Ram Seat Lift
nsboost
1/2 Star Elite Contributing Member
Ram Seat Lift
Post by nsboost »
Made some brackets to lift the back seat in a ram a bit and give the option to move it forward as well THis allows for sub woofers, gun racks, whatever you need to fit behind the rear seat. It also allows the seat to unhook from the bar and tilt forward.
I weld a 5/8 bolt through the upper part of the bracket to act as a stud to sit the seat down on.. but obviously your preference will dictate how you would assemble this. Ill upload the brackets i made for the back of the seat as well later and some pictures of them installed
RAM SEAT RELOCATE v18.f3d
DieselFumes
Re: Ram Seat Lift
Post by DieselFumes »
Great idea and great looking brackets. Very nicely designed, thank you. Here is a dxf for those who may need it.
RamSeatBrackets.dxf
SegoMan DeSigns
Re: Ram Seat Lift
Post by SegoMan DeSigns »
Thanks for the share, do you have any in use photo's to go with the files?
Contiveros
Re: Ram Seat Lift
Post by Contiveros »
thank you for thr share I own 2018 RAM myself will see about trying thid out thank you
DHC2 Plasmacam Custom 7’ x 18’ Plasma Table, Hypertherm 85 Plasma Machine Torch, Miller 875 Plasma Torch, Lincoln Aspect 375 TIG, Lincoln 275 TIG, Miller 200, Lincoln 250 SMAW, Lincoln 256 MiG Spool Gun, Miller 211, Miller 210 MIG, Miller Trailblazer 302
