65 sync
Skidmore
65 sync
Post by Skidmore »
I have a Hypertherm 65sync and a Samson 5x10. It was doing just fine now when I got to cut the table travels throw the cut file but the torch never activates. Has anyone else run into this? Any help would be greatly appreciated, and yes I’m new to this Cnc plasma game.
Josh
rdj357
Re: 65 sync
Post by rdj357 »
Make sure you have the Auto Cut turned on. This is usually on so it's easy to forget that it even exists if it gets bumped off on the controller or the keyboard (Alt-A). Look in the Machine menu and make sure it has a check mark or on the controller for the LED by Auto Cut.
Re: 65 sync
Also have a look for an error being displayed on the front of your plasma cutter.
Skidmore
Re: 65 sync
Post by Skidmore »
No errors on plasma or table, ground is good, air PSI is good.
Skidmore
Re: 65 sync
Post by Skidmore »
Rdj357,
You where right on the money thank you for your help.
rdj357
Re: 65 sync
Post by rdj357 »
No problem, glad to help! Glad you're making sparks again!
Re: 65 sync
Good call Robert :Like
