How to reset X0 Y0 after rotating part?
After rotating a part 90 deg to nest in material better. The X0 Y0 origin changes. How do you reset the part so the X0 Y0 is at the bottom left corner? It would make life a little easier when setting the origin in Mach3. Thanks for any replies. Ken
Arclight Dynamics, ArcPro 12000 5x10 table
Hypertherm Powermax 65
Mach3
Inkscape
Gimp
Mach3
Inkscape
Gimp
- 4.5 Star Member
Re: How to reset X0 Y0 after rotating part?
Look at the very bottom of the screen, right of the centre.
You should see Pos X.............Y.............A (degrees)
Just punch zero into the X & Y boxes.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Thanks! Such a simple thing makes things easier.
Mach3
Inkscape
Gimp
Mach3
Inkscape
Gimp
