HI
I am working out a problem I am having the a servo motor from ClearPath, with a 23 size motor. As shown in the video it is with the dynamic braking function of the motor. It seems others have had similar problems and I wanted to check with member here. Simple check is to manually move the axis without power on. As shown in the video the first motor will momentarily stop the motion then release to continue the moving. The non-working motor will not stop but just smoothly move as indicated in the video. Thanks for your help with my research with the problem.
ClearPath servo
ClearPath servo
Re: ClearPath servo
Hey Tom I have played with those motors a little and although I did not have the same problem as you I had a similar issue. Ended up updating the firmware in the motor and the problem went away. Maybe this is your issue, maybe not, but thought I would mention it.
Re: ClearPath servo
Thanks I have been communicating with a Tech at ClearPath, not done yet. Worked on it again today and still not right, real bad bounce t low speed. I will pass it by the Tech about the firmware update.
Re: ClearPath servo
Update the tech from Clearpath did a remote tune on the servo motor and things are working well now. They use a program called GoToMyPC to remotely connect with the on site PC and run their "Auto Tune" program making changes on the fly watching how things are going. After the tune is stored on the servo and back up on the Hard Drive.
Re: ClearPath servo
I have a question about Auto Tune: How does it work with two motors on an axis? Since it has to be done with the motor moving the load ......
We have a controller that will handle 4 or 5 cClearPath motors and works up to 100 ft of cables. We don't sell it to individuals because of the tuning required. . We do not have a table with the test motors we have on it so tuning was just open loop (no load).
Re: ClearPath servo
That's a very good question Tom, I too am curious now how that would be done.tcaudle wrote: ↑Tue Jun 04, 2024 11:10 am I have a question about Auto Tune: How does it work with two motors on an axis? Since it has to be done with the motor moving the load ......
Thats great Tom, glad you got it sorted outacourtjester wrote: ↑Thu May 23, 2024 5:19 pm Thanks I have been communicating with a Tech at ClearPath, not done yet. Worked on it again today and still not right, real bad bounce t low speed. I will pass it by the Tech about the firmware update.
Re: ClearPath servo
The Auto tune does not work with dual motor axis setups, there are YouTube video showing how to work around that. You would use a single motor axis and load it with what you think the weight of the other axis is and do the auto tune on that. Then copy the tune data on to the other motors on the dual setup.
Her it is
Her it is
Re: ClearPath servo
Cool! Great video Tom, thanks!
