Hello out there.
I have recently bought a StyleCNC 1325R plasma cutting table with a drilling head attachement.
It cuts great now but, now I am beginning to experiament with the drilling head attachement but, i can not get it working.
I am using the provided software (FastCam, FastNest and FastPlot) for greating some of my files. I layer a squar with on point in the middle that i mark and layer as drilling. I export the file over to the plasmacutter with USB but when i run the file it just uses the plasma torch and blast a small hole in the square, were i originally programmed it to drill...
I am quite at a loss here, hope one of you guys can help....
Best regards
Daniel from Denmark
StyleCNC drilling attachement, not working.
Re: StyleCNC drilling attachement, not working.
Not at all familiar with your equipment but it sounds like it could be as simple as selecting the wrong tool when doing your post processing. There must be a different tool or process that you select for drilling so it operates the drill and not the plasma.
I just got it working a couple of hours ago, it was a wiring problem within the control unit. But thank you for your answer Area
Awesome, glad you got it working. Post some pics of your drilling attachment if you get the chance. Curious what its all about.
