This ones driving me nuts
- Sampson Jones
I removed a dogs face from the lower portion of this cross , simply connected the two pieces with the straight line connector . The whole cross completely was together again , grouped the objects , hit export with the dxf tool . When its imported in sheetcam its missing the connector lines ,wtf ?
- Attachments
- Shatzes bestn No face-1.cdr
- (115.15 KiB) Downloaded 60 times
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
CandCNC electronics
Command Lineux
Super z 2
- Sampson Jones
Re: This ones driving me nuts
O k I have confirmed the problem is with the dxf export tool from Lenord Designs . Anybody else had this problem ?
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
don't use connector lines to connect or close curves, they are (mainly) for flow charting, they connect two objects and stay connected when either object is moved
in this case, simplest solution is to ungroup, erase the connectors, turn snap-to-objects on, and use the freehand-tool to draw line segments where needed
- Sampson Jones
Thanks , I the dxf tool must be working correctly then ,my bad .
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
