Steel Plate Lifting Clamps??
Im looking for a diy design on building a set of lifting clamps for lifting the sheets up onto the table "Or" a reasonably priced set to purchase. Everything Ive found store bought has been stupid expensive
Re: Steel Plate Lifting Clamps??
Vertical or horizontal lift? For vertical lifting, I got one of these, works great for up to 1/2". (that's as thick as I've tried to lift, and pretty much the max that will fit in it) Bought mine from Amazon, looks like they're still the best price now.
http://www.amazon.com/Vestil-EPC-10-Ver ... B0052PKQPW
For horizontal lifting, the clamps I use look like this:
4 of them on chains, with two spreaders to keep them from sliding together. One pair of chains goes on each side of the plate, and it works perfectly.
- East German
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
East German wrote:Hallo,
see you here:
http://www.plasmaspider.com/viewtopic.p ... amp#p68207
Regards Peter
That's it, thanks you..
