E04 PTM TORCH/Everlast 102i
Discussion forum for RazorWeld, Everlast, and all other plasma cutters.
AMF
Post by AMF »
Torch cuts as it should, periodically it stops the arc and air flow and throws a E04 code.
You remove this code- I can slightly loosen the cup (just less than tight) E04 code is removed
Cut more- E04 code throws again.
Can tighten or loosen the cup a little (maybe 16th of a turn) code is removed- can continue to cut
Why can I, just barely adjust the cup and the code removes itself??
All suggestions welcome
05Duramax
Re: E04 PTM TORCH/Everlast 102i
Post by 05Duramax »
There are 2 spring loaded pins in the torch under the consumables retaining cap. When the cap is screwed on the pins contact a metal ring on the cap and close a circuit to tell the machine the parts are in place and it can cut. Sounds like your pins and/or the ring they contact are dirty or corroded and work for while and then you need to move the cap to get a good connection again. Give it all a good cleaning and post back with your results.
AMF
Post by AMF »
cleaned contacts and it is working flawless so far, about 4 hours of cut time on .250
Thank you
05Duramax
Post by 05Duramax »
That’s awesome! Happy to hear I was able to help somebody here after all the help I’ve received from the site.
AMF
Post by AMF »
I agree, hands down once of the best forums ive been part of
05Duramax wrote: Sat Jan 04, 2025 8:08 pm There are 2 spring loaded pins in the torch under the consumables retaining cap. When the cap is screwed on the pins contact a metal ring on the cap and close a circuit to tell the machine the parts are in place and it can cut. Sounds like your pins and/or the ring they contact are dirty or corroded and work for while and then you need to move the cap to get a good connection again. Give it all a good cleaning and post back with your results.
:Like :Like :Like
AMF wrote: Mon Jan 06, 2025 12:26 pm I agree, hands down once of the best forums ive been part of
Very much agree!
:Like :Like :Like
Return to “RazorWeld, Everlast, & All Other Plasma Cutters”
