Name Sign with Date Est
Re: Name Sign with Date Est
I couldn't open this in inkscape. I got a failed to load error.
Same thing for me. Inkscape doesn't like many types of dxf files and leaves you limited. Try converting your dxf files to svg files before opening them in Inkscape with https://www.dxfconverter.org/ It has worked great for me and worked on this one. See attached svg
Thanks!!!
thanks Plasmanewbie that conversion site worked great on a file I was having a problem with, did nee to use the simplify function in Inkscape to reduce the nodes.
Thanks for sharing.
Very nice thanks for the share.
when importing the file into inkscape, which do I select on DXF input and SVG input? I am new to inkscape.
If you are looking at the original post, the attachment is in dxf format. So I would imagine you would select dxf. Otherwise try converting to SVG format as was previously suggested.kashindustriesllc wrote: ↑Fri Jul 03, 2020 3:34 am when importing the file into inkscape, which do I select on DXF input and SVG input? I am new to inkscape.
This will make a great gift for our daughter and husband in their new home.
Thank you very much !
You're welcome! It's not my design, but happy to help.
- gslavik
Nice work, Thank you for sharing!
