I took a scroll pattern from google search and did a trace. Moved vector away to one side highlighted lines and removed all color. I then took the vector over top of the original to remove extra lines and double line. I don't know what I did then but I cannot move the vector from the original.I have attached the original and the pattern I was trying to make.
Any help to let me know what I did wrong would be greatly appreciated. This has not happened before.
I tried to ungroup but no go.
I wanted to make a corner bracket so I was going to split it on a 45 degree angle.
Thank you in advance
Gary
Help with trace
Help with trace
- Attachments
- Original jpeg
- Trivet5a.jpg (53.77 KiB) Viewed 1136 times
- scroll.cmx
- Scroll pattern
- (475.73 KiB) Downloaded 82 times
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
- wilber
Re: Help with trace
i norm just import, trace, delete import and save as dxf.
I am not sure on the program you used. I use vcarve and aspire for tracing and drawing.
- Attachments
- scroll.dxf
- (711.36 KiB) Downloaded 107 times
Re: Help with trace
Thank you for the trace! I used Corel X6.wilber wrote:i norm just import, trace, delete import and save as dxf.
Normally I would do the same procedure you describe. When I did the trace, some of the curves were out of round so I placed the vector over the original to move the nodes to the correct position so the curves were smooth.
Thank you for the help.
gary
Sheetcam, Mach 3
Sheetcam, Mach 3
- wilber
Re: Help with trace
any time i can help just let me know
- 4.5 Star Member
Re: Help with trace
I've got X5 but it wouldn't open the file.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Re: Help with trace
Keith,beefy wrote:I've got X5 but it wouldn't open the file.
Keith.
I added a CDR file for you to see if it will open for you. If it does, see left side is colored from original under neath of vector.
I just can't figure out what I may have done.
I did re do the trace and it worked out pretty good. Wilber did one and mine looks close to the one he did.
Thanks for any suggestions,
Gary
- Attachments
- scrollA.cdr
- (573.89 KiB) Downloaded 96 times
Sheetcam, Mach 3
Sheetcam, Mach 3
- 4.5 Star Member
Re: Help with trace
Sorry Gary,
that one wouldn't open in my X5 either. I was looking forward to seeing if I could figure it out too.
Keith.
Keith.
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
