578>0.</GVar578>
<GVar579>0.</GVar579>
<GVar580>0.</GVar580>
<GVar581>0.</GVar581>
<GVar582>0.</GVar582>
<GVar583>0.</GVar583>
<GVar584>0.</GVar584>
<GVar585>0.</GVar585>
<GVar586>0.</GVar586>
<GVar587>0.</GVar587>
<GVar588>0.</GVar588>
<GVar589>0.</GVar589>
<GVar590>0.</GVar590>
<GVar591>0.</GVar591>
<GVar592>0.</GVar592>
<GVar593>0.</GVar593>
<GVar594>0.</GVar594>
<GVar595>0.</GVar595>
<GVar596>0.</GVar596>
<GVar597>0.</GVar597>
<GVar598>0.</GVar598>
<GVar599>0.</GVar599>
<GVar600>0.</GVar600>
</GCodeVar>
<PlugIns>
<XBox360Controller---Lee-Davis-Ver-2.4.1.0>1</XBox360Controller---Lee-Davis-Ver-2.4.1.0>
<SystemTest>0</SystemTest>
<SheetCamRemote>0</SheetCamRemote>
<PoKeys-PoLabs-v3.35-20190516>1</PoKeys-PoLabs-v3.35-20190516><Flash-FlashScreen-SWF-PlugIn-A.Fenerty--B.-Barker-Ver-2.00.046>0</Flash-FlashScreen-SWF-PlugIn-A.Fenerty--B.-Barker-Ver-2.00.046><Video---B.Barker-Ver-1.0>0</Video---B.Barker-Ver-1.0><THC-THC---B.Barker-Ver-1.0a>0</THC-THC---B.Barker-Ver-1.0a></PlugIns>
<XBox>
<BUTTON0>0</BUTTON0>
<BUTTON1>0</BUTTON1>
<BUTTON2>0</BUTTON2>
<BUTTON3>0</BUTTON3>
<BUTTON4>0</BUTTON4>
<BUTTON5>0</BUTTON5>
<BUTTON6>0</BUTTON6>
<BUTTON7>0</BUTTON7>
<AxisLH>0</AxisLH>
<AxisLV>1</AxisLV>
<AxisRH>2</AxisRH>
<AxisRV>6</AxisRV>
<ReverseLH>0</ReverseLH>
<ReverseLV>0</ReverseLV>
<ReverseRH>0</ReverseRH>
<ReverseRV>0</ReverseRV>
<JogStartEnabled>0</JogStartEnabled>
<DisableDiagonalMoves>0</DisableDiagonalMoves>
<SafetySwitch>0</SafetySwitch>
<Macro1>0</Macro1>
<Macro2>0</Macro2>
<OEM1>0</OEM1>
<OEM2>0</OEM2>
<VendorID>0x0000</VendorID>
<ProductID>0x0000</ProductID>
</XBox>
<Normals>
<Distance>0.</Distance>
<ZInhibit>0.</ZInhibit>
<Axis0>1.</Axis0>
<Axis1>1.</Axis1>
<Axis2>1.</Axis2>
<Axis3>1.</Axis3>
<Axis4>0.</Axis4>
<Axis5>0.</Axis5>
<Axis6>0.</Axis6>
<CV>2.</CV>
<XScale>1.</XScale>
<YScale>1.</YScale>
<ZScale>1.</ZScale>
<AScale>1.</AScale>
<BScale>1.</BScale>
<CScale>1.</CScale>
<OffLine>0.</OffLine>
<IJ>1.</IJ>
<RefX>0.</RefX>
<RefY>0.</RefY>
<RefZ>0.</RefZ>
<RefA>0.</RefA>
<RefB>0.</RefB>
<RefC>0.</RefC>
<System>1.</System>
<Rotation>0.</Rotation>
<Plane>1.</Plane>
</Normals>
<SmartMotor><KP>10.</KP></SmartMotor></profile>
Posts: 7829 Joined: Sat Jun 02, 2012 6:04 pm
Post
by acourtjester » Wed Jun 17, 2020 3:03 pm
The adding of the G4 P0.2 is a band aid when put into the G-code. I added it to my Post Processor as a fix for me alone but I had the THC signal problem also. So I have abandoned that BOB and Plug-in for Mach 3 and doug up a computer with a parallel printer port and went back to an spare BOB I had. I am dropping out of the picture on this post as there are others here with more experience with the Pokey stuff I don't want to add confusion. Keep on plugging at it and thing will work out.
robertspark
Posts: 1821 Joined: Mon Jun 12, 2017 6:43 pm
Post
by robertspark » Wed Jun 17, 2020 3:40 pm
acourtjester wrote: ↑ Wed Jun 17, 2020 3:03 pm
Sorry Tom, I hope I wasn't treading on toes, I've not got that much experiance with Pokeys or Mach3 as I've not actively used it for the last couple of years having moved to UCCNC (
here I go plugging that again
You're guidance as an active user of Mach3 is always welcome as I'm sure you may pick up things that I don't not using it actively any more.
robertspark
Post
by robertspark » Wed Jun 17, 2020 3:42 pm
nick7251 wrote: ↑ Wed Jun 17, 2020 2:44 pm
It wouldn't let me upload a .txt either. Only lets me upload picture. So, I pasted it instead.
no problem I'll copy paste and have a look now
robertspark
Post
by robertspark » Wed Jun 17, 2020 3:51 pm
Could you upload (copy + paste) the following Pokeys Plugin config file too, thanks
Plugin configuration
The PoKeys plugin configuration is stored in separate PoKeysMachConfig.xml file in the
AppData\Local folder in your system.
nick7251
Posts: 108 Joined: Tue Dec 17, 2019 6:28 pm
Post
by nick7251 » Wed Jun 17, 2020 3:59 pm
Here is the Pokeys XML. Thanks for looking into this for me. I've been learning a lot.
Code: Select all
<PoKeys><General><ConfiguredDevices>2</ConfiguredDevices></General><Device1><SerialNumber>42100</SerialNumber><UDP>0</UDP><StatusWindow>0</StatusWindow><AssertReset>0</AssertReset><DisableUnavailableDisplay>0</DisableUnavailableDisplay><PoILDROStart>0</PoILDROStart><PoILDROEnable>0</PoILDROEnable><PoILDROEnableWrite>0</PoILDROEnableWrite><OverrideRapidJog>0</OverrideRapidJog><JogLowSpeed>0</JogLowSpeed><JogHighSpeed>0</JogHighSpeed><COMRate>0</COMRate><SpindleSpeed>0</SpindleSpeed><SpindleSensor>0</SpindleSensor><SpindleTicks>0</SpindleTicks><UnsafeJogging>0</UnsafeJogging><Pin1Function>0</Pin1Function><Pin1Map2LED>0</Pin1Map2LED><Pin1Map2Button>1010</Pin1Map2Button><Pin1Map2IO>23</Pin1Map2IO><Pin2Function>0</Pin2Function><Pin2Map2LED>0</Pin2Map2LED><Pin2Map2Button>0</Pin2Map2Button><Pin2Map2IO>0</Pin2Map2IO><Pin3Function>0</Pin3Function><Pin3Map2LED>0</Pin3Map2LED><Pin3Map2Button>0</Pin3Map2Button><Pin3Map2IO>0</Pin3Map2IO><Pin4Function>0</Pin4Function><Pin4Map2LED>0</Pin4Map2LED><Pin4Map2Button>0</Pin4Map2Button><Pin4Map2IO>0</Pin4Map2IO><Pin5Function>0</Pin5Function><Pin5Map2LED>0</Pin5Map2LED><Pin5Map2Button>0</Pin5Map2Button><Pin5Map2IO>0</Pin5Map2IO><Pin6Function>0</Pin6Function><Pin6Map2LED>0</Pin6Map2LED><Pin6Map2Button>0</Pin6Map2Button><Pin6Map2IO>0</Pin6Map2IO><Pin7Function>0</Pin7Function><Pin7Map2LED>0</Pin7Map2LED><Pin7Map2Button>0</Pin7Map2Button><Pin7Map2IO>0</Pin7Map2IO><Pin8Function>130</Pin8Function><Pin8Map2LED>37</Pin8Map2LED><Pin8Map2Button>0</Pin8Map2Button><Pin8Map2IO>28</Pin8Map2IO><Pin9Function>0</Pin9Function><Pin9Map2LED>0</Pin9Map2LED><Pin9Map2Button>0</Pin9Map2Button><Pin9Map2IO>0</Pin9Map2IO><Pin10Function>0</Pin10Function><Pin10Map2LED>0</Pin10Map2LED><Pin10Map2Button>0</Pin10Map2Button><Pin10Map2IO>0</Pin10Map2IO><Pin11Function>0</Pin11Function><Pin11Map2LED>0</Pin11Map2LED><Pin11Map2Button>0</Pin11Map2Button><Pin11Map2IO>0</Pin11Map2IO><Pin12Function>130</Pin12Function><Pin12Map2LED>36</Pin12Map2LED><Pin12Map2Button>0</Pin12Map2Button><Pin12Map2IO>27</Pin12Map2IO><Pin13Function>130</Pin13Function><Pin13Map2LED>38</Pin13Map2LED><Pin13Map2Button>0</Pin13Map2Button><Pin13Map2IO>29</Pin13Map2IO><Pin14Function>0</Pin14Function><Pin14Map2LED>0</Pin14Map2LED><Pin14Map2Button>0</Pin14Map2Button><Pin14Map2IO>0</Pin14Map2IO><Pin15Function>0</Pin15Function><Pin15Map2LED>0</Pin15Map2LED><Pin15Map2Button>0</Pin15Map2Button><Pin15Map2IO>0</Pin15Map2IO><Pin16Function>0</Pin16Function><Pin16Map2LED>0</Pin16Map2LED><Pin16Map2Button>0</Pin16Map2Button><Pin16Map2IO>0</Pin16Map2IO><Pin17Function>0</Pin17Function><Pin17Map2LED>0</Pin17Map2LED><Pin17Map2Button>0</Pin17Map2Button><Pin17Map2IO>0</Pin17Map2IO><Pin18Function>0</Pin18Function><Pin18Map2LED>0</Pin18Map2LED><Pin18Map2Button>0</Pin18Map2Button><Pin18Map2IO>0</Pin18Map2IO><Pin19Function>130</Pin19Function><Pin19Map2LED>0</Pin19Map2LED><Pin19Map2Button>141</Pin19Map2Button><Pin19Map2IO>23</Pin19Map2IO><Pin20Function>0</Pin20Function><Pin20Map2LED>0</Pin20Map2LED><Pin20Map2Button>0</Pin20Map2Button><Pin20Map2IO>29</Pin20Map2IO><Pin21Function>0</Pin21Function><Pin21Map2LED>0</Pin21Map2LED><Pin21Map2Button>0</Pin21Map2Button><Pin21Map2IO>0</Pin21Map2IO><Pin22Function>0</Pin22Function><Pin22Map2LED>0</Pin22Map2LED><Pin22Map2Button>0</Pin22Map2Button><Pin22Map2IO>0</Pin22Map2IO><Pin23Function>0</Pin23Function><Pin23Map2LED>0</Pin23Map2LED><Pin23Map2Button>0</Pin23Map2Button><Pin23Map2IO>0</Pin23Map2IO><Pin24Function>0</Pin24Function><Pin24Map2LED>0</Pin24Map2LED><Pin24Map2Button>0</Pin24Map2Button><Pin24Map2IO>0</Pin24Map2IO><Pin25Function>0</Pin25Function><Pin25Map2LED>0</Pin25Map2LED><Pin25Map2Button>0</Pin25Map2Button><Pin25Map2IO>0</Pin25Map2IO><Pin26Function>0</Pin26Function><Pin26Map2LED>0</Pin26Map2LED><Pin26Map2Button>0</Pin26Map2Button><Pin26Map2IO>0</Pin26Map2IO><Pin27Function>0</Pin27Function><Pin27Map2LED>0</Pin27Map2LED><Pin27Map2Button>0</Pin27Map2Button><Pin27Map2IO>0</Pin27Map2IO><Pin28Function>0</Pin28Function><Pin28Map2LED>0</Pin28Map2LED><Pin28Map2Button>0</Pin28Map2Button><Pin28Map2IO>0</Pin28Map2IO><Pin29Function>0</Pin29Function><Pin29Map2LED>0</Pin29Map2LED><Pin29Map2Button>0</Pin29Map2Button><Pin29Map2IO>0</Pin29Map2IO><Pin30Function>0</Pin30Function><Pin30Map2LED>0</Pin30Map2LED><Pin30Map2Button>0</Pin30Map2Button><Pin30Map2IO>0</Pin30Map2IO><Pin31Function>0</Pin31Function><Pin31Map2LED>0</Pin31Map2LED><Pin31Map2Button>0</Pin31Map2Button><Pin31Map2IO>0</Pin31Map2IO><Pin32Function>0</Pin32Function><Pin32Map2LED>0</Pin32Map2LED><Pin32Map2Button>0</Pin32Map2Button><Pin32Map2IO>0</Pin32Map2IO><Pin33Function>0</Pin33Function><Pin33Map2LED>0</Pin33Map2LED><Pin33Map2Button>0</Pin33Map2Button><Pin33Map2IO>0</Pin33Map2IO><Pin34Function>0</Pin34Function><Pin34Map2LED>0</Pin34Map2LED><Pin34Map2Button>0</Pin34Map2Button><Pin34Map2IO>0</Pin34Map2IO><Pin35Function>0</Pin35Function><Pin35Map2LED>0</Pin35Map2LED><Pin35Map2Button>0</Pin35Map2Button><Pin35Map2IO>0</Pin35Map2IO><Pin36Function>0</Pin36Function><Pin36Map2LED>0</Pin36Map2LED><Pin36Map2Button>0</Pin36Map2Button><Pin36Map2IO>0</Pin36Map2IO><Pin37Function>0</Pin37Function><Pin37Map2LED>0</Pin37Map2LED><Pin37Map2Button>0</Pin37Map2Button><Pin37Map2IO>0</Pin37Map2IO><Pin38Function>0</Pin38Function><Pin38Map2LED>0</Pin38Map2LED><Pin38Map2Button>0</Pin38Map2Button><Pin38Map2IO>0</Pin38Map2IO><Pin39Function>0</Pin39Function><Pin39Map2LED>0</Pin39Map2LED><Pin39Map2Button>0</Pin39Map2Button><Pin39Map2IO>0</Pin39Map2IO><Pin40Function>0</Pin40Function><Pin40Map2LED>0</Pin40Map2LED><Pin40Map2Button>0</Pin40Map2Button><Pin40Map2IO>0</Pin40Map2IO><Pin41Function>0</Pin41Function><Pin41Map2LED>0</Pin41Map2LED><Pin41Map2Button>0</Pin41Map2Button><Pin41Map2IO>0</Pin41Map2IO><Pin42Function>0</Pin42Function><Pin42Map2LED>0</Pin42Map2LED><Pin42Map2Button>0</Pin42Map2Button><Pin42Map2IO>0</Pin42Map2IO><Pin43Function>0</Pin43Function><Pin43Map2LED>0</Pin43Map2LED><Pin43Map2Button>0</Pin43Map2Button><Pin43Map2IO>0</Pin43Map2IO><Pin44Function>0</Pin44Function><Pin44Map2LED>0</Pin44Map2LED><Pin44Map2Button>0</Pin44Map2Button><Pin44Map2IO>0</Pin44Map2IO><Pin45Function>0</Pin45Function><Pin45Map2LED>0</Pin45Map2LED><Pin45Map2Button>0</Pin45Map2Button><Pin45Map2IO>0</Pin45Map2IO><Pin46Function>0</Pin46Function><Pin46Map2LED>0</Pin46Map2LED><Pin46Map2Button>0</Pin46Map2Button><Pin46Map2IO>0</Pin46Map2IO><Pin47Function>0</Pin47Function><Pin47Map2LED>0</Pin47Map2LED><Pin47Map2Button>0</Pin47Map2Button><Pin47Map2IO>0</Pin47Map2IO><Pin48Function>0</Pin48Function><Pin48Map2LED>0</Pin48Map2LED><Pin48Map2Button>0</Pin48Map2Button><Pin48Map2IO>0</Pin48Map2IO><Pin49Function>0</Pin49Function><Pin49Map2LED>0</Pin49Map2LED><Pin49Map2Button>0</Pin49Map2Button><Pin49Map2IO>0</Pin49Map2IO><Pin50Function>0</Pin50Function><Pin50Map2LED>0</Pin50Map2LED><Pin50Map2Button>0</Pin50Map2Button><Pin50Map2IO>0</Pin50Map2IO><Pin51Function>0</Pin51Function><Pin51Map2LED>0</Pin51Map2LED><Pin51Map2Button>0</Pin51Map2Button><Pin51Map2IO>0</Pin51Map2IO><Pin52Function>0</Pin52Function><Pin52Map2LED>0</Pin52Map2LED><Pin52Map2Button>0</Pin52Map2Button><Pin52Map2IO>0</Pin52Map2IO><Pin53Function>0</Pin53Function><Pin53Map2LED>0</Pin53Map2LED><Pin53Map2Button>0</Pin53Map2Button><Pin53Map2IO>0</Pin53Map2IO><Pin54Function>0</Pin54Function><Pin54Map2LED>0</Pin54Map2LED><Pin54Map2Button>0</Pin54Map2Button><Pin54Map2IO>0</Pin54Map2IO><Pin55Function>0</Pin55Function><Pin55Map2LED>0</Pin55Map2LED><Pin55Map2Button>0</Pin55Map2Button><Pin55Map2IO>0</Pin55Map2IO><PendantMode>0</PendantMode><Encoder1A>0</Encoder1A><Encoder1B>1</Encoder1B><Encoder1Options>0</Encoder1Options><Encoder2A>0</Encoder2A><Encoder2B>0</Encoder2B><Encoder2Options>0</Encoder2Options><Encoder3A>0</Encoder3A><Encoder3B>0</Encoder3B><Encoder3Options>0</Encoder3Options><Encoder4A>0</Encoder4A><Encoder4B>0</Encoder4B><Encoder4Options>0</Encoder4Options><Encoder5A>0</Encoder5A><Encoder5B>0</Encoder5B><Encoder5Options>0</Encoder5Options><Encoder6A>0</Encoder6A><Encoder6B>0</Encoder6B><Encoder6Options>0</Encoder6Options><Encoder7A>0</Encoder7A><Encoder7B>0</Encoder7B><Encoder7Options>0</Encoder7Options><Encoder8A>0</Encoder8A><Encoder8B>0</Encoder8B><Encoder8Options>0</Encoder8Options><Encoder9A>0</Encoder9A><Encoder9B>0</Encoder9B><Encoder9Options>0</Encoder9Options><Encoder10A>0</Encoder10A><Encoder10B>0</Encoder10B><Encoder10Options>0</Encoder10Options><Encoder11A>0</Encoder11A><Encoder11B>0</Encoder11B><Encoder11Options>0</Encoder11Options><Encoder12A>0</Encoder12A><Encoder12B>0</Encoder12B><Encoder12Options>0</Encoder12Options><Encoder13A>0</Encoder13A><Encoder13B>0</Encoder13B><Encoder13Options>0</Encoder13Options><Encoder14A>0</Encoder14A><Encoder14B>0</Encoder14B><Encoder14Options>0</Encoder14Options><Encoder15A>0</Encoder15A><Encoder15B>0</Encoder15B><Encoder15Options>0</Encoder15Options><Encoder16A>0</Encoder16A><Encoder16B>0</Encoder16B><Encoder16Options>0</Encoder16Options><Encoder17A>0</Encoder17A><Encoder17B>0</Encoder17B><Encoder17Options>0</Encoder17Options><Encoder18A>0</Encoder18A><Encoder18B>0</Encoder18B><Encoder18Options>0</Encoder18Options><Encoder19A>0</Encoder19A><Encoder19B>0</Encoder19B><Encoder19Options>0</Encoder19Options><Encoder20A>0</Encoder20A><Encoder20B>0</Encoder20B><Encoder20Options>0</Encoder20Options><Encoder21A>0</Encoder21A><Encoder21B>0</Encoder21B><Encoder21Options>0</Encoder21Options><Encoder22A>0</Encoder22A><Encoder22B>0</Encoder22B><Encoder22Options>0</Encoder22Options><Encoder23A>0</Encoder23A><Encoder23B>0</Encoder23B><Encoder23Options>0</Encoder23Options><Encoder24A>0</Encoder24A><Encoder24B>0</Encoder24B><Encoder24Options>0</Encoder24Options><Encoder25A>0</Encoder25A><Encoder25B>0</Encoder25B><Encoder25Options>0</Encoder25Options><Encoder12DRO>0</Encoder12DRO><Encoder1Inpendant>0</Encoder1Inpendant><Encoder22DRO>0</Encoder22DRO><Encoder2Inpendant>0</Encoder2Inpendant><Encoder32DRO>0</Encoder32DRO><Encoder3Inpendant>0</Encoder3Inpendant><Encoder42DRO>0</Encoder42DRO><Encoder4Inpendant>0</Encoder4Inpendant><Encoder52DRO>0</Encoder52DRO><Encoder5Inpendant>0</Encoder5Inpendant><Encoder62DRO>0</Encoder62DRO><Encoder6Inpendant>0</Encoder6Inpendant><Encoder72DRO>0</Encoder72DRO><Encoder7Inpendant>0</Encoder7Inpendant><Encoder82DRO>0</Encoder82DRO><Encoder8Inpendant>0</Encoder8Inpendant><Encoder92DRO>0</Encoder92DRO><Encoder9Inpendant>0</Encoder9Inpendant><Encoder102DRO>0</Encoder102DRO><Encoder10Inpendant>0</Encoder10Inpendant><Encoder112DRO>0</Encoder112DRO><Encoder11Inpendant>0</Encoder11Inpendant><Encoder122DRO>0</Encoder122DRO><Encoder12Inpendant>0</Encoder12Inpendant><Encoder132DRO>0</Encoder132DRO><Encoder13Inpendant>0</Encoder13Inpendant><Encoder142DRO>0</Encoder142DRO><Encoder14Inpendant>0</Encoder14Inpendant><Encoder152DRO>0</Encoder152DRO><Encoder15Inpendant>0</Encoder15Inpendant><Encoder162DRO>0</Encoder162DRO><Encoder16Inpendant>0</Encoder16Inpendant><Encoder172DRO>0</Encoder172DRO><Encoder17Inpendant>0</Encoder17Inpendant><Encoder182DRO>0</Encoder182DRO><Encoder18Inpendant>0</Encoder18Inpendant><Encoder192DRO>0</Encoder192DRO><Encoder19Inpendant>0</Encoder19Inpendant><Encoder202DRO>0</Encoder202DRO><Encoder20Inpendant>0</Encoder20Inpendant><Encoder212DRO>0</Encoder212DRO><Encoder21Inpendant>0</Encoder21Inpendant><Encoder222DRO>0</Encoder222DRO><Encoder22Inpendant>0</Encoder22Inpendant><Encoder232DRO>0</Encoder232DRO><Encoder23Inpendant>0</Encoder23Inpendant><Encoder242DRO>0</Encoder242DRO><Encoder24Inpendant>0</Encoder24Inpendant><Encoder252DRO>0</Encoder252DRO><Encoder25Inpendant>0</Encoder25Inpendant><Encoder262DRO>0</Encoder262DRO><Encoder26Inpendant>0</Encoder26Inpendant><FastEncoders>0</FastEncoders><UltraFastEncoders>0</UltraFastEncoders><UltraFastEncodersOptions>0</UltraFastEncodersOptions><MPGjog>0</MPGjog><MPGjog1x>0</MPGjog1x><MatrixKB1Map2LED>0</MatrixKB1Map2LED><MatrixKB1Map2Button>1010</MatrixKB1Map2Button><MatrixKB1Map2IO>23</MatrixKB1Map2IO><MatrixKB2Map2LED>0</MatrixKB2Map2LED><MatrixKB2Map2Button>0</MatrixKB2Map2Button><MatrixKB2Map2IO>0</MatrixKB2Map2IO><MatrixKB3Map2LED>0</MatrixKB3Map2LED><MatrixKB3Map2Button>0</MatrixKB3Map2Button><MatrixKB3Map2IO>0</MatrixKB3Map2IO><MatrixKB4Map2LED>0</MatrixKB4Map2LED><MatrixKB4Map2Button>0</MatrixKB4Map2Button><MatrixKB4Map2IO>0</MatrixKB4Map2IO><MatrixKB5Map2LED>0</MatrixKB5Map2LED><MatrixKB5Map2Button>0</MatrixKB5Map2Button><MatrixKB5Map2IO>0</MatrixKB5Map2IO><MatrixKB6Map2LED>0</MatrixKB6Map2LED><MatrixKB6Map2Button>0</MatrixKB6Map2Button><MatrixKB6Map2IO>0</MatrixKB6Map2IO><MatrixKB7Map2LED>0</MatrixKB7Map2LED><MatrixKB7Map2Button>0</MatrixKB7Map2Button><MatrixKB7Map2IO>0</MatrixKB7Map2IO><MatrixKB8Map2LED>37</MatrixKB8Map2LED><MatrixKB8Map2Button>0</MatrixKB8Map2Button><MatrixKB8Map2IO>28</MatrixKB8Map2IO><MatrixKB9Map2LED>0</MatrixKB9Map2LED><MatrixKB9Map2Button>0</MatrixKB9Map2Button><MatrixKB9Map2IO>0</MatrixKB9Map2IO><MatrixKB10Map2LED>0</MatrixKB10Map2LED><MatrixKB10Map2Button>0</MatrixKB10Map2Button><MatrixKB10Map2IO>0</MatrixKB10Map2IO><MatrixKB11Map2LED>0</MatrixKB11Map2LED><MatrixKB11Map2Button>0</MatrixKB11Map2Button><MatrixKB11Map2IO>0</MatrixKB11Map2IO><MatrixKB12Map2LED>36</MatrixKB12Map2LED><MatrixKB12Map2Button>0</MatrixKB12Map2Button><MatrixKB12Map2IO>27</MatrixKB12Map2IO><MatrixKB13Map2LED>38</MatrixKB13Map2LED><MatrixKB13Map2Button>0</MatrixKB13Map2Button><MatrixKB13Map2IO>29</MatrixKB13Map2IO><MatrixKB14Map2LED>0</MatrixKB14Map2LED><MatrixKB14Map2Button>0</MatrixKB14Map2Button><MatrixKB14Map2IO>0</MatrixKB14Map2IO><MatrixKB15Map2LED>0</MatrixKB15Map2LED><MatrixKB15Map2Button>0</MatrixKB15Map2Button><MatrixKB15Map2IO>0</MatrixKB15Map2IO><MatrixKB16Map2LED>0</MatrixKB16Map2LED><MatrixKB16Map2Button>0</MatrixKB16Map2Button><MatrixKB16Map2IO>0</MatrixKB16Map2IO><MatrixKB17Map2LED>0</MatrixKB17Map2LED><MatrixKB17Map2Button>0</MatrixKB17Map2Button><MatrixKB17Map2IO>0</MatrixKB17Map2IO><MatrixKB18Map2LED>0</MatrixKB18Map2LED><MatrixKB18Map2Button>0</MatrixKB18Map2Button><MatrixKB18Map2IO>0</MatrixKB18Map2IO><MatrixKB19Map2LED>0</MatrixKB19Map2LED><MatrixKB19Map2Button>141</MatrixKB19Map2Button><MatrixKB19Map2IO>23</MatrixKB19Map2IO><MatrixKB20Map2LED>0</MatrixKB20Map2LED><MatrixKB20Map2Button>0</MatrixKB20Map2Button><MatrixKB20Map2IO>29</MatrixKB20Map2IO><MatrixKB21Map2LED>0</MatrixKB21Map2LED><MatrixKB21Map2Button>0</MatrixKB21Map2Button><MatrixKB21Map2IO>0</MatrixKB21Map2IO><MatrixKB22Map2LED>0</MatrixKB22Map2LED><MatrixKB22Map2Button>0</MatrixKB22Map2Button><MatrixKB22Map2IO>0</MatrixKB22Map2IO><MatrixKB23Map2LED>0</MatrixKB23Map2LED><MatrixKB23Map2Button>0</MatrixKB23Map2Button><MatrixKB23Map2IO>0</MatrixKB23Map2IO><MatrixKB24Map2LED>0</MatrixKB24Map2LED><MatrixKB24Map2Button>0</MatrixKB24Map2Button><MatrixKB24Map2IO>0</MatrixKB24Map2IO><MatrixKB25Map2LED>0</MatrixKB25Map2LED><MatrixKB25Map2Button>0</MatrixKB25Map2Button><MatrixKB25Map2IO>0</MatrixKB25Map2IO><MatrixKB26Map2LED>0</MatrixKB26Map2LED><MatrixKB26Map2Button>0</MatrixKB26Map2Button><MatrixKB26Map2IO>0</MatrixKB26Map2IO><MatrixKB27Map2LED>0</MatrixKB27Map2LED><MatrixKB27Map2Button>0</MatrixKB27Map2Button><MatrixKB27Map2IO>0</MatrixKB27Map2IO><MatrixKB28Map2LED>0</MatrixKB28Map2LED><MatrixKB28Map2Button>0</MatrixKB28Map2Button><MatrixKB28Map2IO>0</MatrixKB28Map2IO><MatrixKB29Map2LED>0</MatrixKB29Map2LED><MatrixKB29Map2Button>0</MatrixKB29Map2Button><MatrixKB29Map2IO>0</MatrixKB29Map2IO><MatrixKB30Map2LED>0</MatrixKB30Map2LED><MatrixKB30Map2Button>0</MatrixKB30Map2Button><MatrixKB30Map2IO>0</MatrixKB30Map2IO><MatrixKB31Map2LED>0</MatrixKB31Map2LED><MatrixKB31Map2Button>0</MatrixKB31Map2Button><MatrixKB31Map2IO>0</MatrixKB31Map2IO><MatrixKB32Map2LED>0</MatrixKB32Map2LED><MatrixKB32Map2Button>0</MatrixKB32Map2Button><MatrixKB32Map2IO>0</MatrixKB32Map2IO><MatrixKB33Map2LED>0</MatrixKB33Map2LED><MatrixKB33Map2Button>0</MatrixKB33Map2Button><MatrixKB33Map2IO>0</MatrixKB33Map2IO><MatrixKB34Map2LED>0</MatrixKB34Map2LED><MatrixKB34Map2Button>0</MatrixKB34Map2Button><MatrixKB34Map2IO>0</MatrixKB34Map2IO><MatrixKB35Map2LED>0</MatrixKB35Map2LED><MatrixKB35Map2Button>0</MatrixKB35Map2Button><MatrixKB35Map2IO>0</MatrixKB35Map2IO><MatrixKB36Map2LED>0</MatrixKB36Map2LED><MatrixKB36Map2Button>0</MatrixKB36Map2Button><MatrixKB36Map2IO>0</MatrixKB36Map2IO><MatrixKB37Map2LED>0</MatrixKB37Map2LED><MatrixKB37Map2Button>0</MatrixKB37Map2Button><MatrixKB37Map2IO>0</MatrixKB37Map2IO><MatrixKB38Map2LED>0</MatrixKB38Map2LED><MatrixKB38Map2Button>0</MatrixKB38Map2Button><MatrixKB38Map2IO>0</MatrixKB38Map2IO><MatrixKB39Map2LED>0</MatrixKB39Map2LED><MatrixKB39Map2Button>0</MatrixKB39Map2Button><MatrixKB39Map2IO>0</MatrixKB39Map2IO><MatrixKB40Map2LED>0</MatrixKB40Map2LED><MatrixKB40Map2Button>0</MatrixKB40Map2Button><MatrixKB40Map2IO>0</MatrixKB40Map2IO><MatrixKB41Map2LED>0</MatrixKB41Map2LED><MatrixKB41Map2Button>0</MatrixKB41Map2Button><MatrixKB41Map2IO>0</MatrixKB41Map2IO><MatrixKB42Map2LED>0</MatrixKB42Map2LED><MatrixKB42Map2Button>0</MatrixKB42Map2Button><MatrixKB42Map2IO>0</MatrixKB42Map2IO><MatrixKB43Map2LED>0</MatrixKB43Map2LED><MatrixKB43Map2Button>0</MatrixKB43Map2Button><MatrixKB43Map2IO>0</MatrixKB43Map2IO><MatrixKB44Map2LED>0</MatrixKB44Map2LED><MatrixKB44Map2Button>0</MatrixKB44Map2Button><MatrixKB44Map2IO>0</MatrixKB44Map2IO><MatrixKB45Map2LED>0</MatrixKB45Map2LED><MatrixKB45Map2Button>0</MatrixKB45Map2Button><MatrixKB45Map2IO>0</MatrixKB45Map2IO><MatrixKB46Map2LED>0</MatrixKB46Map2LED><MatrixKB46Map2Button>0</MatrixKB46Map2Button><MatrixKB46Map2IO>0</MatrixKB46Map2IO><MatrixKB47Map2LED>0</MatrixKB47Map2LED><MatrixKB47Map2Button>0</MatrixKB47Map2Button><MatrixKB47Map2IO>0</MatrixKB47Map2IO><MatrixKB48Map2LED>0</MatrixKB48Map2LED><MatrixKB48Map2Button>0</MatrixKB48Map2Button><MatrixKB48Map2IO>0</MatrixKB48Map2IO><MatrixKB49Map2LED>0</MatrixKB49Map2LED><MatrixKB49Map2Button>0</MatrixKB49Map2Button><MatrixKB49Map2IO>0</MatrixKB49Map2IO><MatrixKB50Map2LED>0</MatrixKB50Map2LED><MatrixKB50Map2Button>0</MatrixKB50Map2Button><MatrixKB50Map2IO>0</MatrixKB50Map2IO><MatrixKB51Map2LED>0</MatrixKB51Map2LED><MatrixKB51Map2Button>0</MatrixKB51Map2Button><MatrixKB51Map2IO>0</MatrixKB51Map2IO><MatrixKB52Map2LED>0</MatrixKB52Map2LED><MatrixKB52Map2Button>0</MatrixKB52Map2Button><MatrixKB52Map2IO>0</MatrixKB52Map2IO><MatrixKB53Map2LED>0</MatrixKB53Map2LED><MatrixKB53Map2Button>0</MatrixKB53Map2Button><MatrixKB53Map2IO>0</MatrixKB53Map2IO><MatrixKB54Map2LED>0</MatrixKB54Map2LED><MatrixKB54Map2Button>0</MatrixKB54Map2Button><MatrixKB54Map2IO>0</MatrixKB54Map2IO><MatrixKB55Map2LED>0</MatrixKB55Map2LED><MatrixKB55Map2Button>0</MatrixKB55Map2Button><MatrixKB55Map2IO>0</MatrixKB55Map2IO><MatrixKB56Map2LED>0</MatrixKB56Map2LED><MatrixKB56Map2Button>0</MatrixKB56Map2Button><MatrixKB56Map2IO>0</MatrixKB56Map2IO><MatrixKB57Map2LED>0</MatrixKB57Map2LED><MatrixKB57Map2Button>0</MatrixKB57Map2Button><MatrixKB57Map2IO>0</MatrixKB57Map2IO><MatrixKB58Map2LED>0</MatrixKB58Map2LED><MatrixKB58Map2Button>0</MatrixKB58Map2Button><MatrixKB58Map2IO>0</MatrixKB58Map2IO><MatrixKB59Map2LED>0</MatrixKB59Map2LED><MatrixKB59Map2Button>0</MatrixKB59Map2Button><MatrixKB59Map2IO>0</MatrixKB59Map2IO><MatrixKB60Map2LED>0</MatrixKB60Map2LED><MatrixKB60Map2Button>0</MatrixKB60Map2Button><MatrixKB60Map2IO>0</MatrixKB60Map2IO><MatrixKB61Map2LED>0</MatrixKB61Map2LED><MatrixKB61Map2Button>0</MatrixKB61Map2Button><MatrixKB61Map2IO>0</MatrixKB61Map2IO><MatrixKB62Map2LED>0</MatrixKB62Map2LED><MatrixKB62Map2Button>0</MatrixKB62Map2Button><MatrixKB62Map2IO>0</MatrixKB62Map2IO><MatrixKB63Map2LED>0</MatrixKB63Map2LED><MatrixKB63Map2Button>0</MatrixKB63Map2Button><MatrixKB63Map2IO>0</MatrixKB63Map2IO><MatrixKB64Map2LED>0</MatrixKB64Map2LED><MatrixKB64Map2Button>0</MatrixKB64Map2Button><MatrixKB64Map2IO>0</MatrixKB64Map2IO><MatrixKB65Map2LED>0</MatrixKB65Map2LED><MatrixKB65Map2Button>0</MatrixKB65Map2Button><MatrixKB65Map2IO>0</MatrixKB65Map2IO><MatrixKB66Map2LED>0</MatrixKB66Map2LED><MatrixKB66Map2Button>0</MatrixKB66Map2Button><MatrixKB66Map2IO>0</MatrixKB66Map2IO><MatrixKB67Map2LED>0</MatrixKB67Map2LED><MatrixKB67Map2Button>0</MatrixKB67Map2Button><MatrixKB67Map2IO>0</MatrixKB67Map2IO><MatrixKB68Map2LED>0</MatrixKB68Map2LED><MatrixKB68Map2Button>0</MatrixKB68Map2Button><MatrixKB68Map2IO>0</MatrixKB68Map2IO><MatrixKB69Map2LED>0</MatrixKB69Map2LED><MatrixKB69Map2Button>0</MatrixKB69Map2Button><MatrixKB69Map2IO>0</MatrixKB69Map2IO><MatrixKB70Map2LED>0</MatrixKB70Map2LED><MatrixKB70Map2Button>0</MatrixKB70Map2Button><MatrixKB70Map2IO>0</MatrixKB70Map2IO><MatrixKB71Map2LED>0</MatrixKB71Map2LED><MatrixKB71Map2Button>0</MatrixKB71Map2Button><MatrixKB71Map2IO>0</MatrixKB71Map2IO><MatrixKB72Map2LED>0</MatrixKB72Map2LED><MatrixKB72Map2Button>0</MatrixKB72Map2Button><MatrixKB72Map2IO>0</MatrixKB72Map2IO><MatrixKB73Map2LED>0</MatrixKB73Map2LED><MatrixKB73Map2Button>0</MatrixKB73Map2Button><MatrixKB73Map2IO>0</MatrixKB73Map2IO><MatrixKB74Map2LED>0</MatrixKB74Map2LED><MatrixKB74Map2Button>0</MatrixKB74Map2Button><MatrixKB74Map2IO>0</MatrixKB74Map2IO><MatrixKB75Map2LED>0</MatrixKB75Map2LED><MatrixKB75Map2Button>0</MatrixKB75Map2Button><MatrixKB75Map2IO>0</MatrixKB75Map2IO><MatrixKB76Map2LED>0</MatrixKB76Map2LED><MatrixKB76Map2Button>0</MatrixKB76Map2Button><MatrixKB76Map2IO>0</MatrixKB76Map2IO><MatrixKB77Map2LED>0</MatrixKB77Map2LED><MatrixKB77Map2Button>0</MatrixKB77Map2Button><MatrixKB77Map2IO>0</MatrixKB77Map2IO><MatrixKB78Map2LED>0</MatrixKB78Map2LED><MatrixKB78Map2Button>0</MatrixKB78Map2Button><MatrixKB78Map2IO>0</MatrixKB78Map2IO><MatrixKB79Map2LED>0</MatrixKB79Map2LED><MatrixKB79Map2Button>0</MatrixKB79Map2Button><MatrixKB79Map2IO>0</MatrixKB79Map2IO><MatrixKB80Map2LED>0</MatrixKB80Map2LED><MatrixKB80Map2Button>0</MatrixKB80Map2Button><MatrixKB80Map2IO>0</MatrixKB80Map2IO><MatrixKB81Map2LED>0</MatrixKB81Map2LED><MatrixKB81Map2Button>0</MatrixKB81Map2Button><MatrixKB81Map2IO>0</MatrixKB81Map2IO><MatrixKB82Map2LED>0</MatrixKB82Map2LED><MatrixKB82Map2Button>0</MatrixKB82Map2Button><MatrixKB82Map2IO>0</MatrixKB82Map2IO><MatrixKB83Map2LED>0</MatrixKB83Map2LED><MatrixKB83Map2Button>0</MatrixKB83Map2Button><MatrixKB83Map2IO>0</MatrixKB83Map2IO><MatrixKB84Map2LED>0</MatrixKB84Map2LED><MatrixKB84Map2Button>0</MatrixKB84Map2Button><MatrixKB84Map2IO>0</MatrixKB84Map2IO><MatrixKB85Map2LED>0</MatrixKB85Map2LED><MatrixKB85Map2Button>0</MatrixKB85Map2Button><MatrixKB85Map2IO>0</MatrixKB85Map2IO><MatrixKB86Map2LED>0</MatrixKB86Map2LED><MatrixKB86Map2Button>0</MatrixKB86Map2Button><MatrixKB86Map2IO>0</MatrixKB86Map2IO><MatrixKB87Map2LED>0</MatrixKB87Map2LED><MatrixKB87Map2Button>0</MatrixKB87Map2Button><MatrixKB87Map2IO>0</MatrixKB87Map2IO><MatrixKB88Map2LED>0</MatrixKB88Map2LED><MatrixKB88Map2Button>0</MatrixKB88Map2Button><MatrixKB88Map2IO>0</MatrixKB88Map2IO><MatrixKB89Map2LED>0</MatrixKB89Map2LED><MatrixKB89Map2Button>0</MatrixKB89Map2Button><MatrixKB89Map2IO>0</MatrixKB89Map2IO><MatrixKB90Map2LED>0</MatrixKB90Map2LED><MatrixKB90Map2Button>0</MatrixKB90Map2Button><MatrixKB90Map2IO>0</MatrixKB90Map2IO><MatrixKB91Map2LED>0</MatrixKB91Map2LED><MatrixKB91Map2Button>0</MatrixKB91Map2Button><MatrixKB91Map2IO>0</MatrixKB91Map2IO><MatrixKB92Map2LED>0</MatrixKB92Map2LED><MatrixKB92Map2Button>0</MatrixKB92Map2Button><MatrixKB92Map2IO>0</MatrixKB92Map2IO><MatrixKB93Map2LED>0</MatrixKB93Map2LED><MatrixKB93Map2Button>0</MatrixKB93Map2Button><MatrixKB93Map2IO>0</MatrixKB93Map2IO><MatrixKB94Map2LED>0</MatrixKB94Map2LED><MatrixKB94Map2Button>0</MatrixKB94Map2Button><MatrixKB94Map2IO>0</MatrixKB94Map2IO><MatrixKB95Map2LED>0</MatrixKB95Map2LED><MatrixKB95Map2Button>0</MatrixKB95Map2Button><MatrixKB95Map2IO>0</MatrixKB95Map2IO><MatrixKB96Map2LED>0</MatrixKB96Map2LED><MatrixKB96Map2Button>0</MatrixKB96Map2Button><MatrixKB96Map2IO>0</MatrixKB96Map2IO><MatrixKB97Map2LED>0</MatrixKB97Map2LED><MatrixKB97Map2Button>0</MatrixKB97Map2Button><MatrixKB97Map2IO>0</MatrixKB97Map2IO><MatrixKB98Map2LED>0</MatrixKB98Map2LED><MatrixKB98Map2Button>0</MatrixKB98Map2Button><MatrixKB98Map2IO>0</MatrixKB98Map2IO><MatrixKB99Map2LED>0</MatrixKB99Map2LED><MatrixKB99Map2Button>0</MatrixKB99Map2Button><MatrixKB99Map2IO>0</MatrixKB99Map2IO><MatrixKB100Map2LED>0</MatrixKB100Map2LED><MatrixKB100Map2Button>0</MatrixKB100Map2Button><MatrixKB100Map2IO>0</MatrixKB100Map2IO><MatrixKB101Map2LED>0</MatrixKB101Map2LED><MatrixKB101Map2Button>0</MatrixKB101Map2Button><MatrixKB101Map2IO>0</MatrixKB101Map2IO><MatrixKB102Map2LED>0</MatrixKB102Map2LED><MatrixKB102Map2Button>0</MatrixKB102Map2Button><MatrixKB102Map2IO>0</MatrixKB102Map2IO><MatrixKB103Map2LED>0</MatrixKB103Map2LED><MatrixKB103Map2Button>0</MatrixKB103Map2Button><MatrixKB103Map2IO>0</MatrixKB103Map2IO><MatrixKB104Map2LED>0</MatrixKB104Map2LED><MatrixKB104Map2Button>0</MatrixKB104Map2Button><MatrixKB104Map2IO>0</MatrixKB104Map2IO><MatrixKB105Map2LED>0</MatrixKB105Map2LED><MatrixKB105Map2Button>0</MatrixKB105Map2Button><MatrixKB105Map2IO>0</MatrixKB105Map2IO><MatrixKB106Map2LED>0</MatrixKB106Map2LED><MatrixKB106Map2Button>0</MatrixKB106Map2Button><MatrixKB106Map2IO>0</MatrixKB106Map2IO><MatrixKB107Map2LED>0</MatrixKB107Map2LED><MatrixKB107Map2Button>0</MatrixKB107Map2Button><MatrixKB107Map2IO>0</MatrixKB107Map2IO><MatrixKB108Map2LED>0</MatrixKB108Map2LED><MatrixKB108Map2Button>0</MatrixKB108Map2Button><MatrixKB108Map2IO>0</MatrixKB108Map2IO><MatrixKB109Map2LED>0</MatrixKB109Map2LED><MatrixKB109Map2Button>0</MatrixKB109Map2Button><MatrixKB109Map2IO>0</MatrixKB109Map2IO><MatrixKB110Map2LED>0</MatrixKB110Map2LED><MatrixKB110Map2Button>0</MatrixKB110Map2Button><MatrixKB110Map2IO>0</MatrixKB110Map2IO><MatrixKB111Map2LED>0</MatrixKB111Map2LED><MatrixKB111Map2Button>0</MatrixKB111Map2Button><MatrixKB111Map2IO>0</MatrixKB111Map2IO><MatrixKB112Map2LED>0</MatrixKB112Map2LED><MatrixKB112Map2Button>0</MatrixKB112Map2Button><MatrixKB112Map2IO>0</MatrixKB112Map2IO><MatrixKB113Map2LED>0</MatrixKB113Map2LED><MatrixKB113Map2Button>0</MatrixKB113Map2Button><MatrixKB113Map2IO>0</MatrixKB113Map2IO><MatrixKB114Map2LED>0</MatrixKB114Map2LED><MatrixKB114Map2Button>0</MatrixKB114Map2Button><MatrixKB114Map2IO>0</MatrixKB114Map2IO><MatrixKB115Map2LED>0</MatrixKB115Map2LED><MatrixKB115Map2Button>0</MatrixKB115Map2Button><MatrixKB115Map2IO>0</MatrixKB115Map2IO><MatrixKB116Map2LED>0</MatrixKB116Map2LED><MatrixKB116Map2Button>0</MatrixKB116Map2Button><MatrixKB116Map2IO>0</MatrixKB116Map2IO><MatrixKB117Map2LED>0</MatrixKB117Map2LED><MatrixKB117Map2Button>0</MatrixKB117Map2Button><MatrixKB117Map2IO>0</MatrixKB117Map2IO><MatrixKB118Map2LED>0</MatrixKB118Map2LED><MatrixKB118Map2Button>0</MatrixKB118Map2Button><MatrixKB118Map2IO>0</MatrixKB118Map2IO><MatrixKB119Map2LED>0</MatrixKB119Map2LED><MatrixKB119Map2Button>0</MatrixKB119Map2Button><MatrixKB119Map2IO>0</MatrixKB119Map2IO><MatrixKB120Map2LED>0</MatrixKB120Map2LED><MatrixKB120Map2Button>0</MatrixKB120Map2Button><MatrixKB120Map2IO>0</MatrixKB120Map2IO><MatrixKB121Map2LED>0</MatrixKB121Map2LED><MatrixKB121Map2Button>0</MatrixKB121Map2Button><MatrixKB121Map2IO>0</MatrixKB121Map2IO><MatrixKB122Map2LED>0</MatrixKB122Map2LED><MatrixKB122Map2Button>0</MatrixKB122Map2Button><MatrixKB122Map2IO>0</MatrixKB122Map2IO><MatrixKB123Map2LED>0</MatrixKB123Map2LED><MatrixKB123Map2Button>0</MatrixKB123Map2Button><MatrixKB123Map2IO>0</MatrixKB123Map2IO><MatrixKB124Map2LED>0</MatrixKB124Map2LED><MatrixKB124Map2Button>0</MatrixKB124Map2Button><MatrixKB124Map2IO>0</MatrixKB124Map2IO><MatrixKB125Map2LED>0</MatrixKB125Map2LED><MatrixKB125Map2Button>0</MatrixKB125Map2Button><MatrixKB125Map2IO>0</MatrixKB125Map2IO><MatrixKB126Map2LED>0</MatrixKB126Map2LED><MatrixKB126Map2Button>0</MatrixKB126Map2Button><MatrixKB126Map2IO>0</MatrixKB126Map2IO><MatrixKB127Map2LED>0</MatrixKB127Map2LED><MatrixKB127Map2Button>0</MatrixKB127Map2Button><MatrixKB127Map2IO>0</MatrixKB127Map2IO><MatrixKB128Map2LED>0</MatrixKB128Map2LED><MatrixKB128Map2Button>0</MatrixKB128Map2Button><MatrixKB128Map2IO>0</MatrixKB128Map2IO><MatrixWidth>0</MatrixWidth><MatrixHeight>0</MatrixHeight><MatrixEnabled>0</MatrixEnabled><MatrixRow1>0</MatrixRow1><MatrixRow2>0</MatrixRow2><MatrixRow3>0</MatrixRow3><MatrixRow4>0</MatrixRow4><MatrixRow5>0</MatrixRow5><MatrixRow6>0</MatrixRow6><MatrixRow7>0</MatrixRow7><MatrixRow8>0</MatrixRow8><MatrixRow9>0</MatrixRow9><MatrixRow10>0</MatrixRow10><MatrixRow11>0</MatrixRow11><MatrixRow12>0</MatrixRow12><MatrixRow13>0</MatrixRow13><MatrixRow14>0</MatrixRow14><MatrixRow15>0</MatrixRow15><MatrixRow16>0</MatrixRow16><MatrixColumn1>0</MatrixColumn1><MatrixColumn2>0</MatrixColumn2><MatrixColumn3>0</MatrixColumn3><MatrixColumn4>0</MatrixColumn4><MatrixColumn5>0</MatrixColumn5><MatrixColumn6>0</MatrixColumn6><MatrixColumn7>0</MatrixColumn7><MatrixColumn8>0</MatrixColumn8><PoExtBus1Map2LED>0</PoExtBus1Map2LED><PoExtBus1Map2IO>0</PoExtBus1Map2IO><PoExtBus1Invert>0</PoExtBus1Invert><PoExtBus2Map2LED>0</PoExtBus2Map2LED><PoExtBus2Map2IO>0</PoExtBus2Map2IO><PoExtBus2Invert>0</PoExtBus2Invert><PoExtBus3Map2LED>0</PoExtBus3Map2LED><PoExtBus3Map2IO>0</PoExtBus3Map2IO><PoExtBus3Invert>0</PoExtBus3Invert><PoExtBus4Map2LED>0</PoExtBus4Map2LED><PoExtBus4Map2IO>0</PoExtBus4Map2IO><PoExtBus4Invert>0</PoExtBus4Invert><PoExtBus5Map2LED>0</PoExtBus5Map2LED><PoExtBus5Map2IO>0</PoExtBus5Map2IO><PoExtBus5Invert>0</PoExtBus5Invert><PoExtBus6Map2LED>0</PoExtBus6Map2LED><PoExtBus6Map2IO>0</PoExtBus6Map2IO><PoExtBus6Invert>0</PoExtBus6Invert><PoExtBus7Map2LED>0</PoExtBus7Map2LED><PoExtBus7Map2IO>0</PoExtBus7Map2IO><PoExtBus7Invert>0</PoExtBus7Invert><PoExtBus8Map2LED>0</PoExtBus8Map2LED><PoExtBus8Map2IO>0</PoExtBus8Map2IO><PoExtBus8Invert>0</PoExtBus8Invert><PoExtBus9Map2LED>0</PoExtBus9Map2LED><PoExtBus9Map2IO>0</PoExtBus9Map2IO><PoExtBus9Invert>0</PoExtBus9Invert><PoExtBus10Map2LED>0</PoExtBus10Map2LED><PoExtBus10Map2IO>0</PoExtBus10Map2IO><PoExtBus10Invert>0</PoExtBus10Invert><PoExtBus11Map2LED>0</PoExtBus11Map2LED><PoExtBus11Map2IO>0</PoExtBus11Map2IO><PoExtBus11Invert>0</PoExtBus11Invert><PoExtBus12Map2LED>0</PoExtBus12Map2LED><PoExtBus12Map2IO>0</PoExtBus12Map2IO><PoExtBus12Invert>0</PoExtBus12Invert><PoExtBus13Map2LED>0</PoExtBus13Map2LED><PoExtBus13Map2IO>0</PoExtBus13Map2IO><PoExtBus13Invert>0</PoExtBus13Invert><PoExtBus14Map2LED>0</PoExtBus14Map2LED><PoExtBus14Map2IO>0</PoExtBus14Map2IO><PoExtBus14Invert>0</PoExtBus14Invert><PoExtBus15Map2LED>0</PoExtBus15Map2LED><PoExtBus15Map2IO>0</PoExtBus15Map2IO><PoExtBus15Invert>0</PoExtBus15Invert><PoExtBus16Map2LED>0</PoExtBus16Map2LED><PoExtBus16Map2IO>0</PoExtBus16Map2IO><PoExtBus16Invert>0</PoExtBus16Invert><PoExtBus17Map2LED>0</PoExtBus17Map2LED><PoExtBus17Map2IO>0</PoExtBus17Map2IO><PoExtBus17Invert>0</PoExtBus17Invert><PoExtBus18Map2LED>0</PoExtBus18Map2LED><PoExtBus18Map2IO>0</PoExtBus18Map2IO><PoExtBus18Invert>0</PoExtBus18Invert><PoExtBus19Map2LED>0</PoExtBus19Map2LED><PoExtBus19Map2IO>0</PoExtBus19Map2IO><PoExtBus19Invert>0</PoExtBus19Invert><PoExtBus20Map2LED>0</PoExtBus20Map2LED><PoExtBus20Map2IO>0</PoExtBus20Map2IO><PoExtBus20Invert>0</PoExtBus20Invert><PoExtBus21Map2LED>0</PoExtBus21Map2LED><PoExtBus21Map2IO>0</PoExtBus21Map2IO><PoExtBus21Invert>0</PoExtBus21Invert><PoExtBus22Map2LED>0</PoExtBus22Map2LED><PoExtBus22Map2IO>0</PoExtBus22Map2IO><PoExtBus22Invert>0</PoExtBus22Invert><PoExtBus23Map2LED>0</PoExtBus23Map2LED><PoExtBus23Map2IO>0</PoExtBus23Map2IO><PoExtBus23Invert>0</PoExtBus23Invert><PoExtBus24Map2LED>0</PoExtBus24Map2LED><PoExtBus24Map2IO>0</PoExtBus24Map2IO><PoExtBus24Invert>0</PoExtBus24Invert><PoExtBus25Map2LED>0</PoExtBus25Map2LED><PoExtBus25Map2IO>0</PoExtBus25Map2IO><PoExtBus25Invert>0</PoExtBus25Invert><PoExtBus26Map2LED>0</PoExtBus26Map2LED><PoExtBus26Map2IO>0</PoExtBus26Map2IO><PoExtBus26Invert>0</PoExtBus26Invert><PoExtBus27Map2LED>0</PoExtBus27Map2LED><PoExtBus27Map2IO>0</PoExtBus27Map2IO><PoExtBus27Invert>0</PoExtBus27Invert><PoExtBus28Map2LED>0</PoExtBus28Map2LED><PoExtBus28Map2IO>0</PoExtBus28Map2IO><PoExtBus28Invert>0</PoExtBus28Invert><PoExtBus29Map2LED>0</PoExtBus29Map2LED><PoExtBus29Map2IO>0</PoExtBus29Map2IO><PoExtBus29Invert>0</PoExtBus29Invert><PoExtBus30Map2LED>0</PoExtBus30Map2LED><PoExtBus30Map2IO>0</PoExtBus30Map2IO><PoExtBus30Invert>0</PoExtBus30Invert><PoExtBus31Map2LED>0</PoExtBus31Map2LED><PoExtBus31Map2IO>0</PoExtBus31Map2IO><PoExtBus31Invert>0</PoExtBus31Invert><PoExtBus32Map2LED>0</PoExtBus32Map2LED><PoExtBus32Map2IO>0</PoExtBus32Map2IO><PoExtBus32Invert>0</PoExtBus32Invert><PoExtBus33Map2LED>0</PoExtBus33Map2LED><PoExtBus33Map2IO>0</PoExtBus33Map2IO><PoExtBus33Invert>0</PoExtBus33Invert><PoExtBus34Map2LED>0</PoExtBus34Map2LED><PoExtBus34Map2IO>0</PoExtBus34Map2IO><PoExtBus34Invert>0</PoExtBus34Invert><PoExtBus35Map2LED>0</PoExtBus35Map2LED><PoExtBus35Map2IO>0</PoExtBus35Map2IO><PoExtBus35Invert>0</PoExtBus35Invert><PoExtBus36Map2LED>0</PoExtBus36Map2LED><PoExtBus36Map2IO>0</PoExtBus36Map2IO><PoExtBus36Invert>0</PoExtBus36Invert><PoExtBus37Map2LED>0</PoExtBus37Map2LED><PoExtBus37Map2IO>0</PoExtBus37Map2IO><PoExtBus37Invert>0</PoExtBus37Invert><PoExtBus38Map2LED>0</PoExtBus38Map2LED><PoExtBus38Map2IO>0</PoExtBus38Map2IO><PoExtBus38Invert>0</PoExtBus38Invert><PoExtBus39Map2LED>0</PoExtBus39Map2LED><PoExtBus39Map2IO>0</PoExtBus39Map2IO><PoExtBus39Invert>0</PoExtBus39Invert><PoExtBus40Map2LED>0</PoExtBus40Map2LED><PoExtBus40Map2IO>0</PoExtBus40Map2IO><PoExtBus40Invert>0</PoExtBus40Invert><PoExtBus41Map2LED>0</PoExtBus41Map2LED><PoExtBus41Map2IO>0</PoExtBus41Map2IO><PoExtBus41Invert>0</PoExtBus41Invert><PoExtBus42Map2LED>0</PoExtBus42Map2LED><PoExtBus42Map2IO>0</PoExtBus42Map2IO><PoExtBus42Invert>0</PoExtBus42Invert><PoExtBus43Map2LED>0</PoExtBus43Map2LED><PoExtBus43Map2IO>0</PoExtBus43Map2IO><PoExtBus43Invert>0</PoExtBus43Invert><PoExtBus44Map2LED>0</PoExtBus44Map2LED><PoExtBus44Map2IO>0</PoExtBus44Map2IO><PoExtBus44Invert>0</PoExtBus44Invert><PoExtBus45Map2LED>0</PoExtBus45Map2LED><PoExtBus45Map2IO>0</PoExtBus45Map2IO><PoExtBus45Invert>0</PoExtBus45Invert><PoExtBus46Map2LED>0</PoExtBus46Map2LED><PoExtBus46Map2IO>0</PoExtBus46Map2IO><PoExtBus46Invert>0</PoExtBus46Invert><PoExtBus47Map2LED>0</PoExtBus47Map2LED><PoExtBus47Map2IO>0</PoExtBus47Map2IO><PoExtBus47Invert>0</PoExtBus47Invert><PoExtBus48Map2LED>0</PoExtBus48Map2LED><PoExtBus48Map2IO>0</PoExtBus48Map2IO><PoExtBus48Invert>0</PoExtBus48Invert><PoExtBus49Map2LED>0</PoExtBus49Map2LED><PoExtBus49Map2IO>0</PoExtBus49Map2IO><PoExtBus49Invert>0</PoExtBus49Invert><PoExtBus50Map2LED>0</PoExtBus50Map2LED><PoExtBus50Map2IO>0</PoExtBus50Map2IO><PoExtBus50Invert>0</PoExtBus50Invert><PoExtBus51Map2LED>0</PoExtBus51Map2LED><PoExtBus51Map2IO>0</PoExtBus51Map2IO><PoExtBus51Invert>0</PoExtBus51Invert><PoExtBus52Map2LED>0</PoExtBus52Map2LED><PoExtBus52Map2IO>0</PoExtBus52Map2IO><PoExtBus52Invert>0</PoExtBus52Invert><PoExtBus53Map2LED>0</PoExtBus53Map2LED><PoExtBus53Map2IO>0</PoExtBus53Map2IO><PoExtBus53Invert>0</PoExtBus53Invert><PoExtBus54Map2LED>0</PoExtBus54Map2LED><PoExtBus54Map2IO>0</PoExtBus54Map2IO><PoExtBus54Invert>0</PoExtBus54Invert><PoExtBus55Map2LED>0</PoExtBus55Map2LED><PoExtBus55Map2IO>0</PoExtBus55Map2IO><PoExtBus55Invert>0</PoExtBus55Invert><PoExtBus56Map2LED>0</PoExtBus56Map2LED><PoExtBus56Map2IO>0</PoExtBus56Map2IO><PoExtBus56Invert>0</PoExtBus56Invert><PoExtBus57Map2LED>0</PoExtBus57Map2LED><PoExtBus57Map2IO>0</PoExtBus57Map2IO><PoExtBus57Invert>0</PoExtBus57Invert><PoExtBus58Map2LED>0</PoExtBus58Map2LED><PoExtBus58Map2IO>0</PoExtBus58Map2IO><PoExtBus58Invert>0</PoExtBus58Invert><PoExtBus59Map2LED>0</PoExtBus59Map2LED><PoExtBus59Map2IO>0</PoExtBus59Map2IO><PoExtBus59Invert>0</PoExtBus59Invert><PoExtBus60Map2LED>0</PoExtBus60Map2LED><PoExtBus60Map2IO>0</PoExtBus60Map2IO><PoExtBus60Invert>0</PoExtBus60Invert><PoExtBus61Map2LED>0</PoExtBus61Map2LED><PoExtBus61Map2IO>0</PoExtBus61Map2IO><PoExtBus61Invert>0</PoExtBus61Invert><PoExtBus62Map2LED>0</PoExtBus62Map2LED><PoExtBus62Map2IO>0</PoExtBus62Map2IO><PoExtBus62Invert>0</PoExtBus62Invert><PoExtBus63Map2LED>0</PoExtBus63Map2LED><PoExtBus63Map2IO>0</PoExtBus63Map2IO><PoExtBus63Invert>0</PoExtBus63Invert><PoExtBus64Map2LED>0</PoExtBus64Map2LED><PoExtBus64Map2IO>0</PoExtBus64Map2IO><PoExtBus64Invert>0</PoExtBus64Invert><PoExtBus65Map2LED>0</PoExtBus65Map2LED><PoExtBus65Map2IO>0</PoExtBus65Map2IO><PoExtBus65Invert>0</PoExtBus65Invert><PoExtBus66Map2LED>0</PoExtBus66Map2LED><PoExtBus66Map2IO>0</PoExtBus66Map2IO><PoExtBus66Invert>0</PoExtBus66Invert><PoExtBus67Map2LED>0</PoExtBus67Map2LED><PoExtBus67Map2IO>0</PoExtBus67Map2IO><PoExtBus67Invert>0</PoExtBus67Invert><PoExtBus68Map2LED>0</PoExtBus68Map2LED><PoExtBus68Map2IO>0</PoExtBus68Map2IO><PoExtBus68Invert>0</PoExtBus68Invert><PoExtBus69Map2LED>0</PoExtBus69Map2LED><PoExtBus69Map2IO>0</PoExtBus69Map2IO><PoExtBus69Invert>0</PoExtBus69Invert><PoExtBus70Map2LED>0</PoExtBus70Map2LED><PoExtBus70Map2IO>0</PoExtBus70Map2IO><PoExtBus70Invert>0</PoExtBus70Invert><PoExtBus71Map2LED>0</PoExtBus71Map2LED><PoExtBus71Map2IO>0</PoExtBus71Map2IO><PoExtBus71Invert>0</PoExtBus71Invert><PoExtBus72Map2LED>0</PoExtBus72Map2LED><PoExtBus72Map2IO>0</PoExtBus72Map2IO><PoExtBus72Invert>0</PoExtBus72Invert><PoExtBus73Map2LED>0</PoExtBus73Map2LED><PoExtBus73Map2IO>0</PoExtBus73Map2IO><PoExtBus73Invert>0</PoExtBus73Invert><PoExtBus74Map2LED>0</PoExtBus74Map2LED><PoExtBus74Map2IO>0</PoExtBus74Map2IO><PoExtBus74Invert>0</PoExtBus74Invert><PoExtBus75Map2LED>0</PoExtBus75Map2LED><PoExtBus75Map2IO>0</PoExtBus75Map2IO><PoExtBus75Invert>0</PoExtBus75Invert><PoExtBus76Map2LED>0</PoExtBus76Map2LED><PoExtBus76Map2IO>0</PoExtBus76Map2IO><PoExtBus76Invert>0</PoExtBus76Invert><PoExtBus77Map2LED>0</PoExtBus77Map2LED><PoExtBus77Map2IO>0</PoExtBus77Map2IO><PoExtBus77Invert>0</PoExtBus77Invert><PoExtBus78Map2LED>0</PoExtBus78Map2LED><PoExtBus78Map2IO>0</PoExtBus78Map2IO><PoExtBus78Invert>0</PoExtBus78Invert><PoExtBus79Map2LED>0</PoExtBus79Map2LED><PoExtBus79Map2IO>0</PoExtBus79Map2IO><PoExtBus79Invert>0</PoExtBus79Invert><PoExtBus80Map2LED>0</PoExtBus80Map2LED><PoExtBus80Map2IO>0</PoExtBus80Map2IO><PoExtBus80Invert>0</PoExtBus80Invert><kbd48CNC_0_ToLED>0</kbd48CNC_0_ToLED><kbd48CNC_0_ToButton>0</kbd48CNC_0_ToButton><kbd48CNC_LEDto_0>0</kbd48CNC_LEDto_0><kbd48CNC_1_ToLED>0</kbd48CNC_1_ToLED><kbd48CNC_1_ToButton>0</kbd48CNC_1_ToButton><kbd48CNC_LEDto_1>0</kbd48CNC_LEDto_1><kbd48CNC_2_ToLED>0</kbd48CNC_2_ToLED><kbd48CNC_2_ToButton>0</kbd48CNC_2_ToButton><kbd48CNC_LEDto_2>0</kbd48CNC_LEDto_2><kbd48CNC_3_ToLED>0</kbd48CNC_3_ToLED><kbd48CNC_3_ToButton>0</kbd48CNC_3_ToButton><kbd48CNC_LEDto_3>0</kbd48CNC_LEDto_3><kbd48CNC_4_ToLED>0</kbd48CNC_4_ToLED><kbd48CNC_4_ToButton>0</kbd48CNC_4_ToButton><kbd48CNC_LEDto_4>0</kbd48CNC_LEDto_4><kbd48CNC_5_ToLED>0</kbd48CNC_5_ToLED><kbd48CNC_5_ToButton>0</kbd48CNC_5_ToButton><kbd48CNC_LEDto_5>0</kbd48CNC_LEDto_5><kbd48CNC_6_ToLED>0</kbd48CNC_6_ToLED><kbd48CNC_6_ToButton>0</kbd48CNC_6_ToButton><kbd48CNC_LEDto_6>0</kbd48CNC_LEDto_6><kbd48CNC_7_ToLED>0</kbd48CNC_7_ToLED><kbd48CNC_7_ToButton>0</kbd48CNC_7_ToButton><kbd48CNC_LEDto_7>0</kbd48CNC_LEDto_7><kbd48CNC_8_ToLED>0</kbd48CNC_8_ToLED><kbd48CNC_8_ToButton>0</kbd48CNC_8_ToButton><kbd48CNC_LEDto_8>0</kbd48CNC_LEDto_8><kbd48CNC_9_ToLED>0</kbd48CNC_9_ToLED><kbd48CNC_9_ToButton>0</kbd48CNC_9_ToButton><kbd48CNC_LEDto_9>0</kbd48CNC_LEDto_9><kbd48CNC_10_ToLED>0</kbd48CNC_10_ToLED><kbd48CNC_10_ToButton>0</kbd48CNC_10_ToButton><kbd48CNC_LEDto_10>0</kbd48CNC_LEDto_10><kbd48CNC_11_ToLED>0</kbd48CNC_11_ToLED><kbd48CNC_11_ToButton>0</kbd48CNC_11_ToButton><kbd48CNC_LEDto_11>0</kbd48CNC_LEDto_11><kbd48CNC_12_ToLED>0</kbd48CNC_12_ToLED><kbd48CNC_12_ToButton>0</kbd48CNC_12_ToButton><kbd48CNC_LEDto_12>0</kbd48CNC_LEDto_12><kbd48CNC_13_ToLED>0</kbd48CNC_13_ToLED><kbd48CNC_13_ToButton>0</kbd48CNC_13_ToButton><kbd48CNC_LEDto_13>0</kbd48CNC_LEDto_13><kbd48CNC_14_ToLED>0</kbd48CNC_14_ToLED><kbd48CNC_14_ToButton>0</kbd48CNC_14_ToButton><kbd48CNC_LEDto_14>0</kbd48CNC_LEDto_14><kbd48CNC_15_ToLED>0</kbd48CNC_15_ToLED><kbd48CNC_15_ToButton>0</kbd48CNC_15_ToButton><kbd48CNC_LEDto_15>0</kbd48CNC_LEDto_15><kbd48CNC_16_ToLED>0</kbd48CNC_16_ToLED><kbd48CNC_16_ToButton>0</kbd48CNC_16_ToButton><kbd48CNC_LEDto_16>0</kbd48CNC_LEDto_16><kbd48CNC_17_ToLED>0</kbd48CNC_17_ToLED><kbd48CNC_17_ToButton>0</kbd48CNC_17_ToButton><kbd48CNC_LEDto_17>0</kbd48CNC_LEDto_17><kbd48CNC_18_ToLED>0</kbd48CNC_18_ToLED><kbd48CNC_18_ToButton>0</kbd48CNC_18_ToButton><kbd48CNC_LEDto_18>0</kbd48CNC_LEDto_18><kbd48CNC_19_ToLED>0</kbd48CNC_19_ToLED><kbd48CNC_19_ToButton>0</kbd48CNC_19_ToButton><kbd48CNC_LEDto_19>0</kbd48CNC_LEDto_19><kbd48CNC_20_ToLED>0</kbd48CNC_20_ToLED><kbd48CNC_20_ToButton>0</kbd48CNC_20_ToButton><kbd48CNC_LEDto_20>0</kbd48CNC_LEDto_20><kbd48CNC_21_ToLED>0</kbd48CNC_21_ToLED><kbd48CNC_21_ToButton>0</kbd48CNC_21_ToButton><kbd48CNC_LEDto_21>0</kbd48CNC_LEDto_21><kbd48CNC_22_ToLED>0</kbd48CNC_22_ToLED><kbd48CNC_22_ToButton>0</kbd48CNC_22_ToButton><kbd48CNC_LEDto_22>0</kbd48CNC_LEDto_22><kbd48CNC_23_ToLED>0</kbd48CNC_23_ToLED><kbd48CNC_23_ToButton>0</kbd48CNC_23_ToButton><kbd48CNC_LEDto_23>0</kbd48CNC_LEDto_23><kbd48CNC_24_ToLED>0</kbd48CNC_24_ToLED><kbd48CNC_24_ToButton>0</kbd48CNC_24_ToButton><kbd48CNC_LEDto_24>0</kbd48CNC_LEDto_24><kbd48CNC_25_ToLED>0</kbd48CNC_25_ToLED><kbd48CNC_25_ToButton>0</kbd48CNC_25_ToButton><kbd48CNC_LEDto_25>0</kbd48CNC_LEDto_25><kbd48CNC_26_ToLED>0</kbd48CNC_26_ToLED><kbd48CNC_26_ToButton>0</kbd48CNC_26_ToButton><kbd48CNC_LEDto_26>0</kbd48CNC_LEDto_26><kbd48CNC_27_ToLED>0</kbd48CNC_27_ToLED><kbd48CNC_27_ToButton>0</kbd48CNC_27_ToButton><kbd48CNC_LEDto_27>0</kbd48CNC_LEDto_27><kbd48CNC_28_ToLED>0</kbd48CNC_28_ToLED><kbd48CNC_28_ToButton>0</kbd48CNC_28_ToButton><kbd48CNC_LEDto_28>0</kbd48CNC_LEDto_28><kbd48CNC_29_ToLED>0</kbd48CNC_29_ToLED><kbd48CNC_29_ToButton>0</kbd48CNC_29_ToButton><kbd48CNC_LEDto_29>0</kbd48CNC_LEDto_29><kbd48CNC_30_ToLED>0</kbd48CNC_30_ToLED><kbd48CNC_30_ToButton>0</kbd48CNC_30_ToButton><kbd48CNC_LEDto_30>0</kbd48CNC_LEDto_30><kbd48CNC_31_ToLED>0</kbd48CNC_31_ToLED><kbd48CNC_31_ToButton>0</kbd48CNC_31_ToButton><kbd48CNC_LEDto_31>0</kbd48CNC_LEDto_31><kbd48CNC_32_ToLED>0</kbd48CNC_32_ToLED><kbd48CNC_32_ToButton>0</kbd48CNC_32_ToButton><kbd48CNC_LEDto_32>0</kbd48CNC_LEDto_32><kbd48CNC_33_ToLED>0</kbd48CNC_33_ToLED><kbd48CNC_33_ToButton>0</kbd48CNC_33_ToButton><kbd48CNC_LEDto_33>0</kbd48CNC_LEDto_33><kbd48CNC_34_ToLED>0</kbd48CNC_34_ToLED><kbd48CNC_34_ToButton>0</kbd48CNC_34_ToButton><kbd48CNC_LEDto_34>0</kbd48CNC_LEDto_34><kbd48CNC_35_ToLED>0</kbd48CNC_35_ToLED><kbd48CNC_35_ToButton>0</kbd48CNC_35_ToButton><kbd48CNC_LEDto_35>0</kbd48CNC_LEDto_35><kbd48CNC_36_ToLED>0</kbd48CNC_36_ToLED><kbd48CNC_36_ToButton>0</kbd48CNC_36_ToButton><kbd48CNC_LEDto_36>0</kbd48CNC_LEDto_36><kbd48CNC_37_ToLED>0</kbd48CNC_37_ToLED><kbd48CNC_37_ToButton>0</kbd48CNC_37_ToButton><kbd48CNC_LEDto_37>0</kbd48CNC_LEDto_37><kbd48CNC_38_ToLED>0</kbd48CNC_38_ToLED><kbd48CNC_38_ToButton>0</kbd48CNC_38_ToButton><kbd48CNC_LEDto_38>0</kbd48CNC_LEDto_38><kbd48CNC_39_ToLED>0</kbd48CNC_39_ToLED><kbd48CNC_39_ToButton>0</kbd48CNC_39_ToButton><kbd48CNC_LEDto_39>0</kbd48CNC_LEDto_39><kbd48CNC_40_ToLED>0</kbd48CNC_40_ToLED><kbd48CNC_40_ToButton>0</kbd48CNC_40_ToButton><kbd48CNC_LEDto_40>0</kbd48CNC_LEDto_40><kbd48CNC_41_ToLED>0</kbd48CNC_41_ToLED><kbd48CNC_41_ToButton>0</kbd48CNC_41_ToButton><kbd48CNC_LEDto_41>0</kbd48CNC_LEDto_41><kbd48CNC_42_ToLED>0</kbd48CNC_42_ToLED><kbd48CNC_42_ToButton>0</kbd48CNC_42_ToButton><kbd48CNC_LEDto_42>0</kbd48CNC_LEDto_42><kbd48CNC_43_ToLED>0</kbd48CNC_43_ToLED><kbd48CNC_43_ToButton>0</kbd48CNC_43_ToButton><kbd48CNC_LEDto_43>0</kbd48CNC_LEDto_43><kbd48CNC_44_ToLED>0</kbd48CNC_44_ToLED><kbd48CNC_44_ToButton>0</kbd48CNC_44_ToButton><kbd48CNC_LEDto_44>0</kbd48CNC_LEDto_44><kbd48CNC_45_ToLED>0</kbd48CNC_45_ToLED><kbd48CNC_45_ToButton>0</kbd48CNC_45_ToButton><kbd48CNC_LEDto_45>0</kbd48CNC_LEDto_45><kbd48CNC_46_ToLED>0</kbd48CNC_46_ToLED><kbd48CNC_46_ToButton>0</kbd48CNC_46_ToButton><kbd48CNC_LEDto_46>0</kbd48CNC_LEDto_46><kbd48CNC_47_ToLED>0</kbd48CNC_47_ToLED><kbd48CNC_47_ToButton>0</kbd48CNC_47_ToButton><kbd48CNC_LEDto_47>0</kbd48CNC_LEDto_47><PELED1>0</PELED1><PEIO1>0</PEIO1><PELED2>0</PELED2><PEIO2>0</PEIO2><PELED3>0</PELED3><PEIO3>0</PEIO3><PELED4>0</PELED4><PEIO4>0</PEIO4><PELED5>0</PELED5><PEIO5>0</PEIO5><PELED6>0</PELED6><PEIO6>0</PEIO6><PELED7>0</PELED7><PEIO7>0</PEIO7><PELED8>0</PELED8><PEIO8>0</PEIO8><PELED9>0</PELED9><PEIO9>0</PEIO9><PELED10>0</PELED10><PEIO10>0</PEIO10><PEChargePump>0</PEChargePump><PEChargePumpInReset>0</PEChargePumpInReset><PEtype>5</PEtype><PEInvertEmergency>0</PEInvertEmergency><ProbingPin>27</ProbingPin><ProbingPinInvert>1</ProbingPinInvert><PulseGenType>128</PulseGenType><PEDontDeref>0</PEDontDeref><PEDisableAutomaticSelection>0</PEDisableAutomaticSelection><SwitchInputFilterConstant>0</SwitchInputFilterConstant><PEExtIn1Map2LED>0</PEExtIn1Map2LED><PEExtIn1Map2IO>0</PEExtIn1Map2IO><PEExtIn2Map2LED>0</PEExtIn2Map2LED><PEExtIn2Map2IO>0</PEExtIn2Map2IO><PEExtIn3Map2LED>0</PEExtIn3Map2LED><PEExtIn3Map2IO>0</PEExtIn3Map2IO><PEExtIn4Map2LED>0</PEExtIn4Map2LED><PEExtIn4Map2IO>0</PEExtIn4Map2IO><PEExtIn5Map2LED>0</PEExtIn5Map2LED><PEExtIn5Map2IO>0</PEExtIn5Map2IO><PEExtIn6Map2LED>0</PEExtIn6Map2LED><PEExtIn6Map2IO>0</PEExtIn6Map2IO><PEExtIn7Map2LED>0</PEExtIn7Map2LED><PEExtIn7Map2IO>0</PEExtIn7Map2IO><PEExtIn8Map2LED>0</PEExtIn8Map2LED><PEExtIn8Map2IO>0</PEExtIn8Map2IO><PEExtIn1ErrorMap2LED>0</PEExtIn1ErrorMap2LED><PEExtIn1ErrorMap2IO>0</PEExtIn1ErrorMap2IO><PEExtIn2ErrorMap2LED>0</PEExtIn2ErrorMap2LED><PEExtIn2ErrorMap2IO>0</PEExtIn2ErrorMap2IO><PEExtIn3ErrorMap2LED>0</PEExtIn3ErrorMap2LED><PEExtIn3ErrorMap2IO>0</PEExtIn3ErrorMap2IO><PEExtIn4ErrorMap2LED>0</PEExtIn4ErrorMap2LED><PEExtIn4ErrorMap2IO>0</PEExtIn4ErrorMap2IO><PEExtOut1Map2LED>0</PEExtOut1Map2LED><PEExtOut1Map2IO>0</PEExtOut1Map2IO><PEExtOut2Map2LED>0</PEExtOut2Map2LED><PEExtOut2Map2IO>0</PEExtOut2Map2IO><PEExtOut3Map2LED>11</PEExtOut3Map2LED><PEExtOut3Map2IO>0</PEExtOut3Map2IO><PEExtOut4Map2LED>0</PEExtOut4Map2LED><PEExtOut4Map2IO>0</PEExtOut4Map2IO><PEExtOut5Map2LED>0</PEExtOut5Map2LED><PEExtOut5Map2IO>0</PEExtOut5Map2IO><PEExtOut6Map2LED>0</PEExtOut6Map2LED><PEExtOut6Map2IO>0</PEExtOut6Map2IO><PEExtOut7Map2LED>0</PEExtOut7Map2LED><PEExtOut7Map2IO>0</PEExtOut7Map2IO><PEExtOut8Map2LED>0</PEExtOut8Map2LED><PEExtOut8Map2IO>0</PEExtOut8Map2IO><PEExtOut9Map2LED>0</PEExtOut9Map2LED><PEExtOut9Map2IO>0</PEExtOut9Map2IO><PEExtOut10Map2LED>0</PEExtOut10Map2LED><PEExtOut10Map2IO>0</PEExtOut10Map2IO><PEExtOut11Map2LED>0</PEExtOut11Map2LED><PEExtOut11Map2IO>0</PEExtOut11Map2IO><PEExtOut12Map2LED>0</PEExtOut12Map2LED><PEExtOut12Map2IO>0</PEExtOut12Map2IO><PEExtOut13Map2LED>0</PEExtOut13Map2LED><PEExtOut13Map2IO>0</PEExtOut13Map2IO><PEExtOut14Map2LED>0</PEExtOut14Map2LED><PEExtOut14Map2IO>0</PEExtOut14Map2IO><PEExtOut15Map2LED>0</PEExtOut15Map2LED><PEExtOut15Map2IO>0</PEExtOut15Map2IO><PEExtOut16Map2LED>0</PEExtOut16Map2LED><PEExtOut16Map2IO>0</PEExtOut16Map2IO><MPGDiv1>0</MPGDiv1><MPGDiv2>0</MPGDiv2><MPGDiv3>0</MPGDiv3><MPGDiv4>0</MPGDiv4><MPGDiv5>0</MPGDiv5><MPGDiv6>0</MPGDiv6><MPGDiv7>0</MPGDiv7><MPGDiv8>0</MPGDiv8><LimitPS1>0</LimitPS1><LimitMS1>0</LimitMS1><HomeS1>3</HomeS1><LimitPInvert1>0</LimitPInvert1><LimitMInvert1>0</LimitMInvert1><HomeInvert1>0</HomeInvert1><EnabledInvert1>0</EnabledInvert1><LimitPS2>0</LimitPS2><LimitMS2>0</LimitMS2><HomeS2>3</HomeS2><LimitPInvert2>0</LimitPInvert2><LimitMInvert2>0</LimitMInvert2><HomeInvert2>0</HomeInvert2><EnabledInvert2>0</EnabledInvert2><LimitPS3>0</LimitPS3><LimitMS3>0</LimitMS3><HomeS3>3</HomeS3><LimitPInvert3>0</LimitPInvert3><LimitMInvert3>0</LimitMInvert3><HomeInvert3>0</HomeInvert3><EnabledInvert3>0</EnabledInvert3><LimitPS4>0</LimitPS4><LimitMS4>0</LimitMS4><HomeS4>0</HomeS4><LimitPInvert4>0</LimitPInvert4><LimitMInvert4>0</LimitMInvert4><HomeInvert4>0</HomeInvert4><EnabledInvert4>0</EnabledInvert4><LimitPS5>0</LimitPS5><LimitMS5>0</LimitMS5><HomeS5>0</HomeS5><LimitPInvert5>0</LimitPInvert5><LimitMInvert5>0</LimitMInvert5><HomeInvert5>0</HomeInvert5><EnabledInvert5>0</EnabledInvert5><LimitPS6>0</LimitPS6><LimitMS6>0</LimitMS6><HomeS6>0</HomeS6><LimitPInvert6>0</LimitPInvert6><LimitMInvert6>0</LimitMInvert6><HomeInvert6>0</HomeInvert6><EnabledInvert6>0</EnabledInvert6><LimitPS7>0</LimitPS7><LimitMS7>0</LimitMS7><HomeS7>0</HomeS7><LimitPInvert7>0</LimitPInvert7><LimitMInvert7>0</LimitMInvert7><HomeInvert7>0</HomeInvert7><EnabledInvert7>0</EnabledInvert7><LimitPS8>0</LimitPS8><LimitMS8>0</LimitMS8><HomeS8>0</HomeS8><LimitPInvert8>0</LimitPInvert8><LimitMInvert8>0</LimitMInvert8><HomeInvert8>0</HomeInvert8><EnabledInvert8>0</EnabledInvert8><THCmode>1</THCmode><THCInvertDirection>0</THCInvertDirection><THCEnableAntiDive>0</THCEnableAntiDive><THCAntiDiveLimit>0</THCAntiDiveLimit><THCDeadband>0</THCDeadband><THCTorchVoltageInput>0</THCTorchVoltageInput><THCReferenceHeightInput>0</THCReferenceHeightInput><THCReferenceVoltage>0</THCReferenceVoltage><THCGain>1000</THCGain><THCArcOKRange>0</THCArcOKRange><StopBeforeHoming>0</StopBeforeHoming><UseLCD>0</UseLCD><LCDRows>0</LCDRows><LCDColumns>0</LCDColumns><PWMPeriod>2500</PWMPeriod><PWMDisableInactive>1</PWMDisableInactive><PWMenable1>0</PWMenable1><PWMduty1>0</PWMduty1><PWMMapDRO1>0</PWMMapDRO1><PWMDROMultiplier1>0.000000</PWMDROMultiplier1><PWMenable2>0</PWMenable2><PWMduty2>0</PWMduty2><PWMMapDRO2>0</PWMMapDRO2><PWMDROMultiplier2>0.000000</PWMDROMultiplier2><PWMenable3>0</PWMenable3><PWMduty3>0</PWMduty3><PWMMapDRO3>0</PWMMapDRO3><PWMDROMultiplier3>0.000000</PWMDROMultiplier3><PWMenable4>0</PWMenable4><PWMduty4>0</PWMduty4><PWMMapDRO4>0</PWMMapDRO4><PWMDROMultiplier4>0.000000</PWMDROMultiplier4><PWMenable5>0</PWMenable5><PWMduty5>0</PWMduty5><PWMMapDRO5>0</PWMMapDRO5><PWMDROMultiplier5>0.000000</PWMDROMultiplier5><PWMenable6>2</PWMenable6><PWMduty6>0</PWMduty6><PWMMapDRO6>817</PWMMapDRO6><PWMDROMultiplier6>0.020000</PWMDROMultiplier6><AnalogInput1>0</AnalogInput1><AnalogDROMapping1>0</AnalogDROMapping1><AnalogJoystickMapping1>0</AnalogJoystickMapping1><AnalogOffset1>0</AnalogOffset1><AnalogGain1_f>0</AnalogGain1_f><AnalogInput2>0</AnalogInput2><AnalogDROMapping2>0</AnalogDROMapping2><AnalogJoystickMapping2>0</AnalogJoystickMapping2><AnalogOffset2>0</AnalogOffset2><AnalogGain2_f>0</AnalogGain2_f><AnalogInput3>0</AnalogInput3><AnalogDROMapping3>0</AnalogDROMapping3><AnalogJoystickMapping3>0</AnalogJoystickMapping3><AnalogOffset3>0</AnalogOffset3><AnalogGain3_f>0</AnalogGain3_f><AnalogInput4>0</AnalogInput4><AnalogDROMapping4>0</AnalogDROMapping4><AnalogJoystickMapping4>0</AnalogJoystickMapping4><AnalogOffset4>0</AnalogOffset4><AnalogGain4_f>0</AnalogGain4_f><AnalogInput5>0</AnalogInput5><AnalogDROMapping5>0</AnalogDROMapping5><AnalogJoystickMapping5>0</AnalogJoystickMapping5><AnalogOffset5>0</AnalogOffset5><AnalogGain5_f>0</AnalogGain5_f><AnalogInput6>0</AnalogInput6><AnalogDROMapping6>0</AnalogDROMapping6><AnalogJoystickMapping6>0</AnalogJoystickMapping6><AnalogOffset6>0</AnalogOffset6><AnalogGain6_f>0</AnalogGain6_f><AnalogInput7>0</AnalogInput7><AnalogDROMapping7>0</AnalogDROMapping7><AnalogJoystickMapping7>0</AnalogJoystickMapping7><AnalogOffset7>0</AnalogOffset7><AnalogGain7_f>0</AnalogGain7_f><AnalogDeadband>0</AnalogDeadband><AnalogJoystick>0</AnalogJoystick><JoystickEnableOEMLED>0</JoystickEnableOEMLED><MatrixLED1Enabled>0</MatrixLED1Enabled><MatrixLED2Enabled>0</MatrixLED2Enabled><MatrixLED1Width>0</MatrixLED1Width><MatrixLED1Height>0</MatrixLED1Height><MatrixLED2Width>0</MatrixLED2Width><MatrixLED2Height>0</MatrixLED2Height><MatrixLED1LED1>0</MatrixLED1LED1><MatrixLED1IO1>0</MatrixLED1IO1><MatrixLED2LED1>0</MatrixLED2LED1><MatrixLED2IO1>0</MatrixLED2IO1><MatrixLED1LED2>0</MatrixLED1LED2><MatrixLED1IO2>0</MatrixLED1IO2><MatrixLED2LED2>0</MatrixLED2LED2><MatrixLED2IO2>0</MatrixLED2IO2><MatrixLED1LED3>0</MatrixLED1LED3><MatrixLED1IO3>0</MatrixLED1IO3><MatrixLED2LED3>0</MatrixLED2LED3><MatrixLED2IO3>0</MatrixLED2IO3><MatrixLED1LED4>0</MatrixLED1LED4><MatrixLED1IO4>0</MatrixLED1IO4><MatrixLED2LED4>0</MatrixLED2LED4><MatrixLED2IO4>0</MatrixLED2IO4><MatrixLED1LED5>0</MatrixLED1LED5><MatrixLED1IO5>0</MatrixLED1IO5><MatrixLED2LED5>0</MatrixLED2LED5><MatrixLED2IO5>0</MatrixLED2IO5><MatrixLED1LED6>0</MatrixLED1LED6><MatrixLED1IO6>0</MatrixLED1IO6><MatrixLED2LED6>0</MatrixLED2LED6><MatrixLED2IO6>0</MatrixLED2IO6><MatrixLED1LED7>0</MatrixLED1LED7><MatrixLED1IO7>0</MatrixLED1IO7><MatrixLED2LED7>0</MatrixLED2LED7><MatrixLED2IO7>0</MatrixLED2IO7><MatrixLED1LED8>0</MatrixLED1LED8><MatrixLED1IO8>0</MatrixLED1IO8><MatrixLED2LED8>0</MatrixLED2LED8><MatrixLED2IO8>0</MatrixLED2IO8><MatrixLED1LED9>0</MatrixLED1LED9><MatrixLED1IO9>0</MatrixLED1IO9><MatrixLED2LED9>0</MatrixLED2LED9><MatrixLED2IO9>0</MatrixLED2IO9><MatrixLED1LED10>0</MatrixLED1LED10><MatrixLED1IO10>0</MatrixLED1IO10><MatrixLED2LED10>0</MatrixLED2LED10><MatrixLED2IO10>0</MatrixLED2IO10><MatrixLED1LED11>0</MatrixLED1LED11><MatrixLED1IO11>0</MatrixLED1IO11><MatrixLED2LED11>0</MatrixLED2LED11><MatrixLED2IO11>0</MatrixLED2IO11><MatrixLED1LED12>0</MatrixLED1LED12><MatrixLED1IO12>0</MatrixLED1IO12><MatrixLED2LED12>0</MatrixLED2LED12><MatrixLED2IO12>0</MatrixLED2IO12><MatrixLED1LED13>0</MatrixLED1LED13><MatrixLED1IO13>0</MatrixLED1IO13><MatrixLED2LED13>0</MatrixLED2LED13><MatrixLED2IO13>0</MatrixLED2IO13><MatrixLED1LED14>0</MatrixLED1LED14><MatrixLED1IO14>0</MatrixLED1IO14><MatrixLED2LED14>0</MatrixLED2LED14><MatrixLED2IO14>0</MatrixLED2IO14><MatrixLED1LED15>0</MatrixLED1LED15><MatrixLED1IO15>0</MatrixLED1IO15><MatrixLED2LED15>0</MatrixLED2LED15><MatrixLED2IO15>0</MatrixLED2IO15><MatrixLED1LED16>0</MatrixLED1LED16><MatrixLED1IO16>0</MatrixLED1IO16><MatrixLED2LED16>0</MatrixLED2LED16><MatrixLED2IO16>0</MatrixLED2IO16><MatrixLED1LED17>0</MatrixLED1LED17><MatrixLED1IO17>0</MatrixLED1IO17><MatrixLED2LED17>0</MatrixLED2LED17><MatrixLED2IO17>0</MatrixLED2IO17><MatrixLED1LED18>0</MatrixLED1LED18><MatrixLED1IO18>0</MatrixLED1IO18><MatrixLED2LED18>0</MatrixLED2LED18><MatrixLED2IO18>0</MatrixLED2IO18><MatrixLED1LED19>0</MatrixLED1LED19><MatrixLED1IO19>0</MatrixLED1IO19><MatrixLED2LED19>0</MatrixLED2LED19><MatrixLED2IO19>0</MatrixLED2IO19><MatrixLED1LED20>0</MatrixLED1LED20><MatrixLED1IO20>0</MatrixLED1IO20><MatrixLED2LED20>0</MatrixLED2LED20><MatrixLED2IO20>0</MatrixLED2IO20><MatrixLED1LED21>0</MatrixLED1LED21><MatrixLED1IO21>0</MatrixLED1IO21><MatrixLED2LED21>0</MatrixLED2LED21><MatrixLED2IO21>0</MatrixLED2IO21><MatrixLED1LED22>0</MatrixLED1LED22><MatrixLED1IO22>0</MatrixLED1IO22><MatrixLED2LED22>0</MatrixLED2LED22><MatrixLED2IO22>0</MatrixLED2IO22><MatrixLED1LED23>0</MatrixLED1LED23><MatrixLED1IO23>0</MatrixLED1IO23><MatrixLED2LED23>0</MatrixLED2LED23><MatrixLED2IO23>0</MatrixLED2IO23><MatrixLED1LED24>0</MatrixLED1LED24><MatrixLED1IO24>0</MatrixLED1IO24><MatrixLED2LED24>0</MatrixLED2LED24><MatrixLED2IO24>0</MatrixLED2IO24><MatrixLED1LED25>0</MatrixLED1LED25><MatrixLED1IO25>0</MatrixLED1IO25><MatrixLED2LED25>0</MatrixLED2LED25><MatrixLED2IO25>0</MatrixLED2IO25><MatrixLED1LED26>0</MatrixLED1LED26><MatrixLED1IO26>0</MatrixLED1IO26><MatrixLED2LED26>0</MatrixLED2LED26><MatrixLED2IO26>0</MatrixLED2IO26><MatrixLED1LED27>0</MatrixLED1LED27><MatrixLED1IO27>0</MatrixLED1IO27><MatrixLED2LED27>0</MatrixLED2LED27><MatrixLED2IO27>0</MatrixLED2IO27><MatrixLED1LED28>0</MatrixLED1LED28><MatrixLED1IO28>0</MatrixLED1IO28><MatrixLED2LED28>0</MatrixLED2LED28><MatrixLED2IO28>0</MatrixLED2IO28><MatrixLED1LED29>0</MatrixLED1LED29><MatrixLED1IO29>0</MatrixLED1IO29><MatrixLED2LED29>0</MatrixLED2LED29><MatrixLED2IO29>0</MatrixLED2IO29><MatrixLED1LED30>0</MatrixLED1LED30><MatrixLED1IO30>0</MatrixLED1IO30><MatrixLED2LED30>0</MatrixLED2LED30><MatrixLED2IO30>0</MatrixLED2IO30><MatrixLED1LED31>0</MatrixLED1LED31><MatrixLED1IO31>0</MatrixLED1IO31><MatrixLED2LED31>0</MatrixLED2LED31><MatrixLED2IO31>0</MatrixLED2IO31><MatrixLED1LED32>0</MatrixLED1LED32><MatrixLED1IO32>0</MatrixLED1IO32><MatrixLED2LED32>0</MatrixLED2LED32><MatrixLED2IO32>0</MatrixLED2IO32><MatrixLED1LED33>0</MatrixLED1LED33><MatrixLED1IO33>0</MatrixLED1IO33><MatrixLED2LED33>0</MatrixLED2LED33><MatrixLED2IO33>0</MatrixLED2IO33><MatrixLED1LED34>0</MatrixLED1LED34><MatrixLED1IO34>0</MatrixLED1IO34><MatrixLED2LED34>0</MatrixLED2LED34><MatrixLED2IO34>0</MatrixLED2IO34><MatrixLED1LED35>0</MatrixLED1LED35><MatrixLED1IO35>0</MatrixLED1IO35><MatrixLED2LED35>0</MatrixLED2LED35><MatrixLED2IO35>0</MatrixLED2IO35><MatrixLED1LED36>0</MatrixLED1LED36><MatrixLED1IO36>0</MatrixLED1IO36><MatrixLED2LED36>0</MatrixLED2LED36><MatrixLED2IO36>0</MatrixLED2IO36><MatrixLED1LED37>0</MatrixLED1LED37><MatrixLED1IO37>0</MatrixLED1IO37><MatrixLED2LED37>0</MatrixLED2LED37><MatrixLED2IO37>0</MatrixLED2IO37><MatrixLED1LED38>0</MatrixLED1LED38><MatrixLED1IO38>0</MatrixLED1IO38><MatrixLED2LED38>0</MatrixLED2LED38><MatrixLED2IO38>0</MatrixLED2IO38><MatrixLED1LED39>0</MatrixLED1LED39><MatrixLED1IO39>0</MatrixLED1IO39><MatrixLED2LED39>0</MatrixLED2LED39><MatrixLED2IO39>0</MatrixLED2IO39><MatrixLED1LED40>0</MatrixLED1LED40><MatrixLED1IO40>0</MatrixLED1IO40><MatrixLED2LED40>0</MatrixLED2LED40><MatrixLED2IO40>0</MatrixLED2IO40><MatrixLED1LED41>0</MatrixLED1LED41><MatrixLED1IO41>0</MatrixLED1IO41><MatrixLED2LED41>0</MatrixLED2LED41><MatrixLED2IO41>0</MatrixLED2IO41><MatrixLED1LED42>0</MatrixLED1LED42><MatrixLED1IO42>0</MatrixLED1IO42><MatrixLED2LED42>0</MatrixLED2LED42><MatrixLED2IO42>0</MatrixLED2IO42><MatrixLED1LED43>0</MatrixLED1LED43><MatrixLED1IO43>0</MatrixLED1IO43><MatrixLED2LED43>0</MatrixLED2LED43><MatrixLED2IO43>0</MatrixLED2IO43><MatrixLED1LED44>0</MatrixLED1LED44><MatrixLED1IO44>0</MatrixLED1IO44><MatrixLED2LED44>0</MatrixLED2LED44><MatrixLED2IO44>0</MatrixLED2IO44><MatrixLED1LED45>0</MatrixLED1LED45><MatrixLED1IO45>0</MatrixLED1IO45><MatrixLED2LED45>0</MatrixLED2LED45><MatrixLED2IO45>0</MatrixLED2IO45><MatrixLED1LED46>0</MatrixLED1LED46><MatrixLED1IO46>0</MatrixLED1IO46><MatrixLED2LED46>0</MatrixLED2LED46><MatrixLED2IO46>0</MatrixLED2IO46><MatrixLED1LED47>0</MatrixLED1LED47><MatrixLED1IO47>0</MatrixLED1IO47><MatrixLED2LED47>0</MatrixLED2LED47><MatrixLED2IO47>0</MatrixLED2IO47><MatrixLED1LED48>0</MatrixLED1LED48><MatrixLED1IO48>0</MatrixLED1IO48><MatrixLED2LED48>0</MatrixLED2LED48><MatrixLED2IO48>0</MatrixLED2IO48><MatrixLED1LED49>0</MatrixLED1LED49><MatrixLED1IO49>0</MatrixLED1IO49><MatrixLED2LED49>0</MatrixLED2LED49><MatrixLED2IO49>0</MatrixLED2IO49><MatrixLED1LED50>0</MatrixLED1LED50><MatrixLED1IO50>0</MatrixLED1IO50><MatrixLED2LED50>0</MatrixLED2LED50><MatrixLED2IO50>0</MatrixLED2IO50><MatrixLED1LED51>0</MatrixLED1LED51><MatrixLED1IO51>0</MatrixLED1IO51><MatrixLED2LED51>0</MatrixLED2LED51><MatrixLED2IO51>0</MatrixLED2IO51><MatrixLED1LED52>0</MatrixLED1LED52><MatrixLED1IO52>0</MatrixLED1IO52><MatrixLED2LED52>0</MatrixLED2LED52><MatrixLED2IO52>0</MatrixLED2IO52><MatrixLED1LED53>0</MatrixLED1LED53><MatrixLED1IO53>0</MatrixLED1IO53><MatrixLED2LED53>0</MatrixLED2LED53><MatrixLED2IO53>0</MatrixLED2IO53><MatrixLED1LED54>0</MatrixLED1LED54><MatrixLED1IO54>0</MatrixLED1IO54><MatrixLED2LED54>0</MatrixLED2LED54><MatrixLED2IO54>0</MatrixLED2IO54><MatrixLED1LED55>0</MatrixLED1LED55><MatrixLED1IO55>0</MatrixLED1IO55><MatrixLED2LED55>0</MatrixLED2LED55><MatrixLED2IO55>0</MatrixLED2IO55><MatrixLED1LED56>0</MatrixLED1LED56><MatrixLED1IO56>0</MatrixLED1IO56><MatrixLED2LED56>0</MatrixLED2LED56><MatrixLED2IO56>0</MatrixLED2IO56><MatrixLED1LED57>0</MatrixLED1LED57><MatrixLED1IO57>0</MatrixLED1IO57><MatrixLED2LED57>0</MatrixLED2LED57><MatrixLED2IO57>0</MatrixLED2IO57><MatrixLED1LED58>0</MatrixLED1LED58><MatrixLED1IO58>0</MatrixLED1IO58><MatrixLED2LED58>0</MatrixLED2LED58><MatrixLED2IO58>0</MatrixLED2IO58><MatrixLED1LED59>0</MatrixLED1LED59><MatrixLED1IO59>0</MatrixLED1IO59><MatrixLED2LED59>0</MatrixLED2LED59><MatrixLED2IO59>0</MatrixLED2IO59><MatrixLED1LED60>0</MatrixLED1LED60><MatrixLED1IO60>0</MatrixLED1IO60><MatrixLED2LED60>0</MatrixLED2LED60><MatrixLED2IO60>0</MatrixLED2IO60><MatrixLED1LED61>0</MatrixLED1LED61><MatrixLED1IO61>0</MatrixLED1IO61><MatrixLED2LED61>0</MatrixLED2LED61><MatrixLED2IO61>0</MatrixLED2IO61><MatrixLED1LED62>0</MatrixLED1LED62><MatrixLED1IO62>0</MatrixLED1IO62><MatrixLED2LED62>0</MatrixLED2LED62><MatrixLED2IO62>0</MatrixLED2IO62><MatrixLED1LED63>0</MatrixLED1LED63><MatrixLED1IO63>0</MatrixLED1IO63><MatrixLED2LED63>0</MatrixLED2LED63><MatrixLED2IO63>0</MatrixLED2IO63><MatrixLED1LED64>0</MatrixLED1LED64><MatrixLED1IO64>0</MatrixLED1IO64><MatrixLED2LED64>0</MatrixLED2LED64><MatrixLED2IO64>0</MatrixLED2IO64></Device1><Device2><SerialNumber>0</SerialNumber><IP>192.168.0.57</IP><UDP>0</UDP><StatusWindow>0</StatusWindow><AssertReset>0</AssertReset><DisableUnavailableDisplay>0</DisableUnavailableDisplay><PoILDROStart>0</PoILDROStart><PoILDROEnable>0</PoILDROEnable><PoILDROEnableWrite>0</PoILDROEnableWrite><OverrideRapidJog>0</OverrideRapidJog><JogLowSpeed>0</JogLowSpeed><JogHighSpeed>0</JogHighSpeed><COMRate>0</COMRate><SpindleSpeed>0</SpindleSpeed><SpindleSensor>0</SpindleSensor><SpindleTicks>0</SpindleTicks><UnsafeJogging>0</UnsafeJogging><Pin1Function>0</Pin1Function><Pin1Map2LED>0</Pin1Map2LED><Pin1Map2Button>0</Pin1Map2Button><Pin1Map2IO>0</Pin1Map2IO><Pin2Function>0</Pin2Function><Pin2Map2LED>0</Pin2Map2LED><Pin2Map2Button>0</Pin2Map2Button><Pin2Map2IO>0</Pin2Map2IO><Pin3Function>0</Pin3Function><Pin3Map2LED>0</Pin3Map2LED><Pin3Map2Button>0</Pin3Map2Button><Pin3Map2IO>0</Pin3Map2IO><Pin4Function>0</Pin4Function><Pin4Map2LED>0</Pin4Map2LED><Pin4Map2Button>0</Pin4Map2Button><Pin4Map2IO>0</Pin4Map2IO><Pin5Function>0</Pin5Function><Pin5Map2LED>0</Pin5Map2LED><Pin5Map2Button>0</Pin5Map2Button><Pin5Map2IO>0</Pin5Map2IO><Pin6Function>0</Pin6Function><Pin6Map2LED>0</Pin6Map2LED><Pin6Map2Button>0</Pin6Map2Button><Pin6Map2IO>0</Pin6Map2IO><Pin7Function>0</Pin7Function><Pin7Map2LED>0</Pin7Map2LED><Pin7Map2Button>0</Pin7Map2Button><Pin7Map2IO>0</Pin7Map2IO><Pin8Function>0</Pin8Function><Pin8Map2LED>0</Pin8Map2LED><Pin8Map2Button>0</Pin8Map2Button><Pin8Map2IO>0</Pin8Map2IO><Pin9Function>0</Pin9Function><Pin9Map2LED>0</Pin9Map2LED><Pin9Map2Button>0</Pin9Map2Button><Pin9Map2IO>0</Pin9Map2IO><Pin10Function>0</Pin10Function><Pin10Map2LED>0</Pin10Map2LED><Pin10Map2Button>0</Pin10Map2Button><Pin10Map2IO>0</Pin10Map2IO><Pin11Function>0</Pin11Function><Pin11Map2LED>0</Pin11Map2LED><Pin11Map2Button>0</Pin11Map2Button><Pin11Map2IO>0</Pin11Map2IO><Pin12Function>0</Pin12Function><Pin12Map2LED>0</Pin12Map2LED><Pin12Map2Button>0</Pin12Map2Button><Pin12Map2IO>0</Pin12Map2IO><Pin13Function>0</Pin13Function><Pin13Map2LED>0</Pin13Map2LED><Pin13Map2Button>0</Pin13Map2Button><Pin13Map2IO>0</Pin13Map2IO><Pin14Function>0</Pin14Function><Pin14Map2LED>0</Pin14Map2LED><Pin14Map2Button>0</Pin14Map2Button><Pin14Map2IO>0</Pin14Map2IO><Pin15Function>0</Pin15Function><Pin15Map2LED>0</Pin15Map2LED><Pin15Map2Button>0</Pin15Map2Button><Pin15Map2IO>0</Pin15Map2IO><Pin16Function>0</Pin16Function><Pin16Map2LED>0</Pin16Map2LED><Pin16Map2Button>0</Pin16Map2Button><Pin16Map2IO>0</Pin16Map2IO><Pin17Function>0</Pin17Function><Pin17Map2LED>0</Pin17Map2LED><Pin17Map2Button>0</Pin17Map2Button><Pin17Map2IO>0</Pin17Map2IO><Pin18Function>0</Pin18Function><Pin18Map2LED>0</Pin18Map2LED><Pin18Map2Button>0</Pin18Map2Button><Pin18Map2IO>0</Pin18Map2IO><Pin19Function>0</Pin19Function><Pin19Map2LED>0</Pin19Map2LED><Pin19Map2Button>0</Pin19Map2Button><Pin19Map2IO>0</Pin19Map2IO><Pin20Function>0</Pin20Function><Pin20Map2LED>0</Pin20Map2LED><Pin20Map2Button>0</Pin20Map2Button><Pin20Map2IO>0</Pin20Map2IO><Pin21Function>0</Pin21Function><Pin21Map2LED>0</Pin21Map2LED><Pin21Map2Button>0</Pin21Map2Button><Pin21Map2IO>0</Pin21Map2IO><Pin22Function>0</Pin22Function><Pin22Map2LED>0</Pin22Map2LED><Pin22Map2Button>0</Pin22Map2Button><Pin22Map2IO>0</Pin22Map2IO><Pin23Function>0</Pin23Function><Pin23Map2LED>0</Pin23Map2LED><Pin23Map2Button>0</Pin23Map2Button><Pin23Map2IO>0</Pin23Map2IO><Pin24Function>0</Pin24Function><Pin24Map2LED>0</Pin24Map2LED><Pin24Map2Button>0</Pin24Map2Button><Pin24Map2IO>0</Pin24Map2IO><Pin25Function>0</Pin25Function><Pin25Map2LED>0</Pin25Map2LED><Pin25Map2Button>0</Pin25Map2Button><Pin25Map2IO>0</Pin25Map2IO><Pin26Function>0</Pin26Function><Pin26Map2LED>0</Pin26Map2LED><Pin26Map2Button>0</Pin26Map2Button><Pin26Map2IO>0</Pin26Map2IO><Pin27Function>0</Pin27Function><Pin27Map2LED>0</Pin27Map2LED><Pin27Map2Button>0</Pin27Map2Button><Pin27Map2IO>0</Pin27Map2IO><Pin28Function>0</Pin28Function><Pin28Map2LED>0</Pin28Map2LED><Pin28Map2Button>0</Pin28Map2Button><Pin28Map2IO>0</Pin28Map2IO><Pin29Function>0</Pin29Function><Pin29Map2LED>0</Pin29Map2LED><Pin29Map2Button>0</Pin29Map2Button><Pin29Map2IO>0</Pin29Map2IO><Pin30Function>0</Pin30Function><Pin30Map2LED>0</Pin30Map2LED><Pin30Map2Button>0</Pin30Map2Button><Pin30Map2IO>0</Pin30Map2IO><Pin31Function>0</Pin31Function><Pin31Map2LED>0</Pin31Map2LED><Pin31Map2Button>0</Pin31Map2Button><Pin31Map2IO>0</Pin31Map2IO><Pin32Function>0</Pin32Function><Pin32Map2LED>0</Pin32Map2LED><Pin32Map2Button>0</Pin32Map2Button><Pin32Map2IO>0</Pin32Map2IO><Pin33Function>0</Pin33Function><Pin33Map2LED>0</Pin33Map2LED><Pin33Map2Button>0</Pin33Map2Button><Pin33Map2IO>0</Pin33Map2IO><Pin34Function>0</Pin34Function><Pin34Map2LED>0</Pin34Map2LED><Pin34Map2Button>0</Pin34Map2Button><Pin34Map2IO>0</Pin34Map2IO><Pin35Function>0</Pin35Function><Pin35Map2LED>0</Pin35Map2LED><Pin35Map2Button>0</Pin35Map2Button><Pin35Map2IO>0</Pin35Map2IO><Pin36Function>0</Pin36Function><Pin36Map2LED>0</Pin36Map2LED><Pin36Map2Button>0</Pin36Map2Button><Pin36Map2IO>0</Pin36Map2IO><Pin37Function>0</Pin37Function><Pin37Map2LED>0</Pin37Map2LED><Pin37Map2Button>0</Pin37Map2Button><Pin37Map2IO>0</Pin37Map2IO><Pin38Function>0</Pin38Function><Pin38Map2LED>0</Pin38Map2LED><Pin38Map2Button>0</Pin38Map2Button><Pin38Map2IO>0</Pin38Map2IO><Pin39Function>0</Pin39Function><Pin39Map2LED>0</Pin39Map2LED><Pin39Map2Button>0</Pin39Map2Button><Pin39Map2IO>0</Pin39Map2IO><Pin40Function>0</Pin40Function><Pin40Map2LED>0</Pin40Map2LED><Pin40Map2Button>0</Pin40Map2Button><Pin40Map2IO>0</Pin40Map2IO><Pin41Function>0</Pin41Function><Pin41Map2LED>0</Pin41Map2LED><Pin41Map2Button>0</Pin41Map2Button><Pin41Map2IO>0</Pin41Map2IO><Pin42Function>0</Pin42Function><Pin42Map2LED>0</Pin42Map2LED><Pin42Map2Button>0</Pin42Map2Button><Pin42Map2IO>0</Pin42Map2IO><Pin43Function>0</Pin43Function><Pin43Map2LED>0</Pin43Map2LED><Pin43Map2Button>0</Pin43Map2Button><Pin43Map2IO>0</Pin43Map2IO><Pin44Function>0</Pin44Function><Pin44Map2LED>0</Pin44Map2LED><Pin44Map2Button>0</Pin44Map2Button><Pin44Map2IO>0</Pin44Map2IO><Pin45Function>0</Pin45Function><Pin45Map2LED>0</Pin45Map2LED><Pin45Map2Button>0</Pin45Map2Button><Pin45Map2IO>0</Pin45Map2IO><Pin46Function>0</Pin46Function><Pin46Map2LED>0</Pin46Map2LED><Pin46Map2Button>0</Pin46Map2Button><Pin46Map2IO>0</Pin46Map2IO><Pin47Function>0</Pin47Function><Pin47Map2LED>0</Pin47Map2LED><Pin47Map2Button>0</Pin47Map2Button><Pin47Map2IO>0</Pin47Map2IO><Pin48Function>0</Pin48Function><Pin48Map2LED>0</Pin48Map2LED><Pin48Map2Button>0</Pin48Map2Button><Pin48Map2IO>0</Pin48Map2IO><Pin49Function>0</Pin49Function><Pin49Map2LED>0</Pin49Map2LED><Pin49Map2Button>0</Pin49Map2Button><Pin49Map2IO>0</Pin49Map2IO><Pin50Function>0</Pin50Function><Pin50Map2LED>0</Pin50Map2LED><Pin50Map2Button>0</Pin50Map2Button><Pin50Map2IO>0</Pin50Map2IO><Pin51Function>0</Pin51Function><Pin51Map2LED>0</Pin51Map2LED><Pin51Map2Button>0</Pin51Map2Button><Pin51Map2IO>0</Pin51Map2IO><Pin52Function>0</Pin52Function><Pin52Map2LED>0</Pin52Map2LED><Pin52Map2Button>0</Pin52Map2Button><Pin52Map2IO>0</Pin52Map2IO><Pin53Function>0</Pin53Function><Pin53Map2LED>0</Pin53Map2LED><Pin53Map2Button>0</Pin53Map2Button><Pin53Map2IO>0</Pin53Map2IO><Pin54Function>0</Pin54Function><Pin54Map2LED>0</Pin54Map2LED><Pin54Map2Button>0</Pin54Map2Button><Pin54Map2IO>0</Pin54Map2IO><Pin55Function>0</Pin55Function><Pin55Map2LED>0</Pin55Map2LED><Pin55Map2Button>0</Pin55Map2Button><Pin55Map2IO>0</Pin55Map2IO><PendantMode>0</PendantMode><Encoder1A>0</Encoder1A><Encoder1B>0</Encoder1B><Encoder1Options>0</Encoder1Options><Encoder2A>0</Encoder2A><Encoder2B>0</Encoder2B><Encoder2Options>0</Encoder2Options><Encoder3A>0</Encoder3A><Encoder3B>0</Encoder3B><Encoder3Options>0</Encoder3Options><Encoder4A>0</Encoder4A><Encoder4B>0</Encoder4B><Encoder4Options>0</Encoder4Options><Encoder5A>0</Encoder5A><Encoder5B>0</Encoder5B><Encoder5Options>0</Encoder5Options><Encoder6A>0</Encoder6A><Encoder6B>0</Encoder6B><Encoder6Options>0</Encoder6Options><Encoder7A>0</Encoder7A><Encoder7B>0</Encoder7B><Encoder7Options>0</Encoder7Options><Encoder8A>0</Encoder8A><Encoder8B>0</Encoder8B><Encoder8Options>0</Encoder8Options><Encoder9A>0</Encoder9A><Encoder9B>0</Encoder9B><Encoder9Options>0</Encoder9Options><Encoder10A>0</Encoder10A><Encoder10B>0</Encoder10B><Encoder10Options>0</Encoder10Options><Encoder11A>0</Encoder11A><Encoder11B>0</Encoder11B><Encoder11Options>0</Encoder11Options><Encoder12A>0</Encoder12A><Encoder12B>0</Encoder12B><Encoder12Options>0</Encoder12Options><Encoder13A>0</Encoder13A><Encoder13B>0</Encoder13B><Encoder13Options>0</Encoder13Options><Encoder14A>0</Encoder14A><Encoder14B>0</Encoder14B><Encoder14Options>0</Encoder14Options><Encoder15A>0</Encoder15A><Encoder15B>0</Encoder15B><Encoder15Options>0</Encoder15Options><Encoder16A>0</Encoder16A><Encoder16B>0</Encoder16B><Encoder16Options>0</Encoder16Options><Encoder17A>0</Encoder17A><Encoder17B>0</Encoder17B><Encoder17Options>0</Encoder17Options><Encoder18A>0</Encoder18A><Encoder18B>0</Encoder18B><Encoder18Options>0</Encoder18Options><Encoder19A>0</Encoder19A><Encoder19B>0</Encoder19B><Encoder19Options>0</Encoder19Options><Encoder20A>0</Encoder20A><Encoder20B>0</Encoder20B><Encoder20Options>0</Encoder20Options><Encoder21A>0</Encoder21A><Encoder21B>0</Encoder21B><Encoder21Options>0</Encoder21Options><Encoder22A>0</Encoder22A><Encoder22B>0</Encoder22B><Encoder22Options>0</Encoder22Options><Encoder23A>0</Encoder23A><Encoder23B>0</Encoder23B><Encoder23Options>0</Encoder23Options><Encoder24A>0</Encoder24A><Encoder24B>0</Encoder24B><Encoder24Options>0</Encoder24Options><Encoder25A>0</Encoder25A><Encoder25B>0</Encoder25B><Encoder25Options>0</Encoder25Options><Encoder12DRO>0</Encoder12DRO><Encoder1Inpendant>0</Encoder1Inpendant><Encoder22DRO>0</Encoder22DRO><Encoder2Inpendant>0</Encoder2Inpendant><Encoder32DRO>0</Encoder32DRO><Encoder3Inpendant>0</Encoder3Inpendant><Encoder42DRO>0</Encoder42DRO><Encoder4Inpendant>0</Encoder4Inpendant><Encoder52DRO>0</Encoder52DRO><Encoder5Inpendant>0</Encoder5Inpendant><Encoder62DRO>0</Encoder62DRO><Encoder6Inpendant>0</Encoder6Inpendant><Encoder72DRO>0</Encoder72DRO><Encoder7Inpendant>0</Encoder7Inpendant><Encoder82DRO>0</Encoder82DRO><Encoder8Inpendant>0</Encoder8Inpendant><Encoder92DRO>0</Encoder92DRO><Encoder9Inpendant>0</Encoder9Inpendant><Encoder102DRO>0</Encoder102DRO><Encoder10Inpendant>0</Encoder10Inpendant><Encoder112DRO>0</Encoder112DRO><Encoder11Inpendant>0</Encoder11Inpendant><Encoder122DRO>0</Encoder122DRO><Encoder12Inpendant>0</Encoder12Inpendant><Encoder132DRO>0</Encoder132DRO><Encoder13Inpendant>0</Encoder13Inpendant><Encoder142DRO>0</Encoder142DRO><Encoder14Inpendant>0</Encoder14Inpendant><Encoder152DRO>0</Encoder152DRO><Encoder15Inpendant>0</Encoder15Inpendant><Encoder162DRO>0</Encoder162DRO><Encoder16Inpendant>0</Encoder16Inpendant><Encoder172DRO>0</Encoder172DRO><Encoder17Inpendant>0</Encoder17Inpendant><Encoder182DRO>0</Encoder182DRO><Encoder18Inpendant>0</Encoder18Inpendant><Encoder192DRO>0</Encoder192DRO><Encoder19Inpendant>0</Encoder19Inpendant><Encoder202DRO>0</Encoder202DRO><Encoder20Inpendant>0</Encoder20Inpendant><Encoder212DRO>0</Encoder212DRO><Encoder21Inpendant>0</Encoder21Inpendant><Encoder222DRO>0</Encoder222DRO><Encoder22Inpendant>0</Encoder22Inpendant><Encoder232DRO>0</Encoder232DRO><Encoder23Inpendant>0</Encoder23Inpendant><Encoder242DRO>0</Encoder242DRO><Encoder24Inpendant>0</Encoder24Inpendant><Encoder252DRO>0</Encoder252DRO><Encoder25Inpendant>0</Encoder25Inpendant><Encoder262DRO>0</Encoder262DRO><Encoder26Inpendant>0</Encoder26Inpendant><FastEncoders>0</FastEncoders><UltraFastEncoders>0</UltraFastEncoders><UltraFastEncodersOptions>0</UltraFastEncodersOptions><MPGjog>0</MPGjog><MPGjog1x>0</MPGjog1x><MatrixKB1Map2LED>0</MatrixKB1Map2LED><MatrixKB1Map2Button>0</MatrixKB1Map2Button><MatrixKB1Map2IO>0</MatrixKB1Map2IO><MatrixKB2Map2LED>0</MatrixKB2Map2LED><MatrixKB2Map2Button>0</MatrixKB2Map2Button><MatrixKB2Map2IO>0</MatrixKB2Map2IO><MatrixKB3Map2LED>0</MatrixKB3Map2LED><MatrixKB3Map2Button>0</MatrixKB3Map2Button><MatrixKB3Map2IO>0</MatrixKB3Map2IO><MatrixKB4Map2LED>0</MatrixKB4Map2LED><MatrixKB4Map2Button>0</MatrixKB4Map2Button><MatrixKB4Map2IO>0</MatrixKB4Map2IO><MatrixKB5Map2LED>0</MatrixKB5Map2LED><MatrixKB5Map2Button>0</MatrixKB5Map2Button><MatrixKB5Map2IO>0</MatrixKB5Map2IO><MatrixKB6Map2LED>0</MatrixKB6Map2LED><MatrixKB6Map2Button>0</MatrixKB6Map2Button><MatrixKB6Map2IO>0</MatrixKB6Map2IO><MatrixKB7Map2LED>0</MatrixKB7Map2LED><MatrixKB7Map2Button>0</MatrixKB7Map2Button><MatrixKB7Map2IO>0</MatrixKB7Map2IO><MatrixKB8Map2LED>0</MatrixKB8Map2LED><MatrixKB8Map2Button>0</MatrixKB8Map2Button><MatrixKB8Map2IO>0</MatrixKB8Map2IO><MatrixKB9Map2LED>0</MatrixKB9Map2LED><MatrixKB9Map2Button>0</MatrixKB9Map2Button><MatrixKB9Map2IO>0</MatrixKB9Map2IO><MatrixKB10Map2LED>0</MatrixKB10Map2LED><MatrixKB10Map2Button>0</MatrixKB10Map2Button><MatrixKB10Map2IO>0</MatrixKB10Map2IO><MatrixKB11Map2LED>0</MatrixKB11Map2LED><MatrixKB11Map2Button>0</MatrixKB11Map2Button><MatrixKB11Map2IO>0</MatrixKB11Map2IO><MatrixKB12Map2LED>0</MatrixKB12Map2LED><MatrixKB12Map2Button>0</MatrixKB12Map2Button><MatrixKB12Map2IO>0</MatrixKB12Map2IO><MatrixKB13Map2LED>0</MatrixKB13Map2LED><MatrixKB13Map2Button>0</MatrixKB13Map2Button><MatrixKB13Map2IO>0</MatrixKB13Map2IO><MatrixKB14Map2LED>0</MatrixKB14Map2LED><MatrixKB14Map2Button>0</MatrixKB14Map2Button><MatrixKB14Map2IO>0</MatrixKB14Map2IO><MatrixKB15Map2LED>0</MatrixKB15Map2LED><MatrixKB15Map2Button>0</MatrixKB15Map2Button><MatrixKB15Map2IO>0</MatrixKB15Map2IO><MatrixKB16Map2LED>0</MatrixKB16Map2LED><MatrixKB16Map2Button>0</MatrixKB16Map2Button><MatrixKB16Map2IO>0</MatrixKB16Map2IO><MatrixKB17Map2LED>0</MatrixKB17Map2LED><MatrixKB17Map2Button>0</MatrixKB17Map2Button><MatrixKB17Map2IO>0</MatrixKB17Map2IO><MatrixKB18Map2LED>0</MatrixKB18Map2LED><MatrixKB18Map2Button>0</MatrixKB18Map2Button><MatrixKB18Map2IO>0</MatrixKB18Map2IO><MatrixKB19Map2LED>0</MatrixKB19Map2LED><MatrixKB19Map2Button>0</MatrixKB19Map2Button><MatrixKB19Map2IO>0</MatrixKB19Map2IO><MatrixKB20Map2LED>0</MatrixKB20Map2LED><MatrixKB20Map2Button>0</MatrixKB20Map2Button><MatrixKB20Map2IO>0</MatrixKB20Map2IO><MatrixKB21Map2LED>0</MatrixKB21Map2LED><MatrixKB21Map2Button>0</MatrixKB21Map2Button><MatrixKB21Map2IO>0</MatrixKB21Map2IO><MatrixKB22Map2LED>0</MatrixKB22Map2LED><MatrixKB22Map2Button>0</MatrixKB22Map2Button><MatrixKB22Map2IO>0</MatrixKB22Map2IO><MatrixKB23Map2LED>0</MatrixKB23Map2LED><MatrixKB23Map2Button>0</MatrixKB23Map2Button><MatrixKB23Map2IO>0</MatrixKB23Map2IO><MatrixKB24Map2LED>0</MatrixKB24Map2LED><MatrixKB24Map2Button>0</MatrixKB24Map2Button><MatrixKB24Map2IO>0</MatrixKB24Map2IO><MatrixKB25Map2LED>0</MatrixKB25Map2LED><MatrixKB25Map2Button>0</MatrixKB25Map2Button><MatrixKB25Map2IO>0</MatrixKB25Map2IO><MatrixKB26Map2LED>0</MatrixKB26Map2LED><MatrixKB26Map2Button>0</MatrixKB26Map2Button><MatrixKB26Map2IO>0</MatrixKB26Map2IO><MatrixKB27Map2LED>0</MatrixKB27Map2LED><MatrixKB27Map2Button>0</MatrixKB27Map2Button><MatrixKB27Map2IO>0</MatrixKB27Map2IO><MatrixKB28Map2LED>0</MatrixKB28Map2LED><MatrixKB28Map2Button>0</MatrixKB28Map2Button><MatrixKB28Map2IO>0</MatrixKB28Map2IO><MatrixKB29Map2LED>0</MatrixKB29Map2LED><MatrixKB29Map2Button>0</MatrixKB29Map2Button><MatrixKB29Map2IO>0</MatrixKB29Map2IO><MatrixKB30Map2LED>0</MatrixKB30Map2LED><MatrixKB30Map2Button>0</MatrixKB30Map2Button><MatrixKB30Map2IO>0</MatrixKB30Map2IO><MatrixKB31Map2LED>0</MatrixKB31Map2LED><MatrixKB31Map2Button>0</MatrixKB31Map2Button><MatrixKB31Map2IO>0</MatrixKB31Map2IO><MatrixKB32Map2LED>0</MatrixKB32Map2LED><MatrixKB32Map2Button>0</MatrixKB32Map2Button><MatrixKB32Map2IO>0</MatrixKB32Map2IO><MatrixKB33Map2LED>0</MatrixKB33Map2LED><MatrixKB33Map2Button>0</MatrixKB33Map2Button><MatrixKB33Map2IO>0</MatrixKB33Map2IO><MatrixKB34Map2LED>0</MatrixKB34Map2LED><MatrixKB34Map2Button>0</MatrixKB34Map2Button><MatrixKB34Map2IO>0</MatrixKB34Map2IO><MatrixKB35Map2LED>0</MatrixKB35Map2LED><MatrixKB35Map2Button>0</MatrixKB35Map2Button><MatrixKB35Map2IO>0</MatrixKB35Map2IO><MatrixKB36Map2LED>0</MatrixKB36Map2LED><MatrixKB36Map2Button>0</MatrixKB36Map2Button><MatrixKB36Map2IO>0</MatrixKB36Map2IO><MatrixKB37Map2LED>0</MatrixKB37Map2LED><MatrixKB37Map2Button>0</MatrixKB37Map2Button><MatrixKB37Map2IO>0</MatrixKB37Map2IO><MatrixKB38Map2LED>0</MatrixKB38Map2LED><MatrixKB38Map2Button>0</MatrixKB38Map2Button><MatrixKB38Map2IO>0</MatrixKB38Map2IO><MatrixKB39Map2LED>0</MatrixKB39Map2LED><MatrixKB39Map2Button>0</MatrixKB39Map2Button><MatrixKB39Map2IO>0</MatrixKB39Map2IO><MatrixKB40Map2LED>0</MatrixKB40Map2LED><MatrixKB40Map2Button>0</MatrixKB40Map2Button><MatrixKB40Map2IO>0</MatrixKB40Map2IO><MatrixKB41Map2LED>0</MatrixKB41Map2LED><MatrixKB41Map2Button>0</MatrixKB41Map2Button><MatrixKB41Map2IO>0</MatrixKB41Map2IO><MatrixKB42Map2LED>0</MatrixKB42Map2LED><MatrixKB42Map2Button>0</MatrixKB42Map2Button><MatrixKB42Map2IO>0</MatrixKB42Map2IO><MatrixKB43Map2LED>0</MatrixKB43Map2LED><MatrixKB43Map2Button>0</MatrixKB43Map2Button><MatrixKB43Map2IO>0</MatrixKB43Map2IO><MatrixKB44Map2LED>0</MatrixKB44Map2LED><MatrixKB44Map2Button>0</MatrixKB44Map2Button><MatrixKB44Map2IO>0</MatrixKB44Map2IO><MatrixKB45Map2LED>0</MatrixKB45Map2LED><MatrixKB45Map2Button>0</MatrixKB45Map2Button><MatrixKB45Map2IO>0</MatrixKB45Map2IO><MatrixKB46Map2LED>0</MatrixKB46Map2LED><MatrixKB46Map2Button>0</MatrixKB46Map2Button><MatrixKB46Map2IO>0</MatrixKB46Map2IO><MatrixKB47Map2LED>0</MatrixKB47Map2LED><MatrixKB47Map2Button>0</MatrixKB47Map2Button><MatrixKB47Map2IO>0</MatrixKB47Map2IO><MatrixKB48Map2LED>0</MatrixKB48Map2LED><MatrixKB48Map2Button>0</MatrixKB48Map2Button><MatrixKB48Map2IO>0</MatrixKB48Map2IO><MatrixKB49Map2LED>0</MatrixKB49Map2LED><MatrixKB49Map2Button>0</MatrixKB49Map2Button><MatrixKB49Map2IO>0</MatrixKB49Map2IO><MatrixKB50Map2LED>0</MatrixKB50Map2LED><MatrixKB50Map2Button>0</MatrixKB50Map2Button><MatrixKB50Map2IO>0</MatrixKB50Map2IO><MatrixKB51Map2LED>0</MatrixKB51Map2LED><MatrixKB51Map2Button>0</MatrixKB51Map2Button><MatrixKB51Map2IO>0</MatrixKB51Map2IO><MatrixKB52Map2LED>0</MatrixKB52Map2LED><MatrixKB52Map2Button>0</MatrixKB52Map2Button><MatrixKB52Map2IO>0</MatrixKB52Map2IO><MatrixKB53Map2LED>0</MatrixKB53Map2LED><MatrixKB53Map2Button>0</MatrixKB53Map2Button><MatrixKB53Map2IO>0</MatrixKB53Map2IO><MatrixKB54Map2LED>0</MatrixKB54Map2LED><MatrixKB54Map2Button>0</MatrixKB54Map2Button><MatrixKB54Map2IO>0</MatrixKB54Map2IO><MatrixKB55Map2LED>0</MatrixKB55Map2LED><MatrixKB55Map2Button>0</MatrixKB55Map2Button><MatrixKB55Map2IO>0</MatrixKB55Map2IO><MatrixKB56Map2LED>0</MatrixKB56Map2LED><MatrixKB56Map2Button>0</MatrixKB56Map2Button><MatrixKB56Map2IO>0</MatrixKB56Map2IO><MatrixKB57Map2LED>0</MatrixKB57Map2LED><MatrixKB57Map2Button>0</MatrixKB57Map2Button><MatrixKB57Map2IO>0</MatrixKB57Map2IO><MatrixKB58Map2LED>0</MatrixKB58Map2LED><MatrixKB58Map2Button>0</MatrixKB58Map2Button><MatrixKB58Map2IO>0</MatrixKB58Map2IO><MatrixKB59Map2LED>0</MatrixKB59Map2LED><MatrixKB59Map2Button>0</MatrixKB59Map2Button><MatrixKB59Map2IO>0</MatrixKB59Map2IO><MatrixKB60Map2LED>0</MatrixKB60Map2LED><MatrixKB60Map2Button>0</MatrixKB60Map2Button><MatrixKB60Map2IO>0</MatrixKB60Map2IO><MatrixKB61Map2LED>0</MatrixKB61Map2LED><MatrixKB61Map2Button>0</MatrixKB61Map2Button><MatrixKB61Map2IO>0</MatrixKB61Map2IO><MatrixKB62Map2LED>0</MatrixKB62Map2LED><MatrixKB62Map2Button>0</MatrixKB62Map2Button><MatrixKB62Map2IO>0</MatrixKB62Map2IO><MatrixKB63Map2LED>0</MatrixKB63Map2LED><MatrixKB63Map2Button>0</MatrixKB63Map2Button><MatrixKB63Map2IO>0</MatrixKB63Map2IO><MatrixKB64Map2LED>0</MatrixKB64Map2LED><MatrixKB64Map2Button>0</MatrixKB64Map2Button><MatrixKB64Map2IO>0</MatrixKB64Map2IO><MatrixKB65Map2LED>0</MatrixKB65Map2LED><MatrixKB65Map2Button>0</MatrixKB65Map2Button><MatrixKB65Map2IO>0</MatrixKB65Map2IO><MatrixKB66Map2LED>0</MatrixKB66Map2LED><MatrixKB66Map2Button>0</MatrixKB66Map2Button><MatrixKB66Map2IO>0</MatrixKB66Map2IO><MatrixKB67Map2LED>0</MatrixKB67Map2LED><MatrixKB67Map2Button>0</MatrixKB67Map2Button><MatrixKB67Map2IO>0</MatrixKB67Map2IO><MatrixKB68Map2LED>0</MatrixKB68Map2LED><MatrixKB68Map2Button>0</MatrixKB68Map2Button><MatrixKB68Map2IO>0</MatrixKB68Map2IO><MatrixKB69Map2LED>0</MatrixKB69Map2LED><MatrixKB69Map2Button>0</MatrixKB69Map2Button><MatrixKB69Map2IO>0</MatrixKB69Map2IO><MatrixKB70Map2LED>0</MatrixKB70Map2LED><MatrixKB70Map2Button>0</MatrixKB70Map2Button><MatrixKB70Map2IO>0</MatrixKB70Map2IO><MatrixKB71Map2LED>0</MatrixKB71Map2LED><MatrixKB71Map2Button>0</MatrixKB71Map2Button><MatrixKB71Map2IO>0</MatrixKB71Map2IO><MatrixKB72Map2LED>0</MatrixKB72Map2LED><MatrixKB72Map2Button>0</MatrixKB72Map2Button><MatrixKB72Map2IO>0</MatrixKB72Map2IO><MatrixKB73Map2LED>0</MatrixKB73Map2LED><MatrixKB73Map2Button>0</MatrixKB73Map2Button><MatrixKB73Map2IO>0</MatrixKB73Map2IO><MatrixKB74Map2LED>0</MatrixKB74Map2LED><MatrixKB74Map2Button>0</MatrixKB74Map2Button><MatrixKB74Map2IO>0</MatrixKB74Map2IO><MatrixKB75Map2LED>0</MatrixKB75Map2LED><MatrixKB75Map2Button>0</MatrixKB75Map2Button><MatrixKB75Map2IO>0</MatrixKB75Map2IO><MatrixKB76Map2LED>0</MatrixKB76Map2LED><MatrixKB76Map2Button>0</MatrixKB76Map2Button><MatrixKB76Map2IO>0</MatrixKB76Map2IO><MatrixKB77Map2LED>0</MatrixKB77Map2LED><MatrixKB77Map2Button>0</MatrixKB77Map2Button><MatrixKB77Map2IO>0</MatrixKB77Map2IO><MatrixKB78Map2LED>0</MatrixKB78Map2LED><MatrixKB78Map2Button>0</MatrixKB78Map2Button><MatrixKB78Map2IO>0</MatrixKB78Map2IO><MatrixKB79Map2LED>0</MatrixKB79Map2LED><MatrixKB79Map2Button>0</MatrixKB79Map2Button><MatrixKB79Map2IO>0</MatrixKB79Map2IO><MatrixKB80Map2LED>0</MatrixKB80Map2LED><MatrixKB80Map2Button>0</MatrixKB80Map2Button><MatrixKB80Map2IO>0</MatrixKB80Map2IO><MatrixKB81Map2LED>0</MatrixKB81Map2LED><MatrixKB81Map2Button>0</MatrixKB81Map2Button><MatrixKB81Map2IO>0</MatrixKB81Map2IO><MatrixKB82Map2LED>0</MatrixKB82Map2LED><MatrixKB82Map2Button>0</MatrixKB82Map2Button><MatrixKB82Map2IO>0</MatrixKB82Map2IO><MatrixKB83Map2LED>0</MatrixKB83Map2LED><MatrixKB83Map2Button>0</MatrixKB83Map2Button><MatrixKB83Map2IO>0</MatrixKB83Map2IO><MatrixKB84Map2LED>0</MatrixKB84Map2LED><MatrixKB84Map2Button>0</MatrixKB84Map2Button><MatrixKB84Map2IO>0</MatrixKB84Map2IO><MatrixKB85Map2LED>0</MatrixKB85Map2LED><MatrixKB85Map2Button>0</MatrixKB85Map2Button><MatrixKB85Map2IO>0</MatrixKB85Map2IO><MatrixKB86Map2LED>0</MatrixKB86Map2LED><MatrixKB86Map2Button>0</MatrixKB86Map2Button><MatrixKB86Map2IO>0</MatrixKB86Map2IO><MatrixKB87Map2LED>0</MatrixKB87Map2LED><MatrixKB87Map2Button>0</MatrixKB87Map2Button><MatrixKB87Map2IO>0</MatrixKB87Map2IO><MatrixKB88Map2LED>0</MatrixKB88Map2LED><MatrixKB88Map2Button>0</MatrixKB88Map2Button><MatrixKB88Map2IO>0</MatrixKB88Map2IO><MatrixKB89Map2LED>0</MatrixKB89Map2LED><MatrixKB89Map2Button>0</MatrixKB89Map2Button><MatrixKB89Map2IO>0</MatrixKB89Map2IO><MatrixKB90Map2LED>0</MatrixKB90Map2LED><MatrixKB90Map2Button>0</MatrixKB90Map2Button><MatrixKB90Map2IO>0</MatrixKB90Map2IO><MatrixKB91Map2LED>0</MatrixKB91Map2LED><MatrixKB91Map2Button>0</MatrixKB91Map2Button><MatrixKB91Map2IO>0</MatrixKB91Map2IO><MatrixKB92Map2LED>0</MatrixKB92Map2LED><MatrixKB92Map2Button>0</MatrixKB92Map2Button><MatrixKB92Map2IO>0</MatrixKB92Map2IO><MatrixKB93Map2LED>0</MatrixKB93Map2LED><MatrixKB93Map2Button>0</MatrixKB93Map2Button><MatrixKB93Map2IO>0</MatrixKB93Map2IO><MatrixKB94Map2LED>0</MatrixKB94Map2LED><MatrixKB94Map2Button>0</MatrixKB94Map2Button><MatrixKB94Map2IO>0</MatrixKB94Map2IO><MatrixKB95Map2LED>0</MatrixKB95Map2LED><MatrixKB95Map2Button>0</MatrixKB95Map2Button><MatrixKB95Map2IO>0</MatrixKB95Map2IO><MatrixKB96Map2LED>0</MatrixKB96Map2LED><MatrixKB96Map2Button>0</MatrixKB96Map2Button><MatrixKB96Map2IO>0</MatrixKB96Map2IO><MatrixKB97Map2LED>0</MatrixKB97Map2LED><MatrixKB97Map2Button>0</MatrixKB97Map2Button><MatrixKB97Map2IO>0</MatrixKB97Map2IO><MatrixKB98Map2LED>0</MatrixKB98Map2LED><MatrixKB98Map2Button>0</MatrixKB98Map2Button><MatrixKB98Map2IO>0</MatrixKB98Map2IO><MatrixKB99Map2LED>0</MatrixKB99Map2LED><MatrixKB99Map2Button>0</MatrixKB99Map2Button><MatrixKB99Map2IO>0</MatrixKB99Map2IO><MatrixKB100Map2LED>0</MatrixKB100Map2LED><MatrixKB100Map2Button>0</MatrixKB100Map2Button><MatrixKB100Map2IO>0</MatrixKB100Map2IO><MatrixKB101Map2LED>0</MatrixKB101Map2LED><MatrixKB101Map2Button>0</MatrixKB101Map2Button><MatrixKB101Map2IO>0</MatrixKB101Map2IO><MatrixKB102Map2LED>0</MatrixKB102Map2LED><MatrixKB102Map2Button>0</MatrixKB102Map2Button><MatrixKB102Map2IO>0</MatrixKB102Map2IO><MatrixKB103Map2LED>0</MatrixKB103Map2LED><MatrixKB103Map2Button>0</MatrixKB103Map2Button><MatrixKB103Map2IO>0</MatrixKB103Map2IO><MatrixKB104Map2LED>0</MatrixKB104Map2LED><MatrixKB104Map2Button>0</MatrixKB104Map2Button><MatrixKB104Map2IO>0</MatrixKB104Map2IO><MatrixKB105Map2LED>0</MatrixKB105Map2LED><MatrixKB105Map2Button>0</MatrixKB105Map2Button><MatrixKB105Map2IO>0</MatrixKB105Map2IO><MatrixKB106Map2LED>0</MatrixKB106Map2LED><MatrixKB106Map2Button>0</MatrixKB106Map2Button><MatrixKB106Map2IO>0</MatrixKB106Map2IO><MatrixKB107Map2LED>0</MatrixKB107Map2LED><MatrixKB107Map2Button>0</MatrixKB107Map2Button><MatrixKB107Map2IO>0</MatrixKB107Map2IO><MatrixKB108Map2LED>0</MatrixKB108Map2LED><MatrixKB108Map2Button>0</MatrixKB108Map2Button><MatrixKB108Map2IO>0</MatrixKB108Map2IO><MatrixKB109Map2LED>0</MatrixKB109Map2LED><MatrixKB109Map2Button>0</MatrixKB109Map2Button><MatrixKB109Map2IO>0</MatrixKB109Map2IO><MatrixKB110Map2LED>0</MatrixKB110Map2LED><MatrixKB110Map2Button>0</MatrixKB110Map2Button><MatrixKB110Map2IO>0</MatrixKB110Map2IO><MatrixKB111Map2LED>0</MatrixKB111Map2LED><MatrixKB111Map2Button>0</MatrixKB111Map2Button><MatrixKB111Map2IO>0</MatrixKB111Map2IO><MatrixKB112Map2LED>0</MatrixKB112Map2LED><MatrixKB112Map2Button>0</MatrixKB112Map2Button><MatrixKB112Map2IO>0</MatrixKB112Map2IO><MatrixKB113Map2LED>0</MatrixKB113Map2LED><MatrixKB113Map2Button>0</MatrixKB113Map2Button><MatrixKB113Map2IO>0</MatrixKB113Map2IO><MatrixKB114Map2LED>0</MatrixKB114Map2LED><MatrixKB114Map2Button>0</MatrixKB114Map2Button><MatrixKB114Map2IO>0</MatrixKB114Map2IO><MatrixKB115Map2LED>0</MatrixKB115Map2LED><MatrixKB115Map2Button>0</MatrixKB115Map2Button><MatrixKB115Map2IO>0</MatrixKB115Map2IO><MatrixKB116Map2LED>0</MatrixKB116Map2LED><MatrixKB116Map2Button>0</MatrixKB116Map2Button><MatrixKB116Map2IO>0</MatrixKB116Map2IO><MatrixKB117Map2LED>0</MatrixKB117Map2LED><MatrixKB117Map2Button>0</MatrixKB117Map2Button><MatrixKB117Map2IO>0</MatrixKB117Map2IO><MatrixKB118Map2LED>0</MatrixKB118Map2LED><MatrixKB118Map2Button>0</MatrixKB118Map2Button><MatrixKB118Map2IO>0</MatrixKB118Map2IO><MatrixKB119Map2LED>0</MatrixKB119Map2LED><MatrixKB119Map2Button>0</MatrixKB119Map2Button><MatrixKB119Map2IO>0</MatrixKB119Map2IO><MatrixKB120Map2LED>0</MatrixKB120Map2LED><MatrixKB120Map2Button>0</MatrixKB120Map2Button><MatrixKB120Map2IO>0</MatrixKB120Map2IO><MatrixKB121Map2LED>0</MatrixKB121Map2LED><MatrixKB121Map2Button>0</MatrixKB121Map2Button><MatrixKB121Map2IO>0</MatrixKB121Map2IO><MatrixKB122Map2LED>0</MatrixKB122Map2LED><MatrixKB122Map2Button>0</MatrixKB122Map2Button><MatrixKB122Map2IO>0</MatrixKB122Map2IO><MatrixKB123Map2LED>0</MatrixKB123Map2LED><MatrixKB123Map2Button>0</MatrixKB123Map2Button><MatrixKB123Map2IO>0</MatrixKB123Map2IO><MatrixKB124Map2LED>0</MatrixKB124Map2LED><MatrixKB124Map2Button>0</MatrixKB124Map2Button><MatrixKB124Map2IO>0</MatrixKB124Map2IO><MatrixKB125Map2LED>0</MatrixKB125Map2LED><MatrixKB125Map2Button>0</MatrixKB125Map2Button><MatrixKB125Map2IO>0</MatrixKB125Map2IO><MatrixKB126Map2LED>0</MatrixKB126Map2LED><MatrixKB126Map2Button>0</MatrixKB126Map2Button><MatrixKB126Map2IO>0</MatrixKB126Map2IO><MatrixKB127Map2LED>0</MatrixKB127Map2LED><MatrixKB127Map2Button>0</MatrixKB127Map2Button><MatrixKB127Map2IO>0</MatrixKB127Map2IO><MatrixKB128Map2LED>0</MatrixKB128Map2LED><MatrixKB128Map2Button>0</MatrixKB128Map2Button><MatrixKB128Map2IO>0</MatrixKB128Map2IO><MatrixWidth>0</MatrixWidth><MatrixHeight>0</MatrixHeight><MatrixEnabled>0</MatrixEnabled><MatrixRow1>0</MatrixRow1><MatrixRow2>0</MatrixRow2><MatrixRow3>0</MatrixRow3><MatrixRow4>0</MatrixRow4><MatrixRow5>0</MatrixRow5><MatrixRow6>0</MatrixRow6><MatrixRow7>0</MatrixRow7><MatrixRow8>0</MatrixRow8><MatrixRow9>0</MatrixRow9><MatrixRow10>0</MatrixRow10><MatrixRow11>0</MatrixRow11><MatrixRow12>0</MatrixRow12><MatrixRow13>0</MatrixRow13><MatrixRow14>0</MatrixRow14><MatrixRow15>0</MatrixRow15><MatrixRow16>0</MatrixRow16><MatrixColumn1>0</MatrixColumn1><MatrixColumn2>0</MatrixColumn2><MatrixColumn3>0</MatrixColumn3><MatrixColumn4>0</MatrixColumn4><MatrixColumn5>0</MatrixColumn5><MatrixColumn6>0</MatrixColumn6><MatrixColumn7>0</MatrixColumn7><MatrixColumn8>0</MatrixColumn8><PoExtBus1Map2LED>0</PoExtBus1Map2LED><PoExtBus1Map2IO>0</PoExtBus1Map2IO><PoExtBus1Invert>0</PoExtBus1Invert><PoExtBus2Map2LED>0</PoExtBus2Map2LED><PoExtBus2Map2IO>0</PoExtBus2Map2IO><PoExtBus2Invert>0</PoExtBus2Invert><PoExtBus3Map2LED>0</PoExtBus3Map2LED><PoExtBus3Map2IO>0</PoExtBus3Map2IO><PoExtBus3Invert>0</PoExtBus3Invert><PoExtBus4Map2LED>0</PoExtBus4Map2LED><PoExtBus4Map2IO>0</PoExtBus4Map2IO><PoExtBus4Invert>0</PoExtBus4Invert><PoExtBus5Map2LED>0</PoExtBus5Map2LED><PoExtBus5Map2IO>0</PoExtBus5Map2IO><PoExtBus5Invert>0</PoExtBus5Invert><PoExtBus6Map2LED>0</PoExtBus6Map2LED><PoExtBus6Map2IO>0</PoExtBus6Map2IO><PoExtBus6Invert>0</PoExtBus6Invert><PoExtBus7Map2LED>0</PoExtBus7Map2LED><PoExtBus7Map2IO>0</PoExtBus7Map2IO><PoExtBus7Invert>0</PoExtBus7Invert><PoExtBus8Map2LED>0</PoExtBus8Map2LED><PoExtBus8Map2IO>0</PoExtBus8Map2IO><PoExtBus8Invert>0</PoExtBus8Invert><PoExtBus9Map2LED>0</PoExtBus9Map2LED><PoExtBus9Map2IO>0</PoExtBus9Map2IO><PoExtBus9Invert>0</PoExtBus9Invert><PoExtBus10Map2LED>0</PoExtBus10Map2LED><PoExtBus10Map2IO>0</PoExtBus10Map2IO><PoExtBus10Invert>0</PoExtBus10Invert><PoExtBus11Map2LED>0</PoExtBus11Map2LED><PoExtBus11Map2IO>0</PoExtBus11Map2IO><PoExtBus11Invert>0</PoExtBus11Invert><PoExtBus12Map2LED>0</PoExtBus12Map2LED><PoExtBus12Map2IO>0</PoExtBus12Map2IO><PoExtBus12Invert>0</PoExtBus12Invert><PoExtBus13Map2LED>0</PoExtBus13Map2LED><PoExtBus13Map2IO>0</PoExtBus13Map2IO><PoExtBus13Invert>0</PoExtBus13Invert><PoExtBus14Map2LED>0</PoExtBus14Map2LED><PoExtBus14Map2IO>0</PoExtBus14Map2IO><PoExtBus14Invert>0</PoExtBus14Invert><PoExtBus15Map2LED>0</PoExtBus15Map2LED><PoExtBus15Map2IO>0</PoExtBus15Map2IO><PoExtBus15Invert>0</PoExtBus15Invert><PoExtBus16Map2LED>0</PoExtBus16Map2LED><PoExtBus16Map2IO>0</PoExtBus16Map2IO><PoExtBus16Invert>0</PoExtBus16Invert><PoExtBus17Map2LED>0</PoExtBus17Map2LED><PoExtBus17Map2IO>0</PoExtBus17Map2IO><PoExtBus17Invert>0</PoExtBus17Invert><PoExtBus18Map2LED>0</PoExtBus18Map2LED><PoExtBus18Map2IO>0</PoExtBus18Map2IO><PoExtBus18Invert>0</PoExtBus18Invert><PoExtBus19Map2LED>0</PoExtBus19Map2LED><PoExtBus19Map2IO>0</PoExtBus19Map2IO><PoExtBus19Invert>0</PoExtBus19Invert><PoExtBus20Map2LED>0</PoExtBus20Map2LED><PoExtBus20Map2IO>0</PoExtBus20Map2IO><PoExtBus20Invert>0</PoExtBus20Invert><PoExtBus21Map2LED>0</PoExtBus21Map2LED><PoExtBus21Map2IO>0</PoExtBus21Map2IO><PoExtBus21Invert>0</PoExtBus21Invert><PoExtBus22Map2LED>0</PoExtBus22Map2LED><PoExtBus22Map2IO>0</PoExtBus22Map2IO><PoExtBus22Invert>0</PoExtBus22Invert><PoExtBus23Map2LED>0</PoExtBus23Map2LED><PoExtBus23Map2IO>0</PoExtBus23Map2IO><PoExtBus23Invert>0</PoExtBus23Invert><PoExtBus24Map2LED>0</PoExtBus24Map2LED><PoExtBus24Map2IO>0</PoExtBus24Map2IO><PoExtBus24Invert>0</PoExtBus24Invert><PoExtBus25Map2LED>0</PoExtBus25Map2LED><PoExtBus25Map2IO>0</PoExtBus25Map2IO><PoExtBus25Invert>0</PoExtBus25Invert><PoExtBus26Map2LED>0</PoExtBus26Map2LED><PoExtBus26Map2IO>0</PoExtBus26Map2IO><PoExtBus26Invert>0</PoExtBus26Invert><PoExtBus27Map2LED>0</PoExtBus27Map2LED><PoExtBus27Map2IO>0</PoExtBus27Map2IO><PoExtBus27Invert>0</PoExtBus27Invert><PoExtBus28Map2LED>0</PoExtBus28Map2LED><PoExtBus28Map2IO>0</PoExtBus28Map2IO><PoExtBus28Invert>0</PoExtBus28Invert><PoExtBus29Map2LED>0</PoExtBus29Map2LED><PoExtBus29Map2IO>0</PoExtBus29Map2IO><PoExtBus29Invert>0</PoExtBus29Invert><PoExtBus30Map2LED>0</PoExtBus30Map2LED><PoExtBus30Map2IO>0</PoExtBus30Map2IO><PoExtBus30Invert>0</PoExtBus30Invert><PoExtBus31Map2LED>0</PoExtBus31Map2LED><PoExtBus31Map2IO>0</PoExtBus31Map2IO><PoExtBus31Invert>0</PoExtBus31Invert><PoExtBus32Map2LED>0</PoExtBus32Map2LED><PoExtBus32Map2IO>0</PoExtBus32Map2IO><PoExtBus32Invert>0</PoExtBus32Invert><PoExtBus33Map2LED>0</PoExtBus33Map2LED><PoExtBus33Map2IO>0</PoExtBus33Map2IO><PoExtBus33Invert>0</PoExtBus33Invert><PoExtBus34Map2LED>0</PoExtBus34Map2LED><PoExtBus34Map2IO>0</PoExtBus34Map2IO><PoExtBus34Invert>0</PoExtBus34Invert><PoExtBus35Map2LED>0</PoExtBus35Map2LED><PoExtBus35Map2IO>0</PoExtBus35Map2IO><PoExtBus35Invert>0</PoExtBus35Invert><PoExtBus36Map2LED>0</PoExtBus36Map2LED><PoExtBus36Map2IO>0</PoExtBus36Map2IO><PoExtBus36Invert>0</PoExtBus36Invert><PoExtBus37Map2LED>0</PoExtBus37Map2LED><PoExtBus37Map2IO>0</PoExtBus37Map2IO><PoExtBus37Invert>0</PoExtBus37Invert><PoExtBus38Map2LED>0</PoExtBus38Map2LED><PoExtBus38Map2IO>0</PoExtBus38Map2IO><PoExtBus38Invert>0</PoExtBus38Invert><PoExtBus39Map2LED>0</PoExtBus39Map2LED><PoExtBus39Map2IO>0</PoExtBus39Map2IO><PoExtBus39Invert>0</PoExtBus39Invert><PoExtBus40Map2LED>0</PoExtBus40Map2LED><PoExtBus40Map2IO>0</PoExtBus40Map2IO><PoExtBus40Invert>0</PoExtBus40Invert><PoExtBus41Map2LED>0</PoExtBus41Map2LED><PoExtBus41Map2IO>0</PoExtBus41Map2IO><PoExtBus41Invert>0</PoExtBus41Invert><PoExtBus42Map2LED>0</PoExtBus42Map2LED><PoExtBus42Map2IO>0</PoExtBus42Map2IO><PoExtBus42Invert>0</PoExtBus42Invert><PoExtBus43Map2LED>0</PoExtBus43Map2LED><PoExtBus43Map2IO>0</PoExtBus43Map2IO><PoExtBus43Invert>0</PoExtBus43Invert><PoExtBus44Map2LED>0</PoExtBus44Map2LED><PoExtBus44Map2IO>0</PoExtBus44Map2IO><PoExtBus44Invert>0</PoExtBus44Invert><PoExtBus45Map2LED>0</PoExtBus45Map2LED><PoExtBus45Map2IO>0</PoExtBus45Map2IO><PoExtBus45Invert>0</PoExtBus45Invert><PoExtBus46Map2LED>0</PoExtBus46Map2LED><PoExtBus46Map2IO>0</PoExtBus46Map2IO><PoExtBus46Invert>0</PoExtBus46Invert><PoExtBus47Map2LED>0</PoExtBus47Map2LED><PoExtBus47Map2IO>0</PoExtBus47Map2IO><PoExtBus47Invert>0</PoExtBus47Invert><PoExtBus48Map2LED>0</PoExtBus48Map2LED><PoExtBus48Map2IO>0</PoExtBus48Map2IO><PoExtBus48Invert>0</PoExtBus48Invert><PoExtBus49Map2LED>0</PoExtBus49Map2LED><PoExtBus49Map2IO>0</PoExtBus49Map2IO><PoExtBus49Invert>0</PoExtBus49Invert><PoExtBus50Map2LED>0</PoExtBus50Map2LED><PoExtBus50Map2IO>0</PoExtBus50Map2IO><PoExtBus50Invert>0</PoExtBus50Invert><PoExtBus51Map2LED>0</PoExtBus51Map2LED><PoExtBus51Map2IO>0</PoExtBus51Map2IO><PoExtBus51Invert>0</PoExtBus51Invert><PoExtBus52Map2LED>0</PoExtBus52Map2LED><PoExtBus52Map2IO>0</PoExtBus52Map2IO><PoExtBus52Invert>0</PoExtBus52Invert><PoExtBus53Map2LED>0</PoExtBus53Map2LED><PoExtBus53Map2IO>0</PoExtBus53Map2IO><PoExtBus53Invert>0</PoExtBus53Invert><PoExtBus54Map2LED>0</PoExtBus54Map2LED><PoExtBus54Map2IO>0</PoExtBus54Map2IO><PoExtBus54Invert>0</PoExtBus54Invert><PoExtBus55Map2LED>0</PoExtBus55Map2LED><PoExtBus55Map2IO>0</PoExtBus55Map2IO><PoExtBus55Invert>0</PoExtBus55Invert><PoExtBus56Map2LED>0</PoExtBus56Map2LED><PoExtBus56Map2IO>0</PoExtBus56Map2IO><PoExtBus56Invert>0</PoExtBus56Invert><PoExtBus57Map2LED>0</PoExtBus57Map2LED><PoExtBus57Map2IO>0</PoExtBus57Map2IO><PoExtBus57Invert>0</PoExtBus57Invert><PoExtBus58Map2LED>0</PoExtBus58Map2LED><PoExtBus58Map2IO>0</PoExtBus58Map2IO><PoExtBus58Invert>0</PoExtBus58Invert><PoExtBus59Map2LED>0</PoExtBus59Map2LED><PoExtBus59Map2IO>0</PoExtBus59Map2IO><PoExtBus59Invert>0</PoExtBus59Invert><PoExtBus60Map2LED>0</PoExtBus60Map2LED><PoExtBus60Map2IO>0</PoExtBus60Map2IO><PoExtBus60Invert>0</PoExtBus60Invert><PoExtBus61Map2LED>0</PoExtBus61Map2LED><PoExtBus61Map2IO>0</PoExtBus61Map2IO><PoExtBus61Invert>0</PoExtBus61Invert><PoExtBus62Map2LED>0</PoExtBus62Map2LED><PoExtBus62Map2IO>0</PoExtBus62Map2IO><PoExtBus62Invert>0</PoExtBus62Invert><PoExtBus63Map2LED>0</PoExtBus63Map2LED><PoExtBus63Map2IO>0</PoExtBus63Map2IO><PoExtBus63Invert>0</PoExtBus63Invert><PoExtBus64Map2LED>0</PoExtBus64Map2LED><PoExtBus64Map2IO>0</PoExtBus64Map2IO><PoExtBus64Invert>0</PoExtBus64Invert><PoExtBus65Map2LED>0</PoExtBus65Map2LED><PoExtBus65Map2IO>0</PoExtBus65Map2IO><PoExtBus65Invert>0</PoExtBus65Invert><PoExtBus66Map2LED>0</PoExtBus66Map2LED><PoExtBus66Map2IO>0</PoExtBus66Map2IO><PoExtBus66Invert>0</PoExtBus66Invert><PoExtBus67Map2LED>0</PoExtBus67Map2LED><PoExtBus67Map2IO>0</PoExtBus67Map2IO><PoExtBus67Invert>0</PoExtBus67Invert><PoExtBus68Map2LED>0</PoExtBus68Map2LED><PoExtBus68Map2IO>0</PoExtBus68Map2IO><PoExtBus68Invert>0</PoExtBus68Invert><PoExtBus69Map2LED>0</PoExtBus69Map2LED><PoExtBus69Map2IO>0</PoExtBus69Map2IO><PoExtBus69Invert>0</PoExtBus69Invert><PoExtBus70Map2LED>0</PoExtBus70Map2LED><PoExtBus70Map2IO>0</PoExtBus70Map2IO><PoExtBus70Invert>0</PoExtBus70Invert><PoExtBus71Map2LED>0</PoExtBus71Map2LED><PoExtBus71Map2IO>0</PoExtBus71Map2IO><PoExtBus71Invert>0</PoExtBus71Invert><PoExtBus72Map2LED>0</PoExtBus72Map2LED><PoExtBus72Map2IO>0</PoExtBus72Map2IO><PoExtBus72Invert>0</PoExtBus72Invert><PoExtBus73Map2LED>0</PoExtBus73Map2LED><PoExtBus73Map2IO>0</PoExtBus73Map2IO><PoExtBus73Invert>0</PoExtBus73Invert><PoExtBus74Map2LED>0</PoExtBus74Map2LED><PoExtBus74Map2IO>0</PoExtBus74Map2IO><PoExtBus74Invert>0</PoExtBus74Invert><PoExtBus75Map2LED>0</PoExtBus75Map2LED><PoExtBus75Map2IO>0</PoExtBus75Map2IO><PoExtBus75Invert>0</PoExtBus75Invert><PoExtBus76Map2LED>0</PoExtBus76Map2LED><PoExtBus76Map2IO>0</PoExtBus76Map2IO><PoExtBus76Invert>0</PoExtBus76Invert><PoExtBus77Map2LED>0</PoExtBus77Map2LED><PoExtBus77Map2IO>0</PoExtBus77Map2IO><PoExtBus77Invert>0</PoExtBus77Invert><PoExtBus78Map2LED>0</PoExtBus78Map2LED><PoExtBus78Map2IO>0</PoExtBus78Map2IO><PoExtBus78Invert>0</PoExtBus78Invert><PoExtBus79Map2LED>0</PoExtBus79Map2LED><PoExtBus79Map2IO>0</PoExtBus79Map2IO><PoExtBus79Invert>0</PoExtBus79Invert><PoExtBus80Map2LED>0</PoExtBus80Map2LED><PoExtBus80Map2IO>0</PoExtBus80Map2IO><PoExtBus80Invert>0</PoExtBus80Invert><kbd48CNC_0_ToLED>0</kbd48CNC_0_ToLED><kbd48CNC_0_ToButton>0</kbd48CNC_0_ToButton><kbd48CNC_LEDto_0>0</kbd48CNC_LEDto_0><kbd48CNC_1_ToLED>0</kbd48CNC_1_ToLED><kbd48CNC_1_ToButton>0</kbd48CNC_1_ToButton><kbd48CNC_LEDto_1>0</kbd48CNC_LEDto_1><kbd48CNC_2_ToLED>0</kbd48CNC_2_ToLED><kbd48CNC_2_ToButton>0</kbd48CNC_2_ToButton><kbd48CNC_LEDto_2>0</kbd48CNC_LEDto_2><kbd48CNC_3_ToLED>0</kbd48CNC_3_ToLED><kbd48CNC_3_ToButton>0</kbd48CNC_3_ToButton><kbd48CNC_LEDto_3>0</kbd48CNC_LEDto_3><kbd48CNC_4_ToLED>0</kbd48CNC_4_ToLED><kbd48CNC_4_ToButton>0</kbd48CNC_4_ToButton><kbd48CNC_LEDto_4>0</kbd48CNC_LEDto_4><kbd48CNC_5_ToLED>0</kbd48CNC_5_ToLED><kbd48CNC_5_ToButton>0</kbd48CNC_5_ToButton><kbd48CNC_LEDto_5>0</kbd48CNC_LEDto_5><kbd48CNC_6_ToLED>0</kbd48CNC_6_ToLED><kbd48CNC_6_ToButton>0</kbd48CNC_6_ToButton><kbd48CNC_LEDto_6>0</kbd48CNC_LEDto_6><kbd48CNC_7_ToLED>0</kbd48CNC_7_ToLED><kbd48CNC_7_ToButton>0</kbd48CNC_7_ToButton><kbd48CNC_LEDto_7>0</kbd48CNC_LEDto_7><kbd48CNC_8_ToLED>0</kbd48CNC_8_ToLED><kbd48CNC_8_ToButton>0</kbd48CNC_8_ToButton><kbd48CNC_LEDto_8>0</kbd48CNC_LEDto_8><kbd48CNC_9_ToLED>0</kbd48CNC_9_ToLED><kbd48CNC_9_ToButton>0</kbd48CNC_9_ToButton><kbd48CNC_LEDto_9>0</kbd48CNC_LEDto_9><kbd48CNC_10_ToLED>0</kbd48CNC_10_ToLED><kbd48CNC_10_ToButton>0</kbd48CNC_10_ToButton><kbd48CNC_LEDto_10>0</kbd48CNC_LEDto_10><kbd48CNC_11_ToLED>0</kbd48CNC_11_ToLED><kbd48CNC_11_ToButton>0</kbd48CNC_11_ToButton><kbd48CNC_LEDto_11>0</kbd48CNC_LEDto_11><kbd48CNC_12_ToLED>0</kbd48CNC_12_ToLED><kbd48CNC_12_ToButton>0</kbd48CNC_12_ToButton><kbd48CNC_LEDto_12>0</kbd48CNC_LEDto_12><kbd48CNC_13_ToLED>0</kbd48CNC_13_ToLED><kbd48CNC_13_ToButton>0</kbd48CNC_13_ToButton><kbd48CNC_LEDto_13>0</kbd48CNC_LEDto_13><kbd48CNC_14_ToLED>0</kbd48CNC_14_ToLED><kbd48CNC_14_ToButton>0</kbd48CNC_14_ToButton><kbd48CNC_LEDto_14>0</kbd48CNC_LEDto_14><kbd48CNC_15_ToLED>0</kbd48CNC_15_ToLED><kbd48CNC_15_ToButton>0</kbd48CNC_15_ToButton><kbd48CNC_LEDto_15>0</kbd48CNC_LEDto_15><kbd48CNC_16_ToLED>0</kbd48CNC_16_ToLED><kbd48CNC_16_ToButton>0</kbd48CNC_16_ToButton><kbd48CNC_LEDto_16>0</kbd48CNC_LEDto_16><kbd48CNC_17_ToLED>0</kbd48CNC_17_ToLED><kbd48CNC_17_ToButton>0</kbd48CNC_17_ToButton><kbd48CNC_LEDto_17>0</kbd48CNC_LEDto_17><kbd48CNC_18_ToLED>0</kbd48CNC_18_ToLED><kbd48CNC_18_ToButton>0</kbd48CNC_18_ToButton><kbd48CNC_LEDto_18>0</kbd48CNC_LEDto_18><kbd48CNC_19_ToLED>0</kbd48CNC_19_ToLED><kbd48CNC_19_ToButton>0</kbd48CNC_19_ToButton><kbd48CNC_LEDto_19>0</kbd48CNC_LEDto_19><kbd48CNC_20_ToLED>0</kbd48CNC_20_ToLED><kbd48CNC_20_ToButton>0</kbd48CNC_20_ToButton><kbd48CNC_LEDto_20>0</kbd48CNC_LEDto_20><kbd48CNC_21_ToLED>0</kbd48CNC_21_ToLED><kbd48CNC_21_ToButton>0</kbd48CNC_21_ToButton><kbd48CNC_LEDto_21>0</kbd48CNC_LEDto_21><kbd48CNC_22_ToLED>0</kbd48CNC_22_ToLED><kbd48CNC_22_ToButton>0</kbd48CNC_22_ToButton><kbd48CNC_LEDto_22>0</kbd48CNC_LEDto_22><kbd48CNC_23_ToLED>0</kbd48CNC_23_ToLED><kbd48CNC_23_ToButton>0</kbd48CNC_23_ToButton><kbd48CNC_LEDto_23>0</kbd48CNC_LEDto_23><kbd48CNC_24_ToLED>0</kbd48CNC_24_ToLED><kbd48CNC_24_ToButton>0</kbd48CNC_24_ToButton><kbd48CNC_LEDto_24>0</kbd48CNC_LEDto_24><kbd48CNC_25_ToLED>0</kbd48CNC_25_ToLED><kbd48CNC_25_ToButton>0</kbd48CNC_25_ToButton><kbd48CNC_LEDto_25>0</kbd48CNC_LEDto_25><kbd48CNC_26_ToLED>0</kbd48CNC_26_ToLED><kbd48CNC_26_ToButton>0</kbd48CNC_26_ToButton><kbd48CNC_LEDto_26>0</kbd48CNC_LEDto_26><kbd48CNC_27_ToLED>0</kbd48CNC_27_ToLED><kbd48CNC_27_ToButton>0</kbd48CNC_27_ToButton><kbd48CNC_LEDto_27>0</kbd48CNC_LEDto_27><kbd48CNC_28_ToLED>0</kbd48CNC_28_ToLED><kbd48CNC_28_ToButton>0</kbd48CNC_28_ToButton><kbd48CNC_LEDto_28>0</kbd48CNC_LEDto_28><kbd48CNC_29_ToLED>0</kbd48CNC_29_ToLED><kbd48CNC_29_ToButton>0</kbd48CNC_29_ToButton><kbd48CNC_LEDto_29>0</kbd48CNC_LEDto_29><kbd48CNC_30_ToLED>0</kbd48CNC_30_ToLED><kbd48CNC_30_ToButton>0</kbd48CNC_30_ToButton><kbd48CNC_LEDto_30>0</kbd48CNC_LEDto_30><kbd48CNC_31_ToLED>0</kbd48CNC_31_ToLED><kbd48CNC_31_ToButton>0</kbd48CNC_31_ToButton><kbd48CNC_LEDto_31>0</kbd48CNC_LEDto_31><kbd48CNC_32_ToLED>0</kbd48CNC_32_ToLED><kbd48CNC_32_ToButton>0</kbd48CNC_32_ToButton><kbd48CNC_LEDto_32>0</kbd48CNC_LEDto_32><kbd48CNC_33_ToLED>0</kbd48CNC_33_ToLED><kbd48CNC_33_ToButton>0</kbd48CNC_33_ToButton><kbd48CNC_LEDto_33>0</kbd48CNC_LEDto_33><kbd48CNC_34_ToLED>0</kbd48CNC_34_ToLED><kbd48CNC_34_ToButton>0</kbd48CNC_34_ToButton><kbd48CNC_LEDto_34>0</kbd48CNC_LEDto_34><kbd48CNC_35_ToLED>0</kbd48CNC_35_ToLED><kbd48CNC_35_ToButton>0</kbd48CNC_35_ToButton><kbd48CNC_LEDto_35>0</kbd48CNC_LEDto_35><kbd48CNC_36_ToLED>0</kbd48CNC_36_ToLED><kbd48CNC_36_ToButton>0</kbd48CNC_36_ToButton><kbd48CNC_LEDto_36>0</kbd48CNC_LEDto_36><kbd48CNC_37_ToLED>0</kbd48CNC_37_ToLED><kbd48CNC_37_ToButton>0</kbd48CNC_37_ToButton><kbd48CNC_LEDto_37>0</kbd48CNC_LEDto_37><kbd48CNC_38_ToLED>0</kbd48CNC_38_ToLED><kbd48CNC_38_ToButton>0</kbd48CNC_38_ToButton><kbd48CNC_LEDto_38>0</kbd48CNC_LEDto_38><kbd48CNC_39_ToLED>0</kbd48CNC_39_ToLED><kbd48CNC_39_ToButton>0</kbd48CNC_39_ToButton><kbd48CNC_LEDto_39>0</kbd48CNC_LEDto_39><kbd48CNC_40_ToLED>0</kbd48CNC_40_ToLED><kbd48CNC_40_ToButton>0</kbd48CNC_40_ToButton><kbd48CNC_LEDto_40>0</kbd48CNC_LEDto_40><kbd48CNC_41_ToLED>0</kbd48CNC_41_ToLED><kbd48CNC_41_ToButton>0</kbd48CNC_41_ToButton><kbd48CNC_LEDto_41>0</kbd48CNC_LEDto_41><kbd48CNC_42_ToLED>0</kbd48CNC_42_ToLED><kbd48CNC_42_ToButton>0</kbd48CNC_42_ToButton><kbd48CNC_LEDto_42>0</kbd48CNC_LEDto_42><kbd48CNC_43_ToLED>0</kbd48CNC_43_ToLED><kbd48CNC_43_ToButton>0</kbd48CNC_43_ToButton><kbd48CNC_LEDto_43>0</kbd48CNC_LEDto_43><kbd48CNC_44_ToLED>0</kbd48CNC_44_ToLED><kbd48CNC_44_ToButton>0</kbd48CNC_44_ToButton><kbd48CNC_LEDto_44>0</kbd48CNC_LEDto_44><kbd48CNC_45_ToLED>0</kbd48CNC_45_ToLED><kbd48CNC_45_ToButton>0</kbd48CNC_45_ToButton><kbd48CNC_LEDto_45>0</kbd48CNC_LEDto_45><kbd48CNC_46_ToLED>0</kbd48CNC_46_ToLED><kbd48CNC_46_ToButton>0</kbd48CNC_46_ToButton><kbd48CNC_LEDto_46>0</kbd48CNC_LEDto_46><kbd48CNC_47_ToLED>0</kbd48CNC_47_ToLED><kbd48CNC_47_ToButton>0</kbd48CNC_47_ToButton><kbd48CNC_LEDto_47>0</kbd48CNC_LEDto_47><PELED1>0</PELED1><PEIO1>0</PEIO1><PELED2>0</PELED2><PEIO2>0</PEIO2><PELED3>0</PELED3><PEIO3>0</PEIO3><PELED4>0</PELED4><PEIO4>0</PEIO4><PELED5>0</PELED5><PEIO5>0</PEIO5><PELED6>0</PELED6><PEIO6>0</PEIO6><PELED7>0</PELED7><PEIO7>0</PEIO7><PELED8>0</PELED8><PEIO8>0</PEIO8><PELED9>0</PELED9><PEIO9>0</PEIO9><PELED10>0</PELED10><PEIO10>0</PEIO10><PEChargePump>0</PEChargePump><PEChargePumpInReset>0</PEChargePumpInReset><PEtype>0</PEtype><PEInvertEmergency>0</PEInvertEmergency><ProbingPin>0</ProbingPin><ProbingPinInvert>0</ProbingPinInvert><PulseGenType>0</PulseGenType><PEDontDeref>0</PEDontDeref><PEDisableAutomaticSelection>0</PEDisableAutomaticSelection><SwitchInputFilterConstant>0</SwitchInputFilterConstant><PEExtIn1Map2LED>0</PEExtIn1Map2LED><PEExtIn1Map2IO>0</PEExtIn1Map2IO><PEExtIn2Map2LED>0</PEExtIn2Map2LED><PEExtIn2Map2IO>0</PEExtIn2Map2IO><PEExtIn3Map2LED>0</PEExtIn3Map2LED><PEExtIn3Map2IO>0</PEExtIn3Map2IO><PEExtIn4Map2LED>0</PEExtIn4Map2LED><PEExtIn4Map2IO>0</PEExtIn4Map2IO><PEExtIn5Map2LED>0</PEExtIn5Map2LED><PEExtIn5Map2IO>0</PEExtIn5Map2IO><PEExtIn6Map2LED>0</PEExtIn6Map2LED><PEExtIn6Map2IO>0</PEExtIn6Map2IO><PEExtIn7Map2LED>0</PEExtIn7Map2LED><PEExtIn7Map2IO>0</PEExtIn7Map2IO><PEExtIn8Map2LED>0</PEExtIn8Map2LED><PEExtIn8Map2IO>0</PEExtIn8Map2IO><PEExtIn1ErrorMap2LED>0</PEExtIn1ErrorMap2LED><PEExtIn1ErrorMap2IO>0</PEExtIn1ErrorMap2IO><PEExtIn2ErrorMap2LED>0</PEExtIn2ErrorMap2LED><PEExtIn2ErrorMap2IO>0</PEExtIn2ErrorMap2IO><PEExtIn3ErrorMap2LED>0</PEExtIn3ErrorMap2LED><PEExtIn3ErrorMap2IO>0</PEExtIn3ErrorMap2IO><PEExtIn4ErrorMap2LED>0</PEExtIn4ErrorMap2LED><PEExtIn4ErrorMap2IO>0</PEExtIn4ErrorMap2IO><PEExtOut1Map2LED>0</PEExtOut1Map2LED><PEExtOut1Map2IO>0</PEExtOut1Map2IO><PEExtOut2Map2LED>0</PEExtOut2Map2LED><PEExtOut2Map2IO>0</PEExtOut2Map2IO><PEExtOut3Map2LED>0</PEExtOut3Map2LED><PEExtOut3Map2IO>0</PEExtOut3Map2IO><PEExtOut4Map2LED>0</PEExtOut4Map2LED><PEExtOut4Map2IO>0</PEExtOut4Map2IO><PEExtOut5Map2LED>0</PEExtOut5Map2LED><PEExtOut5Map2IO>0</PEExtOut5Map2IO><PEExtOut6Map2LED>0</PEExtOut6Map2LED><PEExtOut6Map2IO>0</PEExtOut6Map2IO><PEExtOut7Map2LED>0</PEExtOut7Map2LED><PEExtOut7Map2IO>0</PEExtOut7Map2IO><PEExtOut8Map2LED>0</PEExtOut8Map2LED><PEExtOut8Map2IO>0</PEExtOut8Map2IO><PEExtOut9Map2LED>0</PEExtOut9Map2LED><PEExtOut9Map2IO>0</PEExtOut9Map2IO><PEExtOut10Map2LED>0</PEExtOut10Map2LED><PEExtOut10Map2IO>0</PEExtOut10Map2IO><PEExtOut11Map2LED>0</PEExtOut11Map2LED><PEExtOut11Map2IO>0</PEExtOut11Map2IO><PEExtOut12Map2LED>0</PEExtOut12Map2LED><PEExtOut12Map2IO>0</PEExtOut12Map2IO><PEExtOut13Map2LED>0</PEExtOut13Map2LED><PEExtOut13Map2IO>0</PEExtOut13Map2IO><PEExtOut14Map2LED>0</PEExtOut14Map2LED><PEExtOut14Map2IO>0</PEExtOut14Map2IO><PEExtOut15Map2LED>0</PEExtOut15Map2LED><PEExtOut15Map2IO>0</PEExtOut15Map2IO><PEExtOut16Map2LED>0</PEExtOut16Map2LED><PEExtOut16Map2IO>0</PEExtOut16Map2IO><MPGDiv1>0</MPGDiv1><MPGDiv2>0</MPGDiv2><MPGDiv3>0</MPGDiv3><MPGDiv4>0</MPGDiv4><MPGDiv5>0</MPGDiv5><MPGDiv6>0</MPGDiv6><MPGDiv7>0</MPGDiv7><MPGDiv8>0</MPGDiv8><LimitPS1>0</LimitPS1><LimitMS1>0</LimitMS1><HomeS1>0</HomeS1><LimitPInvert1>0</LimitPInvert1><LimitMInvert1>0</LimitMInvert1><HomeInvert1>0</HomeInvert1><EnabledInvert1>0</EnabledInvert1><LimitPS2>0</LimitPS2><LimitMS2>0</LimitMS2><HomeS2>0</HomeS2><LimitPInvert2>0</LimitPInvert2><LimitMInvert2>0</LimitMInvert2><HomeInvert2>0</HomeInvert2><EnabledInvert2>0</EnabledInvert2><LimitPS3>0</LimitPS3><LimitMS3>0</LimitMS3><HomeS3>0</HomeS3><LimitPInvert3>0</LimitPInvert3><LimitMInvert3>0</LimitMInvert3><HomeInvert3>0</HomeInvert3><EnabledInvert3>0</EnabledInvert3><LimitPS4>0</LimitPS4><LimitMS4>0</LimitMS4><HomeS4>0</HomeS4><LimitPInvert4>0</LimitPInvert4><LimitMInvert4>0</LimitMInvert4><HomeInvert4>0</HomeInvert4><EnabledInvert4>0</EnabledInvert4><LimitPS5>0</LimitPS5><LimitMS5>0</LimitMS5><HomeS5>0</HomeS5><LimitPInvert5>0</LimitPInvert5><LimitMInvert5>0</LimitMInvert5><HomeInvert5>0</HomeInvert5><EnabledInvert5>0</EnabledInvert5><LimitPS6>0</LimitPS6><LimitMS6>0</LimitMS6><HomeS6>0</HomeS6><LimitPInvert6>0</LimitPInvert6><LimitMInvert6>0</LimitMInvert6><HomeInvert6>0</HomeInvert6><EnabledInvert6>0</EnabledInvert6><LimitPS7>0</LimitPS7><LimitMS7>0</LimitMS7><HomeS7>0</HomeS7><LimitPInvert7>0</LimitPInvert7><LimitMInvert7>0</LimitMInvert7><HomeInvert7>0</HomeInvert7><EnabledInvert7>0</EnabledInvert7><LimitPS8>0</LimitPS8><LimitMS8>0</LimitMS8><HomeS8>0</HomeS8><LimitPInvert8>0</LimitPInvert8><LimitMInvert8>0</LimitMInvert8><HomeInvert8>0</HomeInvert8><EnabledInvert8>0</EnabledInvert8><THCmode>0</THCmode><THCInvertDirection>0</THCInvertDirection><THCEnableAntiDive>0</THCEnableAntiDive><THCAntiDiveLimit>0</THCAntiDiveLimit><THCDeadband>0</THCDeadband><THCTorchVoltageInput>0</THCTorchVoltageInput><THCReferenceHeightInput>0</THCReferenceHeightInput><THCReferenceVoltage>0</THCReferenceVoltage><THCGain>1</THCGain><THCArcOKRange>0</THCArcOKRange><StopBeforeHoming>0</StopBeforeHoming><UseLCD>0</UseLCD><LCDRows>0</LCDRows><LCDColumns>0</LCDColumns><PWMPeriod>0</PWMPeriod><PWMDisableInactive>0</PWMDisableInactive><PWMenable1>0</PWMenable1><PWMduty1>0</PWMduty1><PWMMapDRO1>0</PWMMapDRO1><PWMDROMultiplier1>0.000000</PWMDROMultiplier1><PWMenable2>0</PWMenable2><PWMduty2>0</PWMduty2><PWMMapDRO2>0</PWMMapDRO2><PWMDROMultiplier2>0.000000</PWMDROMultiplier2><PWMenable3>0</PWMenable3><PWMduty3>0</PWMduty3><PWMMapDRO3>0</PWMMapDRO3><PWMDROMultiplier3>0.000000</PWMDROMultiplier3><PWMenable4>0</PWMenable4><PWMduty4>0</PWMduty4><PWMMapDRO4>0</PWMMapDRO4><PWMDROMultiplier4>0.000000</PWMDROMultiplier4><PWMenable5>0</PWMenable5><PWMduty5>0</PWMduty5><PWMMapDRO5>0</PWMMapDRO5><PWMDROMultiplier5>0.000000</PWMDROMultiplier5><PWMenable6>0</PWMenable6><PWMduty6>0</PWMduty6><PWMMapDRO6>0</PWMMapDRO6><PWMDROMultiplier6>0.000000</PWMDROMultiplier6><AnalogInput1>0</AnalogInput1><AnalogDROMapping1>0</AnalogDROMapping1><AnalogJoystickMapping1>0</AnalogJoystickMapping1><AnalogOffset1>0</AnalogOffset1><AnalogGain1_f>0</AnalogGain1_f><AnalogInput2>0</AnalogInput2><AnalogDROMapping2>0</AnalogDROMapping2><AnalogJoystickMapping2>0</AnalogJoystickMapping2><AnalogOffset2>0</AnalogOffset2><AnalogGain2_f>0</AnalogGain2_f><AnalogInput3>0</AnalogInput3><AnalogDROMapping3>0</AnalogDROMapping3><AnalogJoystickMapping3>0</AnalogJoystickMapping3><AnalogOffset3>0</AnalogOffset3><AnalogGain3_f>0</AnalogGain3_f><AnalogInput4>0</AnalogInput4><AnalogDROMapping4>0</AnalogDROMapping4><AnalogJoystickMapping4>0</AnalogJoystickMapping4><AnalogOffset4>0</AnalogOffset4><AnalogGain4_f>0</AnalogGain4_f><AnalogInput5>0</AnalogInput5><AnalogDROMapping5>0</AnalogDROMapping5><AnalogJoystickMapping5>0</AnalogJoystickMapping5><AnalogOffset5>0</AnalogOffset5><AnalogGain5_f>0</AnalogGain5_f><AnalogInput6>0</AnalogInput6><AnalogDROMapping6>0</AnalogDROMapping6><AnalogJoystickMapping6>0</AnalogJoystickMapping6><AnalogOffset6>0</AnalogOffset6><AnalogGain6_f>0</AnalogGain6_f><AnalogInput7>0</AnalogInput7><AnalogDROMapping7>0</AnalogDROMapping7><AnalogJoystickMapping7>0</AnalogJoystickMapping7><AnalogOffset7>0</AnalogOffset7><AnalogGain7_f>0</AnalogGain7_f><AnalogDeadband>0</AnalogDeadband><AnalogJoystick>0</AnalogJoystick><JoystickEnableOEMLED>0</JoystickEnableOEMLED><MatrixLED1Enabled>0</MatrixLED1Enabled><MatrixLED2Enabled>0</MatrixLED2Enabled><MatrixLED1Width>0</MatrixLED1Width><MatrixLED1Height>0</MatrixLED1Height><MatrixLED2Width>0</MatrixLED2Width><MatrixLED2Height>0</MatrixLED2Height><MatrixLED1LED1>0</MatrixLED1LED1><MatrixLED1IO1>0</MatrixLED1IO1><MatrixLED2LED1>0</MatrixLED2LED1><MatrixLED2IO1>0</MatrixLED2IO1><MatrixLED1LED2>0</MatrixLED1LED2><MatrixLED1IO2>0</MatrixLED1IO2><MatrixLED2LED2>0</MatrixLED2LED2><MatrixLED2IO2>0</MatrixLED2IO2><MatrixLED1LED3>0</MatrixLED1LED3><MatrixLED1IO3>0</MatrixLED1IO3><MatrixLED2LED3>0</MatrixLED2LED3><MatrixLED2IO3>0</MatrixLED2IO3><MatrixLED1LED4>0</MatrixLED1LED4><MatrixLED1IO4>0</MatrixLED1IO4><MatrixLED2LED4>0</MatrixLED2LED4><MatrixLED2IO4>0</MatrixLED2IO4><MatrixLED1LED5>0</MatrixLED1LED5><MatrixLED1IO5>0</MatrixLED1IO5><MatrixLED2LED5>0</MatrixLED2LED5><MatrixLED2IO5>0</MatrixLED2IO5><MatrixLED1LED6>0</MatrixLED1LED6><MatrixLED1IO6>0</MatrixLED1IO6><MatrixLED2LED6>0</MatrixLED2LED6><MatrixLED2IO6>0</MatrixLED2IO6><MatrixLED1LED7>0</MatrixLED1LED7><MatrixLED1IO7>0</MatrixLED1IO7><MatrixLED2LED7>0</MatrixLED2LED7><MatrixLED2IO7>0</MatrixLED2IO7><MatrixLED1LED8>0</MatrixLED1LED8><MatrixLED1IO8>0</MatrixLED1IO8><MatrixLED2LED8>0</MatrixLED2LED8><MatrixLED2IO8>0</MatrixLED2IO8><MatrixLED1LED9>0</MatrixLED1LED9><MatrixLED1IO9>0</MatrixLED1IO9><MatrixLED2LED9>0</MatrixLED2LED9><MatrixLED2IO9>0</MatrixLED2IO9><MatrixLED1LED10>0</MatrixLED1LED10><MatrixLED1IO10>0</MatrixLED1IO10><MatrixLED2LED10>0</MatrixLED2LED10><MatrixLED2IO10>0</MatrixLED2IO10><MatrixLED1LED11>0</MatrixLED1LED11><MatrixLED1IO11>0</MatrixLED1IO11><MatrixLED2LED11>0</MatrixLED2LED11><MatrixLED2IO11>0</MatrixLED2IO11><MatrixLED1LED12>0</MatrixLED1LED12><MatrixLED1IO12>0</MatrixLED1IO12><MatrixLED2LED12>0</MatrixLED2LED12><MatrixLED2IO12>0</MatrixLED2IO12><MatrixLED1LED13>0</MatrixLED1LED13><MatrixLED1IO13>0</MatrixLED1IO13><MatrixLED2LED13>0</MatrixLED2LED13><MatrixLED2IO13>0</MatrixLED2IO13><MatrixLED1LED14>0</MatrixLED1LED14><MatrixLED1IO14>0</MatrixLED1IO14><MatrixLED2LED14>0</MatrixLED2LED14><MatrixLED2IO14>0</MatrixLED2IO14><MatrixLED1LED15>0</MatrixLED1LED15><MatrixLED1IO15>0</MatrixLED1IO15><MatrixLED2LED15>0</MatrixLED2LED15><MatrixLED2IO15>0</MatrixLED2IO15><MatrixLED1LED16>0</MatrixLED1LED16><MatrixLED1IO16>0</MatrixLED1IO16><MatrixLED2LED16>0</MatrixLED2LED16><MatrixLED2IO16>0</MatrixLED2IO16><MatrixLED1LED17>0</MatrixLED1LED17><MatrixLED1IO17>0</MatrixLED1IO17><MatrixLED2LED17>0</MatrixLED2LED17><MatrixLED2IO17>0</MatrixLED2IO17><MatrixLED1LED18>0</MatrixLED1LED18><MatrixLED1IO18>0</MatrixLED1IO18><MatrixLED2LED18>0</MatrixLED2LED18><MatrixLED2IO18>0</MatrixLED2IO18><MatrixLED1LED19>0</MatrixLED1LED19><MatrixLED1IO19>0</MatrixLED1IO19><MatrixLED2LED19>0</MatrixLED2LED19><MatrixLED2IO19>0</MatrixLED2IO19><MatrixLED1LED20>0</MatrixLED1LED20><MatrixLED1IO20>0</MatrixLED1IO20><MatrixLED2LED20>0</MatrixLED2LED20><MatrixLED2IO20>0</MatrixLED2IO20><MatrixLED1LED21>0</MatrixLED1LED21><MatrixLED1IO21>0</MatrixLED1IO21><MatrixLED2LED21>0</MatrixLED2LED21><MatrixLED2IO21>0</MatrixLED2IO21><MatrixLED1LED22>0</MatrixLED1LED22><MatrixLED1IO22>0</MatrixLED1IO22><MatrixLED2LED22>0</MatrixLED2LED22><MatrixLED2IO22>0</MatrixLED2IO22><MatrixLED1LED23>0</MatrixLED1LED23><MatrixLED1IO23>0</MatrixLED1IO23><MatrixLED2LED23>0</MatrixLED2LED23><MatrixLED2IO23>0</MatrixLED2IO23><MatrixLED1LED24>0</MatrixLED1LED24><MatrixLED1IO24>0</MatrixLED1IO24><MatrixLED2LED24>0</MatrixLED2LED24><MatrixLED2IO24>0</MatrixLED2IO24><MatrixLED1LED25>0</MatrixLED1LED25><MatrixLED1IO25>0</MatrixLED1IO25><MatrixLED2LED25>0</MatrixLED2LED25><MatrixLED2IO25>0</MatrixLED2IO25><MatrixLED1LED26>0</MatrixLED1LED26><MatrixLED1IO26>0</MatrixLED1IO26><MatrixLED2LED26>0</MatrixLED2LED26><MatrixLED2IO26>0</MatrixLED2IO26><MatrixLED1LED27>0</MatrixLED1LED27><MatrixLED1IO27>0</MatrixLED1IO27><MatrixLED2LED27>0</MatrixLED2LED27><MatrixLED2IO27>0</MatrixLED2IO27><MatrixLED1LED28>0</MatrixLED1LED28><MatrixLED1IO28>0</MatrixLED1IO28><MatrixLED2LED28>0</MatrixLED2LED28><MatrixLED2IO28>0</MatrixLED2IO28><MatrixLED1LED29>0</MatrixLED1LED29><MatrixLED1IO29>0</MatrixLED1IO29><MatrixLED2LED29>0</MatrixLED2LED29><MatrixLED2IO29>0</MatrixLED2IO29><MatrixLED1LED30>0</MatrixLED1LED30><MatrixLED1IO30>0</MatrixLED1IO30><MatrixLED2LED30>0</MatrixLED2LED30><MatrixLED2IO30>0</MatrixLED2IO30><MatrixLED1LED31>0</MatrixLED1LED31><MatrixLED1IO31>0</MatrixLED1IO31><MatrixLED2LED31>0</MatrixLED2LED31><MatrixLED2IO31>0</MatrixLED2IO31><MatrixLED1LED32>0</MatrixLED1LED32><MatrixLED1IO32>0</MatrixLED1IO32><MatrixLED2LED32>0</MatrixLED2LED32><MatrixLED2IO32>0</MatrixLED2IO32><MatrixLED1LED33>0</MatrixLED1LED33><MatrixLED1IO33>0</MatrixLED1IO33><MatrixLED2LED33>0</MatrixLED2LED33><MatrixLED2IO33>0</MatrixLED2IO33><MatrixLED1LED34>0</MatrixLED1LED34><MatrixLED1IO34>0</MatrixLED1IO34><MatrixLED2LED34>0</MatrixLED2LED34><MatrixLED2IO34>0</MatrixLED2IO34><MatrixLED1LED35>0</MatrixLED1LED35><MatrixLED1IO35>0</MatrixLED1IO35><MatrixLED2LED35>0</MatrixLED2LED35><MatrixLED2IO35>0</MatrixLED2IO35><MatrixLED1LED36>0</MatrixLED1LED36><MatrixLED1IO36>0</MatrixLED1IO36><MatrixLED2LED36>0</MatrixLED2LED36><MatrixLED2IO36>0</MatrixLED2IO36><MatrixLED1LED37>0</MatrixLED1LED37><MatrixLED1IO37>0</MatrixLED1IO37><MatrixLED2LED37>0</MatrixLED2LED37><MatrixLED2IO37>0</MatrixLED2IO37><MatrixLED1LED38>0</MatrixLED1LED38><MatrixLED1IO38>0</MatrixLED1IO38><MatrixLED2LED38>0</MatrixLED2LED38><MatrixLED2IO38>0</MatrixLED2IO38><MatrixLED1LED39>0</MatrixLED1LED39><MatrixLED1IO39>0</MatrixLED1IO39><MatrixLED2LED39>0</MatrixLED2LED39><MatrixLED2IO39>0</MatrixLED2IO39><MatrixLED1LED40>0</MatrixLED1LED40><MatrixLED1IO40>0</MatrixLED1IO40><MatrixLED2LED40>0</MatrixLED2LED40><MatrixLED2IO40>0</MatrixLED2IO40><MatrixLED1LED41>0</MatrixLED1LED41><MatrixLED1IO41>0</MatrixLED1IO41><MatrixLED2LED41>0</MatrixLED2LED41><MatrixLED2IO41>0</MatrixLED2IO41><MatrixLED1LED42>0</MatrixLED1LED42><MatrixLED1IO42>0</MatrixLED1IO42><MatrixLED2LED42>0</MatrixLED2LED42><MatrixLED2IO42>0</MatrixLED2IO42><MatrixLED1LED43>0</MatrixLED1LED43><MatrixLED1IO43>0</MatrixLED1IO43><MatrixLED2LED43>0</MatrixLED2LED43><MatrixLED2IO43>0</MatrixLED2IO43><MatrixLED1LED44>0</MatrixLED1LED44><MatrixLED1IO44>0</MatrixLED1IO44><MatrixLED2LED44>0</MatrixLED2LED44><MatrixLED2IO44>0</MatrixLED2IO44><MatrixLED1LED45>0</MatrixLED1LED45><MatrixLED1IO45>0</MatrixLED1IO45><MatrixLED2LED45>0</MatrixLED2LED45><MatrixLED2IO45>0</MatrixLED2IO45><MatrixLED1LED46>0</MatrixLED1LED46><MatrixLED1IO46>0</MatrixLED1IO46><MatrixLED2LED46>0</MatrixLED2LED46><MatrixLED2IO46>0</MatrixLED2IO46><MatrixLED1LED47>0</MatrixLED1LED47><MatrixLED1IO47>0</MatrixLED1IO47><MatrixLED2LED47>0</MatrixLED2LED47><MatrixLED2IO47>0</MatrixLED2IO47><MatrixLED1LED48>0</MatrixLED1LED48><MatrixLED1IO48>0</MatrixLED1IO48><MatrixLED2LED48>0</MatrixLED2LED48><MatrixLED2IO48>0</MatrixLED2IO48><MatrixLED1LED49>0</MatrixLED1LED49><MatrixLED1IO49>0</MatrixLED1IO49><MatrixLED2LED49>0</MatrixLED2LED49><MatrixLED2IO49>0</MatrixLED2IO49><MatrixLED1LED50>0</MatrixLED1LED50><MatrixLED1IO50>0</MatrixLED1IO50><MatrixLED2LED50>0</MatrixLED2LED50><MatrixLED2IO50>0</MatrixLED2IO50><MatrixLED1LED51>0</MatrixLED1LED51><MatrixLED1IO51>0</MatrixLED1IO51><MatrixLED2LED51>0</MatrixLED2LED51><MatrixLED2IO51>0</MatrixLED2IO51><MatrixLED1LED52>0</MatrixLED1LED52><MatrixLED1IO52>0</MatrixLED1IO52><MatrixLED2LED52>0</MatrixLED2LED52><MatrixLED2IO52>0</MatrixLED2IO52><MatrixLED1LED53>0</MatrixLED1LED53><MatrixLED1IO53>0</MatrixLED1IO53><MatrixLED2LED53>0</MatrixLED2LED53><MatrixLED2IO53>0</MatrixLED2IO53><MatrixLED1LED54>0</MatrixLED1LED54><MatrixLED1IO54>0</MatrixLED1IO54><MatrixLED2LED54>0</MatrixLED2LED54><MatrixLED2IO54>0</MatrixLED2IO54><MatrixLED1LED55>0</MatrixLED1LED55><MatrixLED1IO55>0</MatrixLED1IO55><MatrixLED2LED55>0</MatrixLED2LED55><MatrixLED2IO55>0</MatrixLED2IO55><MatrixLED1LED56>0</MatrixLED1LED56><MatrixLED1IO56>0</MatrixLED1IO56><MatrixLED2LED56>0</MatrixLED2LED56><MatrixLED2IO56>0</MatrixLED2IO56><MatrixLED1LED57>0</MatrixLED1LED57><MatrixLED1IO57>0</MatrixLED1IO57><MatrixLED2LED57>0</MatrixLED2LED57><MatrixLED2IO57>0</MatrixLED2IO57><MatrixLED1LED58>0</MatrixLED1LED58><MatrixLED1IO58>0</MatrixLED1IO58><MatrixLED2LED58>0</MatrixLED2LED58><MatrixLED2IO58>0</MatrixLED2IO58><MatrixLED1LED59>0</MatrixLED1LED59><MatrixLED1IO59>0</MatrixLED1IO59><MatrixLED2LED59>0</MatrixLED2LED59><MatrixLED2IO59>0</MatrixLED2IO59><MatrixLED1LED60>0</MatrixLED1LED60><MatrixLED1IO60>0</MatrixLED1IO60><MatrixLED2LED60>0</MatrixLED2LED60><MatrixLED2IO60>0</MatrixLED2IO60><MatrixLED1LED61>0</MatrixLED1LED61><MatrixLED1IO61>0</MatrixLED1IO61><MatrixLED2LED61>0</MatrixLED2LED61><MatrixLED2IO61>0</MatrixLED2IO61><MatrixLED1LED62>0</MatrixLED1LED62><MatrixLED1IO62>0</MatrixLED1IO62><MatrixLED2LED62>0</MatrixLED2LED62><MatrixLED2IO62>0</MatrixLED2IO62><MatrixLED1LED63>0</MatrixLED1LED63><MatrixLED1IO63>0</MatrixLED1IO63><MatrixLED2LED63>0</MatrixLED2LED63><MatrixLED2IO63>0</MatrixLED2IO63><MatrixLED1LED64>0</MatrixLED1LED64><MatrixLED1IO64>0</MatrixLED1IO64><MatrixLED2LED64>0</MatrixLED2LED64><MatrixLED2IO64>0</MatrixLED2IO64></Device2><Device3><SerialNumber>0</SerialNumber><IP>192.168.0.57</IP><UDP>0</UDP><StatusWindow>0</StatusWindow><AssertReset>0</AssertReset><DisableUnavailableDisplay>0</DisableUnavailableDisplay><PoILDROStart>0</PoILDROStart><PoILDROEnable>0</PoILDROEnable><PoILDROEnableWrite>0</PoILDROEnableWrite><OverrideRapidJog>0</OverrideRapidJog><JogLowSpeed>0</JogLowSpeed><JogHighSpeed>0</JogHighSpeed><COMRate>0</COMRate><SpindleSpeed>0</SpindleSpeed><SpindleSensor>0</SpindleSensor><SpindleTicks>0</SpindleTicks><UnsafeJogging>0</UnsafeJogging><Pin1Function>0</Pin1Function><Pin1Map2LED>0</Pin1Map2LED><Pin1Map2Button>0</Pin1Map2Button><Pin1Map2IO>0</Pin1Map2IO><Pin2Function>0</Pin2Function><Pin2Map2LED>0</Pin2Map2LED><Pin2Map2Button>0</Pin2Map2Button><Pin2Map2IO>0</Pin2Map2IO><Pin3Function>0</Pin3Function><Pin3Map2LED>0</Pin3Map2LED><Pin3Map2Button>0</Pin3Map2Button><Pin3Map2IO>0</Pin3Map2IO><Pin4Function>0</Pin4Function><Pin4Map2LED>0</Pin4Map2LED><Pin4Map2Button>0</Pin4Map2Button><Pin4Map2IO>0</Pin4Map2IO><Pin5Function>0</Pin5Function><Pin5Map2LED>0</Pin5Map2LED><Pin5Map2Button>0</Pin5Map2Button><Pin5Map2IO>0</Pin5Map2IO><Pin6Function>0</Pin6Function><Pin6Map2LED>0</Pin6Map2LED><Pin6Map2Button>0</Pin6Map2Button><Pin6Map2IO>0</Pin6Map2IO><Pin7Function>0</Pin7Function><Pin7Map2LED>0</Pin7Map2LED><Pin7Map2Button>0</Pin7Map2Button><Pin7Map2IO>0</Pin7Map2IO><Pin8Function>0</Pin8Function><Pin8Map2LED>0</Pin8Map2LED><Pin8Map2Button>0</Pin8Map2Button><Pin8Map2IO>0</Pin8Map2IO><Pin9Function>0</Pin9Function><Pin9Map2LED>0</Pin9Map2LED><Pin9Map2Button>0</Pin9Map2Button><Pin9Map2IO>0</Pin9Map2IO><Pin10Function>0</Pin10Function><Pin10Map2LED>0</Pin10Map2LED><Pin10Map2Button>0</Pin10Map2Button><Pin10Map2IO>0</Pin10Map2IO><Pin11Function>0</Pin11Function><Pin11Map2LED>0</Pin11Map2LED><Pin11Map2Button>0</Pin11Map2Button><Pin11Map2IO>0</Pin11Map2IO><Pin12Function>0</Pin12Function><Pin12Map2LED>0</Pin12Map2LED><Pin12Map2Button>0</Pin12Map2Button><Pin12Map2IO>0</Pin12Map2IO><Pin13Function>0</Pin13Function><Pin13Map2LED>0</Pin13Map2LED><Pin13Map2Button>0</Pin13Map2Button><Pin13Map2IO>0</Pin13Map2IO><Pin14Function>0</Pin14Function><Pin14Map2LED>0</Pin14Map2LED><Pin14Map2Button>0</Pin14Map2Button><Pin14Map2IO>0</Pin14Map2IO><Pin15Function>0</Pin15Function><Pin15Map2LED>0</Pin15Map2LED><Pin15Map2Button>0</Pin15Map2Button><Pin15Map2IO>0</Pin15Map2IO><Pin16Function>0</Pin16Function><Pin16Map2LED>0</Pin16Map2LED><Pin16Map2Button>0</Pin16Map2Button><Pin16Map2IO>0</Pin16Map2IO><Pin17Function>0</Pin17Function><Pin17Map2LED>0</Pin17Map2LED><Pin17Map2Button>0</Pin17Map2Button><Pin17Map2IO>0</Pin17Map2IO><Pin18Function>0</Pin18Function><Pin18Map2LED>0</Pin18Map2LED><Pin18Map2Button>0</Pin18Map2Button><Pin18Map2IO>0</Pin18Map2IO><Pin19Function>0</Pin19Function><Pin19Map2LED>0</Pin19Map2LED><Pin19Map2Button>0</Pin19Map2Button><Pin19Map2IO>0</Pin19Map2IO><Pin20Function>0</Pin20Function><Pin20Map2LED>0</Pin20Map2LED><Pin20Map2Button>0</Pin20Map2Button><Pin20Map2IO>0</Pin20Map2IO><Pin21Function>0</Pin21Function><Pin21Map2LED>0</Pin21Map2LED><Pin21Map2Button>0</Pin21Map2Button><Pin21Map2IO>0</Pin21Map2IO><Pin22Function>0</Pin22Function><Pin22Map2LED>0</Pin22Map2LED><Pin22Map2Button>0</Pin22Map2Button><Pin22Map2IO>0</Pin22Map2IO><Pin23Function>0</Pin23Function><Pin23Map2LED>0</Pin23Map2LED><Pin23Map2Button>0</Pin23Map2Button><Pin23Map2IO>0</Pin23Map2IO><Pin24Function>0</Pin24Function><Pin24Map2LED>0</Pin24Map2LED><Pin24Map2Button>0</Pin24Map2Button><Pin24Map2IO>0</Pin24Map2IO><Pin25Function>0</Pin25Function><Pin25Map2LED>0</Pin25Map2LED><Pin25Map2Button>0</Pin25Map2Button><Pin25Map2IO>0</Pin25Map2IO><Pin26Function>0</Pin26Function><Pin26Map2LED>0</Pin26Map2LED><Pin26Map2Button>0</Pin26Map2Button><Pin26Map2IO>0</Pin26Map2IO><Pin27Function>0</Pin27Function><Pin27Map2LED>0</Pin27Map2LED><Pin27Map2Button>0</Pin27Map2Button><Pin27Map2IO>0</Pin27Map2IO><Pin28Function>0</Pin28Function><Pin28Map2LED>0</Pin28Map2LED><Pin28Map2Button>0</Pin28Map2Button><Pin28Map2IO>0</Pin28Map2IO><Pin29Function>0</Pin29Function><Pin29Map2LED>0</Pin29Map2LED><Pin29Map2Button>0</Pin29Map2Button><Pin29Map2IO>0</Pin29Map2IO><Pin30Function>0</Pin30Function><Pin30Map2LED>0</Pin30Map2LED><Pin30Map2Button>0</Pin30Map2Button><Pin30Map2IO>0</Pin30Map2IO><Pin31Function>0</Pin31Function><Pin31Map2LED>0</Pin31Map2LED><Pin31Map2Button>0</Pin31Map2Button><Pin31Map2IO>0</Pin31Map2IO><Pin32Function>0</Pin32Function><Pin32Map2LED>0</Pin32Map2LED><Pin32Map2Button>0</Pin32Map2Button><Pin32Map2IO>0</Pin32Map2IO><Pin33Function>0</Pin33Function><Pin33Map2LED>0</Pin33Map2LED><Pin33Map2Button>0</Pin33Map2Button><Pin33Map2IO>0</Pin33Map2IO><Pin34Function>0</Pin34Function><Pin34Map2LED>0</Pin34Map2LED><Pin34Map2Button>0</Pin34Map2Button><Pin34Map2IO>0</Pin34Map2IO><Pin35Function>0</Pin35Function><Pin35Map2LED>0</Pin35Map2LED><Pin35Map2Button>0</Pin35Map2Button><Pin35Map2IO>0</Pin35Map2IO><Pin36Function>0</Pin36Function><Pin36Map2LED>0</Pin36Map2LED><Pin36Map2Button>0</Pin36Map2Button><Pin36Map2IO>0</Pin36Map2IO><Pin37Function>0</Pin37Function><Pin37Map2LED>0</Pin37Map2LED><Pin37Map2Button>0</Pin37Map2Button><Pin37Map2IO>0</Pin37Map2IO><Pin38Function>0</Pin38Function><Pin38Map2LED>0</Pin38Map2LED><Pin38Map2Button>0</Pin38Map2Button><Pin38Map2IO>0</Pin38Map2IO><Pin39Function>0</Pin39Function><Pin39Map2LED>0</Pin39Map2LED><Pin39Map2Button>0</Pin39Map2Button><Pin39Map2IO>0</Pin39Map2IO><Pin40Function>0</Pin40Function><Pin40Map2LED>0</Pin40Map2LED><Pin40Map2Button>0</Pin40Map2Button><Pin40Map2IO>0</Pin40Map2IO><Pin41Function>0</Pin41Function><Pin41Map2LED>0</Pin41Map2LED><Pin41Map2Button>0</Pin41Map2Button><Pin41Map2IO>0</Pin41Map2IO><Pin42Function>0</Pin42Function><Pin42Map2LED>0</Pin42Map2LED><Pin42Map2Button>0</Pin42Map2Button><Pin42Map2IO>0</Pin42Map2IO><Pin43Function>0</Pin43Function><Pin43Map2LED>0</Pin43Map2LED><Pin43Map2Button>0</Pin43Map2Button><Pin43Map2IO>0</Pin43Map2IO><Pin44Function>0</Pin44Function><Pin44Map2LED>0</Pin44Map2LED><Pin44Map2Button>0</Pin44Map2Button><Pin44Map2IO>0</Pin44Map2IO><Pin45Function>0</Pin45Function><Pin45Map2LED>0</Pin45Map2LED><Pin45Map2Button>0</Pin45Map2Button><Pin45Map2IO>0</Pin45Map2IO><Pin46Function>0</Pin46Function><Pin46Map2LED>0</Pin46Map2LED><Pin46Map2Button>0</Pin46Map2Button><Pin46Map2IO>0</Pin46Map2IO><Pin47Function>0</Pin47Function><Pin47Map2LED>0</Pin47Map2LED><Pin47Map2Button>0</Pin47Map2Button><Pin47Map2IO>0</Pin47Map2IO><Pin48Function>0</Pin48Function><Pin48Map2LED>0</Pin48Map2LED><Pin48Map2Button>0</Pin48Map2Button><Pin48Map2IO>0</Pin48Map2IO><Pin49Function>0</Pin49Function><Pin49Map2LED>0</Pin49Map2LED><Pin49Map2Button>0</Pin49Map2Button><Pin49Map2IO>0</Pin49Map2IO><Pin50Function>0</Pin50Function><Pin50Map2LED>0</Pin50Map2LED><Pin50Map2Button>0</Pin50Map2Button><Pin50Map2IO>0</Pin50Map2IO><Pin51Function>0</Pin51Function><Pin51Map2LED>0</Pin51Map2LED><Pin51Map2Button>0</Pin51Map2Button><Pin51Map2IO>0</Pin51Map2IO><Pin52Function>0</Pin52Function><Pin52Map2LED>0</Pin52Map2LED><Pin52Map2Button>0</Pin52Map2Button><Pin52Map2IO>0</Pin52Map2IO><Pin53Function>0</Pin53Function><Pin53Map2LED>0</Pin53Map2LED><Pin53Map2Button>0</Pin53Map2Button><Pin53Map2IO>0</Pin53Map2IO><Pin54Function>0</Pin54Function><Pin54Map2LED>0</Pin54Map2LED><Pin54Map2Button>0</Pin54Map2Button><Pin54Map2IO>0</Pin54Map2IO><Pin55Function>0</Pin55Function><Pin55Map2LED>0</Pin55Map2LED><Pin55Map2Button>0</Pin55Map2Button><Pin55Map2IO>0</Pin55Map2IO><PendantMode>0</PendantMode><Encoder1A>0</Encoder1A><Encoder1B>0</Encoder1B><Encoder1Options>0</Encoder1Options><Encoder2A>0</Encoder2A><Encoder2B>0</Encoder2B><Encoder2Options>0</Encoder2Options><Encoder3A>0</Encoder3A><Encoder3B>0</Encoder3B><Encoder3Options>0</Encoder3Options><Encoder4A>0</Encoder4A><Encoder4B>0</Encoder4B><Encoder4Options>0</Encoder4Options><Encoder5A>0</Encoder5A><Encoder5B>0</Encoder5B><Encoder5Options>0</Encoder5Options><Encoder6A>0</Encoder6A><Encoder6B>0</Encoder6B><Encoder6Options>0</Encoder6Options><Encoder7A>0</Encoder7A><Encoder7B>0</Encoder7B><Encoder7Options>0</Encoder7Options><Encoder8A>0</Encoder8A><Encoder8B>0</Encoder8B><Encoder8Options>0</Encoder8Options><Encoder9A>0</Encoder9A><Encoder9B>0</Encoder9B><Encoder9Options>0</Encoder9Options><Encoder10A>0</Encoder10A><Encoder10B>0</Encoder10B><Encoder10Options>0</Encoder10Options><Encoder11A>0</Encoder11A><Encoder11B>0</Encoder11B><Encoder11Options>0</Encoder11Options><Encoder12A>0</Encoder12A><Encoder12B>0</Encoder12B><Encoder12Options>0</Encoder12Options><Encoder13A>0</Encoder13A><Encoder13B>0</Encoder13B><Encoder13Options>0</Encoder13Options><Encoder14A>0</Encoder14A><Encoder14B>0</Encoder14B><Encoder14Options>0</Encoder14Options><Encoder15A>0</Encoder15A><Encoder15B>0</Encoder15B><Encoder15Options>0</Encoder15Options><Encoder16A>0</Encoder16A><Encoder16B>0</Encoder16B><Encoder16Options>0</Encoder16Options><Encoder17A>0</Encoder17A><Encoder17B>0</Encoder17B><Encoder17Options>0</Encoder17Options><Encoder18A>0</Encoder18A><Encoder18B>0</Encoder18B><Encoder18Options>0</Encoder18Options><Encoder19A>0</Encoder19A><Encoder19B>0</Encoder19B><Encoder19Options>0</Encoder19Options><Encoder20A>0</Encoder20A><Encoder20B>0</Encoder20B><Encoder20Options>0</Encoder20Options><Encoder21A>0</Encoder21A><Encoder21B>0</Encoder21B><Encoder21Options>0</Encoder21Options><Encoder22A>0</Encoder22A><Encoder22B>0</Encoder22B><Encoder22Options>0</Encoder22Options><Encoder23A>0</Encoder23A><Encoder23B>0</Encoder23B><Encoder23Options>0</Encoder23Options><Encoder24A>0</Encoder24A><Encoder24B>0</Encoder24B><Encoder24Options>0</Encoder24Options><Encoder25A>0</Encoder25A><Encoder25B>0</Encoder25B><Encoder25Options>0</Encoder25Options><Encoder12DRO>0</Encoder12DRO><Encoder1Inpendant>0</Encoder1Inpendant><Encoder22DRO>0</Encoder22DRO><Encoder2Inpendant>0</Encoder2Inpendant><Encoder32DRO>0</Encoder32DRO><Encoder3Inpendant>0</Encoder3Inpendant><Encoder42DRO>0</Encoder42DRO><Encoder4Inpendant>0</Encoder4Inpendant><Encoder52DRO>0</Encoder52DRO><Encoder5Inpendant>0</Encoder5Inpendant><Encoder62DRO>0</Encoder62DRO><Encoder6Inpendant>0</Encoder6Inpendant><Encoder72DRO>0</Encoder72DRO><Encoder7Inpendant>0</Encoder7Inpendant><Encoder82DRO>0</Encoder82DRO><Encoder8Inpendant>0</Encoder8Inpendant><Encoder92DRO>0</Encoder92DRO><Encoder9Inpendant>0</Encoder9Inpendant><Encoder102DRO>0</Encoder102DRO><Encoder10Inpendant>0</Encoder10Inpendant><Encoder112DRO>0</Encoder112DRO><Encoder11Inpendant>0</Encoder11Inpendant><Encoder122DRO>0</Encoder122DRO><Encoder12Inpendant>0</Encoder12Inpendant><Encoder132DRO>0</Encoder132DRO><Encoder13Inpendant>0</Encoder13Inpendant><Encoder142DRO>0</Encoder142DRO><Encoder14Inpendant>0</Encoder14Inpendant><Encoder152DRO>0</Encoder152DRO><Encoder15Inpendant>0</Encoder15Inpendant><Encoder162DRO>0</Encoder162DRO><Encoder16Inpendant>0</Encoder16Inpendant><Encoder172DRO>0</Encoder172DRO><Encoder17Inpendant>0</Encoder17Inpendant><Encoder182DRO>0</Encoder182DRO><Encoder18Inpendant>0</Encoder18Inpendant><Encoder192DRO>0</Encoder192DRO><Encoder19Inpendant>0</Encoder19Inpendant><Encoder202DRO>0</Encoder202DRO><Encoder20Inpendant>0</Encoder20Inpendant><Encoder212DRO>0</Encoder212DRO><Encoder21Inpendant>0</Encoder21Inpendant><Encoder222DRO>0</Encoder222DRO><Encoder22Inpendant>0</Encoder22Inpendant><Encoder232DRO>0</Encoder232DRO><Encoder23Inpendant>0</Encoder23Inpendant><Encoder242DRO>0</Encoder242DRO><Encoder24Inpendant>0</Encoder24Inpendant><Encoder252DRO>0</Encoder252DRO><Encoder25Inpendant>0</Encoder25Inpendant><Encoder262DRO>0</Encoder262DRO><Encoder26Inpendant>0</Encoder26Inpendant><FastEncoders>0</FastEncoders><UltraFastEncoders>0</UltraFastEncoders><UltraFastEncodersOptions>0</UltraFastEncodersOptions><MPGjog>0</MPGjog><MPGjog1x>0</MPGjog1x><MatrixKB1Map2LED>0</MatrixKB1Map2LED><MatrixKB1Map2Button>0</MatrixKB1Map2Button><MatrixKB1Map2IO>0</MatrixKB1Map2IO><MatrixKB2Map2LED>0</MatrixKB2Map2LED><MatrixKB2Map2Button>0</MatrixKB2Map2Button><MatrixKB2Map2IO>0</MatrixKB2Map2IO><MatrixKB3Map2LED>0</MatrixKB3Map2LED><MatrixKB3Map2Button>0</MatrixKB3Map2Button><MatrixKB3Map2IO>0</MatrixKB3Map2IO><MatrixKB4Map2LED>0</MatrixKB4Map2LED><MatrixKB4Map2Button>0</MatrixKB4Map2Button><MatrixKB4Map2IO>0</MatrixKB4Map2IO><MatrixKB5Map2LED>0</MatrixKB5Map2LED><MatrixKB5Map2Button>0</MatrixKB5Map2Button><MatrixKB5Map2IO>0</MatrixKB5Map2IO><MatrixKB6Map2LED>0</MatrixKB6Map2LED><MatrixKB6Map2Button>0</MatrixKB6Map2Button><MatrixKB6Map2IO>0</MatrixKB6Map2IO><MatrixKB7Map2LED>0</MatrixKB7Map2LED><MatrixKB7Map2Button>0</MatrixKB7Map2Button><MatrixKB7Map2IO>0</MatrixKB7Map2IO><MatrixKB8Map2LED>0</MatrixKB8Map2LED><MatrixKB8Map2Button>0</MatrixKB8Map2Button><MatrixKB8Map2IO>0</MatrixKB8Map2IO><MatrixKB9Map2LED>0</MatrixKB9Map2LED><MatrixKB9Map2Button>0</MatrixKB9Map2Button><MatrixKB9Map2IO>0</MatrixKB9Map2IO><MatrixKB10Map2LED>0</MatrixKB10Map2LED><MatrixKB10Map2Button>0</MatrixKB10Map2Button><MatrixKB10Map2IO>0</MatrixKB10Map2IO><MatrixKB11Map2LED>0</MatrixKB11Map2LED><MatrixKB11Map2Button>0</MatrixKB11Map2Button><MatrixKB11Map2IO>0</MatrixKB11Map2IO><MatrixKB12Map2LED>0</MatrixKB12Map2LED><MatrixKB12Map2Button>0</MatrixKB12Map2Button><MatrixKB12Map2IO>0</MatrixKB12Map2IO><MatrixKB13Map2LED>0</MatrixKB13Map2LED><MatrixKB13Map2Button>0</MatrixKB13Map2Button><MatrixKB13Map2IO>0</MatrixKB13Map2IO><MatrixKB14Map2LED>0</MatrixKB14Map2LED><MatrixKB14Map2Button>0</MatrixKB14Map2Button><MatrixKB14Map2IO>0</MatrixKB14Map2IO><MatrixKB15Map2LED>0</MatrixKB15Map2LED><MatrixKB15Map2Button>0</MatrixKB15Map2Button><MatrixKB15Map2IO>0</MatrixKB15Map2IO><MatrixKB16Map2LED>0</MatrixKB16Map2LED><MatrixKB16Map2Button>0</MatrixKB16Map2Button><MatrixKB16Map2IO>0</MatrixKB16Map2IO><MatrixKB17Map2LED>0</MatrixKB17Map2LED><MatrixKB17Map2Button>0</MatrixKB17Map2Button><MatrixKB17Map2IO>0</MatrixKB17Map2IO><MatrixKB18Map2LED>0</MatrixKB18Map2LED><MatrixKB18Map2Button>0</MatrixKB18Map2Button><MatrixKB18Map2IO>0</MatrixKB18Map2IO><MatrixKB19Map2LED>0</MatrixKB19Map2LED><MatrixKB19Map2Button>0</MatrixKB19Map2Button><MatrixKB19Map2IO>0</MatrixKB19Map2IO><MatrixKB20Map2LED>0</MatrixKB20Map2LED><MatrixKB20Map2Button>0</MatrixKB20Map2Button><MatrixKB20Map2IO>0</MatrixKB20Map2IO><MatrixKB21Map2LED>0</MatrixKB21Map2LED><MatrixKB21Map2Button>0</MatrixKB21Map2Button><MatrixKB21Map2IO>0</MatrixKB21Map2IO><MatrixKB22Map2LED>0</MatrixKB22Map2LED><MatrixKB22Map2Button>0</MatrixKB22Map2Button><MatrixKB22Map2IO>0</MatrixKB22Map2IO><MatrixKB23Map2LED>0</MatrixKB23Map2LED><MatrixKB23Map2Button>0</MatrixKB23Map2Button><MatrixKB23Map2IO>0</MatrixKB23Map2IO><MatrixKB24Map2LED>0</MatrixKB24Map2LED><MatrixKB24Map2Button>0</MatrixKB24Map2Button><MatrixKB24Map2IO>0</MatrixKB24Map2IO><MatrixKB25Map2LED>0</MatrixKB25Map2LED><MatrixKB25Map2Button>0</MatrixKB25Map2Button><MatrixKB25Map2IO>0</MatrixKB25Map2IO><MatrixKB26Map2LED>0</MatrixKB26Map2LED><MatrixKB26Map2Button>0</MatrixKB26Map2Button><MatrixKB26Map2IO>0</MatrixKB26Map2IO><MatrixKB27Map2LED>0</MatrixKB27Map2LED><MatrixKB27Map2Button>0</MatrixKB27Map2Button><MatrixKB27Map2IO>0</MatrixKB27Map2IO><MatrixKB28Map2LED>0</MatrixKB28Map2LED><MatrixKB28Map2Button>0</MatrixKB28Map2Button><MatrixKB28Map2IO>0</MatrixKB28Map2IO><MatrixKB29Map2LED>0</MatrixKB29Map2LED><MatrixKB29Map2Button>0</MatrixKB29Map2Button><MatrixKB29Map2IO>0</MatrixKB29Map2IO><MatrixKB30Map2LED>0</MatrixKB30Map2LED><MatrixKB30Map2Button>0</MatrixKB30Map2Button><MatrixKB30Map2IO>0</MatrixKB30Map2IO><MatrixKB31Map2LED>0</MatrixKB31Map2LED><MatrixKB31Map2Button>0</MatrixKB31Map2Button><MatrixKB31Map2IO>0</MatrixKB31Map2IO><MatrixKB32Map2LED>0</MatrixKB32Map2LED><MatrixKB32Map2Button>0</MatrixKB32Map2Button><MatrixKB32Map2IO>0</MatrixKB32Map2IO><MatrixKB33Map2LED>0</MatrixKB33Map2LED><MatrixKB33Map2Button>0</MatrixKB33Map2Button><MatrixKB33Map2IO>0</MatrixKB33Map2IO><MatrixKB34Map2LED>0</MatrixKB34Map2LED><MatrixKB34Map2Button>0</MatrixKB34Map2Button><MatrixKB34Map2IO>0</MatrixKB34Map2IO><MatrixKB35Map2LED>0</MatrixKB35Map2LED><MatrixKB35Map2Button>0</MatrixKB35Map2Button><MatrixKB35Map2IO>0</MatrixKB35Map2IO><MatrixKB36Map2LED>0</MatrixKB36Map2LED><MatrixKB36Map2Button>0</MatrixKB36Map2Button><MatrixKB36Map2IO>0</MatrixKB36Map2IO><MatrixKB37Map2LED>0</MatrixKB37Map2LED><MatrixKB37Map2Button>0</MatrixKB37Map2Button><MatrixKB37Map2IO>0</MatrixKB37Map2IO><MatrixKB38Map2LED>0</MatrixKB38Map2LED><MatrixKB38Map2Button>0</MatrixKB38Map2Button><MatrixKB38Map2IO>0</MatrixKB38Map2IO><MatrixKB39Map2LED>0</MatrixKB39Map2LED><MatrixKB39Map2Button>0</MatrixKB39Map2Button><MatrixKB39Map2IO>0</MatrixKB39Map2IO><MatrixKB40Map2LED>0</MatrixKB40Map2LED><MatrixKB40Map2Button>0</MatrixKB40Map2Button><MatrixKB40Map2IO>0</MatrixKB40Map2IO><MatrixKB41Map2LED>0</MatrixKB41Map2LED><MatrixKB41Map2Button>0</MatrixKB41Map2Button><MatrixKB41Map2IO>0</MatrixKB41Map2IO><MatrixKB42Map2LED>0</MatrixKB42Map2LED><MatrixKB42Map2Button>0</MatrixKB42Map2Button><MatrixKB42Map2IO>0</MatrixKB42Map2IO><MatrixKB43Map2LED>0</MatrixKB43Map2LED><MatrixKB43Map2Button>0</MatrixKB43Map2Button><MatrixKB43Map2IO>0</MatrixKB43Map2IO><MatrixKB44Map2LED>0</MatrixKB44Map2LED><MatrixKB44Map2Button>0</MatrixKB44Map2Button><MatrixKB44Map2IO>0</MatrixKB44Map2IO><MatrixKB45Map2LED>0</MatrixKB45Map2LED><MatrixKB45Map2Button>0</MatrixKB45Map2Button><MatrixKB45Map2IO>0</MatrixKB45Map2IO><MatrixKB46Map2LED>0</MatrixKB46Map2LED><MatrixKB46Map2Button>0</MatrixKB46Map2Button><MatrixKB46Map2IO>0</MatrixKB46Map2IO><MatrixKB47Map2LED>0</MatrixKB47Map2LED><MatrixKB47Map2Button>0</MatrixKB47Map2Button><MatrixKB47Map2IO>0</MatrixKB47Map2IO><MatrixKB48Map2LED>0</MatrixKB48Map2LED><MatrixKB48Map2Button>0</MatrixKB48Map2Button><MatrixKB48Map2IO>0</MatrixKB48Map2IO><MatrixKB49Map2LED>0</MatrixKB49Map2LED><MatrixKB49Map2Button>0</MatrixKB49Map2Button><MatrixKB49Map2IO>0</MatrixKB49Map2IO><MatrixKB50Map2LED>0</MatrixKB50Map2LED><MatrixKB50Map2Button>0</MatrixKB50Map2Button><MatrixKB50Map2IO>0</MatrixKB50Map2IO><MatrixKB51Map2LED>0</MatrixKB51Map2LED><MatrixKB51Map2Button>0</MatrixKB51Map2Button><MatrixKB51Map2IO>0</MatrixKB51Map2IO><MatrixKB52Map2LED>0</MatrixKB52Map2LED><MatrixKB52Map2Button>0</MatrixKB52Map2Button><MatrixKB52Map2IO>0</MatrixKB52Map2IO><MatrixKB53Map2LED>0</MatrixKB53Map2LED><MatrixKB53Map2Button>0</MatrixKB53Map2Button><MatrixKB53Map2IO>0</MatrixKB53Map2IO><MatrixKB54Map2LED>0</MatrixKB54Map2LED><MatrixKB54Map2Button>0</MatrixKB54Map2Button><MatrixKB54Map2IO>0</MatrixKB54Map2IO><MatrixKB55Map2LED>0</MatrixKB55Map2LED><MatrixKB55Map2Button>0</MatrixKB55Map2Button><MatrixKB55Map2IO>0</MatrixKB55Map2IO><MatrixKB56Map2LED>0</MatrixKB56Map2LED><MatrixKB56Map2Button>0</MatrixKB56Map2Button><MatrixKB56Map2IO>0</MatrixKB56Map2IO><MatrixKB57Map2LED>0</MatrixKB57Map2LED><MatrixKB57Map2Button>0</MatrixKB57Map2Button><MatrixKB57Map2IO>0</MatrixKB57Map2IO><MatrixKB58Map2LED>0</MatrixKB58Map2LED><MatrixKB58Map2Button>0</MatrixKB58Map2Button><MatrixKB58Map2IO>0</MatrixKB58Map2IO><MatrixKB59Map2LED>0</MatrixKB59Map2LED><MatrixKB59Map2Button>0</MatrixKB59Map2Button><MatrixKB59Map2IO>0</MatrixKB59Map2IO><MatrixKB60Map2LED>0</MatrixKB60Map2LED><MatrixKB60Map2Button>0</MatrixKB60Map2Button><MatrixKB60Map2IO>0</MatrixKB60Map2IO><MatrixKB61Map2LED>0</MatrixKB61Map2LED><MatrixKB61Map2Button>0</MatrixKB61Map2Button><MatrixKB61Map2IO>0</MatrixKB61Map2IO><MatrixKB62Map2LED>0</MatrixKB62Map2LED><MatrixKB62Map2Button>0</MatrixKB62Map2Button><MatrixKB62Map2IO>0</MatrixKB62Map2IO><MatrixKB63Map2LED>0</MatrixKB63Map2LED><MatrixKB63Map2Button>0</MatrixKB63Map2Button><MatrixKB63Map2IO>0</MatrixKB63Map2IO><MatrixKB64Map2LED>0</MatrixKB64Map2LED><MatrixKB64Map2Button>0</MatrixKB64Map2Button><MatrixKB64Map2IO>0</MatrixKB64Map2IO><MatrixKB65Map2LED>0</MatrixKB65Map2LED><MatrixKB65Map2Button>0</MatrixKB65Map2Button><MatrixKB65Map2IO>0</MatrixKB65Map2IO><MatrixKB66Map2LED>0</MatrixKB66Map2LED><MatrixKB66Map2Button>0</MatrixKB66Map2Button><MatrixKB66Map2IO>0</MatrixKB66Map2IO><MatrixKB67Map2LED>0</MatrixKB67Map2LED><MatrixKB67Map2Button>0</MatrixKB67Map2Button><MatrixKB67Map2IO>0</MatrixKB67Map2IO><MatrixKB68Map2LED>0</MatrixKB68Map2LED><MatrixKB68Map2Button>0</MatrixKB68Map2Button><MatrixKB68Map2IO>0</MatrixKB68Map2IO><MatrixKB69Map2LED>0</MatrixKB69Map2LED><MatrixKB69Map2Button>0</MatrixKB69Map2Button><MatrixKB69Map2IO>0</MatrixKB69Map2IO><MatrixKB70Map2LED>0</MatrixKB70Map2LED><MatrixKB70Map2Button>0</MatrixKB70Map2Button><MatrixKB70Map2IO>0</MatrixKB70Map2IO><MatrixKB71Map2LED>0</MatrixKB71Map2LED><MatrixKB71Map2Button>0</MatrixKB71Map2Button><MatrixKB71Map2IO>0</MatrixKB71Map2IO><MatrixKB72Map2LED>0</MatrixKB72Map2LED><MatrixKB72Map2Button>0</MatrixKB72Map2Button><MatrixKB72Map2IO>0</MatrixKB72Map2IO><MatrixKB73Map2LED>0</MatrixKB73Map2LED><MatrixKB73Map2Button>0</MatrixKB73Map2Button><MatrixKB73Map2IO>0</MatrixKB73Map2IO><MatrixKB74Map2LED>0</MatrixKB74Map2LED><MatrixKB74Map2Button>0</MatrixKB74Map2Button><MatrixKB74Map2IO>0</MatrixKB74Map2IO><MatrixKB75Map2LED>0</MatrixKB75Map2LED><MatrixKB75Map2Button>0</MatrixKB75Map2Button><MatrixKB75Map2IO>0</MatrixKB75Map2IO><MatrixKB76Map2LED>0</MatrixKB76Map2LED><MatrixKB76Map2Button>0</MatrixKB76Map2Button><MatrixKB76Map2IO>0</MatrixKB76Map2IO><MatrixKB77Map2LED>0</MatrixKB77Map2LED><MatrixKB77Map2Button>0</MatrixKB77Map2Button><MatrixKB77Map2IO>0</MatrixKB77Map2IO><MatrixKB78Map2LED>0</MatrixKB78Map2LED><MatrixKB78Map2Button>0</MatrixKB78Map2Button><MatrixKB78Map2IO>0</MatrixKB78Map2IO><MatrixKB79Map2LED>0</MatrixKB79Map2LED><MatrixKB79Map2Button>0</MatrixKB79Map2Button><MatrixKB79Map2IO>0</MatrixKB79Map2IO><MatrixKB80Map2LED>0</MatrixKB80Map2LED><MatrixKB80Map2Button>0</MatrixKB80Map2Button><MatrixKB80Map2IO>0</MatrixKB80Map2IO><MatrixKB81Map2LED>0</MatrixKB81Map2LED><MatrixKB81Map2Button>0</MatrixKB81Map2Button><MatrixKB81Map2IO>0</MatrixKB81Map2IO><MatrixKB82Map2LED>0</MatrixKB82Map2LED><MatrixKB82Map2Button>0</MatrixKB82Map2Button><MatrixKB82Map2IO>0</MatrixKB82Map2IO><MatrixKB83Map2LED>0</MatrixKB83Map2LED><MatrixKB83Map2Button>0</MatrixKB83Map2Button><MatrixKB83Map2IO>0</MatrixKB83Map2IO><MatrixKB84Map2LED>0</MatrixKB84Map2LED><MatrixKB84Map2Button>0</MatrixKB84Map2Button><MatrixKB84Map2IO>0</MatrixKB84Map2IO><MatrixKB85Map2LED>0</MatrixKB85Map2LED><MatrixKB85Map2Button>0</MatrixKB85Map2Button><MatrixKB85Map2IO>0</MatrixKB85Map2IO><MatrixKB86Map2LED>0</MatrixKB86Map2LED><MatrixKB86Map2Button>0</MatrixKB86Map2Button><MatrixKB86Map2IO>0</MatrixKB86Map2IO><MatrixKB87Map2LED>0</MatrixKB87Map2LED><MatrixKB87Map2Button>0</MatrixKB87Map2Button><MatrixKB87Map2IO>0</MatrixKB87Map2IO><MatrixKB88Map2LED>0</MatrixKB88Map2LED><MatrixKB88Map2Button>0</MatrixKB88Map2Button><MatrixKB88Map2IO>0</MatrixKB88Map2IO><MatrixKB89Map2LED>0</MatrixKB89Map2LED><MatrixKB89Map2Button>0</MatrixKB89Map2Button><MatrixKB89Map2IO>0</MatrixKB89Map2IO><MatrixKB90Map2LED>0</MatrixKB90Map2LED><MatrixKB90Map2Button>0</MatrixKB90Map2Button><MatrixKB90Map2IO>0</MatrixKB90Map2IO><MatrixKB91Map2LED>0</MatrixKB91Map2LED><MatrixKB91Map2Button>0</MatrixKB91Map2Button><MatrixKB91Map2IO>0</MatrixKB91Map2IO><MatrixKB92Map2LED>0</MatrixKB92Map2LED><MatrixKB92Map2Button>0</MatrixKB92Map2Button><MatrixKB92Map2IO>0</MatrixKB92Map2IO><MatrixKB93Map2LED>0</MatrixKB93Map2LED><MatrixKB93Map2Button>0</MatrixKB93Map2Button><MatrixKB93Map2IO>0</MatrixKB93Map2IO><MatrixKB94Map2LED>0</MatrixKB94Map2LED><MatrixKB94Map2Button>0</MatrixKB94Map2Button><MatrixKB94Map2IO>0</MatrixKB94Map2IO><MatrixKB95Map2LED>0</MatrixKB95Map2LED><MatrixKB95Map2Button>0</MatrixKB95Map2Button><MatrixKB95Map2IO>0</MatrixKB95Map2IO><MatrixKB96Map2LED>0</MatrixKB96Map2LED><MatrixKB96Map2Button>0</MatrixKB96Map2Button><MatrixKB96Map2IO>0</MatrixKB96Map2IO><MatrixKB97Map2LED>0</MatrixKB97Map2LED><MatrixKB97Map2Button>0</MatrixKB97Map2Button><MatrixKB97Map2IO>0</MatrixKB97Map2IO><MatrixKB98Map2LED>0</MatrixKB98Map2LED><MatrixKB98Map2Button>0</MatrixKB98Map2Button><MatrixKB98Map2IO>0</MatrixKB98Map2IO><MatrixKB99Map2LED>0</MatrixKB99Map2LED><MatrixKB99Map2Button>0</MatrixKB99Map2Button><MatrixKB99Map2IO>0</MatrixKB99Map2IO><MatrixKB100Map2LED>0</MatrixKB100Map2LED><MatrixKB100Map2Button>0</MatrixKB100Map2Button><MatrixKB100Map2IO>0</MatrixKB100Map2IO><MatrixKB101Map2LED>0</MatrixKB101Map2LED><MatrixKB101Map2Button>0</MatrixKB101Map2Button><MatrixKB101Map2IO>0</MatrixKB101Map2IO><MatrixKB102Map2LED>0</MatrixKB102Map2LED><MatrixKB102Map2Button>0</MatrixKB102Map2Button><MatrixKB102Map2IO>0</MatrixKB102Map2IO><MatrixKB103Map2LED>0</MatrixKB103Map2LED><MatrixKB103Map2Button>0</MatrixKB103Map2Button><MatrixKB103Map2IO>0</MatrixKB103Map2IO><MatrixKB104Map2LED>0</MatrixKB104Map2LED><MatrixKB104Map2Button>0</MatrixKB104Map2Button><MatrixKB104Map2IO>0</MatrixKB104Map2IO><MatrixKB105Map2LED>0</MatrixKB105Map2LED><MatrixKB105Map2Button>0</MatrixKB105Map2Button><MatrixKB105Map2IO>0</MatrixKB105Map2IO><MatrixKB106Map2LED>0</MatrixKB106Map2LED><MatrixKB106Map2Button>0</MatrixKB106Map2Button><MatrixKB106Map2IO>0</MatrixKB106Map2IO><MatrixKB107Map2LED>0</MatrixKB107Map2LED><MatrixKB107Map2Button>0</MatrixKB107Map2Button><MatrixKB107Map2IO>0</MatrixKB107Map2IO><MatrixKB108Map2LED>0</MatrixKB108Map2LED><MatrixKB108Map2Button>0</MatrixKB108Map2Button><MatrixKB108Map2IO>0</MatrixKB108Map2IO><MatrixKB109Map2LED>0</MatrixKB109Map2LED><MatrixKB109Map2Button>0</MatrixKB109Map2Button><MatrixKB109Map2IO>0</MatrixKB109Map2IO><MatrixKB110Map2LED>0</MatrixKB110Map2LED><MatrixKB110Map2Button>0</MatrixKB110Map2Button><MatrixKB110Map2IO>0</MatrixKB110Map2IO><MatrixKB111Map2LED>0</MatrixKB111Map2LED><MatrixKB111Map2Button>0</MatrixKB111Map2Button><MatrixKB111Map2IO>0</MatrixKB111Map2IO><MatrixKB112Map2LED>0</MatrixKB112Map2LED><MatrixKB112Map2Button>0</MatrixKB112Map2Button><MatrixKB112Map2IO>0</MatrixKB112Map2IO><MatrixKB113Map2LED>0</MatrixKB113Map2LED><MatrixKB113Map2Button>0</MatrixKB113Map2Button><MatrixKB113Map2IO>0</MatrixKB113Map2IO><MatrixKB114Map2LED>0</MatrixKB114Map2LED><MatrixKB114Map2Button>0</MatrixKB114Map2Button><MatrixKB114Map2IO>0</MatrixKB114Map2IO><MatrixKB115Map2LED>0</MatrixKB115Map2LED><MatrixKB115Map2Button>0</MatrixKB115Map2Button><MatrixKB115Map2IO>0</MatrixKB115Map2IO><MatrixKB116Map2LED>0</MatrixKB116Map2LED><MatrixKB116Map2Button>0</MatrixKB116Map2Button><MatrixKB116Map2IO>0</MatrixKB116Map2IO><MatrixKB117Map2LED>0</MatrixKB117Map2LED><MatrixKB117Map2Button>0</MatrixKB117Map2Button><MatrixKB117Map2IO>0</MatrixKB117Map2IO><MatrixKB118Map2LED>0</MatrixKB118Map2LED><MatrixKB118Map2Button>0</MatrixKB118Map2Button><MatrixKB118Map2IO>0</MatrixKB118Map2IO><MatrixKB119Map2LED>0</MatrixKB119Map2LED><MatrixKB119Map2Button>0</MatrixKB119Map2Button><MatrixKB119Map2IO>0</MatrixKB119Map2IO><MatrixKB120Map2LED>0</MatrixKB120Map2LED><MatrixKB120Map2Button>0</MatrixKB120Map2Button><MatrixKB120Map2IO>0</MatrixKB120Map2IO><MatrixKB121Map2LED>0</MatrixKB121Map2LED><MatrixKB121Map2Button>0</MatrixKB121Map2Button><MatrixKB121Map2IO>0</MatrixKB121Map2IO><MatrixKB122Map2LED>0</MatrixKB122Map2LED><MatrixKB122Map2Button>0</MatrixKB122Map2Button><MatrixKB122Map2IO>0</MatrixKB122Map2IO><MatrixKB123Map2LED>0</MatrixKB123Map2LED><MatrixKB123Map2Button>0</MatrixKB123Map2Button><MatrixKB123Map2IO>0</MatrixKB123Map2IO><MatrixKB124Map2LED>0</MatrixKB124Map2LED><MatrixKB124Map2Button>0</MatrixKB124Map2Button><MatrixKB124Map2IO>0</MatrixKB124Map2IO><MatrixKB125Map2LED>0</MatrixKB125Map2LED><MatrixKB125Map2Button>0</MatrixKB125Map2Button><MatrixKB125Map2IO>0</MatrixKB125Map2IO><MatrixKB126Map2LED>0</MatrixKB126Map2LED><MatrixKB126Map2Button>0</MatrixKB126Map2Button><MatrixKB126Map2IO>0</MatrixKB126Map2IO><MatrixKB127Map2LED>0</MatrixKB127Map2LED><MatrixKB127Map2Button>0</MatrixKB127Map2Button><MatrixKB127Map2IO>0</MatrixKB127Map2IO><MatrixKB128Map2LED>0</MatrixKB128Map2LED><MatrixKB128Map2Button>0</MatrixKB128Map2Button><MatrixKB128Map2IO>0</MatrixKB128Map2IO><MatrixWidth>0</MatrixWidth><MatrixHeight>0</MatrixHeight><MatrixEnabled>0</MatrixEnabled><MatrixRow1>0</MatrixRow1><MatrixRow2>0</MatrixRow2><MatrixRow3>0</MatrixRow3><MatrixRow4>0</MatrixRow4><MatrixRow5>0</MatrixRow5><MatrixRow6>0</MatrixRow6><MatrixRow7>0</MatrixRow7><MatrixRow8>0</MatrixRow8><MatrixRow9>0</MatrixRow9><MatrixRow10>0</MatrixRow10><MatrixRow11>0</MatrixRow11><MatrixRow12>0</MatrixRow12><MatrixRow13>0</MatrixRow13><MatrixRow14>0</MatrixRow14><MatrixRow15>0</MatrixRow15><MatrixRow16>0</MatrixRow16><MatrixColumn1>0</MatrixColumn1><MatrixColumn2>0</MatrixColumn2><MatrixColumn3>0</MatrixColumn3><MatrixColumn4>0</MatrixColumn4><MatrixColumn5>0</MatrixColumn5><MatrixColumn6>0</MatrixColumn6><MatrixColumn7>0</MatrixColumn7><MatrixColumn8>0</MatrixColumn8><PoExtBus1Map2LED>0</PoExtBus1Map2LED><PoExtBus1Map2IO>0</PoExtBus1Map2IO><PoExtBus1Invert>0</PoExtBus1Invert><PoExtBus2Map2LED>0</PoExtBus2Map2LED><PoExtBus2Map2IO>0</PoExtBus2Map2IO><PoExtBus2Invert>0</PoExtBus2Invert><PoExtBus3Map2LED>0</PoExtBus3Map2LED><PoExtBus3Map2IO>0</PoExtBus3Map2IO><PoExtBus3Invert>0</PoExtBus3Invert><PoExtBus4Map2LED>0</PoExtBus4Map2LED><PoExtBus4Map2IO>0</PoExtBus4Map2IO><PoExtBus4Invert>0</PoExtBus4Invert><PoExtBus5Map2LED>0</PoExtBus5Map2LED><PoExtBus5Map2IO>0</PoExtBus5Map2IO><PoExtBus5Invert>0</PoExtBus5Invert><PoExtBus6Map2LED>0</PoExtBus6Map2LED><PoExtBus6Map2IO>0</PoExtBus6Map2IO><PoExtBus6Invert>0</PoExtBus6Invert><PoExtBus7Map2LED>0</PoExtBus7Map2LED><PoExtBus7Map2IO>0</PoExtBus7Map2IO><PoExtBus7Invert>0</PoExtBus7Invert><PoExtBus8Map2LED>0</PoExtBus8Map2LED><PoExtBus8Map2IO>0</PoExtBus8Map2IO><PoExtBus8Invert>0</PoExtBus8Invert><PoExtBus9Map2LED>0</PoExtBus9Map2LED><PoExtBus9Map2IO>0</PoExtBus9Map2IO><PoExtBus9Invert>0</PoExtBus9Invert><PoExtBus10Map2LED>0</PoExtBus10Map2LED><PoExtBus10Map2IO>0</PoExtBus10Map2IO><PoExtBus10Invert>0</PoExtBus10Invert><PoExtBus11Map2LED>0</PoExtBus11Map2LED><PoExtBus11Map2IO>0</PoExtBus11Map2IO><PoExtBus11Invert>0</PoExtBus11Invert><PoExtBus12Map2LED>0</PoExtBus12Map2LED><PoExtBus12Map2IO>0</PoExtBus12Map2IO><PoExtBus12Invert>0</PoExtBus12Invert><PoExtBus13Map2LED>0</PoExtBus13Map2LED><PoExtBus13Map2IO>0</PoExtBus13Map2IO><PoExtBus13Invert>0</PoExtBus13Invert><PoExtBus14Map2LED>0</PoExtBus14Map2LED><PoExtBus14Map2IO>0</PoExtBus14Map2IO><PoExtBus14Invert>0</PoExtBus14Invert><PoExtBus15Map2LED>0</PoExtBus15Map2LED><PoExtBus15Map2IO>0</PoExtBus15Map2IO><PoExtBus15Invert>0</PoExtBus15Invert><PoExtBus16Map2LED>0</PoExtBus16Map2LED><PoExtBus16Map2IO>0</PoExtBus16Map2IO><PoExtBus16Invert>0</PoExtBus16Invert><PoExtBus17Map2LED>0</PoExtBus17Map2LED><PoExtBus17Map2IO>0</PoExtBus17Map2IO><PoExtBus17Invert>0</PoExtBus17Invert><PoExtBus18Map2LED>0</PoExtBus18Map2LED><PoExtBus18Map2IO>0</PoExtBus18Map2IO><PoExtBus18Invert>0</PoExtBus18Invert><PoExtBus19Map2LED>0</PoExtBus19Map2LED><PoExtBus19Map2IO>0</PoExtBus19Map2IO><PoExtBus19Invert>0</PoExtBus19Invert><PoExtBus20Map2LED>0</PoExtBus20Map2LED><PoExtBus20Map2IO>0</PoExtBus20Map2IO><PoExtBus20Invert>0</PoExtBus20Invert><PoExtBus21Map2LED>0</PoExtBus21Map2LED><PoExtBus21Map2IO>0</PoExtBus21Map2IO><PoExtBus21Invert>0</PoExtBus21Invert><PoExtBus22Map2LED>0</PoExtBus22Map2LED><PoExtBus22Map2IO>0</PoExtBus22Map2IO><PoExtBus22Invert>0</PoExtBus22Invert><PoExtBus23Map2LED>0</PoExtBus23Map2LED><PoExtBus23Map2IO>0</PoExtBus23Map2IO><PoExtBus23Invert>0</PoExtBus23Invert><PoExtBus24Map2LED>0</PoExtBus24Map2LED><PoExtBus24Map2IO>0</PoExtBus24Map2IO><PoExtBus24Invert>0</PoExtBus24Invert><PoExtBus25Map2LED>0</PoExtBus25Map2LED><PoExtBus25Map2IO>0</PoExtBus25Map2IO><PoExtBus25Invert>0</PoExtBus25Invert><PoExtBus26Map2LED>0</PoExtBus26Map2LED><PoExtBus26Map2IO>0</PoExtBus26Map2IO><PoExtBus26Invert>0</PoExtBus26Invert><PoExtBus27Map2LED>0</PoExtBus27Map2LED><PoExtBus27Map2IO>0</PoExtBus27Map2IO><PoExtBus27Invert>0</PoExtBus27Invert><PoExtBus28Map2LED>0</PoExtBus28Map2LED><PoExtBus28Map2IO>0</PoExtBus28Map2IO><PoExtBus28Invert>0</PoExtBus28Invert><PoExtBus29Map2LED>0</PoExtBus29Map2LED><PoExtBus29Map2IO>0</PoExtBus29Map2IO><PoExtBus29Invert>0</PoExtBus29Invert><PoExtBus30Map2LED>0</PoExtBus30Map2LED><PoExtBus30Map2IO>0</PoExtBus30Map2IO><PoExtBus30Invert>0</PoExtBus30Invert><PoExtBus31Map2LED>0</PoExtBus31Map2LED><PoExtBus31Map2IO>0</PoExtBus31Map2IO><PoExtBus31Invert>0</PoExtBus31Invert><PoExtBus32Map2LED>0</PoExtBus32Map2LED><PoExtBus32Map2IO>0</PoExtBus32Map2IO><PoExtBus32Invert>0</PoExtBus32Invert><PoExtBus33Map2LED>0</PoExtBus33Map2LED><PoExtBus33Map2IO>0</PoExtBus33Map2IO><PoExtBus33Invert>0</PoExtBus33Invert><PoExtBus34Map2LED>0</PoExtBus34Map2LED><PoExtBus34Map2IO>0</PoExtBus34Map2IO><PoExtBus34Invert>0</PoExtBus34Invert><PoExtBus35Map2LED>0</PoExtBus35Map2LED><PoExtBus35Map2IO>0</PoExtBus35Map2IO><PoExtBus35Invert>0</PoExtBus35Invert><PoExtBus36Map2LED>0</PoExtBus36Map2LED><PoExtBus36Map2IO>0</PoExtBus36Map2IO><PoExtBus36Invert>0</PoExtBus36Invert><PoExtBus37Map2LED>0</PoExtBus37Map2LED><PoExtBus37Map2IO>0</PoExtBus37Map2IO><PoExtBus37Invert>0</PoExtBus37Invert><PoExtBus38Map2LED>0</PoExtBus38Map2LED><PoExtBus38Map2IO>0</PoExtBus38Map2IO><PoExtBus38Invert>0</PoExtBus38Invert><PoExtBus39Map2LED>0</PoExtBus39Map2LED><PoExtBus39Map2IO>0</PoExtBus39Map2IO><PoExtBus39Invert>0</PoExtBus39Invert><PoExtBus40Map2LED>0</PoExtBus40Map2LED><PoExtBus40Map2IO>0</PoExtBus40Map2IO><PoExtBus40Invert>0</PoExtBus40Invert><PoExtBus41Map2LED>0</PoExtBus41Map2LED><PoExtBus41Map2IO>0</PoExtBus41Map2IO><PoExtBus41Invert>0</PoExtBus41Invert><PoExtBus42Map2LED>0</PoExtBus42Map2LED><PoExtBus42Map2IO>0</PoExtBus42Map2IO><PoExtBus42Invert>0</PoExtBus42Invert><PoExtBus43Map2LED>0</PoExtBus43Map2LED><PoExtBus43Map2IO>0</PoExtBus43Map2IO><PoExtBus43Invert>0</PoExtBus43Invert><PoExtBus44Map2LED>0</PoExtBus44Map2LED><PoExtBus44Map2IO>0</PoExtBus44Map2IO><PoExtBus44Invert>0</PoExtBus44Invert><PoExtBus45Map2LED>0</PoExtBus45Map2LED><PoExtBus45Map2IO>0</PoExtBus45Map2IO><PoExtBus45Invert>0</PoExtBus45Invert><PoExtBus46Map2LED>0</PoExtBus46Map2LED><PoExtBus46Map2IO>0</PoExtBus46Map2IO><PoExtBus46Invert>0</PoExtBus46Invert><PoExtBus47Map2LED>0</PoExtBus47Map2LED><PoExtBus47Map2IO>0</PoExtBus47Map2IO><PoExtBus47Invert>0</PoExtBus47Invert><PoExtBus48Map2LED>0</PoExtBus48Map2LED><PoExtBus48Map2IO>0</PoExtBus48Map2IO><PoExtBus48Invert>0</PoExtBus48Invert><PoExtBus49Map2LED>0</PoExtBus49Map2LED><PoExtBus49Map2IO>0</PoExtBus49Map2IO><PoExtBus49Invert>0</PoExtBus49Invert><PoExtBus50Map2LED>0</PoExtBus50Map2LED><PoExtBus50Map2IO>0</PoExtBus50Map2IO><PoExtBus50Invert>0</PoExtBus50Invert><PoExtBus51Map2LED>0</PoExtBus51Map2LED><PoExtBus51Map2IO>0</PoExtBus51Map2IO><PoExtBus51Invert>0</PoExtBus51Invert><PoExtBus52Map2LED>0</PoExtBus52Map2LED><PoExtBus52Map2IO>0</PoExtBus52Map2IO><PoExtBus52Invert>0</PoExtBus52Invert><PoExtBus53Map2LED>0</PoExtBus53Map2LED><PoExtBus53Map2IO>0</PoExtBus53Map2IO><PoExtBus53Invert>0</PoExtBus53Invert><PoExtBus54Map2LED>0</PoExtBus54Map2LED><PoExtBus54Map2IO>0</PoExtBus54Map2IO><PoExtBus54Invert>0</PoExtBus54Invert><PoExtBus55Map2LED>0</PoExtBus55Map2LED><PoExtBus55Map2IO>0</PoExtBus55Map2IO><PoExtBus55Invert>0</PoExtBus55Invert><PoExtBus56Map2LED>0</PoExtBus56Map2LED><PoExtBus56Map2IO>0</PoExtBus56Map2IO><PoExtBus56Invert>0</PoExtBus56Invert><PoExtBus57Map2LED>0</PoExtBus57Map2LED><PoExtBus57Map2IO>0</PoExtBus57Map2IO><PoExtBus57Invert>0</PoExtBus57Invert><PoExtBus58Map2LED>0</PoExtBus58Map2LED><PoExtBus58Map2IO>0</PoExtBus58Map2IO><PoExtBus58Invert>0</PoExtBus58Invert><PoExtBus59Map2LED>0</PoExtBus59Map2LED><PoExtBus59Map2IO>0</PoExtBus59Map2IO><PoExtBus59Invert>0</PoExtBus59Invert><PoExtBus60Map2LED>0</PoExtBus60Map2LED><PoExtBus60Map2IO>0</PoExtBus60Map2IO><PoExtBus60Invert>0</PoExtBus60Invert><PoExtBus61Map2LED>0</PoExtBus61Map2LED><PoExtBus61Map2IO>0</PoExtBus61Map2IO><PoExtBus61Invert>0</PoExtBus61Invert><PoExtBus62Map2LED>0</PoExtBus62Map2LED><PoExtBus62Map2IO>0</PoExtBus62Map2IO><PoExtBus62Invert>0</PoExtBus62Invert><PoExtBus63Map2LED>0</PoExtBus63Map2LED><PoExtBus63Map2IO>0</PoExtBus63Map2IO><PoExtBus63Invert>0</PoExtBus63Invert><PoExtBus64Map2LED>0</PoExtBus64Map2LED><PoExtBus64Map2IO>0</PoExtBus64Map2IO><PoExtBus64Invert>0</PoExtBus64Invert><PoExtBus65Map2LED>0</PoExtBus65Map2LED><PoExtBus65Map2IO>0</PoExtBus65Map2IO><PoExtBus65Invert>0</PoExtBus65Invert><PoExtBus66Map2LED>0</PoExtBus66Map2LED><PoExtBus66Map2IO>0</PoExtBus66Map2IO><PoExtBus66Invert>0</PoExtBus66Invert><PoExtBus67Map2LED>0</PoExtBus67Map2LED><PoExtBus67Map2IO>0</PoExtBus67Map2IO><PoExtBus67Invert>0</PoExtBus67Invert><PoExtBus68Map2LED>0</PoExtBus68Map2LED><PoExtBus68Map2IO>0</PoExtBus68Map2IO><PoExtBus68Invert>0</PoExtBus68Invert><PoExtBus69Map2LED>0</PoExtBus69Map2LED><PoExtBus69Map2IO>0</PoExtBus69Map2IO><PoExtBus69Invert>0</PoExtBus69Invert><PoExtBus70Map2LED>0</PoExtBus70Map2LED><PoExtBus70Map2IO>0</PoExtBus70Map2IO><PoExtBus70Invert>0</PoExtBus70Invert><PoExtBus71Map2LED>0</PoExtBus71Map2LED><PoExtBus71Map2IO>0</PoExtBus71Map2IO><PoExtBus71Invert>0</PoExtBus71Invert><PoExtBus72Map2LED>0</PoExtBus72Map2LED><PoExtBus72Map2IO>0</PoExtBus72Map2IO><PoExtBus72Invert>0</PoExtBus72Invert><PoExtBus73Map2LED>0</PoExtBus73Map2LED><PoExtBus73Map2IO>0</PoExtBus73Map2IO><PoExtBus73Invert>0</PoExtBus73Invert><PoExtBus74Map2LED>0</PoExtBus74Map2LED><PoExtBus74Map2IO>0</PoExtBus74Map2IO><PoExtBus74Invert>0</PoExtBus74Invert><PoExtBus75Map2LED>0</PoExtBus75Map2LED><PoExtBus75Map2IO>0</PoExtBus75Map2IO><PoExtBus75Invert>0</PoExtBus75Invert><PoExtBus76Map2LED>0</PoExtBus76Map2LED><PoExtBus76Map2IO>0</PoExtBus76Map2IO><PoExtBus76Invert>0</PoExtBus76Invert><PoExtBus77Map2LED>0</PoExtBus77Map2LED><PoExtBus77Map2IO>0</PoExtBus77Map2IO><PoExtBus77Invert>0</PoExtBus77Invert><PoExtBus78Map2LED>0</PoExtBus78Map2LED><PoExtBus78Map2IO>0</PoExtBus78Map2IO><PoExtBus78Invert>0</PoExtBus78Invert><PoExtBus79Map2LED>0</PoExtBus79Map2LED><PoExtBus79Map2IO>0</PoExtBus79Map2IO><PoExtBus79Invert>0</PoExtBus79Invert><PoExtBus80Map2LED>0</PoExtBus80Map2LED><PoExtBus80Map2IO>0</PoExtBus80Map2IO><PoExtBus80Invert>0</PoExtBus80Invert><kbd48CNC_0_ToLED>0</kbd48CNC_0_ToLED><kbd48CNC_0_ToButton>0</kbd48CNC_0_ToButton><kbd48CNC_LEDto_0>0</kbd48CNC_LEDto_0><kbd48CNC_1_ToLED>0</kbd48CNC_1_ToLED><kbd48CNC_1_ToButton>0</kbd48CNC_1_ToButton><kbd48CNC_LEDto_1>0</kbd48CNC_LEDto_1><kbd48CNC_2_ToLED>0</kbd48CNC_2_ToLED><kbd48CNC_2_ToButton>0</kbd48CNC_2_ToButton><kbd48CNC_LEDto_2>0</kbd48CNC_LEDto_2><kbd48CNC_3_ToLED>0</kbd48CNC_3_ToLED><kbd48CNC_3_ToButton>0</kbd48CNC_3_ToButton><kbd48CNC_LEDto_3>0</kbd48CNC_LEDto_3><kbd48CNC_4_ToLED>0</kbd48CNC_4_ToLED><kbd48CNC_4_ToButton>0</kbd48CNC_4_ToButton><kbd48CNC_LEDto_4>0</kbd48CNC_LEDto_4><kbd48CNC_5_ToLED>0</kbd48CNC_5_ToLED><kbd48CNC_5_ToButton>0</kbd48CNC_5_ToButton><kbd48CNC_LEDto_5>0</kbd48CNC_LEDto_5><kbd48CNC_6_ToLED>0</kbd48CNC_6_ToLED><kbd48CNC_6_ToButton>0</kbd48CNC_6_ToButton><kbd48CNC_LEDto_6>0</kbd48CNC_LEDto_6><kbd48CNC_7_ToLED>0</kbd48CNC_7_ToLED><kbd48CNC_7_ToButton>0</kbd48CNC_7_ToButton><kbd48CNC_LEDto_7>0</kbd48CNC_LEDto_7><kbd48CNC_8_ToLED>0</kbd48CNC_8_ToLED><kbd48CNC_8_ToButton>0</kbd48CNC_8_ToButton><kbd48CNC_LEDto_8>0</kbd48CNC_LEDto_8><kbd48CNC_9_ToLED>0</kbd48CNC_9_ToLED><kbd48CNC_9_ToButton>0</kbd48CNC_9_ToButton><kbd48CNC_LEDto_9>0</kbd48CNC_LEDto_9><kbd48CNC_10_ToLED>0</kbd48CNC_10_ToLED><kbd48CNC_10_ToButton>0</kbd48CNC_10_ToButton><kbd48CNC_LEDto_10>0</kbd48CNC_LEDto_10><kbd48CNC_11_ToLED>0</kbd48CNC_11_ToLED><kbd48CNC_11_ToButton>0</kbd48CNC_11_ToButton><kbd48CNC_LEDto_11>0</kbd48CNC_LEDto_11><kbd48CNC_12_ToLED>0</kbd48CNC_12_ToLED><kbd48CNC_12_ToButton>0</kbd48CNC_12_ToButton><kbd48CNC_LEDto_12>0</kbd48CNC_LEDto_12><kbd48CNC_13_ToLED>0</kbd48CNC_13_ToLED><kbd48CNC_13_ToButton>0</kbd48CNC_13_ToButton><kbd48CNC_LEDto_13>0</kbd48CNC_LEDto_13><kbd48CNC_14_ToLED>0</kbd48CNC_14_ToLED><kbd48CNC_14_ToButton>0</kbd48CNC_14_ToButton><kbd48CNC_LEDto_14>0</kbd48CNC_LEDto_14><kbd48CNC_15_ToLED>0</kbd48CNC_15_ToLED><kbd48CNC_15_ToButton>0</kbd48CNC_15_ToButton><kbd48CNC_LEDto_15>0</kbd48CNC_LEDto_15><kbd48CNC_16_ToLED>0</kbd48CNC_16_ToLED><kbd48CNC_16_ToButton>0</kbd48CNC_16_ToButton><kbd48CNC_LEDto_16>0</kbd48CNC_LEDto_16><kbd48CNC_17_ToLED>0</kbd48CNC_17_ToLED><kbd48CNC_17_ToButton>0</kbd48CNC_17_ToButton><kbd48CNC_LEDto_17>0</kbd48CNC_LEDto_17><kbd48CNC_18_ToLED>0</kbd48CNC_18_ToLED><kbd48CNC_18_ToButton>0</kbd48CNC_18_ToButton><kbd48CNC_LEDto_18>0</kbd48CNC_LEDto_18><kbd48CNC_19_ToLED>0</kbd48CNC_19_ToLED><kbd48CNC_19_ToButton>0</kbd48CNC_19_ToButton><kbd48CNC_LEDto_19>0</kbd48CNC_LEDto_19><kbd48CNC_20_ToLED>0</kbd48CNC_20_ToLED><kbd48CNC_20_ToButton>0</kbd48CNC_20_ToButton><kbd48CNC_LEDto_20>0</kbd48CNC_LEDto_20><kbd48CNC_21_ToLED>0</kbd48CNC_21_ToLED><kbd48CNC_21_ToButton>0</kbd48CNC_21_ToButton><kbd48CNC_LEDto_21>0</kbd48CNC_LEDto_21><kbd48CNC_22_ToLED>0</kbd48CNC_22_ToLED><kbd48CNC_22_ToButton>0</kbd48CNC_22_ToButton><kbd48CNC_LEDto_22>0</kbd48CNC_LEDto_22><kbd48CNC_23_ToLED>0</kbd48CNC_23_ToLED><kbd48CNC_23_ToButton>0</kbd48CNC_23_ToButton><kbd48CNC_LEDto_23>0</kbd48CNC_LEDto_23><kbd48CNC_24_ToLED>0</kbd48CNC_24_ToLED><kbd48CNC_24_ToButton>0</kbd48CNC_24_ToButton><kbd48CNC_LEDto_24>0</kbd48CNC_LEDto_24><kbd48CNC_25_ToLED>0</kbd48CNC_25_ToLED><kbd48CNC_25_ToButton>0</kbd48CNC_25_ToButton><kbd48CNC_LEDto_25>0</kbd48CNC_LEDto_25><kbd48CNC_26_ToLED>0</kbd48CNC_26_ToLED><kbd48CNC_26_ToButton>0</kbd48CNC_26_ToButton><kbd48CNC_LEDto_26>0</kbd48CNC_LEDto_26><kbd48CNC_27_ToLED>0</kbd48CNC_27_ToLED><kbd48CNC_27_ToButton>0</kbd48CNC_27_ToButton><kbd48CNC_LEDto_27>0</kbd48CNC_LEDto_27><kbd48CNC_28_ToLED>0</kbd48CNC_28_ToLED><kbd48CNC_28_ToButton>0</kbd48CNC_28_ToButton><kbd48CNC_LEDto_28>0</kbd48CNC_LEDto_28><kbd48CNC_29_ToLED>0</kbd48CNC_29_ToLED><kbd48CNC_29_ToButton>0</kbd48CNC_29_ToButton><kbd48CNC_LEDto_29>0</kbd48CNC_LEDto_29><kbd48CNC_30_ToLED>0</kbd48CNC_30_ToLED><kbd48CNC_30_ToButton>0</kbd48CNC_30_ToButton><kbd48CNC_LEDto_30>0</kbd48CNC_LEDto_30><kbd48CNC_31_ToLED>0</kbd48CNC_31_ToLED><kbd48CNC_31_ToButton>0</kbd48CNC_31_ToButton><kbd48CNC_LEDto_31>0</kbd48CNC_LEDto_31><kbd48CNC_32_ToLED>0</kbd48CNC_32_ToLED><kbd48CNC_32_ToButton>0</kbd48CNC_32_ToButton><kbd48CNC_LEDto_32>0</kbd48CNC_LEDto_32><kbd48CNC_33_ToLED>0</kbd48CNC_33_ToLED><kbd48CNC_33_ToButton>0</kbd48CNC_33_ToButton><kbd48CNC_LEDto_33>0</kbd48CNC_LEDto_33><kbd48CNC_34_ToLED>0</kbd48CNC_34_ToLED><kbd48CNC_34_ToButton>0</kbd48CNC_34_ToButton><kbd48CNC_LEDto_34>0</kbd48CNC_LEDto_34><kbd48CNC_35_ToLED>0</kbd48CNC_35_ToLED><kbd48CNC_35_ToButton>0</kbd48CNC_35_ToButton><kbd48CNC_LEDto_35>0</kbd48CNC_LEDto_35><kbd48CNC_36_ToLED>0</kbd48CNC_36_ToLED><kbd48CNC_36_ToButton>0</kbd48CNC_36_ToButton><kbd48CNC_LEDto_36>0</kbd48CNC_LEDto_36><kbd48CNC_37_ToLED>0</kbd48CNC_37_ToLED><kbd48CNC_37_ToButton>0</kbd48CNC_37_ToButton><kbd48CNC_LEDto_37>0</kbd48CNC_LEDto_37><kbd48CNC_38_ToLED>0</kbd48CNC_38_ToLED><kbd48CNC_38_ToButton>0</kbd48CNC_38_ToButton><kbd48CNC_LEDto_38>0</kbd48CNC_LEDto_38><kbd48CNC_39_ToLED>0</kbd48CNC_39_ToLED><kbd48CNC_39_ToButton>0</kbd48CNC_39_ToButton><kbd48CNC_LEDto_39>0</kbd48CNC_LEDto_39><kbd48CNC_40_ToLED>0</kbd48CNC_40_ToLED><kbd48CNC_40_ToButton>0</kbd48CNC_40_ToButton><kbd48CNC_LEDto_40>0</kbd48CNC_LEDto_40><kbd48CNC_41_ToLED>0</kbd48CNC_41_ToLED><kbd48CNC_41_ToButton>0</kbd48CNC_41_ToButton><kbd48CNC_LEDto_41>0</kbd48CNC_LEDto_41><kbd48CNC_42_ToLED>0</kbd48CNC_42_ToLED><kbd48CNC_42_ToButton>0</kbd48CNC_42_ToButton><kbd48CNC_LEDto_42>0</kbd48CNC_LEDto_42><kbd48CNC_43_ToLED>0</kbd48CNC_43_ToLED><kbd48CNC_43_ToButton>0</kbd48CNC_43_ToButton><kbd48CNC_LEDto_43>0</kbd48CNC_LEDto_43><kbd48CNC_44_ToLED>0</kbd48CNC_44_ToLED><kbd48CNC_44_ToButton>0</kbd48CNC_44_ToButton><kbd48CNC_LEDto_44>0</kbd48CNC_LEDto_44><kbd48CNC_45_ToLED>0</kbd48CNC_45_ToLED><kbd48CNC_45_ToButton>0</kbd48CNC_45_ToButton><kbd48CNC_LEDto_45>0</kbd48CNC_LEDto_45><kbd48CNC_46_ToLED>0</kbd48CNC_46_ToLED><kbd48CNC_46_ToButton>0</kbd48CNC_46_ToButton><kbd48CNC_LEDto_46>0</kbd48CNC_LEDto_46><kbd48CNC_47_ToLED>0</kbd48CNC_47_ToLED><kbd48CNC_47_ToButton>0</kbd48CNC_47_ToButton><kbd48CNC_LEDto_47>0</kbd48CNC_LEDto_47><PELED1>0</PELED1><PEIO1>0</PEIO1><PELED2>0</PELED2><PEIO2>0</PEIO2><PELED3>0</PELED3><PEIO3>0</PEIO3><PELED4>0</PELED4><PEIO4>0</PEIO4><PELED5>0</PELED5><PEIO5>0</PEIO5><PELED6>0</PELED6><PEIO6>0</PEIO6><PELED7>0</PELED7><PEIO7>0</PEIO7><PELED8>0</PELED8><PEIO8>0</PEIO8><PELED9>0</PELED9><PEIO9>0</PEIO9><PELED10>0</PELED10><PEIO10>0</PEIO10><PEChargePump>0</PEChargePump><PEChargePumpInReset>0</PEChargePumpInReset><PEtype>0</PEtype><PEInvertEmergency>0</PEInvertEmergency><ProbingPin>0</ProbingPin><ProbingPinInvert>0</ProbingPinInvert><PulseGenType>0</PulseGenType><PEDontDeref>0</PEDontDeref><PEDisableAutomaticSelection>0</PEDisableAutomaticSelection><SwitchInputFilterConstant>0</SwitchInputFilterConstant><PEExtIn1Map2LED>0</PEExtIn1Map2LED><PEExtIn1Map2IO>0</PEExtIn1Map2IO><PEExtIn2Map2LED>0</PEExtIn2Map2LED><PEExtIn2Map2IO>0</PEExtIn2Map2IO><PEExtIn3Map2LED>0</PEExtIn3Map2LED><PEExtIn3Map2IO>0</PEExtIn3Map2IO><PEExtIn4Map2LED>0</PEExtIn4Map2LED><PEExtIn4Map2IO>0</PEExtIn4Map2IO><PEExtIn5Map2LED>0</PEExtIn5Map2LED><PEExtIn5Map2IO>0</PEExtIn5Map2IO><PEExtIn6Map2LED>0</PEExtIn6Map2LED><PEExtIn6Map2IO>0</PEExtIn6Map2IO><PEExtIn7Map2LED>0</PEExtIn7Map2LED><PEExtIn7Map2IO>0</PEExtIn7Map2IO><PEExtIn8Map2LED>0</PEExtIn8Map2LED><PEExtIn8Map2IO>0</PEExtIn8Map2IO><PEExtIn1ErrorMap2LED>0</PEExtIn1ErrorMap2LED><PEExtIn1ErrorMap2IO>0</PEExtIn1ErrorMap2IO><PEExtIn2ErrorMap2LED>0</PEExtIn2ErrorMap2LED><PEExtIn2ErrorMap2IO>0</PEExtIn2ErrorMap2IO><PEExtIn3ErrorMap2LED>0</PEExtIn3ErrorMap2LED><PEExtIn3ErrorMap2IO>0</PEExtIn3ErrorMap2IO><PEExtIn4ErrorMap2LED>0</PEExtIn4ErrorMap2LED><PEExtIn4ErrorMap2IO>0</PEExtIn4ErrorMap2IO><PEExtOut1Map2LED>0</PEExtOut1Map2LED><PEExtOut1Map2IO>0</PEExtOut1Map2IO><PEExtOut2Map2LED>0</PEExtOut2Map2LED><PEExtOut2Map2IO>0</PEExtOut2Map2IO><PEExtOut3Map2LED>0</PEExtOut3Map2LED><PEExtOut3Map2IO>0</PEExtOut3Map2IO><PEExtOut4Map2LED>0</PEExtOut4Map2LED><PEExtOut4Map2IO>0</PEExtOut4Map2IO><PEExtOut5Map2LED>0</PEExtOut5Map2LED><PEExtOut5Map2IO>0</PEExtOut5Map2IO><PEExtOut6Map2LED>0</PEExtOut6Map2LED><PEExtOut6Map2IO>0</PEExtOut6Map2IO><PEExtOut7Map2LED>0</PEExtOut7Map2LED><PEExtOut7Map2IO>0</PEExtOut7Map2IO><PEExtOut8Map2LED>0</PEExtOut8Map2LED><PEExtOut8Map2IO>0</PEExtOut8Map2IO><PEExtOut9Map2LED>0</PEExtOut9Map2LED><PEExtOut9Map2IO>0</PEExtOut9Map2IO><PEExtOut10Map2LED>0</PEExtOut10Map2LED><PEExtOut10Map2IO>0</PEExtOut10Map2IO><PEExtOut11Map2LED>0</PEExtOut11Map2LED><PEExtOut11Map2IO>0</PEExtOut11Map2IO><PEExtOut12Map2LED>0</PEExtOut12Map2LED><PEExtOut12Map2IO>0</PEExtOut12Map2IO><PEExtOut13Map2LED>0</PEExtOut13Map2LED><PEExtOut13Map2IO>0</PEExtOut13Map2IO><PEExtOut14Map2LED>0</PEExtOut14Map2LED><PEExtOut14Map2IO>0</PEExtOut14Map2IO><PEExtOut15Map2LED>0</PEExtOut15Map2LED><PEExtOut15Map2IO>0</PEExtOut15Map2IO><PEExtOut16Map2LED>0</PEExtOut16Map2LED><PEExtOut16Map2IO>0</PEExtOut16Map2IO><MPGDiv1>0</MPGDiv1><MPGDiv2>0</MPGDiv2><MPGDiv3>0</MPGDiv3><MPGDiv4>0</MPGDiv4><MPGDiv5>0</MPGDiv5><MPGDiv6>0</MPGDiv6><MPGDiv7>0</MPGDiv7><MPGDiv8>0</MPGDiv8><LimitPS1>0</LimitPS1><LimitMS1>0</LimitMS1><HomeS1>0</HomeS1><LimitPInvert1>0</LimitPInvert1><LimitMInvert1>0</LimitMInvert1><HomeInvert1>0</HomeInvert1><EnabledInvert1>0</EnabledInvert1><LimitPS2>0</LimitPS2><LimitMS2>0</LimitMS2><HomeS2>0</HomeS2><LimitPInvert2>0</LimitPInvert2><LimitMInvert2>0</LimitMInvert2><HomeInvert2>0</HomeInvert2><EnabledInvert2>0</EnabledInvert2><LimitPS3>0</LimitPS3><LimitMS3>0</LimitMS3><HomeS3>0</HomeS3><LimitPInvert3>0</LimitPInvert3><LimitMInvert3>0</LimitMInvert3><HomeInvert3>0</HomeInvert3><EnabledInvert3>0</EnabledInvert3><LimitPS4>0</LimitPS4><LimitMS4>0</LimitMS4><HomeS4>0</HomeS4><LimitPInvert4>0</LimitPInvert4><LimitMInvert4>0</LimitMInvert4><HomeInvert4>0</HomeInvert4><EnabledInvert4>0</EnabledInvert4><LimitPS5>0</LimitPS5><LimitMS5>0</LimitMS5><HomeS5>0</HomeS5><LimitPInvert5>0</LimitPInvert5><LimitMInvert5>0</LimitMInvert5><HomeInvert5>0</HomeInvert5><EnabledInvert5>0</EnabledInvert5><LimitPS6>0</LimitPS6><LimitMS6>0</LimitMS6><HomeS6>0</HomeS6><LimitPInvert6>0</LimitPInvert6><LimitMInvert6>0</LimitMInvert6><HomeInvert6>0</HomeInvert6><EnabledInvert6>0</EnabledInvert6><LimitPS7>0</LimitPS7><LimitMS7>0</LimitMS7><HomeS7>0</HomeS7><LimitPInvert7>0</LimitPInvert7><LimitMInvert7>0</LimitMInvert7><HomeInvert7>0</HomeInvert7><EnabledInvert7>0</EnabledInvert7><LimitPS8>0</LimitPS8><LimitMS8>0</LimitMS8><HomeS8>0</HomeS8><LimitPInvert8>0</LimitPInvert8><LimitMInvert8>0</LimitMInvert8><HomeInvert8>0</HomeInvert8><EnabledInvert8>0</EnabledInvert8><THCmode>0</THCmode><THCInvertDirection>0</THCInvertDirection><THCEnableAntiDive>0</THCEnableAntiDive><THCAntiDiveLimit>0</THCAntiDiveLimit><THCDeadband>0</THCDeadband><THCTorchVoltageInput>0</THCTorchVoltageInput><THCReferenceHeightInput>0</THCReferenceHeightInput><THCReferenceVoltage>0</THCReferenceVoltage><THCGain>1</THCGain><THCArcOKRange>0</THCArcOKRange><StopBeforeHoming>0</StopBeforeHoming><UseLCD>0</UseLCD><LCDRows>0</LCDRows><LCDColumns>0</LCDColumns><PWMPeriod>0</PWMPeriod><PWMDisableInactive>0</PWMDisableInactive><PWMenable1>0</PWMenable1><PWMduty1>0</PWMduty1><PWMMapDRO1>0</PWMMapDRO1><PWMDROMultiplier1>0.000000</PWMDROMultiplier1><PWMenable2>0</PWMenable2><PWMduty2>0</PWMduty2><PWMMapDRO2>0</PWMMapDRO2><PWMDROMultiplier2>0.000000</PWMDROMultiplier2><PWMenable3>0</PWMenable3><PWMduty3>0</PWMduty3><PWMMapDRO3>0</PWMMapDRO3><PWMDROMultiplier3>0.000000</PWMDROMultiplier3><PWMenable4>0</PWMenable4><PWMduty4>0</PWMduty4><PWMMapDRO4>0</PWMMapDRO4><PWMDROMultiplier4>0.000000</PWMDROMultiplier4><PWMenable5>0</PWMenable5><PWMduty5>0</PWMduty5><PWMMapDRO5>0</PWMMapDRO5><PWMDROMultiplier5>0.000000</PWMDROMultiplier5><PWMenable6>0</PWMenable6><PWMduty6>0</PWMduty6><PWMMapDRO6>0</PWMMapDRO6><PWMDROMultiplier6>0.000000</PWMDROMultiplier6><AnalogInput1>0</AnalogInput1><AnalogDROMapping1>0</AnalogDROMapping1><AnalogJoystickMapping1>0</AnalogJoystickMapping1><AnalogOffset1>0</AnalogOffset1><AnalogGain1_f>0</AnalogGain1_f><AnalogInput2>0</AnalogInput2><AnalogDROMapping2>0</AnalogDROMapping2><AnalogJoystickMapping2>0</AnalogJoystickMapping2><AnalogOffset2>0</AnalogOffset2><AnalogGain2_f>0</AnalogGain2_f><AnalogInput3>0</AnalogInput3><AnalogDROMapping3>0</AnalogDROMapping3><AnalogJoystickMapping3>0</AnalogJoystickMapping3><AnalogOffset3>0</AnalogOffset3><AnalogGain3_f>0</AnalogGain3_f><AnalogInput4>0</AnalogInput4><AnalogDROMapping4>0</AnalogDROMapping4><AnalogJoystickMapping4>0</AnalogJoystickMapping4><AnalogOffset4>0</AnalogOffset4><AnalogGain4_f>0</AnalogGain4_f><AnalogInput5>0</AnalogInput5><AnalogDROMapping5>0</AnalogDROMapping5><AnalogJoystickMapping5>0</AnalogJoystickMapping5><AnalogOffset5>0</AnalogOffset5><AnalogGain5_f>0</AnalogGain5_f><AnalogInput6>0</AnalogInput6><AnalogDROMapping6>0</AnalogDROMapping6><AnalogJoystickMapping6>0</AnalogJoystickMapping6><AnalogOffset6>0</AnalogOffset6><AnalogGain6_f>0</AnalogGain6_f><AnalogInput7>0</AnalogInput7><AnalogDROMapping7>0</AnalogDROMapping7><AnalogJoystickMapping7>0</AnalogJoystickMapping7><AnalogOffset7>0</AnalogOffset7><AnalogGain7_f>0</AnalogGain7_f><AnalogDeadband>0</AnalogDeadband><AnalogJoystick>0</AnalogJoystick><JoystickEnableOEMLED>0</JoystickEnableOEMLED><MatrixLED1Enabled>0</MatrixLED1Enabled><MatrixLED2Enabled>0</MatrixLED2Enabled><MatrixLED1Width>0</MatrixLED1Width><MatrixLED1Height>0</MatrixLED1Height><MatrixLED2Width>0</MatrixLED2Width><MatrixLED2Height>0</MatrixLED2Height><MatrixLED1LED1>0</MatrixLED1LED1><MatrixLED1IO1>0</MatrixLED1IO1><MatrixLED2LED1>0</MatrixLED2LED1><MatrixLED2IO1>0</MatrixLED2IO1><MatrixLED1LED2>0</MatrixLED1LED2><MatrixLED1IO2>0</MatrixLED1IO2><MatrixLED2LED2>0</MatrixLED2LED2><MatrixLED2IO2>0</MatrixLED2IO2><MatrixLED1LED3>0</MatrixLED1LED3><MatrixLED1IO3>0</MatrixLED1IO3><MatrixLED2LED3>0</MatrixLED2LED3><MatrixLED2IO3>0</MatrixLED2IO3><MatrixLED1LED4>0</MatrixLED1LED4><MatrixLED1IO4>0</MatrixLED1IO4><MatrixLED2LED4>0</MatrixLED2LED4><MatrixLED2IO4>0</MatrixLED2IO4><MatrixLED1LED5>0</MatrixLED1LED5><MatrixLED1IO5>0</MatrixLED1IO5><MatrixLED2LED5>0</MatrixLED2LED5><MatrixLED2IO5>0</MatrixLED2IO5><MatrixLED1LED6>0</MatrixLED1LED6><MatrixLED1IO6>0</MatrixLED1IO6><MatrixLED2LED6>0</MatrixLED2LED6><MatrixLED2IO6>0</MatrixLED2IO6><MatrixLED1LED7>0</MatrixLED1LED7><MatrixLED1IO7>0</MatrixLED1IO7><MatrixLED2LED7>0</MatrixLED2LED7><MatrixLED2IO7>0</MatrixLED2IO7><MatrixLED1LED8>0</MatrixLED1LED8><MatrixLED1IO8>0</MatrixLED1IO8><MatrixLED2LED8>0</MatrixLED2LED8><MatrixLED2IO8>0</MatrixLED2IO8><MatrixLED1LED9>0</MatrixLED1LED9><MatrixLED1IO9>0</MatrixLED1IO9><MatrixLED2LED9>0</MatrixLED2LED9><MatrixLED2IO9>0</MatrixLED2IO9><MatrixLED1LED10>0</MatrixLED1LED10><MatrixLED1IO10>0</MatrixLED1IO10><MatrixLED2LED10>0</MatrixLED2LED10><MatrixLED2IO10>0</MatrixLED2IO10><MatrixLED1LED11>0</MatrixLED1LED11><MatrixLED1IO11>0</MatrixLED1IO11><MatrixLED2LED11>0</MatrixLED2LED11><MatrixLED2IO11>0</MatrixLED2IO11><MatrixLED1LED12>0</MatrixLED1LED12><MatrixLED1IO12>0</MatrixLED1IO12><MatrixLED2LED12>0</MatrixLED2LED12><MatrixLED2IO12>0</MatrixLED2IO12><MatrixLED1LED13>0</MatrixLED1LED13><MatrixLED1IO13>0</MatrixLED1IO13><MatrixLED2LED13>0</MatrixLED2LED13><MatrixLED2IO13>0</MatrixLED2IO13><MatrixLED1LED14>0</MatrixLED1LED14><MatrixLED1IO14>0</MatrixLED1IO14><MatrixLED2LED14>0</MatrixLED2LED14><MatrixLED2IO14>0</MatrixLED2IO14><MatrixLED1LED15>0</MatrixLED1LED15><MatrixLED1IO15>0</MatrixLED1IO15><MatrixLED2LED15>0</MatrixLED2LED15><MatrixLED2IO15>0</MatrixLED2IO15><MatrixLED1LED16>0</MatrixLED1LED16><MatrixLED1IO16>0</MatrixLED1IO16><MatrixLED2LED16>0</MatrixLED2LED16><MatrixLED2IO16>0</MatrixLED2IO16><MatrixLED1LED17>0</MatrixLED1LED17><MatrixLED1IO17>0</MatrixLED1IO17><MatrixLED2LED17>0</MatrixLED2LED17><MatrixLED2IO17>0</MatrixLED2IO17><MatrixLED1LED18>0</MatrixLED1LED18><MatrixLED1IO18>0</MatrixLED1IO18><MatrixLED2LED18>0</MatrixLED2LED18><MatrixLED2IO18>0</MatrixLED2IO18><MatrixLED1LED19>0</MatrixLED1LED19><MatrixLED1IO19>0</MatrixLED1IO19><MatrixLED2LED19>0</MatrixLED2LED19><MatrixLED2IO19>0</MatrixLED2IO19><MatrixLED1LED20>0</MatrixLED1LED20><MatrixLED1IO20>0</MatrixLED1IO20><MatrixLED2LED20>0</MatrixLED2LED20><MatrixLED2IO20>0</MatrixLED2IO20><MatrixLED1LED21>0</MatrixLED1LED21><MatrixLED1IO21>0</MatrixLED1IO21><MatrixLED2LED21>0</MatrixLED2LED21><MatrixLED2IO21>0</MatrixLED2IO21><MatrixLED1LED22>0</MatrixLED1LED22><MatrixLED1IO22>0</MatrixLED1IO22><MatrixLED2LED22>0</MatrixLED2LED22><MatrixLED2IO22>0</MatrixLED2IO22><MatrixLED1LED23>0</MatrixLED1LED23><MatrixLED1IO23>0</MatrixLED1IO23><MatrixLED2LED23>0</MatrixLED2LED23><MatrixLED2IO23>0</MatrixLED2IO23><MatrixLED1LED24>0</MatrixLED1LED24><MatrixLED1IO24>0</MatrixLED1IO24><MatrixLED2LED24>0</MatrixLED2LED24><MatrixLED2IO24>0</MatrixLED2IO24><MatrixLED1LED25>0</MatrixLED1LED25><MatrixLED1IO25>0</MatrixLED1IO25><MatrixLED2LED25>0</MatrixLED2LED25><MatrixLED2IO25>0</MatrixLED2IO25><MatrixLED1LED26>0</MatrixLED1LED26><MatrixLED1IO26>0</MatrixLED1IO26><MatrixLED2LED26>0</MatrixLED2LED26><MatrixLED2IO26>0</MatrixLED2IO26><MatrixLED1LED27>0</MatrixLED1LED27><MatrixLED1IO27>0</MatrixLED1IO27><MatrixLED2LED27>0</MatrixLED2LED27><MatrixLED2IO27>0</MatrixLED2IO27><MatrixLED1LED28>0</MatrixLED1LED28><MatrixLED1IO28>0</MatrixLED1IO28><MatrixLED2LED28>0</MatrixLED2LED28><MatrixLED2IO28>0</MatrixLED2IO28><MatrixLED1LED29>0</MatrixLED1LED29><MatrixLED1IO29>0</MatrixLED1IO29><MatrixLED2LED29>0</MatrixLED2LED29><MatrixLED2IO29>0</MatrixLED2IO29><MatrixLED1LED30>0</MatrixLED1LED30><MatrixLED1IO30>0</MatrixLED1IO30><MatrixLED2LED30>0</MatrixLED2LED30><MatrixLED2IO30>0</MatrixLED2IO30><MatrixLED1LED31>0</MatrixLED1LED31><MatrixLED1IO31>0</MatrixLED1IO31><MatrixLED2LED31>0</MatrixLED2LED31><MatrixLED2IO31>0</MatrixLED2IO31><MatrixLED1LED32>0</MatrixLED1LED32><MatrixLED1IO32>0</MatrixLED1IO32><MatrixLED2LED32>0</MatrixLED2LED32><MatrixLED2IO32>0</MatrixLED2IO32><MatrixLED1LED33>0</MatrixLED1LED33><MatrixLED1IO33>0</MatrixLED1IO33><MatrixLED2LED33>0</MatrixLED2LED33><MatrixLED2IO33>0</MatrixLED2IO33><MatrixLED1LED34>0</MatrixLED1LED34><MatrixLED1IO34>0</MatrixLED1IO34><MatrixLED2LED34>0</MatrixLED2LED34><MatrixLED2IO34>0</MatrixLED2IO34><MatrixLED1LED35>0</MatrixLED1LED35><MatrixLED1IO35>0</MatrixLED1IO35><MatrixLED2LED35>0</MatrixLED2LED35><MatrixLED2IO35>0</MatrixLED2IO35><MatrixLED1LED36>0</MatrixLED1LED36><MatrixLED1IO36>0</MatrixLED1IO36><MatrixLED2LED36>0</MatrixLED2LED36><MatrixLED2IO36>0</MatrixLED2IO36><MatrixLED1LED37>0</MatrixLED1LED37><MatrixLED1IO37>0</MatrixLED1IO37><MatrixLED2LED37>0</MatrixLED2LED37><MatrixLED2IO37>0</MatrixLED2IO37><MatrixLED1LED38>0</MatrixLED1LED38><MatrixLED1IO38>0</MatrixLED1IO38><MatrixLED2LED38>0</MatrixLED2LED38><MatrixLED2IO38>0</MatrixLED2IO38><MatrixLED1LED39>0</MatrixLED1LED39><MatrixLED1IO39>0</MatrixLED1IO39><MatrixLED2LED39>0</MatrixLED2LED39><MatrixLED2IO39>0</MatrixLED2IO39><MatrixLED1LED40>0</MatrixLED1LED40><MatrixLED1IO40>0</MatrixLED1IO40><MatrixLED2LED40>0</MatrixLED2LED40><MatrixLED2IO40>0</MatrixLED2IO40><MatrixLED1LED41>0</MatrixLED1LED41><MatrixLED1IO41>0</MatrixLED1IO41><MatrixLED2LED41>0</MatrixLED2LED41><MatrixLED2IO41>0</MatrixLED2IO41><MatrixLED1LED42>0</MatrixLED1LED42><MatrixLED1IO42>0</MatrixLED1IO42><MatrixLED2LED42>0</MatrixLED2LED42><MatrixLED2IO42>0</MatrixLED2IO42><MatrixLED1LED43>0</MatrixLED1LED43><MatrixLED1IO43>0</MatrixLED1IO43><MatrixLED2LED43>0</MatrixLED2LED43><MatrixLED2IO43>0</MatrixLED2IO43><MatrixLED1LED44>0</MatrixLED1LED44><MatrixLED1IO44>0</MatrixLED1IO44><MatrixLED2LED44>0</MatrixLED2LED44><MatrixLED2IO44>0</MatrixLED2IO44><MatrixLED1LED45>0</MatrixLED1LED45><MatrixLED1IO45>0</MatrixLED1IO45><MatrixLED2LED45>0</MatrixLED2LED45><MatrixLED2IO45>0</MatrixLED2IO45><MatrixLED1LED46>0</MatrixLED1LED46><MatrixLED1IO46>0</MatrixLED1IO46><MatrixLED2LED46>0</MatrixLED2LED46><MatrixLED2IO46>0</MatrixLED2IO46><MatrixLED1LED47>0</MatrixLED1LED47><MatrixLED1IO47>0</MatrixLED1IO47><MatrixLED2LED47>0</MatrixLED2LED47><MatrixLED2IO47>0</MatrixLED2IO47><MatrixLED1LED48>0</MatrixLED1LED48><MatrixLED1IO48>0</MatrixLED1IO48><MatrixLED2LED48>0</MatrixLED2LED48><MatrixLED2IO48>0</MatrixLED2IO48><MatrixLED1LED49>0</MatrixLED1LED49><MatrixLED1IO49>0</MatrixLED1IO49><MatrixLED2LED49>0</MatrixLED2LED49><MatrixLED2IO49>0</MatrixLED2IO49><MatrixLED1LED50>0</MatrixLED1LED50><MatrixLED1IO50>0</MatrixLED1IO50><MatrixLED2LED50>0</MatrixLED2LED50><MatrixLED2IO50>0</MatrixLED2IO50><MatrixLED1LED51>0</MatrixLED1LED51><MatrixLED1IO51>0</MatrixLED1IO51><MatrixLED2LED51>0</MatrixLED2LED51><MatrixLED2IO51>0</MatrixLED2IO51><MatrixLED1LED52>0</MatrixLED1LED52><MatrixLED1IO52>0</MatrixLED1IO52><MatrixLED2LED52>0</MatrixLED2LED52><MatrixLED2IO52>0</MatrixLED2IO52><MatrixLED1LED53>0</MatrixLED1LED53><MatrixLED1IO53>0</MatrixLED1IO53><MatrixLED2LED53>0</MatrixLED2LED53><MatrixLED2IO53>0</MatrixLED2IO53><MatrixLED1LED54>0</MatrixLED1LED54><MatrixLED1IO54>0</MatrixLED1IO54><MatrixLED2LED54>0</MatrixLED2LED54><MatrixLED2IO54>0</MatrixLED2IO54><MatrixLED1LED55>0</MatrixLED1LED55><MatrixLED1IO55>0</MatrixLED1IO55><MatrixLED2LED55>0</MatrixLED2LED55><MatrixLED2IO55>0</MatrixLED2IO55><MatrixLED1LED56>0</MatrixLED1LED56><MatrixLED1IO56>0</MatrixLED1IO56><MatrixLED2LED56>0</MatrixLED2LED56><MatrixLED2IO56>0</MatrixLED2IO56><MatrixLED1LED57>0</MatrixLED1LED57><MatrixLED1IO57>0</MatrixLED1IO57><MatrixLED2LED57>0</MatrixLED2LED57><MatrixLED2IO57>0</MatrixLED2IO57><MatrixLED1LED58>0</MatrixLED1LED58><MatrixLED1IO58>0</MatrixLED1IO58><MatrixLED2LED58>0</MatrixLED2LED58><MatrixLED2IO58>0</MatrixLED2IO58><MatrixLED1LED59>0</MatrixLED1LED59><MatrixLED1IO59>0</MatrixLED1IO59><MatrixLED2LED59>0</MatrixLED2LED59><MatrixLED2IO59>0</MatrixLED2IO59><MatrixLED1LED60>0</MatrixLED1LED60><MatrixLED1IO60>0</MatrixLED1IO60><MatrixLED2LED60>0</MatrixLED2LED60><MatrixLED2IO60>0</MatrixLED2IO60><MatrixLED1LED61>0</MatrixLED1LED61><MatrixLED1IO61>0</MatrixLED1IO61><MatrixLED2LED61>0</MatrixLED2LED61><MatrixLED2IO61>0</MatrixLED2IO61><MatrixLED1LED62>0</MatrixLED1LED62><MatrixLED1IO62>0</MatrixLED1IO62><MatrixLED2LED62>0</MatrixLED2LED62><MatrixLED2IO62>0</MatrixLED2IO62><MatrixLED1LED63>0</MatrixLED1LED63><MatrixLED1IO63>0</MatrixLED1IO63><MatrixLED2LED63>0</MatrixLED2LED63><MatrixLED2IO63>0</MatrixLED2IO63><MatrixLED1LED64>0</MatrixLED1LED64><MatrixLED1IO64>0</MatrixLED1IO64><MatrixLED2LED64>0</MatrixLED2LED64><MatrixLED2IO64>0</MatrixLED2IO64></Device3></PoKeys>
nick7251
Posts: 108 Joined: Tue Dec 17, 2019 6:28 pm
Post
by nick7251 » Wed Jun 17, 2020 4:00 pm
acourtjester wrote: ↑ Wed Jun 17, 2020 3:03 pm
The adding of the G4 P0.2 is a band aid when put into the G-code. I added it to my Post Processor as a fix for me alone but I had the THC signal problem also. So I have abandoned that BOB and Plug-in for Mach 3 and doug up a computer with a parallel printer port and went back to an spare BOB I had. I am dropping out of the picture on this post as there are others here with more experience with the Pokey stuff I don't want to add confusion. Keep on plugging at it and thing will work out.
Thanks so much acourtjester for you help. I always learn great things from you. If we say something that peaks your interests again, please don't hesitate to jump back in.
robertspark
Posts: 1821 Joined: Mon Jun 12, 2017 6:43 pm
Post
by robertspark » Wed Jun 17, 2020 5:19 pm
Nick,
try this ( I have a few other suggestions too [not related to this issue]... but do you have a THC??)
in case you are curious .... pdf page 37 sort of explains it
https://machmotion.com/documentation/So ... Manual.pdf
basically it resets the offsets you've applied (all those G92 Z0 etc etc are cleared....) ... or it may do (it depends on how its been set up..... and how the plugin works with it).... its not needed for Plasma IMO
nick7251
Post
by nick7251 » Wed Jun 17, 2020 5:41 pm
robertspark wrote: ↑ Wed Jun 17, 2020 5:19 pm
Nick,
2020-06-17 22_15_15-C__Program Files (x86)_SheetCam TNG Development_posts_Mach3 plasma.scpost - Edit.png
YOU FOUND IT!!! I turned that setting off and DRO stayed put at the end of the cycle. Thank you so much.
Yes I do have a THC. It is a Proma 150. My next mountain to tackle is to get that set up an working.
robertspark
Post
by robertspark » Wed Jun 17, 2020 5:47 pm
nick7251 wrote: ↑ Wed Jun 17, 2020 5:41 pm
Oh dear!
nick7251
Post
by nick7251 » Wed Jun 17, 2020 5:51 pm
robertspark wrote: ↑ Wed Jun 17, 2020 5:47 pm
Oh dear!
Haha. Came with the table. It wouldn't take too much to talk me into using something else. But I am cost conscientious.
robertspark
Post
by robertspark » Wed Jun 17, 2020 5:57 pm
nick7251 wrote: ↑ Wed Jun 17, 2020 5:51 pm
what do you value your time at currently? $50/hr....$100/hr.....$200/hr .... or free....
Look.... have a go at it.... if it works great.... if it disappoints you (as it did me).... do the neighbourly thing and ...err pass it on to someone else via ebay..... who will pop up here asking for help
seriously I'll try to help (my posts on the proma are everywhere....).... the setup of another THC would be similar anyway so what you learn now will be no loss
nick7251
Post
by nick7251 » Wed Jun 17, 2020 6:03 pm
robertspark wrote: ↑ Wed Jun 17, 2020 5:57 pm
Do you have recomendations for one that would work better with my current setup? That being Windows 10, Mach3, Sheetcam, Pokeys56cnc. I already know that windows is not an RTC and I should use linux...
I gave linuxcnc a short go. I was lost. Always been a windows guy, so it was hard to understand.
Also I don't believe Pokeys is supported in linuxcnc. I just bought the pokeys board, so I want to really get it working.
robertspark
Post
by robertspark » Wed Jun 17, 2020 6:32 pm
here are a few more suggestions....
Note: the persistent jog can be an issue sometimes with plugins for MPG's.... in my experiance (on the general config tab.... but if it works for you then great)
robertspark
Post
by robertspark » Wed Jun 17, 2020 6:35 pm
One more to watch.... it can make the THC work all the time.... especially the proma given there is no way to disable it without adding relays and other hacks....
