Powermax 85 sweating
Cut these bucket mounts from 1.75 inch thick QT100 with my powermax 85. Wasnt sure if the machine would blow up or not as it was a hot day and I was running it wide open for around 20 minutes straight then would stop and let the fan stop before continuing the cut. Was impressed that it cut it, tho I think it is time to look for an oxyfuel head as this is way beyond the machines rated capacity.
Re: Powermax 85 sweating
What thickness?
Nevermind. I see it says 1.75".
That's gotta be a typo
No. Thats the only reason I posted it. Nothing special about the ears. But there is something great about the thickness, esp with only 85 amps.
Are you sure it's not .75'' instead of 1.75''? If it is 1.75'' you got a heck of a machine, I've done 1'' mild steel with my 85 amp and the cut was not as straight as yours, for the big holes you probably drilled a hole first with a drill...no way the machine pierced 1.75'' steel. Anyway you did a fantastic job if this is 1.75'' thick!
Next you fellas are going to say my tape is wrong. I didnt say i was moving at 150 ipm tho did I?
Yes I sure did predrill start points, even do for 1"
- ROKCRLER
Wow! I would have never thought that possible. Well done!
You sure are getting your $$$ worth on that Hypertherm 85!
Very impressive indeed!
That is freaking incredible. I cant even do near that good on 1" with my powermax 85. That blows me away. What was the IPM?
- SegoMan DeSigns
This makes me want to find some 2" to give the 105 a work out
Oh I wanna see that!SegoMan DeSigns wrote: ↑Fri Jun 23, 2023 2:04 pm This makes me want to find some 2" to give the 105 a work out
I set it at 2.5 ipm as a starting point, ended up using 4-5 ipm. I discovered a 75 cent powermax upgrade one day a year or so ago from frustration that i will try to post when i have time.It will make yours cut like mine. I will probably post it in the hypertherm section tho.
Cutnweld - Just curious - what is your 75 cent upgrade - in a few words? Maybe just give us a hint. I have a powermax 85 and perhaps it would apply to my machine as well.
I too am curious...and sounds like it will fit my budget.
I happen to know cutnweld, and run the same "upgrade" on my table. Many thanks to him for sharing this. Without it I get ugly beveled cuts on 3/8. With it, nice straight cuts on 1" which is the thickest I have cut yet with my PM 85.
The 75 cent fix is just a rubber o-ring, installed where indicated by the arrow in this screenshot from cutnweld's cutting picture above. Seems to stop some of the excessive air blow-by (for cooling purposes or what???) and increases air pressure at the nozzle.
Cutnweld is free to chime in with corrections or additions.
Shop-built 5x10 table powered by QtPlasmaC
Hypertherm PM 85 machine torch
Lincoln PowerMig 255C
Lincoln Square Wave Tig 255
Ermak SpeedBend Pro
Ermak SpeedBend Pro
Isn't there already an oring installed there?
My thought exactly. I assume he is using a Duramax torch with his Powermax 85. I also have a Duramax torch on my 85 and get good clean cuts on 3/8" material - not ugly ones. Most all plasma cuts will have some bevel, and I believe the bevel angle decreases as the material thickness increases.
That's a fantastic cut, I too looked at the 1.75 and then with a tape photo that resolved all doubts
just amazing
stan kern
just amazing
stan kern
Very interesting, thanks for posting back. When I have the chance I will look deeper into this with my PM65 torch.
