Plasmacam
Plasmacam
I recently bought a plasma cam used. It won't initialize the gantry or carriage. motors move a couple of inches and stop. I replaced the controller and the head cable. Can someone please help getting pretty aggrivating.
Re: Plasmacam
check to see if everything is square
Re: Plasmacam
Can you move the gantry and carriage freely by hand? If not check your alinement of the drive gears. If your gantry and carriage are parked already in the corner it will only move an inch or so bumping its limit switchs to locate it self. After you initialize the unit do you get any error messages? If not, try using the control panel on the table to move the gantry and carriage. More details would help.
Re: Plasmacam
Error message falling carriage gantry. If you move it to the center of the table it only moves a couple of inches and stops, move it toward the edge and it slams the table and stops.
Re: Plasmacam
Juat a thought your X rail drive shaft might be broken. Or pulley, belt, or pinion is slipping on drive shaft.
Vern
Vern
- dgeorgester
Re: Plasmacam
I remember having that problem. After a while the limit switches get gummed up with plasma dust. Changing the limit switches fixed the problem.
