sheet cam ?
abmagrum
sheet cam ?
Post by abmagrum »
On import
If a object appears onto the right of the sheetcam table .
how do you get it to appear on the left?
where its suppose to be?
thanks
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
urbnsr
Re: sheet cam ?
Post by urbnsr »
When you import in SheetCam, a window comes up. The drawing position part of that window can control where it displays on SheetCam's table. Is the lower left radio button (or any left option) selected in your case?
HTH
Paul
abmagrum
Re: sheet cam ?
Post by abmagrum »
hi, Urbnsr
it only happens on this one file. I have the left corner checked .
I clicked on metric and it moved 3/4 's the way to were it should be.
maybe its just a bad file?
thanks
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
muzza
Re: sheet cam ?
Post by muzza »
If you check the file there is probably a dot at the lower left point that you need to remove.
Murray
_Ogre
Re: sheet cam ?
Post by _Ogre »
on the bottom of the sheetcam screen is your mouse x,y coordinates and pos x,y,a. (position x,y,a)
with pos x,y,a you can move the part x, y or rotate.
rarely does a dxf file come up that i don't have to tweek these pos x,y,a settings.
i draw everything with origin at 0,0
when i import into sheetcam pos will read oddball random figures with 90* rotation.
i figured it was bug in sheetcam.
it is also handy if you have a single part of many that you want to cut separately
using sheetcam you can move the object to a new layer, reset pos x,y and
rotate to make the object appear at 0,0 and easy to cut
abmagrum
Re: sheet cam ?
Post by abmagrum »
thanks guys :)
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
Largemouthlou
Re: sheet cam ?
Post by Largemouthlou »
The last few times I used SC at the shop on some of the imports,the drawing would show on the left side.. I checked the drawings and there was nothing extra in them. There were no other start points then the drawing so I just used the nesting button and move the drawing to the right and all was fine. Still not sure what caused those drawings to go to the left, but Les has been doing some updates..
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
urbnsr
Re: sheet cam ?
Post by urbnsr »
A release or two ago of the development version did shift (some of) my drawings a bit to the right. I was in too much of a hurry to look into it and selected "drawing origin" in the drawing position of the import window.
Paul
Return to “SheetCam”
