Is there a way to save a partially used sheet in sheet cam for later use. What i mean is if i load a full sheet. cut a few things out of it and then later re open that partially used sheet in sheet cam to nest more parts on it.
Patrick
Continuing on partially used material
96x120 BullTear (star labs) cnc table
Candcnc ether cut with dthc4
Hypertherm Powermax 85
Miller Xmt 350 MPa
Miller XR-30a
Miller S-54d feeder
Millermatic 350p with XR-Alumapro
http://www.borstmetalworks.com
http://www.facebook.com/BorstMetalWorks
Miller Xmt 350 MPa
Miller XR-30a
Miller S-54d feeder
Re: Continuing on partially used material
Yep. Just save the job file, and when you reopen that job file later you can add new parts to the existing. Just remember to disable the cutting operations for the already-cut parts so you don't try to cut them out of the nothing. ![Wink ;)](./images/smilies/icon_e_wink.gif)
Thank you very much. this will save me much time and wasted material from trying to cut on partially use sheets.
Patrick
Patrick
Miller Xmt 350 MPa
Miller XR-30a
Miller S-54d feeder
Miller Xmt 350 MPa
Miller XR-30a
Miller S-54d feeder
