Lightning strike part 3. Now with video.
Someone please tell me how to, or even if, I can edit the topic titles so I dont have to keep making new topics. I tried all the edit buttons I could find, but that don't mean much.
After attempting the straight line tests suggested by Weldguy, SRdesign, and tcaudle in the previous topic, I decided to try to video each screen and torch movements. I will describe the length of the video and what it is of before each youtube link.
To start, here is an 8 second video of the torch actions.
I will ad more as they upload. I also have some other info to share about the CandCNC program as well as the utility hub and how it affects the plasma screen.
Re: Lightning strike part 3. Now with video.
As the next one uploads, more on the Cand CNC program. Normally the plasma head will stay on default 85 amp setting until a code is started in the CandCNC program. Then the plasma screen will adjust according to code. Now, when the CandCNC program is not active, the plasma screen is default 85, but as soon as the program is activated, the screen goes to 45 amp. Same with the utility hub. As soon as I double click on the hub, the plasma screen goes to 45 amp even with no code loaded in the CandCnc. Also it says license not valid or something like that. However this came with the table and has always been licensed to me. So maybe the surge has corrupted my programs too?
9 seconds of the plasma screen. Even though the torch has quit cutting, the screen shows on which coincides with CandCNC program, which says torch is still on.
Here's 8 seconds of the prgram screen. As SRdesign mentions to watch the voltage box, it shows none.
However the torch stays on and a "fault" light appears.
Messages say nothing more than machine powered on.
Is the hub utility power source plugged into one of those power strips. Sounds like you are losing power to the hub utility intermittently. I had a similar issue. The 2 red lites on the hub utility would drop out and the screen on the hypertherm would default to whatever amp i the dial was set to. I then unplugged the hub utility and cycled the power. I found out my power strip was not making contact with the 115v prongs. Since then, I threw the power strip out and got a real 4 wall plug wired. Sometimes it does have to be reset though.
I had that EXACT same problem ..Now before starting , i clean the surface with 409 ...Ii appears the ohmic sensing is affected by the dirty surface. Since I started doing the cleaning , I havent had the problem . Took a long time to figure this out . I also " spritz " the surface with compressed air as the torch is cutting .
Ok, so with some of the tests given here, and with Arclight tech support, we've narrowed it down to the Hypertherm head. At least as far as the DTHC part goes. Still not sure why the hypertherm goes to 45 amp just by double clicking the candcnc prgram with no job or code loaded. But waiting to hear from Hypertherm about the parts I may need. I'll update again as soon as I hear more.
Just watched the VId again. The DTHC is saying "my voltage is too low" raise the head to increase the gap to get the prescribed voltage. In the back of the PWM. Take the cover off and what is the ratio jumper set to.
Also try with the DTHC off.
It will cut ok with dthc off, on manual.
I don't know that my pwm box has a cover to remove. I'll have to look at that. But I bought it from Arclight whom has my serial numbers on file etc. I believe it's supposed to be 50:1?
Well, after contacting Hypertherm's tech support with the help of Arclight's tech support, we think we have it figured. The power board and the divider card are bad. Estimated $1600 for parts.
Are pwm, divider card, and cpc port the same thing, just different brands and setups?
Not sure on nomenclature. However, take some pics of your PWM, and other external items. This is built by CandCNC. Did you visually see the voltage jumper ratio in the PWM. Also where is your work lead connected to. I made a clamp set up where I clamp it to the material I am cutting. I am trying to follow what new parts did you get after the lightning strike. If it was a new PWM I am pretty sure the jumpers are not set to hypertherm's. I had the same issue when I got my system and did not know I had to move the jumper. Once I did that everything was fixed. Not saying that is your problem but you need to be 100% sure the jumper setting is correct before more parts replacement.
Ok, figured out that jumper you mention. It is set on 50:1. Here's a few pics. 2 of what I refer to as the PWM, and 1 of the "CPC port"?
The jumper looks right. Where is the CAT 5 to the DCP-01. Is it just not hooked up.
Probably doesn't need the current probe.
How does it work without a current probe ?
The current probe takes the place of the arcok. If your cutter has arcok or arc transfer contacts then you don't need it.
Never had a cable to that port.
Just got a message my parts are in, so soon as I can pick them up, the fun begins. Will there be more issues as mentioned earlier that such a power spike may cause unseen and unpredictable issues...........
I use an battery backup UPS to help protect my computer and controller from AC power issues and when I am done using the machine for the day I turn the power off completely at the battery backup to prevent any overnight issues if there is a lightning storm or something. Can just unplug everything from the wall also but I like the battery backup.
