My machine came with no homing /limit switches.
I'd like to add this to the machine.
I could us a relay to accomplish this but wondering if I can just use the 12-36VDC signal coming from the proximity sensor?
Thanks in advance!
Adding NPN proximity switches to table i/o board?
- Tristar500
5X7, 6x11 plasma own design
Mach3,4 SheetCam, CorelDRAW 2020 Inkscape .0.92
Homebuilt 3 axis mill
Homebuilt 5 axis mill
PrimeWeld cut 60
Hypertherm 350
Miller Symchrowave 250 DX
Several mig welders
You are only as old as the woman you feel.
PrimeWeld cut 60
Hypertherm 350
Several mig welders
Re: Adding NPN proximity switches to table i/o board?
I dont see why not but not sure but Tom from C&CNC is often here answering questions, maybe he will chime in.
There's a diagram in the candcnc manual that shows how to use proximity sensors for homes. You have to use an external power source if I remember correctly.
Cross posted.
https://www.candcnc.com/supportforum/vi ... 51&p=20508
I added proximity sensors to my DIY table and here is some info that may help. They are mostly the same Electronics just different mounting for the 2 types.
viewtopic.php?f=122&t=36054
