A few Q on my Plasmacam.
Ok so Im running Pc v3.11
1. I keep getting run over from my lead outs/ lead in's and its making my projects look crappy !
2. I'm cutting 16.g hot rolled and Im getting a good bit of bow up when cutting how do I combat this without a water table?
I left my plasma cam book at the in-laws and for some reason I cant get the video manuel to work. Im trying to get my diving problem figured out.... Height pierce 0.02 rapid travel 0.05 Arc Vshift 0.999 zshift -0.2 .... It will go down pierce come up and cut then dip then up then close then so close Ill get scratch marks on the surface some times it ll shift the whole 4x4 sheet .
Re: A few Q on my Plasmacam.
Im running a HP 380.... Its set at 27amps running cut speed between 90-114 and getting a good deal of dross.
I have been going through some post and I think I have Q2. taken care of.
- geo4932
Your diving problem is caused by the pierce height being too low. It is supposed to be approx 2X the cut height.
Your pierce should be .150
Rapid travel acceleration is always .1
Cut height .063
Start the Arc Voltage Shift at .8 You will have to adjust the Arc Voltage Shift to get the correct cut height. If the torch is cutting too close, then increase the Arc voltage shift. If the torch is too high, then decrease the arc voltage shift.
George
Cut height .063
George
Thanks for the info things have been really slow due to it being -15 for a daily high and my air compressor cant run unless the ambient temp is above 32*. I really like my a/c but if I would of known about the temp thing when I was buying it I would of gone in a different direction !
Hang a small space heater in front of it to warm the oil.MIFab wrote:Thanks for the info things have been really slow due to it being -15 for a daily high and my air compressor cant run unless the ambient temp is above 32*. I really like my a/c but if I would of known about the temp thing when I was buying it I would of gone in a different direction !
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
My compressor is outside of my shop (noise abatement!) and has been for 5 years. It starts hard on mornings like today (-5 F here in NH), but once it runs a few cycles it is ok! One of these days I expect to see a connecting rod and pisting hanging out through the compressor block! (backup compressor is ready when needed!)
Jim Colt Hypertherm
Jim Colt Hypertherm
- CNCCAJUN
It is cold this winter.
While working in my shop on the electrical yesterday I noticed it was down to 57*F.
It gets much colder and I will need a heater in there.
If I lived up north I wouldn't be able to get out of bed . . . you guys must have real will power . . .
Steve in Louisiana . . .
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
No kidding, Be careful steve, all that flood water might start freezing!
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
57 degrees heck that's swimming weather here
and I was thinking 40 was nice
we have 15 degrees and a snow storm coming
yep im staying in bed![Smile :)](./images/smilies/icon_e_smile.gif)
![Laughing :lol:](./images/smilies/icon_lol.gif)
![Confused :?](./images/smilies/icon_e_confused.gif)
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
It's been -40 deg F here for a few days. Even for a diehard Canadian that's too cold!
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Duramax mini torch with Snap n Cut
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
57 is definitely t shirt weather here in NH. Open all the doors and windows!
It is zero F out right now, snowing and expect to have a foot acumulation by nightfall. This on top of the 8" we got on Monday. Some talk about the temp "getting down to freezing".......this time of the year we talk of it "getting up to freezing"! 32 F feels pretty nice actually!
Jim Colt
Jim Colt
- tnbndr
Especially if the sun is out!!! Downright Tropical!32 F feels pretty nice actually!
Cold lol as I type this it is -31 and falling.
I wish I could see a pic of the heating element that is for the 7.5hp 80 gal Quincy but I can find one. Im wondering is if I could get a hot water tank element that would fit .
![Shocked :shock:](./images/smilies/icon_eek.gif)
