Help with auto cad 2004
I am new to cutting and have been using an older version to scale and edit dxf files. I think I'm getting a pretty good idea for what I need it for. I was wonder if there was a way to import images or files that are not dxf files to trace and make dxf
Re: Help with auto cad 2004
you can typically drag and drop images into autocad and then scale them to suit. I usually change the color of my line to magenta or some other easily seen color that way you can see what you have traced as you go.
- tnbndr
Also go to the Insert Menu, Raster Image File and select any image file to import. I do as Stillworking and change to a color that I can see as a trace an image. You can trace using lines, arcs, circles, etc. The software I use won't recognize polylines or splines so I stay away althought they would be easier and faster to use. You can also use the "sketch" command to free trace or draw. It takes a little playing around to get used to and you need to set your segments large enough or you get a real choppy cut.
