Made some brackets to lift the back seat in a ram a bit and give the option to move it forward as well THis allows for sub woofers, gun racks, whatever you need to fit behind the rear seat. It also allows the seat to unhook from the bar and tilt forward.
I weld a 5/8 bolt through the upper part of the bracket to act as a stud to sit the seat down on.. but obviously your preference will dictate how you would assemble this. Ill upload the brackets i made for the back of the seat as well later and some pictures of them installed
Ram Seat Lift
- 1/2 Star Elite Contributing Member
Ram Seat Lift
Re: Ram Seat Lift
Great idea and great looking brackets. Very nicely designed, thank you. Here is a dxf for those who may need it.
- SegoMan DeSigns
Re: Ram Seat Lift
Thanks for the share, do you have any in use photo's to go with the files?
Re: Ram Seat Lift
thank you for thr share I own 2018 RAM myself will see about trying thid out thank you
DHC2 Plasmacam Custom 7’ x 18’ Plasma Table, Hypertherm 85 Plasma Machine Torch, Miller 875 Plasma Torch, Lincoln Aspect 375 TIG, Lincoln 275 TIG, Miller 200, Lincoln 250 SMAW, Lincoln 256 MiG Spool Gun, Miller 211, Miller 210 MIG, Miller Trailblazer 302
Re: Ram Seat Lift
Contiveros wrote: ↑Sat Apr 20, 2024 8:06 am thank you for thr share I own 2018 RAM myself will see about trying thid out thank you
Got a slight revision as well as the plates needed for the back of the seat to hook onto the little retaining bars. Im super slammed... so bare with me... and give me a bit and ill try to get them posted
