i am new to cnc in general, a total newb to cnc plasma cutting. just did a test of our new bulltear 4x8 w/ dthc, mach3 bladerunner and powermax 65. the table was a turn key and came loaded with all the mach3 setup done. the torch fired and cut the shapes i had drawn just out of scale. i am fairly well versed in autocad 2000 and use it for all technical drawings. i had drawn simple shapes ''plasma test'' 2- 2'' circles and 2- 2'' squares and an arc thingy. the circles and squares cut great, they were just 4.5'' across instead of 2'' as drawn. any ideas of what i did wrong?
plasma test
![Image](http://i306.photobucket.com/albums/nn255/_ogre/Misc/Plasma/plasmatestModel1copy_zps01d51beb.jpg)
so i moved on to my first real project. ''mrt bronco3'' is a couple of simple signs to be cut out of 10 ga mild steel. it took me a few times to get all of the arcs drawn to make 1 pierce per letter, when i run sheetcam it has the outside of one sign cut first then the letters. then sheetcam jumps around cutting some letters in the 2nd sign then some letters in the 3rd sign, then the outside of one sign and then the rest of the letters. how do i move pierce point and the layout of the cuts?
mrt bronc3
![Image](http://i306.photobucket.com/albums/nn255/_ogre/Misc/Plasma/mrtbronco3Model1copy_zps88ce9cdf.jpg)
i'll upload both plasma test and mrt broco3 dxf files
