Hello all,
I was wondering if anyone has the files for the side skirts for the Samson 5x10 so I can build a down draft table? I primarily use this table for the local FFA kids to make projects on. In Montana the winters are too cold to have my shop doors open. If I need to buy them I’m open to that also. Thank you in advance, and any help in this matter would be greatly appreciated.
Josh
5x10 Samson down draft side panels
- rdj357
Re: 5x10 Samson down draft side panels
You should have it already -use the file explorer to open the ProgramFiles(x86) directory on your hard drive. Go to the PlasmaCAM folder and then Examples. You should see the basic side panels there that you can cut. There are 3 panels in the file, you cut them all twice and it makes a set.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Thank you sir I will give it a try.
Josh
Josh
Robert I looked and I do not have that file, is there anyway you could help me?
- rdj357
Weird. Here ya go!
Robert Johnson
