26 gauge sheet
dharms
26 gauge sheet
Post by dharms »
Hi All,
Say has anyone cut 26 ga. sheet? I have a Thermal Dynamics A120 and Torchmate 2 and was hoping someone might have the settings that would work. I also have AVHC.
Any help would be appreciated.
Thanks in Advance.
mlinehan
Re: 26 gauge sheet
Post by mlinehan »
Use 40A, 180 ipm, 0.14 cut height
gary42095
Re: 26 gauge sheet
Post by gary42095 »
180ipm seems aweful slow to me on 26 ga not sure about td cut settings but i know hypertherm is up around 400ipm down to 25 amps. your going to want 0s pierce delay as well. i just cut 22ga on a powermax 85 and had some tuning trouble using mach/sheetcam until i found a box in settings to use mach delay. that cleared it up for me. my speed was 325@40 amps
danny
Re: 26 gauge sheet
Post by danny »
gary42095 wrote:180ipm seems aweful slow to me on 26 ga not sure about td cut settings but i know hypertherm is up around 400ipm down to 25 amps. your going to want 0s pierce delay as well. i just cut 22ga on a powermax 85 and had some tuning trouble using mach/sheetcam until i found a box in settings to use mach delay. that cleared it up for me. my speed was 325@40 amps
Hi Gary,
Just wondering where the box you mentioned is and if it would lower the pierce delay
Thanks, Danny
2X2 Shop built table,proma thc,TB6560 bob
TD cut master 52,SL 100 machine torch
mach3, sheetcam, 26cfm compressor, Ref.air dryer, water seperator, motorguard toilet paper filter
