4x4 welding table help
Wildnorth
Re: 4x4 welding table help
Post by Wildnorth »
Faulknerm wrote:Yesterday I built a fixturing table from 15" wide 3/8 thick channel. I made some upright posts from 4x4 x .250 tubing for a motorcycle frame jig. I've also got some brackets for the kneck tube adjustment. Once I finish it all up I'll make a new post to share.
How did you make out with the motorcycle jig?
tylerd
Post by tylerd »
These are the first items I cut on my table, I got a little bit of bevel but they should work out great, here are the pics, and thanks for the awesome files and posts!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
Reid53
Post by Reid53 »
hemichargersrt8 wrote:The next square is built in the same way, all puzzle tabbed and has a welding assembly template included as well.
Your squares look EXACTLY like Fireball Tool products. Have you gotten permission to use his designs? You should have at least given him credit for his design.
nalin400m
Post by nalin400m »
#PATENTPENDING
https://www.fireballtool.com/
Nalin Manufacturing, LLC
Hypertherm Powermax 85
Bulltear Starlab 4'x8'
bbkf2009
Post by bbkf2009 »
I can tell just by comparing the fire ball tools and hemichargers they aren't exactly the same(hemichargers has bolt holes n the side, and no tabs in the corners). Sure they're similar but it's a damn square.... hemicharger put a ton of thought and time into everything he's contributed here. I doubt those two guys are the only ones who've drawn squares like these
tylerd
Post by tylerd »
bbkf2009 wrote:I can tell just by comparing the fire ball tools and hemichargers they aren't exactly the same(hemichargers has bolt holes n the side, and no tabs in the corners). Sure they're similar but it's a damn square.... hemicharger put a ton of thought and time into everything he's contributed here. I doubt those two guys are the only ones who've drawn squares like these
Could not have said it better myself!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
steel 35
Post by steel 35 »
nalin400m wrote:
Reid53 wrote:
#PATENTPENDING
Thanks for sharing that I can use both designs now and come up with something that will work for my custom table :D
Special thanks for sharing how to draw such a complicated puzzle and make things work.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
hemichargersrt8
Post by hemichargersrt8 »
What has made this thread so valuable to all members has been the open exchange and discussion of ideas.
Carpenters and later metal fabricators, have been joining two or more pieces of wood or steel to form a 90 degree angle since the beginning of time.
Positioning two known angle devices to create a third angle probably came 5 minutes later, HMMM, I wonder if it is too late to apply for a patent?
ryanjg117
Post by ryanjg117 »
Not a contributing member yet, so can't see the files, but curious if this has been redesigned for 1/4" thick plate? (I know others have already asked, but I didn't see an answer.)
Also, I'd love to get it laser cut but sadly down own one (or a plasma table). Any feel for what one might pay to have this cut at a shop? I'm located in the PNW.
radicalrescue
Post by radicalrescue »
located in the PNW. wear is this ..
SNLLC
Post by SNLLC »
hemichargersrt8 wrote: Fri Nov 24, 2017 10:38 pm Thanks and yes, the new table plans I posted some time ago use 16mm (.63") holes.
http://plasmaspider.com/viewtopic.php?f=6&t=23989
So just to clarify, all the files you listed for the table and the brackets in this thread use 5/8" holes but the files on the other thread you linked to in this post are setup for 16mm?
Thanks for all the work you've done on this. Wish I would have seen this post about $2k in weld table ago...
dholt87
Post by dholt87 »
Thank you everyone for the incredible files!
kbenz
Post by kbenz »
awesome. thanks for the files on the squares
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
3DwaterjetXD
Post by 3DwaterjetXD »
Definitely look like some spare time cutting going on here. We are hoping to add some of these pieces to our old table that has just has two holes drilled for an old vise - take on / take off.... I think my son won't know what to use all of them for so he'll have to just start welding stuff up out of scrap metal - lol. A big Thank you for the sharing. Would love to make this out of 3/8' or even 1/2" - no bracing required - just pure heat sink
MS76
Post by MS76 »
A big thank you to Hemi and all members!
seajinx
Post by seajinx »
acourtjester wrote: Tue Apr 04, 2017 11:43 am Here is the 2' X 4' table I have and the clamps I cut from the file here. I welded a hanger rail under the table for clamp storage.
Can you direct me to the file for the clamps, I can't seem to find it, no matter what i type in search.
James79
Post by James79 »
seajinx wrote: Sat Mar 14, 2020 12:21 pm
Its on page 2 of this thread
Biltstrong
Post by Biltstrong »
hemichargersrt8 wrote: Sat Jan 07, 2017 8:27 pm here is one version I have drawn. I laser cut and carefully welded to reduce excessive heat. Because of the puzzle tabs, the table assembled very flat and stable. I will upload the accessories when I get a chance.
fixture top 29-5X47-5 375 ms 1 pce.dxf
fixture rib short 29-5X47-5 187 ms 5 pcs.dxf
fixture rib long 29-5X47-5 187 ms 4 pcs.dxf
This is awesome and my first time commenting on anything. I see the post is rather old. I love the clamps and just now getting into the industry. Ive been working on truck for years. Taking plasma cutting up on the side is a ton of fun. However, my plasma table is only 4x4 for now. Is there a welding table that is 4x4? Again, I see this post is over 3 years old, just wondering if something new has come about?
Thanks for the help in advance.
jmartinez
Post by jmartinez »
Late to the party. Nice table thanks for the share. What size material are you guys using for the table top?
jmartinez wrote: Wed Feb 01, 2023 1:20 pm Late to the party. Nice table thanks for the share. What size material are you guys using for the table top?
I have several store bought tables and the tops are 5/8" thick. I think anything 1/4" and thicker would be fine, depending on the overall size and intended use.
