It is currently Sat Oct 20, 2018 11:17 am
Starting a new oven build!
Cracker Red
Re: Starting a new oven build!
Postby Cracker Red » Fri Feb 13, 2015 8:54 am
Question for you OldSarge...
If you built another oven would you hang the lights from the ceiling or are you happy with them on the sides?
Did you use those porcelain bulb bases inside the housings or something else?
I'm putting together a 4x4x6 (the size of the local sheets are 4x10) in a similar fashion to yours.
CNCCAJUN
Postby CNCCAJUN » Fri Feb 13, 2015 11:21 am
Do you guys leave your oven on at a low temp (80F to 90F) to keep moisture level down?
Guy near me that powder coats swears it cuts his warm up time significantly & he has zero moisture issues . .
Steve :D
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
TMC
Postby TMC » Fri Feb 13, 2015 2:18 pm
Oldsarge very impressive build!! Congrats
Talbot Metal Crafting
DynaTorch 4x4 SuperB
Hypertherm PMX 85
Corel 7X
Solid Edge
SheetCam
Easton, Maryland
shinertx
Postby shinertx » Sat Feb 14, 2015 1:31 pm
Oldsarge wrote:Another good day in the shop! Didn't quite get everything finished I wanted, but did get everything finished I could! :lol:
Got a good deal on 6 feet of heat proof wiring, some glass for the access door, and some other bits & pieces I needed. Bill, sorry I missed you! I was back just shortly after 10, so we probably passed each other on the road!
Got the inside sheeted today, put the 5x10 sheets on the table for the back, and cut out the hole for the fan, and a grate for the return air. Fit like a glove! Then I cut the sides, and included a hole to countersink the light fixtures... Saw this on a build on Ted's site and liked the way it looked, and the fact that no bulbs will be hanging out there for me to break! Installed the fan, and blocked in and sealed the channel to make it air tight for the return air. Also sealed the inside seams with 600 degree caulking.
Tomorrow I'll plus up the hinge corners to support the door, and will frame out the door as well. Hoping to be able to get to some of the wiring as well. Sure wish I didn't mess up on the sheet count!
Oldsarge,
What size of blower fan did you use.
A few more days like today & I should have it wrapped up! Can't wait to fire it up & test it out.... Night all!
Oldsarge
Plasmacam 4x4
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
Bobcat320
Postby Bobcat320 » Thu Nov 19, 2015 4:55 pm
akpilot wrote:looking good !!! I built a 4x4x6 oven last year (propane) They are a lot of work but well worth it..
Hello AKPilot,
I realize this is an old thread, but was wondering if would share how you built your propane oven? I am still looking to build a larger oven, and had not considered propane, may be a good way for me to go!
Carl
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
poppopsworkshop
Postby poppopsworkshop » Thu Jul 14, 2016 2:47 pm
I like the control box. Do you have info on it so I could build one or purchace one complete ?
LakeCruiser
Postby LakeCruiser » Tue Sep 06, 2016 5:29 pm
Ole Sarge, Can you shoot us a pic of the access door. I have reached that point and need some ideas.
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
Return to “Powder Coat”
