Cutting round holes
brewman114
Cutting round holes
Post by brewman114 »
I have seen many posts here with pictures of the final cuts that show small holes cut that are near perfect. I would like to know how that is achieved. I would seem that I can get a perfect circle until I cut smaller than an inch, then it begins to oblong the hole. Help please!!!
PlasmaRoute 4X8
Hypertherm Powermax 65
Corel X5
AutoCad 2012
SheetCam
Mach 3
Inkscape
WSS
Re: Cutting round holes
Post by WSS »
The leads are an important part of it, almost as important as your machines motion. But you also can gain from locking (freezing?) the thc and slowing the ipm down to around 60% of the normal F (feed) speed. Experiment with different speeds on different size holes. Attached is a 1/2" piece with two 11/16" holes that were within .015", just had a little ding from the lead out to knock off with a die grinder. the holes were cut @14.4ipm and the torch locked at .125" then back to thc and 24ipm for outside cut.
WSS
brewman114
Your talking about having the holes cut with the THC turned off and set a specific height right. And then the rest of the cut to operate normally with THC on?
PlasmaRoute 4X8
Corel X5
AutoCad 2012
SheetCam
Mach 3
Inkscape
WSS
Post by WSS »
Yes, the smaller the hole the higher the specific height. This is because of being closer to the pierce crater and resulting booger. A water based anti-spatter helps too, it sheds the pierce booger and lets the torch track better and not stutter on the top side dross. Pierce from dead center of the hole if you can and 90 degree out to the cut, if your machine has good motion.
WSS
brewman114
Cool, I will give it a try. Thanks
PlasmaRoute 4X8
Corel X5
AutoCad 2012
SheetCam
Mach 3
Inkscape
If you send me your direct email I will send you a presentation called best practices for plasma cutting holes.
Jim Colt jim.colt@hypertherm.com
brewman114 wrote:I have seen many posts here with pictures of the final cuts that show small holes cut that are near perfect. I would like to know how that is achieved. I would seem that I can get a perfect circle until I cut smaller than an inch, then it begins to oblong the hole. Help please!!!
