I even have the feather touch mod inside the box.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
acourtjester wrote:could you have the Dir + and - wires reversed on those drivers.
Are you using the same drive ratio on the Y & A as the X axis?
Thanks Sean, I can't see why some users have the voltage disparity, not yet correlated it with what THC they are running though, might be interesting to find out. If its just a CandCNC thing, it could be adjusted but as you say its not critical, just causes issues when posting on the 'net as the first thing most will say is "your voltage is off....."SeanP wrote:Glad its going well Dave, well it's looking good to me at this stage.
I wouldn't worry about voltage, just find your own settings and work with those, seen a few people mention it on the 45, even once you get a baseline for a certain thickness I seem to have to tweak +3 or 4 volts as the consumables wear usually.
The way I get around that divot on a outside cut like that is to use a lead out an hold the piece as it's about to drop, I have a old hard drive magnet on a stick to catch parts.
For holes I use the torch off, but still find it better to still use a short 2 -3mm lead out just to be sure it's moving away from the part, no overburn but have the torch off around .065mm 'before end' using that seems to cover most thicknesses really.
Yeah its the worst part of getting a new tableacourtjester wrote:do a search here on divots Jim Colt has posts giving info on what to do there.
Nozzle blow out may be a bad pierce.
Working with cut rules (path rules) should help with other things. As you say the wavy cuts are fixed you may need to just fine turn your operational configuration to get it where you are happy.
Yes 45adavek0974 wrote: SeanP, thanks, I gather thats at 45A??? Will try again tomorrow.
Sorry didn't get a chance today, away on hols in the morning, you know what it's likeSeanP wrote: I have a few bits to cut tomorrow, if I get chance I will try that 35mm sq just for comparison.
