i ended up with a 5 pack of hypertherm 85 amp consumables
any reason i can't use the 85 amp nozzle for cutting at 65 amps in on a pm 65?
i hate to toss them
85 nozzle on pm 65 torch?
- _Ogre
an ogre smiley how cool!
Re: 85 nozzle on pm 65 torch?
I'm sure Jim Colt can provide the technical details, but I bet the 85 amp nozzles will change the arc's intensity to make a difference in the cut quality. Can you use them? I would probably try one just to see, but.....
Don't do it unless you want bad cuts. The orifice hole on a 85 consumable is larger and will give you a weaker plasma beam.
- _Ogre
thanks, figured that was the case
The orifice is larger on the 85 amp nozzles as compared to 65 amp. They will work, but slower cut speeds and more dross is likely.
Jim Colt Hypertherm
Jim Colt Hypertherm
