Magnetic breakaway and settings
- 4.5 Star Member
Re: Magnetic breakaway and settings
For those who don't have a magnetic breakaway yet but do have a floating head for touch off, you could add a second microswitch on the floating head.
I installed one and have it activate just 1mm above the touch off microswitch. It's wired into the estop circuit. It has shut down my system on numerous occasions when for whatever reason the torch touched the metal when it was not supposed to.
It won't be as protective as a breakaway. For instance, purely sideways pressure will not lift the floating head, but it's better than no safeguard at all.
I also look at my cut paths and try to never have the torch pass over a part that has already been cut. That includes a part it has just finished, e.g. the lead in/out is on the left of the part and after the cut is done the torch moves to the right, crossing over the part. Next thing is have your safe Z quite high so immediately after a lead out the torch raises quite high before rapiding to the next position.
Sheetcam sticks a "go back to zero" command at the end of my gcode. I always delete that so at the end of the cut the torch raises to safe z and doesn't go anywhere. One day I'll modify the post processor so it doesn't put that command there.
Keith
Keith
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
If you have the Feather Touch the Z swtich should be wire for ESTOP NOT a limit because limits are ignore if you are doing a REF (homing move) and the ohmic sensor misses
- East German
Hallo,
here is my Magnetic breakaway.
Works fine.....The brackets are made of plastic.
Regards Peter
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Only time I have needed a break away is when I try to fit parts in where I shouldn't and don't ck the parameters of the cuts on the material cause of distractions or simple carelessness on my part. Have done that twice over the past 7 yrs.
Last time being two nights ago Need two new pces for the duramax I just hooked up
Need a do not disturb sign up when I'm cutting!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- Capstone
So I looked more closely at the torch with the damaged sleeve removed. It makes sense now. Thanks Steve
Here's an illustration. Hope it helps someone else too.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
- steel 35
My question Is for a additional Micro switch; (Breakaway) wired in place of the Feather touch jumper, so If the breakaway releases will the limit shut it down accordingly?tcaudle wrote:If you have the Feather Touch the Z swtich should be wire for ESTOP NOT a limit because limits are ignore if you are doing a REF (homing move) and the ohmic sensor misses
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- _Ogre
that is the best advice. i too edit my start starts to where the torch heads away from any possible tip up.beefy wrote:I also look at my cut paths and try to never have the torch pass over a part that has already been cut. That includes a part it has just finished, e.g. the lead in/out is on the left of the part and after the cut is done the torch moves to the right, crossing over the part. Next thing is have your safe Z quite high so immediately after a lead out the torch raises quite high before rapiding to the next position.
Keith
i looked at the post for the last 0,0 command. i don't see it, you may need to edit g-code for ever
there's a lot of magic in those post processors, way beyond my level of intelligence
if i'm doing a repeat cut, i edit g-code to move off the material for reloading material
an ogre smiley how cool!
- 4.5 Star Member
I'm sure I modified a post processor a long time ago but with changing PCs etc that one "vanished". Normally I just ask Les or one of the other lads and they just tell me where to look in the post processor and what to change, I don't really know the Lua programming. I generally always have a glance through the gcode after I've generated the tap file, just to check there's no obvious problems. Feels like I've already been deleting that last line forever though_Ogre wrote: i looked at the post for the last 0,0 command. i don't see it, you may need to edit g-code for ever
Keith.
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
I have a candcnc DTHC II and when it stops with e-stop, the motors are still on and im not loosing any steps.
i just replace torch, hit reset, then continue cutting where it stopped.
I added a switch to my breakaway and will wire it to the estop.
Very nice. We have a burntable. They sell the torch holders for ~$35. They are not truly break-away, so I re-designed the holder for magnets. I've been through three final printed iterations and finally found one where the mag force is right. The switch is next. Very good ideas.
Are you going the market the holder????
Or maybe post the print file??
have fun
Tom
have fun
Tom
To delete the go to home command at the end of the job:
Click:
Options---> machine--->post processor
at the bottom, click edit post, it will open a new window.
Scroll down until you find something like this:
function OnFinish()
finalCut = true
endZ = safeZ
OnRapid()
endX = 0
endY = 0
offX = 0
offY = 0
offZ = 0
OnRapid()
post.Text(" S900 \n")
post.Text(" M22 \n")
post.Text(thcOffCode)
post.Text(" (DTHC is off)\n");
post.Text (" M05 M30\n")
And delete the ones i have put in red
I reccomend saving under a different name, so you can always revert back to your original post.
Click:
function OnFinish()
finalCut = true
endZ = safeZ
OnRapid()
endX = 0
endY = 0
offX = 0
offY = 0
offZ = 0
OnRapid()
Can't upload the files. The forum doesn't take STL's. It gets fixed, I'll put 'em up. I have no plans on marketing.acourtjester wrote:Are you going the market the holder????
have fun
Tom
I think you can put the file in a Zip format and upload it that way
have fun
Tom
have fun
Tom
smart guy, right there.
Check out www.plasmatorchprotectionsystems.com
We have there magnetic breakaway on our Torchmate CNC and love it.
So if I understand this correctly, what you are doing is triggering a feed hold, vs an estop, in Mach? That way you don't lose position? The downside being that the torch wouldn't be shut off. Although I guess that could be triggered as well?East German wrote:Hallo,
Port& Pins Input Signal........OEM Trig......select a free Input Pin (see Pic)
Config....System Hotkeys.....External button..........1001 Pauses
1000 Start
1007 zero All
1021 Reset
160 Regen Toolpath
Hope This Helps!
Regards Peter
- East German
Hallo
the OEM Code 225 makes the Plasma Relais is of, see the Picture.
Works very well on my Plasma Table Feedhold+Torch off.
Peter
Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Check out www.plasmatorchprotectionsystem.com . we have been using there unit for a number of years on a Torchmate CNC it has saved our machine torch many times, never damaged a machine torch yet after literally thousands of hours use .
WHY NOT USE A COLLISION SENSOR MOUNTED BEHIND THE TORCH TO IMMEDIATELY STOP THE TORCH HEAD AND PREVENT ANY DAMAGE OR LOSS TO THE TORCH
Depends on how you have the FT-01 wired . The LIMIT jumper on the FT-01 has been changed to E-Stop function IF you have the mechanical swtich setup NC and assigned to the e-stop string. inserting the Breakaway sensor into the string then becomes easy by just pulling the jumper on the FT-01 and making it part of the E-stop circuit . Has to be wired on the normally open of the switch if its designed to be activated when the plate is in place and opens when it breaks away.
